Homebridge startet nicht
Begonnen von chris76e, 02 März 2017, 22:28:44
chris76e
versuche schon seit 6 Stunden die Homebridge auf meinen Raspberry zuinstallieren. Schaffes es nicht das der startet.
Kann mir jemand helfen?
Mar  2 22:21:21 raspberrypi systemd[1]: Starting HA Bridge...
Mar  2 22:21:21 raspberrypi systemd[1]: Started HA Bridge.
Mar  2 22:21:23 raspberrypi java[1421]: 2017-03-02 22:21:22,998 [main] INFO  com.bwssystems.HABridge.HABridge - HA Bridge (v4.1.4) starting....
Mar  2 22:21:23 raspberrypi java[1421]: 2017-03-02 22:21:23,023 [main] INFO  com.bwssystems.HABridge.BridgeSettings - reading from config file: /etc/habridge/habridge.config
Mar  2 22:21:23 raspberrypi java[1421]: 2017-03-02 22:21:23,040 [main] WARN  com.bwssystems.HABridge.BridgeSettings - Error reading the file: /etc/habridge/habridge.config - Does not exist or is not readable. continuing...
Mar  2 22:21:23 raspberrypi java[1421]: 2017-03-02 22:21:23,054 [main] INFO  com.bwssystems.HABridge.BridgeSettings - Adding 192.168.178.192 as our default upnp config address.
Mar  2 22:21:23 raspberrypi java[1421]: 2017-03-02 22:21:23,056 [main] INFO  com.bwssystems.HABridge.HABridge - HA Bridge initializing....
Mar  2 22:21:23 raspberrypi java[1421]: 2017-03-02 22:21:23,095 [main] INFO  com.bwssystems.HABridge.SystemControl - System control service started....
Mar  2 22:21:23 raspberrypi java[1421]: 2017-03-02 22:21:23.403:INFO::Thread-0: Logging initialized @1453ms
Mar  2 22:21:23 raspberrypi java[1421]: 2017-03-02 22:21:23,500 [main] INFO  com.bwssystems.HABridge.util.UDPDatagramSender - Initializing UDP response Socket...
Mar  2 22:21:23 raspberrypi java[1421]: 2017-03-02 22:21:23,508 [main] INFO  com.bwssystems.HABridge.util.UDPDatagramSender - UDP response Seocket initialized to: 50000
Mar  2 22:21:23 raspberrypi java[1421]: 2017-03-02 22:21:23,518 [main] INFO  com.bwssystems.HABridge.plugins.harmony.HarmonyHome - Harmony Home created. No Harmony devices configured.
Mar  2 22:21:23 raspberrypi java[1421]: 2017-03-02 22:21:23,526 [main] INFO  com.bwssystems.HABridge.plugins.NestBridge.NestHome - Nest Home created. No Nest configured.
Mar  2 22:21:23 raspberrypi java[1421]: 2017-03-02 22:21:23,529 [main] INFO  com.bwssystems.HABridge.plugins.hue.HueHome - Hue passthru Home created. No Hue passtrhu systems configured.
Mar  2 22:21:23 raspberrypi java[1421]: 2017-03-02 22:21:23,533 [main] INFO  com.bwssystems.HABridge.plugins.hal.HalHome - HAL Home created. No HAL devices configured.
Mar  2 22:21:23 raspberrypi java[1421]: 2017-03-02 22:21:23,536 [main] INFO  com.bwssystems.HABridge.plugins.mqtt.MQTTHome - MQTT Home created. No MQTT Clients configured.
Mar  2 22:21:23 raspberrypi java[1421]: 2017-03-02 22:21:23,540 [main] INFO  com.bwssystems.HABridge.plugins.hass.HassHome - HomeAssistant Home created. No HomeAssistants configured.
Mar  2 22:21:23 raspberrypi java[1421]: 2017-03-02 22:21:23,542 [main] INFO  com.bwssystems.HABridge.plugins.exec.CommandHome - Command Home for system program execution created.
