Fehlermeldung nach heutigem update...
Begonnen von Rampler, 12 Juli 2015, 16:21:18
Rampler
Direkt nach dem Start kommt:
PERL WARNING: Use of uninitialized value $cq in hash element at ./FHEM/10_CUL_HM.pm line 7670.
3 HMUART (2 via ESP8266), 1 DUOFERN, 12 ESP8266, SolvisBen, GoodWE WR, RPI2 (Bullseye), ZWAVE, HM-Classic, und hoch zufrieden ...
Danke an alle, die was dazu beigetragen haben !!
Rampler
Kann das Thema bitte jemand in den Homematic Bereich verschieben.... ?!
Mit Stand heute kommt nun:
PERL WARNING: Use of uninitialized value $cq in hash element at ./FHEM/10_CUL_HM.pm line 7671
dindihi
Hab genau das gleiche Problem:
2015.07.23 12:18:41.872 1: PERL WARNING: Use of uninitialized value $cq in hash element at ./FHEM/10_CUL_HM.pm line 7671.
2015.07.23 12:18:41.872 3: stacktrace:
2015.07.23 12:18:41.872 3:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (7671)
2015.07.23 12:18:41.872 3:     main::CUL_HM_unQEntity              called by ./FHEM/10_CUL_HM.pm (2945)
2015.07.23 12:18:41.873 3:     main::CUL_HM_parseCommon            called by ./FHEM/10_CUL_HM.pm (1197)
2015.07.23 12:18:41.873 3:     main::CUL_HM_Parse                  called by fhem.pl (3178)
2015.07.23 12:18:41.873 3:     main::Dispatch                      called by ./FHEM/00_HMLAN.pm (738)
2015.07.23 12:18:41.873 3:     main::HMLAN_Parse                   called by ./FHEM/00_HMLAN.pm (561)
2015.07.23 12:18:41.873 3:     main::HMLAN_Read                    called by fhem.pl (3041)
2015.07.23 12:18:41.873 3:     main::CallFn                        called by fhem.pl (647)
2015.07.23 12:18:41.875 1: PERL WARNING: Use of uninitialized value $cq in hash element at ./FHEM/10_CUL_HM.pm line 7671.
2015.07.23 12:18:41.875 3: stacktrace:
2015.07.23 12:18:41.875 3:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (7671)
2015.07.23 12:18:41.876 3:     main::CUL_HM_unQEntity              called by ./FHEM/10_CUL_HM.pm (1878)
2015.07.23 12:18:41.876 3:     main::CUL_HM_Parse                  called by fhem.pl (3178)
2015.07.23 12:18:41.876 3:     main::Dispatch                      called by ./FHEM/00_HMLAN.pm (738)
2015.07.23 12:18:41.876 3:     main::HMLAN_Parse                   called by ./FHEM/00_HMLAN.pm (561)
2015.07.23 12:18:41.876 3:     main::HMLAN_Read                    called by fhem.pl (3041)
2015.07.23 12:18:41.876 3:     main::CallFn                        called by fhem.pl (647)
2015.07.23 12:18:42.572 3: CUL_HM set EZ.LED.Front.Sw off
2015.07.23 12:18:43.144 1: PERL WARNING: Use of uninitialized value $cq in hash element at ./FHEM/10_CUL_HM.pm line 7671.
2015.07.23 12:18:43.145 3: stacktrace:
2015.07.23 12:18:43.145 3:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (7671)
2015.07.23 12:18:43.145 3:     main::CUL_HM_unQEntity              called by ./FHEM/10_CUL_HM.pm (7629)
2015.07.23 12:18:43.145 3:     main::CUL_HM_stateUpdatDly          called by ./FHEM/10_CUL_HM.pm (1813)
2015.07.23 12:18:43.145 3:     main::CUL_HM_Parse                  called by fhem.pl (3178)
2015.07.23 12:18:43.146 3:     main::Dispatch                      called by ./FHEM/00_HMLAN.pm (738)
2015.07.23 12:18:43.146 3:     main::HMLAN_Parse                   called by ./FHEM/00_HMLAN.pm (561)
2015.07.23 12:18:43.146 3:     main::HMLAN_Read                    called by fhem.pl (3041)
2015.07.23 12:18:43.146 3:     main::CallFn                        called by fhem.pl (647)
2015.07.23 12:18:43.953 3: CUL_HM set EZ.LED.Side.Sw off
2015.07.23 12:18:44.177 1: PERL WARNING: Use of uninitialized value $cq in hash element at ./FHEM/10_CUL_HM.pm line 7671.
2015.07.23 12:18:44.177 3: stacktrace:
2015.07.23 12:18:44.177 3:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (7671)
2015.07.23 12:18:44.178 3:     main::CUL_HM_unQEntity              called by ./FHEM/10_CUL_HM.pm (7629)
2015.07.23 12:18:44.178 3:     main::CUL_HM_stateUpdatDly          called by ./FHEM/10_CUL_HM.pm (1813)
2015.07.23 12:18:44.178 3:     main::CUL_HM_Parse                  called by fhem.pl (3178)
2015.07.23 12:18:44.178 3:     main::Dispatch                      called by ./FHEM/00_HMLAN.pm (738)
2015.07.23 12:18:44.179 3:     main::HMLAN_Parse                   called by ./FHEM/00_HMLAN.pm (561)
Puschel74
#3
Rampler als Beitragsersteller kann den Beitrag nach Homematic verschieben.
Oder man bittet den Admin/GlobalModerator den Beitrag zu verschieben.
Generell sollten solche "Probleme" auch im richtigen Forenbereich gepostet werden.
