Immer mal wieder einen attack ....
Begonnen von Rampler, 17 Februar 2015, 08:09:00
martinp876
Logge die messages des RM  und Teile die hmids in deinem system mit. Welche ID wird den als attack angezeigt?
Evtl sind die devices nur fwaehnlich
west2107
Auszug aus altem Log:
Die ID 1EBF55 gehört mir nicht.
Daemon with PID 24005 started!
2016.01.22 02:00:00 3: System Neustart HM-USB-Adapter
2016.01.22 02:00:00 1: 127.0.0.1:1234 disconnected, waiting to reappear (hmusb)
2016.01.22 02:00:00 1: HMLAN_Parse: hmusb new condition disconnected
2016.01.22 02:00:01 1: 127.0.0.1:1234 reappeared (hmusb)
2016.01.22 02:00:01 1: HMLAN_Parse: hmusb new condition init
2016.01.22 02:00:02 1: HMLAN_Parse: hmusb new condition ok
2016.01.22 02:10:16 2: CUL_HM RM_232E02 attack:,011EBF07340289010E:11EBF55340289010E
2016.01.22 02:10:17 2: CUL_HM RM_232E02 attack:,011EBF07340289010E:11EBF55340289010E
2016.01.22 02:10:19 2: CUL_HM RM_232E02 attack:,011EBF07340289010E:11EBF55340289010E
2016.01.22 02:10:20 2: CUL_HM RM_232E02 attack:,011EBF07340289010E:11EBF55340289010E
2016.01.22 02:40:22 2: CUL_HM RM_232E02 attack:,011EBF07340289010E:11EBF55340289010E
2016.01.22 03:10:28 2: CUL_HM RM_232E02 attack:,011EBF07340289010E:11EBF55340289010E
2016.01.22 03:10:29 2: CUL_HM RM_232E02 attack:,011EBF07340289010E:11EBF55340289010E
2016.01.22 03:40:34 2: CUL_HM RM_232E02 attack:,011EBF07340289010E:11EBF55340289010E
2016.01.22 03:40:36 2: CUL_HM RM_232E02 attack:,011EBF07340289010E:11EBF55340289010E
2016.01.22 03:40:37 2: CUL_HM RM_232E02 attack:,011EBF07340289010E:11EBF55340289010E
2016.01.22 04:10:40 2: CUL_HM RM_232E02 attack:,011EBF07340289010E:11EBF55340289010E
2016.01.22 04:10:41 2: CUL_HM RM_232E02 attack:,011EBF07340289010E:11EBF55340289010E
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
ein List vom RM_232E02 und von eimem HM-RM . Seriennummer entfernt.,
   CFGFN      /opt/fhem/FHEM/HOMEMATIC_Komponenten.cfg
   DEF        340289
   IODev      hmusb
   LASTInputDev hmusb
   MSGCNT     215
   NAME       RM_232E02
   NR         347
   NTFY_ORDER 50-RM_232E02
   STATE      off
   TYPE       CUL_HM
   hmusb_MSGCNT 215
   hmusb_RAWMSG E1EBF55,0000,0861BCDC,FF,FFA5,55B0011EBF55340289010E
   hmusb_RSSI -91
   hmusb_TIME 2016-01-23 08:46:37
   lastMsg    No:03 - t:10 s:340289 d:1EBF07 0601010051
   peerList   self01,
   protCmdDel 1
   protErrIoAttack 213 last_at:2016-01-23 08:46:37
   protErrIoId_1EBF55 213 last_at:2016-01-23 08:46:37
   protLastRcv 2016-01-22 08:41:19
   protResnd  1 last_at:2016-01-22 08:11:16
   protResndFail 1 last_at:2016-01-22 08:11:22
   protSnd    3 last_at:2016-01-22 08:41:19
   protState  CMDs_done
   rssi_at_hmusb avg:-82 min:-82 max:-82 lst:-82 cnt:2
   rssi_hmusb avg:-81 min:-81 max:-81 lst:-81 cnt:1
   sdTeam     sdLead
   Readings:
     2016-01-22 08:10:50   Activity        alive
     2016-01-21 17:44:56   CommandAccepted yes
     2016-01-21 17:43:22   D-firmware      1.1
     2016-01-21 17:43:22   D-serialNr      LBO0180056
     2016-01-21 17:48:45   PairedTo        0x1EBF07
     2016-01-21 17:43:26   R-pairCentral   0x1EBF07
     2016-01-21 17:48:45   RegL_00:        02:01 0A:1E 0B:BF 0C:07 00:00
     2016-01-22 08:41:19   battery         ok
     2016-01-21 17:47:36   eventNo         0C
     2016-01-22 08:41:19   level           1
     2016-01-22 08:10:50   peerList        self01,
     2016-01-21 17:48:39   powerOn         2016-01-21 17:48:39
     2016-01-22 08:41:19   recentStateType info
     2016-01-23 08:46:37   sabotageAttackId_ErrIoId_1EBF55  cnt:213
     2016-01-22 07:11:17   sabotageAttack_ErrIoAttack cnt 58
     2016-01-23 08:46:37   sabotageAttack_ErrIoAttack cnt 213
     2016-01-21 17:47:36   smoke_detect    none
     2016-01-22 08:41:19   state           off
     2016-01-21 20:04:35   teamCall        from RM_232E02:8
   Helper:
     HM_CMDNR   3
     cSnd       011EBF07340289010E,011EBF07340289010E
     fkt        sdLead
     mId        0042
     rxType     2
     Expert:
       def        1
       det        0
       raw        1
       tpl        0
     Io:
       newChn     +340289,00,00,00