Mar  2 22:21:23 raspberrypi java[1421]: 2017-03-02 22:21:23,675 [Thread-0] INFO  spark.webserver.JettySparkServer - == Spark has ignited ...
Mar  2 22:21:23 raspberrypi java[1421]: 2017-03-02 22:21:23,680 [Thread-0] INFO  spark.webserver.JettySparkServer - >> Listening on 0.0.0.0:80
Mar  2 22:21:23 raspberrypi java[1421]: 2017-03-02 22:21:23.690:INFO:oejs.Server:Thread-0: jetty-9.3.z-SNAPSHOT
Mar  2 22:21:23 raspberrypi java[1421]: 2017-03-02 22:21:23,817 [Thread-0] ERROR spark.webserver.JettySparkServer - ignite failed
Mar  2 22:21:23 raspberrypi java[1421]: java.net.BindException: Address already in use
Mar  2 22:21:23 raspberrypi java[1421]: at sun.nio.ch.Net.bind0(Native Method)
Mar  2 22:21:23 raspberrypi java[1421]: at sun.nio.ch.Net.bind(Net.java:433)
Mar  2 22:21:23 raspberrypi java[1421]: at sun.nio.ch.Net.bind(Net.java:425)
Mar  2 22:21:23 raspberrypi java[1421]: at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:223)
Mar  2 22:21:23 raspberrypi java[1421]: at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:74)
Mar  2 22:21:23 raspberrypi java[1421]: at org.eclipse.jetty.server.ServerConnector.open(ServerConnector.java:326)
Mar  2 22:21:23 raspberrypi java[1421]: at org.eclipse.jetty.server.AbstractNetworkConnector.doStart(AbstractNetworkConnector.java:80)
Mar  2 22:21:23 raspberrypi java[1421]: at org.eclipse.jetty.server.ServerConnector.doStart(ServerConnector.java:244)
Mar  2 22:21:23 raspberrypi java[1421]: at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
Mar  2 22:21:23 raspberrypi java[1421]: at org.eclipse.jetty.server.Server.doStart(Server.java:384)
Mar  2 22:21:23 raspberrypi java[1421]: at spark.webserver.JettySparkServer.ignite(JettySparkServer.java:131)
Mar  2 22:21:23 raspberrypi java[1421]: at spark.SparkInstance.lambda$init$0(SparkInstance.java:341)
Mar  2 22:21:23 raspberrypi java[1421]: at java.lang.Thread.run(Thread.java:745)
Mar  2 22:21:23 raspberrypi systemd[1]: habridge.service: main process exited, code=exited, status=100/n/a
Mar  2 22:21:23 raspberrypi systemd[1]: Unit habridge.service entered failed state.
Mar  2 22:21:33 raspberrypi systemd[1]: Reloading.
Mar  2 22:21:49 raspberrypi systemd[1]: Starting Session c5 of user pi.
Mar  2 22:21:49 raspberrypi systemd[1]: Started Session c5 of user pi.
Mar  2 22:21:58 raspberrypi rsyslogd-2007: action 'action 17' suspended, next retry is Thu Mar  2 22:22:28 2017 [try http://www.rsyslog.com/e/2007 ]
Mar  2 22:21:58 raspberrypi systemd[1]: Starting Session c6 of user pi.
Mar  2 22:21:58 raspberrypi systemd[1]: Started Session c6 of user pi.
MadMax-FHEM
Ich kenne jetzt Homebridge nicht wirklich aber das hier sieht so aus als würde versucht werden Port 80 zu öffnen und da scheint wohl schon was zu laufen:
anderer Webserver?
Läuft die Bridge selbst vielleicht schon??
Gruß, Joachim
FHEM PI3 Buster (Test)
chris76e
#2
Wenn ich die Ip Adresse aufrufe bekomme ich eine 404 Seite....
Habe vermutlich mehrmal die Homebridge Installiert, blicke da nicht mehr durch----- :-[
Wie kann man die am besten wieder deinstallieren?
