HomeMatic Heizungssteuerung HM-CC-TC Grafig
Begonnen von Guest, 04 Februar 2012, 13:32:32
Guest
Broadcast and 000000 have so far always coincided here. Not that that
is a guarantee though. I also wondered why this is double, but one
could assume that receivers would interpret a dst of 000000 without
broadcast bit as a faulty message. The radiochip is not exclusively
used for Homematic, so there are probably variations that we would
never see. (like the dst is now a network address)
Possibly this one can be looked up in the datasheet for the radio, so
i'll investigate tonight.
On the wake up I have a trace. It involves making a setting on the
thermostat (going from C to F if I remember correctly). That would not
require waking up a valve.
I'll forward that trace tonight when I'm back home.
kind regards,
--Johan
On Wed, Feb 8, 2012 at 2:33 PM, Rudolf Koenig wrote:
>> BROADCAST : no explanation required, msg sent without destination address.
> Little bit strange, as there is also the broadcast address of 000000.
> What should we do if they (bit and address) do not match?
>> WAKEUP: as the thermostats are normally sleeping setting this bit
>> should wake up the thermostat
> This makes little sense to me, since I thought that the thermostat is sending a
> command to the valve on wakeup, and this is the signal for the CCU/fhem to
> start sending. Do you have some evidence, that the CC-TC is awake more often?
>> WAKEMEUP: normal status "1" for the thermostat. Just means I'm
>> currently asleep
> Another strange bit. Normally you are not talking when you are sleeping, I hope
> the CC-TC is no exception. Anyway I'll add the bits, just in order to be able
> to analyze them.
> To unsubscribe from this group, send email to
> fhem-users+unsubscribe@googlegroups.com
Hi Johan,
I've added your interpretation of the command bits to the hmProtocoleEvents
decoding (see the SVN). Could you please check, if it is done correctly?
Thanks,
  Rudi
Guest
Rudolph.
You are running the evaluation here:
1624         my @culHmCmdBits = ( "", "WAKEMEUP", "BCAST", "WAKEUP",
"BURST", "BIDI", "RPTED", "RPTEN");
1639    my $cmdInt = hex($cmd)>>8;
1640    my $cmdBits="TYPE=".(hex($cmd)&0xff);
1641    for(my $i = 0; $i < @culHmCmdBits; $i++) {
1642    $cmdBits .= ",$culHmCmdBits[$i]" if($cmdInt & (1<<$i));
So I assume you are evaluating from LSBit to MSBit
In that order line 1624 should look like this:
1624         my @culHmCmdBits = ( "WAKEUP", "WAKEMEUP", "BCAST", "",
where you also may replace BURST with "", because bits 3 and 4 are
never active on my setup (so unconfirmed).
Moving the WAKEUP to the first bit is a modification I sent in a later message.
Note that the bits shown here will not be in line with the message in
hmProtocolEvents since this replacement is still here:
1645    $cmd = "0A$1" if($cmd =~ m/0B(..)/);
1646    $cmd = "A4$1" if($cmd =~ m/84(..)/);
1647    $cmd = "8000" if(($cmd =~ m/A40./ || $cmd eq "0400") && $len eq "1A");
1648    $cmd = "A0$1" if($cmd =~ m/A4(..)/);
and thanks to you and the team for all the other improvements put in
the CUL_HM module. Nice surprise after updatefhem started working
again.
--Johan
On Sat, Feb 11, 2012 at 4:03 PM, Rudolf Koenig wrote:
> Hi Johan,
> Thanks,
>  Rudi