       nextSend   1453448479.57343
       prefIO
       rxt        0
       vccu
       p:
         340289
         00
         00
         00
     Mrssi:
       mNo        03
       Io:
         hmusb      -80
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
     Rpt:
       IO         hmusb
       flg        A
       ts         1453448479.50234
       ack:
         HASH(0x2b97fb8)
         0380021EBF0734028900
     Rssi:
       At_hmusb:
         avg        -82
         cnt        2
         lst        -82
         max        -82
         min        -82
       Hmusb:
         avg        -81
         cnt        1
         lst        -81
         max        -81
         min        -81
   IODev      hmusb
   actCycle   028:00
   actStatus  alive
   alias      RM_Z0
   autoReadReg 4_reqStatus
   devStateIcon off:RM_on dead:RM_off set_test:RM_T set_alarmOff:RM_on set_alarmOn:RM_AT MISSIN.*:RM_off RESPON.*:RM_off smoke-Alarm:RM_A smoke_detect:RM_A
   expert     2_full
   firmware   1.1
   fp_Alarm   240,370,0,
   group      Rauchmelder
   model      HM-SEC-SD
   msgRepeat  1
   peerIDs    00000000,34028901,
   room       Alarm
   serialNr   ??????????
   subType    smokeDetector
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
und hier von einem HM-RM:
   DEF        2A55E5
   IODev      hmusb
   LASTInputDev hmusb
   MSGCNT     3
   NAME       RM_2A55E5
   NR         332
   NTFY_ORDER 50-RM_2A55E5
   STATE      off
   TYPE       CUL_HM
   hmusb_MSGCNT 3
   hmusb_RAWMSG E2A55E5,0000,031B13EB,FF,FFA8,02A0102A55E51EBF070601010059
   hmusb_RSSI -88
   hmusb_TIME 2016-01-22 08:11:19
   lastMsg    No:02 - t:10 s:2A55E5 d:1EBF07 0601010059
   peerList   self01,
   protLastRcv 2016-01-22 08:11:19
   protSnd    3 last_at:2016-01-22 08:11:19
   protState  CMDs_done
   rssi_at_hmusb avg:-89.33 min:-90 max:-88 lst:-88 cnt:3
   rssi_hmusb avg:-89.5 min:-90 max:-89 lst:-89 cnt:2
   sdTeam     sdLead
   Readings:
     2016-01-22 08:10:51   Activity        alive
     2015-12-11 19:59:03   CommandAccepted yes
     2015-12-11 15:20:43   D-firmware      1.1
     2015-12-11 15:20:43   D-serialNr      LEQ0228825
     2015-12-11 20:25:29   PairedTo        0x1EBF07
     2015-12-10 18:28:41   R-pairCentral   0x1EBF07
     2015-12-11 20:25:29   RegL_00:        02:01 0A:1E 0B:BF 0C:07 00:00
     2016-01-22 08:11:19   battery         ok
     2016-01-19 19:26:19   eventNo         0C
     2016-01-22 08:11:19   level           1
     2016-01-22 08:11:19   recentStateType info
     2016-01-19 19:26:19   smoke_detect    none
     2016-01-22 08:11:19   state           off
     2015-12-11 20:10:15   teamCall        from RM_2A55E5:1
   Helper:
     HM_CMDNR   2
     cSnd       ,011EBF072A55E5010E
     fkt        sdLead
     mId        0042
     rxType     2
     Expert:
       def        1
       det        0
       raw        1
       tpl        0
     Io:
       newChn     +2A55E5,00,00,00
       nextSend   1453446679.48006
       prefIO
       rxt        0
       vccu
       p:
         2A55E5
         00
         00
         00
     Mrssi:
       mNo        02
       Io:
         hmusb      -86
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
     Rpt:
       IO         hmusb
       flg        A
       ts         1453446679.38461
       ack:
         HASH(0x2b96ed0)
         0280021EBF072A55E500
     Rssi:
       At_hmusb:
         avg        -89.3333333333333
         cnt        3
         lst        -88
         max        -88
         min        -90
       Hmusb:
         avg        -89.5
         cnt        2
         lst        -89
         max        -89
         min        -90
   IODev      hmusb
   actCycle   028:00
   actStatus  alive
   alias      RM_Z7
   expert     2_full
   firmware   1.1
   fp_Alarm   80,225,1,
   group      Rauchmelder
   model      HM-SEC-SD
   msgRepeat  1
   peerIDs    00000000,2A55E501,
   room       Alarm
   serialNr   ???????????
   webCmd     teamCall:alarmOff:alarmOn
martinp876
Das verhalten ist..... Zumindest neu für mich. Kannst du doch einmal sniffen wie unter sniffen beschrieben?
