(SOLVED - restart of fhem process - )backup command not found in fhem
Begonnen von riker1, 28 Mai 2018, 12:52:05
riker1
Hi
wieso kommt die Fehlermeldung backup command not found.
Das ist doch ein build in command. oder?
danke T
FHEM    5.26.1 Ubuntu 18, FHEM    5.26.1 RPI 3 , Actoren: IT ,Tasmota, ESPEasy,
MAX CUBE, MAX HT, MAX WT, Selbstbau nanoCULs, FS 20,Tasmota, Homematic, FTK, SW. DIM, Smoke,KODI,Squeezebox
nils_
#1
viele Wege in FHEM es gibt!
riker1
ist möglich, aber
denke nicht, habe 2 fhem installationen.
Auf der einen läuft das Update, backup läuft auf beiden nicht.
2018.05.28 12:32:33 0: Can't locate utf8.pm in @INC (you may need to install the utf8 module) (@INC contains: . /etc/perl /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabihf/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabihf/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl ./FHEM) at ./FHEM/50_TelegramBot.pm line 168.
BEGIN failed--compilation aborted at ./FHEM/50_TelegramBot.pm line 168.
2018.05.28 12:38:05 1: reload: Error:Modul 98_backup deactivated:
Can't locate File/Glob.pm in @INC (you may need to install the File::Glob module) (@INC contains: . /etc/perl /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabihf/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabihf/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl ./FHEM) at ./FHEM/98_backup.pm line 155.
BEGIN failed--compilation aborted at ./FHEM/98_backup.pm line 155.
2018.05.28 12:38:05 0: Can't locate File/Glob.pm in @INC (you may need to install the File::Glob module) (@INC contains: . /etc/perl /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabihf/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabihf/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl ./FHEM) at ./FHEM/98_backup.pm line 155.
2018.05.28 12:59:47 1: PERL WARNING: Subroutine backup_Initialize redefined at ./FHEM/98_backup.pm line 39.
2018.05.28 12:59:47 1: PERL WARNING: Subroutine CommandBackup redefined at ./FHEM/98_backup.pm line 48.
2018.05.28 12:59:47 1: PERL WARNING: Subroutine parseConfig redefined at ./FHEM/98_backup.pm line 113.
2018.05.28 12:59:47 1: reload: Error:Modul 98_backup deactivated:
2018.05.28 12:59:47 0: Can't locate File/Glob.pm in @INC (you may need to install the File::Glob module) (@INC contains: . /etc/perl /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabihf/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabihf/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl ./FHEM) at ./FHEM/98_backup.pm line 155.
riker1
also der fhem bei dem update geht und backup nicht, hat im log:
2018.05.28 13:13:17 1: reload: Error:Modul 98_backup deactivated:
Global symbol "$fhemForked" requires explicit package name at ./FHEM/98_backup.pm line 201.
BEGIN not safe after errors--compilation aborted at ./FHEM/98_backup.pm line 202.
2018.05.28 13:13:17 0: Global symbol "$fhemForked" requires explicit package name at ./FHEM/98_backup.pm line 201.
2018.05.28 13:17:24 1: reload: Error:Modul 98_backup deactivated:
2018.05.28 13:17:24 0: Global symbol "$fhemForked" requires explicit package name at ./FHEM/98_backup.pm line 201.
riker1
ah, nach einen restart ging das backup nun.
Dann ist es doch mit dem anderen Thema verbunden.
das das update klemmt
