Fhem stockt immer wieder.
Begonnen von Caleus, 12 Januar 2019, 12:33:52
Caleus
Guten Morgen
also ich habe nun mal ein paar logs aufgezeichnet und das letzte von "no bad guy found" wäre das hier
[Freezemon] myFreezemon: possible freeze starting at 05:31:44, delay is 1.242 possibly caused by: no bad guy found :-(
2019.01.13 05:31:43.953 4: : HTTP response code 200
2019.01.13 05:31:43.953 5: HttpUtils : Got data, length: 23
2019.01.13 05:31:43.953 5: HttpUtils response header:
HTTP/1.1 200 OK
Server: nginx/1.12.2
Date: Sun, 13 Jan 2019 04:31:43 GMT
Content-Type: application/json
Content-Length: 23
Connection: close
Access-Control-Allow-Origin: *
Access-Control-Allow-Methods: GET, POST, OPTIONS
Access-Control-Expose-Headers: Content-Length,Content-Type,Date,Server,Connection
Strict-Transport-Security: max-age=31536000; includeSubDomains; preload
2019.01.13 05:31:43.953 5: TelegramBot_Callback HomeBot: called from Polling
2019.01.13 05:31:43.953 5: TelegramBot_Callback HomeBot: data returned :{"ok":true,"result":[]}:
2019.01.13 05:31:43.954 5: TelegramBot_Deepencode HomeBot: encoded a String from :1: to :1:
2019.01.13 05:31:43.954 5: TelegramBot_Deepencode HomeBot: found an ARRAY
2019.01.13 05:31:43.954 5: TelegramBot_Deepencode HomeBot: found a HASH
2019.01.13 05:31:43.954 5: TelegramBot_Callback HomeBot: after encoding
2019.01.13 05:31:43.954 5: TelegramBot_Callback HomeBot: polling returned result? 0
2019.01.13 05:31:43.954 5: UpdatePoll HomeBot: number of results 0
2019.01.13 05:31:43.954 5: TelegramBot_UpdatePoll HomeBot: called
2019.01.13 05:31:43.954 5: TelegramBot_UpdatePoll HomeBot: - Initiate non blocking polling - With callback set
2019.01.13 05:31:43.955 5: TelegramBot_readToken: Read Telegram API token from file
2019.01.13 05:31:43.956 4: TelegramBot_UpdatePoll HomeBot: initiate polling with nonblockingGet with 120s
2019.01.13 05:31:43.956 5: HttpUtils url=
2019.01.13 05:31:43.957 4: IP: api.telegram.org -> 149.154.167.220
2019.01.13 05:31:43.958 5: TelegramBot_UpdatePoll HomeBot: - Ende > next polling started
2019.01.13 05:31:43.958 4: TelegramBot_Callback HomeBot: resulted in SUCCESS from Polling
2019.01.13 05:31:43.958 5: TelegramBot_Callback HomeBot: - Ende > Control back to FHEM
--- log skips     1.283 secs.
2019.01.13 05:31:45.241 5: HttpUtils request header:
GET /bot588317852:AAEF7WqdNa97iPKMLCVu6yVrrW9gVFOzVm4/getUpdates?offset=11174092&limit=5&timeout=120 HTTP/1.0
Host: api.telegram.org
Accept-Encoding: gzip,deflate
agent: TelegramBot/1.0
User-Agent: TelegramBot/1.0
Accept: application/json
Accept-Charset: utf-8
2019.01.13 05:31:45.242 5: [Freezemon] myFreezemon: ----------- Starting Freeze handling at 2019.01.13 05:31:45.242 ---------------------
Caleus
KernSani
Hmmm... da kann man gut sehen, dass der TelegramBot erfolgreich gepollt hat und FHEM dann erstmal ein Weilchen nichts mehr macht -zumindest keine Logeinträge mehr schreibt, d.h. es wird irgendetwas verarbeitet.
