shutdown restart funktioniert nicht
Begonnen von bgewehr, 05 Januar 2013, 13:05:41
bgewehr
Ist eine FritzBox 7390!
auf ps | grep fhem per Telnet auf Port 23 kommt
Server> ps | grep fhem
Server>  1655 root      1244 S    {startfhem} /bin/sh /var/InternerSpeicher/fhem/start
Server>  1791 root     18284 S    perl fhem.pl fhem.cfg
nun shutdown restart führt zu ... meterweise logs nach dem Schema
Server> # system-load 2 curr: perl runnable: 2
Server> system-load 7 curr: perl runnable: 2
Server> SysRq : Changing Loglevel
Server> Loglevel set to 4
Server> [AVMDBG_OVR] -> skip header  should not happen!
Server> http header does not start at beginning of packet -> skip header  should not happen!
Server> system-load 2 curr: ctlmgr_ctl runnable: 3
Server> system-load 2 curr: perl runnable: 1
Server> system-load 3 curr: ctlmgr_ctl runnable: 1
Server> avm_pa: telephony active (reduce)
Server> avm_pa: telephony inactive
Server> system-load 2 curr: ctlmgr_ctl runnable: 2
Server> avm_pa: load reduce 0 => 1, rate 1750 (pps 33)
Server> avm_pa: load reduce 1 => 0, rate 1750 (pps 33 ov_pps 0)
Server> TFFS: F�llstand > 75 ... trigger Cleanup
Server> [AHA] SIGHUP received
Server>
Server>
Server>
Server>
Server> [aha: avm_home_upper_connection_thread] Error: message received (ret=-1, errno 4, 'Interrupted system call')
Server>
Server>
Server> nactive
Server> system-load 1 curr: perl runnable: 2
Server> avm_pa: load reduce 0 => 1, rate 1989 (pps 39)
Server> avm_pa: load reduce 1 => 0, rate 1989 (pps 39 ov_pps 0)
Server> system-load 2 curr: ctlmgr runnable: 2
Server> avm_pa: load reduce 0 => 1, rate 1989 (pps 41)
Server> avm_pa: load reduce 1 => 0, rate 1989 (pps 55 ov_pps 0)
Server> system-load 3 curr: perl runnable: 3
Server> system-load 2 curr: ctlmgr_ctl runnable: 1
Server> system-load 1 curr: ctlmgr_ctl runnable: 1
Server> system-load 1 curr: ctlmgr_ctl runnable: 2
Server> system-load 1 curr: ctlmgr_ctl runnable: 3
Server> system-load 3 curr: perl runnable: 1
Server> system-load 5 curr: perl runnable: 1
Server> system-load 6 curr: ctlmgr_ctl runnable: 3
Server> system-load 6 curr: perl runnable: 3
Server> system-load 6 curr: perl runnable: 1
Server> system-load 3 curr: perl runnable: 2
Server> [vap-0: 16:00:50:f2:01:01] discard assoc_req frame wrong bssid
Server> system-load 2 curr: perl runnable: 2
Server> system-load 3 curr: ctlmgr_ctl runnable: 3
Server> kdsld: flushing internet sessions
Server> system-load 3 curr: ctlmgr runnable: 4
Server> vdsl_pa_dev_transmit(vdsl) 1
Server> vdsl_pa_dev_transmit(vdsl) 1system-load 1 curr: perl runnable: 1
Server> system-load 1 curr: perl runnable: 3
Server> system-load 2 curr: ctlmgr_ctl runnable: 5
Server> system-load 2 curr: ctlmgr_ctl runnable: 7
Server> system-load 2 curr: ctlmgr runnable: 4
Server> system-load 2 curr: ar7cfgctl runnable: 3
Server> system-load 1 curr: ar7cfgctl runnable: 2
Server> do_page_fault() #2: sending SIGSEGV to smbd for invalid read access from
Server> 00000000 (epc == 00000000, ra == 004507BD)
Server> __ratelimit: 18 callbacks suppressed
Dann Stille!
dann wieder ps | grep fhem:
Server>  3451 root      1236 S    grep fhem
Auf dem Web-Interface kein response.
Muss die Box neu starten, damit wieder alles läuft...
FritzBox 7590, Synology DS216+II mit Docker
Docker: FHEM mit hmlan, Homebridge, node-red, mosquitto, ems-collector für Buderus EMS mit AVR Net-IO
Gartenwasser über MQTT auf R/Pi A+
Volkszaehler.org auf R/Pi 2B mit Pi_Erweiterung
Raspberrymatic auf R/Pi 4B mit RPI-RF-MOD u. CUL868
Puschel74
auch wenn ich jetzt, ahnungslos, über das Ziel hinaus schiesse ...
Hast du schonmal das Recover-File für die 7390 vom AVM-ftp-Server gezogen und die Box mal in den
"Urzustand" zurück gesetzt?
ACHTUNG!! Anleitung genauestens lesen und daran halten!!!
