Dimmer mit Taster peeren
Begonnen von eule66, 03 März 2016, 12:12:35
eule66
Hallo
in den Readings beim virtuellen Aktor Btn01 steht: peerList
Taster_Stube_Btn01
ein get hm peer check bringt folgendes Ergebniss
peerCheck done:
peer not defined
    Taster_Stube_Btn01 id:2FF55501
    Taster_Stube_Btn02 id:2FF55501
peer not verified. Check that peer is set on both sides
    Wz.Dimmer1 p:Taster_Stube_Btn01
    Wz.Dimmer1 p:Taster_Stube_Btn02
    Wz.Dimmer2 p:Taster_Stube_Btn01
    Wz.Dimmer2 p:Taster_Stube_Btn02
im Logfile steht folgendes:
16-03-05 10:31:23 CUL_HM Taster battery: ok
2016-03-05 10:31:23 CUL_HM Taster CMDs_done
2016-03-05 10:31:23 CUL_HM Taster Taster_Stube_Btn02 Short
2016-03-05 10:31:23 CUL_HM Taster_Stube_Btn02 Short (to virtueller_Aktor)
2016-03-05 10:31:23 CUL_HM Taster_Stube_Btn02 trigger: Short_221
2016-03-05 10:31:23 CUL_HM Taster_Stube_Btn02 trigger_cnt: 221
2016-03-05 10:31:23 CUL_HM virtueller_Aktor_Btn2 OFF
2016-03-05 10:31:23 CUL_HM virtueller_Aktor_Btn2 trigLast: Taster_Stube_Btn02:short
2016-03-05 10:31:23 CUL_HM virtueller_Aktor_Btn2 trig_Taster_Stube_Btn02: short
2016-03-05 10:31:23 CUL_HM virtueller_Aktor_Btn2 virtActState: OFF
2016-03-05 10:31:23 CUL_HM virtueller_Aktor_Btn2 virtActTrigNo: 221
2016-03-05 10:31:23 CUL_HM virtueller_Aktor_Btn2 virtActTrigRpt: 1
2016-03-05 10:31:23 CUL_HM virtueller_Aktor_Btn2 virtActTrigType: short_Release
2016-03-05 10:31:23 CUL_HM virtueller_Aktor_Btn2 virtActTrigger: Taster_Stube_Btn02
2016-03-05 10:31:23 CUL_HM Taster battery: ok
2016-03-05 10:31:23 CUL_HM Taster_Stube_Btn02 Short (to 2FF555)
2016-03-05 10:31:23 CUL_HM Taster_Stube_Btn02 Short (to HM_2C4424)
2016-03-05 10:31:23 structure Wz.Dimmer.alle undefined
2016-03-05 10:31:23 CUL_HM Wz.Dimmer1 deviceMsg: 96.5 (to Taster)
2016-03-05 10:31:23 CUL_HM Wz.Dimmer1 dim: up:96.5
2016-03-05 10:31:23 CUL_HM Wz.Dimmer1 level: 96.5
2016-03-05 10:31:23 CUL_HM Wz.Dimmer1 overheat: off
2016-03-05 10:31:23 CUL_HM Wz.Dimmer1 overload: off
2016-03-05 10:31:23 CUL_HM Wz.Dimmer1 pct: 96.5
2016-03-05 10:31:23 CUL_HM Wz.Dimmer1 reduced: off
2016-03-05 10:31:23 CUL_HM Wz.Dimmer1 chn:96.5 phys:0
2016-03-05 10:31:23 CUL_HM Wz.Dimmer1 timedOn: off
2016-03-05 10:31:25 CUL_HM HM_3356A2 phyLevel: 100
2016-03-05 10:31:25 CUL_HM HM_3356A2 CMDs_done
2016-03-05 10:31:25 CUL_HM HM_3356A2 chn:???  phys:100
2016-03-05 10:31:25 CUL_HM HM_3356A2_Sw1_V_01 phyLevel: 100
2016-03-05 10:31:25 CUL_HM HM_3356A2_Sw1_V_01 on
2016-03-05 10:31:25 CUL_HM HM_3356A2_Sw1_V_02 phyLevel: 100
2016-03-05 10:31:25 CUL_HM HM_3356A2_Sw1_V_02 chn:off  phys:100
2016-03-05 10:31:25 structure Wz.Dimmer.alle undefined
2016-03-05 10:31:25 CUL_HM Wz.Dimmer2 deviceMsg: on (to VCCU)
2016-03-05 10:31:25 CUL_HM Wz.Dimmer2 dim: stop:on
2016-03-05 10:31:25 CUL_HM Wz.Dimmer2 level: 100