Wenn du die Catch*-Attribute noch aktivierdt, finder man möglicherweise mehr Details.
Freezemon kann leider nur Hinweise geben, wer einen Freeze verursacht hat. Das ,,warum" ist dann Handarbeit :-(
global dnsServer hattest du gesetzt, oder?
Kurz, weil mobil
Caleus
Ja also global dnsServer habe ich nun gestern gesetzt auf die Fritzbox IP, welche Einstellung für fm_CatchCmds
und fm_CatchFnCalls soll es den sein 0 bis 5 habe ich ?
Caleus
KernSani
0 bedeutet inaktiv, alles größer 0 bedeautet aktiv und gibt den Loglevel an... also 3 oder so...
Kurz, weil mobil
Caleus
#19
so hier mal  ein log mit gestztem fm_CatchCmds und fm_CatchFnCalls beides auf 5 (hoffe ich)
[Freezemon] myFreezemon: possible freeze starting at 14:07:51, delay is 4.376 possibly caused by: no bad guy found :-(
2019.01.13 14:07:50.048 4: : HTTP response code 200
2019.01.13 14:07:50.048 5: HttpUtils : Got data, length: 23
2019.01.13 14:07:50.048 5: HttpUtils response header:
HTTP/1.1 200 OK
Date: Sun, 13 Jan 2019 13:07:50 GMT
Content-Length: 23
Connection: close
2019.01.13 14:07:50.049 5: TelegramBot_Callback HomeBot: called from Polling
2019.01.13 14:07:50.049 5: TelegramBot_Callback HomeBot: data returned :{"ok":true,"result":[]}:
2019.01.13 14:07:50.049 5: TelegramBot_Deepencode HomeBot: found an ARRAY
2019.01.13 14:07:50.049 5: TelegramBot_Deepencode HomeBot: encoded a String from :1: to :1:
2019.01.13 14:07:50.049 5: TelegramBot_Deepencode HomeBot: found a HASH
2019.01.13 14:07:50.049 5: TelegramBot_Callback HomeBot: after encoding
2019.01.13 14:07:50.049 5: TelegramBot_Callback HomeBot: polling returned result? 0
2019.01.13 14:07:50.049 5: UpdatePoll HomeBot: number of results 0
2019.01.13 14:07:50.050 5: TelegramBot_UpdatePoll HomeBot: called
2019.01.13 14:07:50.050 5: TelegramBot_UpdatePoll HomeBot: - Initiate non blocking polling - With callback set
2019.01.13 14:07:50.051 5: TelegramBot_readToken: Read Telegram API token from file
2019.01.13 14:07:50.052 4: TelegramBot_UpdatePoll HomeBot: initiate polling with nonblockingGet with 120s
2019.01.13 14:07:50.052 5: HttpUtils url=
2019.01.13 14:07:50.053 4: IP: api.telegram.org -> 149.154.167.220
2019.01.13 14:07:50.054 5: TelegramBot_UpdatePoll HomeBot: - Ende > next polling started
2019.01.13 14:07:50.054 4: TelegramBot_Callback HomeBot: resulted in SUCCESS from Polling
2019.01.13 14:07:50.054 5: TelegramBot_Callback HomeBot: - Ende > Control back to FHEM
2019.01.13 14:07:50.073 4: GHoma_d33aa0 RX: 5A A5 00 16 90 01 0A E0 35 23 D3 3A A0 FF FE 01 81 39 00 00 01 01 20 00 02 90 13 5B B5
2019.01.13 14:07:50.080 5: rg_battery: not on any display, ignoring notify
2019.01.13 14:07:50.088 5: End notify loop for GHoma_d33aa0
--- log skips     5.287 secs.
2019.01.13 14:07:55.375 5: HttpUtils request header:
2019.01.13 14:07:55.376 5: [Freezemon] myFreezemon: ----------- Starting Freeze handling at 2019.01.13 14:07:55.376 ---------------------
Caleus
Caleus