Hmm
wenn ich systemctl status homebridge eingebe
kommt das hier
pi@raspberrypi:~ $ systemctl status homebridge
● homebridge.service - LSB: Start daemon at boot time for homebridge
   Loaded: loaded (/etc/init.d/homebridge)
   Active: active (exited) since Thu 2017-03-02 22:37:47 CET; 35min ago
pi@raspberrypi:~ $
scheint also zulaufen, aber wie kann ich die Weboberfläche aufrufen? Laut anleitungen läuft das ja auf der IP von Raspberry
Jetzt verstehe ich noch weniger
wenn ich sudo systemctl status homebridge eingebe, bekomme ich diese Meldung
   Active: active (exited) since Thu 2017-03-02 22:37:47 CET; 40min ago
Mar 02 22:37:46 raspberrypi su[549]: Successful su for pi by root
Mar 02 22:37:46 raspberrypi su[549]: + ??? root:pi
Mar 02 22:37:46 raspberrypi su[549]: pam_unix(su:session): session opened f...0)
Mar 02 22:37:47 raspberrypi homebridge[530]: Homebridge starting
Mar 02 22:37:47 raspberrypi homebridge[530]: Homebridge is not running
Mar 02 22:37:47 raspberrypi systemd[1]: Started LSB: Start daemon at boot ti....
Hint: Some lines were ellipsized, use -l to show in full.
pi@raspberrypi:~ $
MadMax-FHEM
Wie gesagt ich kenne Homebridge nicht aber kann es sein dass du hier eine "alexa-Bridge" (also HUE-Emulator wenn man so will) startest!?
Also Homebridge und ha-Bridge ist nicht gleich (soweit ich weiß)...
Nach welcher Anleitung bist du vorgegangen?
Und WAS wolltest du tatsächlich installieren??
Gruß, Joachim
chris76e
#4
Ich möchte eigentlich die Alexa Bridge haben. Ich glaube ich habe mich total verannt und verschieden Anleitungen durcheinander gewurfen.
Habe mit dieser Anleitung angefangen
https://www.computerhilfen.de/info/fhem-mit-dem-amazon-echo-per-sprache-steuern.html
und bin hier geendet https://smartapfel.de/anleitung-homebridge-auf-einem-raspberry-pi-einrichten/
MadMax-FHEM
Ja das wird wohl eher (vermute ich) nicht funktionieren:
HA-Bridge nicht gleich HomeBridge!
Also Installation mit HA-Bridge anfangen und dann mit HomeBridge beenden scheint tatsächlich nicht zu gehen...
Ich weiß ja nicht was du noch alles auf dem System hast/hattest und wieviel du bereits "zerschossen" hast...
...aber wenn du noch nicht viel hattest, dann vielleicht alles auf NULL und von vorne.
(Daher probiere ich sowas immer erst mal auf einem Testsystem aus, das ich zur Not wieder platt machen kann und notiere mir die Schritte damit ich dann auf dem "echten" System weiß wie ich es mache und nicht auch dort noch wilde Installationsorgien durchführe)
Ich habe sie selbst nicht durchgeführt aber diese Anleitung ist aktuell und du kannst, da es im Forum ist auch Fragen stellen...
...ist also eine "interaktive" Anleitung:
https://forum.fhem.de/index.php/topic,66920.0.html
Viel Erfolg, Joachim
chris76e
Danke Joachim, das werde ich machen, aber nicht mehr heute   ;D
Christian
MadMax-FHEM
Christian
Gerne, hoffe es hilft!
Äh, wieso? Heute ist doch schon morgen ;)
Gruß, Joachim
chris76e
Habe jetzt nach den richtigen gesucht, und schon kann ich mit Alexa meinen Deckenfluter schalten.
Hat keine 15 minuten gedaueret.  :P
MadMax-FHEM
Gratuliere!
Viel Spaß dann!
Gruß, Joachim
chris76e