2016-03-05 10:31:25 CUL_HM Wz.Dimmer2 overheat: off
2016-03-05 10:31:25 CUL_HM Wz.Dimmer2 overload: off
2016-03-05 10:31:25 CUL_HM Wz.Dimmer2 pct: 100
2016-03-05 10:31:25 CUL_HM Wz.Dimmer2 phyLevel: 100
2016-03-05 10:31:25 CUL_HM Wz.Dimmer2 reduced: off
2016-03-05 10:31:25 CUL_HM Wz.Dimmer2 on
2016-03-05 10:31:25 CUL_HM Wz.Dimmer2 timedOn: off
2016-03-05 10:31:26 CUL_HM HM_2C4424 phyLevel: 100
2016-03-05 10:31:26 CUL_HM HM_2C4424 CMDs_done
2016-03-05 10:31:26 CUL_HM HM_2C4424 chn:???  phys:100
2016-03-05 10:31:26 CUL_HM HM_2C4424_Sw1_V_01 phyLevel: 100
2016-03-05 10:31:26 CUL_HM HM_2C4424_Sw1_V_01 chn:45  phys:100
2016-03-05 10:31:26 CUL_HM HM_2C4424_Sw1_V_02 phyLevel: 100
2016-03-05 10:31:26 CUL_HM HM_2C4424_Sw1_V_02 chn:57  phys:100
2016-03-05 10:31:26 structure Wz.Dimmer.alle on
2016-03-05 10:31:26 CUL_HM Wz.Dimmer1 deviceMsg: on (to VCCU)
2016-03-05 10:31:26 CUL_HM Wz.Dimmer1 dim: stop:on
2016-03-05 10:31:26 CUL_HM Wz.Dimmer1 level: 100
2016-03-05 10:31:26 CUL_HM Wz.Dimmer1 overheat: off
2016-03-05 10:31:26 CUL_HM Wz.Dimmer1 overload: off
2016-03-05 10:31:26 CUL_HM Wz.Dimmer1 pct: 100
2016-03-05 10:31:26 CUL_HM Wz.Dimmer1 phyLevel: 100
2016-03-05 10:31:26 CUL_HM Wz.Dimmer1 reduced: off
2016-03-05 10:31:26 CUL_HM Wz.Dimmer1 on
2016-03-05 10:31:26 CUL_HM Wz.Dimmer1 timedOn: off
Was mache ich falsch?
martinp876
Dann nutze erst einmal codetags. Dann mache ein
get hm param -c peerIDs
eule66
Hallo Martin
ein get hm param -c peerIDs brachte folgende Ergebnisse
param done:
param list
    entity                 : peerIDs                 |
    BWM_Kueche             : 00000000 ,
    BWM_Stube              : 00000000 ,
    HM_3356A2_Sw1_V_01     : 00000000 ,
    HM_3356A2_Sw1_V_02     : 00000000 ,
    Keller.Sd.Zirku        : 00000000 ,
    Kueche_Fenster         : 00000000 ,
    Stube_Fenster          : 00000000 ,
    Taster_Stube_Btn01     : 00000000 ,12345601 ,2FF55501 ,
    Taster_Stube_Btn02     : 00000000 ,12345602 ,2FF55501 ,
    Wz.Dimmer1             : 00000000 ,30FC5C01 ,30FC5C02 ,
    Wz.Dimmer2             : 00000000 ,30FC5C01 ,30FC5C02 ,
    Wz.Sd.TV               : 00000000 ,
    virtueller_Aktor_Btn1   : 30FC5C01 ,
    virtueller_Aktor_Btn2   : 30FC5C02 ,
martinp876
Die ids sehe ich jetzt nicht. Ist wohl so, dass tast1 die 30fc5c01 hat und mit 2 dimmern sowie einem virtuellen aktor gepeert ist. Es sind aber nur 2peers eingetragen. Fehlt einer - oder?
Beim 2. sieht es identisch aus.
Frage: wenn die meldung kommt, das beim peering etwas nicht stimmt, kan man dies nicht mit Bordmitteln prüfen? Alles was hier geprüft wird ist die symetrie.
Obendrein wird 2ff555 als nicht existent reklamiert(not defined) wenn es den nicht gibt sollte er entfernt werden.
Du solltest ein getconfig machen. Du kannst das in den Attributen korrigieren, was aber keinerlei Sinn macht.