Damit solltest du "interne" "Verbiegungen" in den Bits und Bytes wieder gerade rücken können.
Nachdem der Beitrag schon länger so geht wäre ein Recover die schnellere Variante (ca. 5 Minuten) ;-)
Wenns hilft ist gut wenn nicht, naja - ists auch nicht schlimm.
justme1968
mir ist es zwei mal auf einer synology diskstation passiert. durch zufall habe ich bei einem mal in der consolen ausgabe ein fehler beim öffnen des telnet posts gesehen. ich tippe zumindest bei mir auf ein timing problem das beim restart der port noch belegt ist und dann das restart hängt.
locodriver
Ich habe heute auch mal mit Putty die Veränderung der laufenden Prozesse protokolliert, habe aber k.A., wie das zu interpretieren ist:
Zuerst laufendes fhem: #  4309 boxusr80 14920 S    perl fhem.pl fhem.cfg
dann shutdown restart: #  4800 boxusr80 10848 S    perl fhem.pl fhem.cfg
Neutart mit Putty:     #  4800 boxusr80 10856 S    perl fhem.pl fhem.cfg
nach neuem Aufruf von fhem im Browser:
 # ps | grep fhem
 4800 boxusr80 13296 S    perl fhem.pl fhem.cfg
 4821 root      1416 S    grep fhem
Den Tipp zum Recovern der FB habe ich noch nicht getestet.
Uwe
fhem 6.0 auf Rpi3 Bookworm
HM-LAN-CFG (FW 0.965), HM-MOD-UART, 2x HM-TC-IT-WM-W-EU, 4x HM-Sec-RHS und 3x HM-CC-RT-DN, 6x HM-LC-Bl1-FM mit je 1x Somfy-Motor,
2x HM-LC-SW2-FM für Licht und Lüfter, 2x HM-PB-6-WM55, Alexa, Jeelinkcross, CUL, CUNO2, IR-Blaster
ChrisW
Hab im Windows Bereich auch schon mal deswegen was aufgemacht. Da Funktioniert es bis heute leider auch nicht :(
Raspberry PI3 mit allem möglichen.
justme1968
gerade eben ist ein neu start schief gegangen. das hier sind die zeilen aus dem log:2013.01.21 23:57:55 0: Server shutdown
2013.01.21 23:57:57 1: Including /usr/local/FHEM/etc/fhem.cfg
2013.01.21 23:57:57 1: telnetPort: Can't open server port at 7072: Address already in use. Exiting.
  andre
bgewehr
Das klingt ja so, als würde es schin helfen, noch ein bisschen zu warten... kann das wer einbauen?
locodriver
Ich will das Thema heute noch mal aufnehmen:
Das Problem besteht nach wie vor, ich habe gerade ein update gefahren und der Neustart klappte wieder nicht. Ich kopiere mal die Putty-Ausgaben:
# Use of uninitialized value in string eq at fhem.pl line 2698, <$fh> line 21.
Use of uninitialized value $str in join or string at fhem.pl line 2701, <$fh> line 21.
Use of uninitialized value in string eq at fhem.pl line 2698, <$fh> line 136.
Use of uninitialized value $str in join or string at fhem.pl line 2701, <$fh> line 136.
Use of uninitialized value in string eq at fhem.pl line 2698, <$fh> line 221.
Use of uninitialized value $str in join or string at fhem.pl line 2701, <$fh> line 221.
Use of uninitialized value in string eq at fhem.pl line 2698, <$fh> line 232.
Use of uninitialized value $str in join or string at fhem.pl line 2701, <$fh> line 232.
Use of uninitialized value in hash element at ./FHEM/10_CUL_HM.pm line 3033.
Use of uninitialized value $lstAr in split at ./FHEM/10_CUL_HM.pm line 3034.
# ls
CHANGED         dfu-programmer  fhem.cfg.org    lib             startfhem
FHEM            docs            fhem.pl         log             unused
backup          fhem.cfg        fhem.pl.org     perl            www
# ./startfhem
chown: unknown user boxusr80
Vielleicht hilft das bei der Suche nach dem Fehler?
Danke Uwe.
justme1968
zumindest auf meiner syno passiert es fast regelmäßig und immer mit der besagten telnet port meldung.
  andre
justme1968
gerade eben bemerkt das es mit einem rereadcfg bei mir immer reproduzierbar ist. die 'Address already in use' meldung kommt und fhem beendet sich.
das telnet_Undef wird auch nicht aufgerufen und das scheint die einzige stelle zu sein von wo aus TcpServer_Close aufgerufen wird.
  nadre
bgewehr
Seit meinem letzten fhem Update läuft shutdown auch mit Restart!
locodriver
Das ist ja mal 'ne gute Nachricht, werde ich am WE auch ausprobieren. Das Neustarten mit Putty nervt doch ganz schön...
Hast du noch irgendwas in den Einstellungen geändert?
Danke Uwe
locodriver
... und leider hat sich bei mir nichts geändert - also weiter Putty nutzen. :-(
Schönes WE
Uwe
