Ansage bei Müllabfuhr fehlerhaft nach Calendarupdate
Begonnen von raspklaus, 14 Februar 2016, 10:30:47
raspklaus
Sorry,
ich hatte das aus den vorherigen Threats kopiert. Ich habe nun nochmal alles in der Testumgebung eingespielt und hier die Ausgaben:
Das Log:
2016.02.15 09:33:34 5: Triggering RemovalCheck
2016.02.15 09:33:34 4: RemovalCheck exec {
my $RemovalBlack = "off";;
my $RemovalBrown = "off";;
my $RemovalBlue = "off";;
my $RemovalYellow = "off";;
my $RemovalToxic = "off";;
my $RemovalPaper = "off";;
my $RemovalGreen = "off";;
my $rcal = "";;
my $rcal= fhem("get Abfall text next 4,1");;
my @events = split ("\n", $rcal);;
my $tomorrow = strftime "%d.%m.%y", localtime(time + 86400);;
foreach my $event (@events)
my RemovalCheckvalues = split(" ", $event);;
if ($values[0] eq $tomorrow)
  if ($values[3] eq "Restmüll") {$RemovalBlack = "on"}
  elsif ($values[3] eq "Biomüllabfuhr") {$RemovalBrown = "on"}
  elsif ($values[3] eq "Papiertonne") {$RemovalBlue = "on"}
  elsif ($values[3] eq "Gelber") {$RemovalYellow = "on"}
  elsif ($values[3] eq "Schadstoffsammlung") {$RemovalToxic = "on"}
  elsif ($values[3] eq "Papiersammlung") {$RemovalPaper = "on"}
  elsif ($values[3] eq "Grünabfallsammlung") {$RemovalGreen = "on"}
fhem("set RemovalBlack $RemovalBlack");;
fhem("set RemovalBrown $RemovalBrown");;
fhem("set RemovalBlue $RemovalBlue");;
fhem("set RemovalYellow $RemovalYellow");;
fhem("set RemovalToxic $RemovalToxic");;
fhem("set RemovalPaper $RemovalPaper");;
fhem("set RemovalGreen $RemovalGreen");;
return;;
2016.02.15 09:33:34 1: PERL WARNING: "my" variable $rcal masks earlier declaration in same scope at (eval 11278) line 11.
2016.02.15 09:33:34 3: eval: {
my $rcal = "";
return;
2016.02.15 09:33:34 3: RemovalCheck return value: No such class RemovalCheckvalues at (eval 11278) line 17, near "{
my RemovalCheckvalues"
syntax error at (eval 11278) line 17, near "my RemovalCheckvalues ="
Global symbol "@values" requires explicit package name at (eval 11278) line 19.
Global symbol "@values" requires explicit package name at (eval 11278) line 21.
Global symbol "@values" requires explicit package name at (eval 11278) line 22.
Global symbol "@values" requires explicit package name at (eval 11278) line 23.
Global symbol "@values" requires explicit package name at (eval 11278) line 24.
Global symbol "@values" requires explicit package name at (eval 11278) line 25.
Global symbol "@values" requires explicit package name at (eval 11278) line 26.
Global symbol "@values" requires explicit package name at (eval 11278) line 27.
Kopie des notify aus dem Webinterface:
RemovalCheck {
my $rcal = "";
my @@events = split ("\n", $rcal);
my $tomorrow = strftime "%%d.%%m.%%y", localtime(time + 86400);
foreach my $event (@@events)
my @values = split(" ", $event);
return;
und hier die Ausgabe für get Abfall text next 4
15.02.16 06:00 Abfuhrtermin Biomüllabfuhr am 15.02.2016
22.02.16 06:00 Abfuhrtermin Restmüll am 22.02.2016
23.02.16 06:00 Abfuhrtermin Papiertonne am 23.02.2016
29.02.16 06:00 Abfuhrtermin Biomüllabfuhr am 29.02.2016
Puschel74
#16
Und nochmal:
LOG
notify:
Es fehlt diese Zeile
Ergo: Die Logausgabe passt immer noch nicht zum gezeigten notify.
Edith: Im notify sieht die Zeile so
aus und hat mit der Logausgabe aber immer noch nichts zu tun.
Es bleibt dabei - das notify passt nicht zum Log.
Edith1: Abgesehen davon wird $rcal zweimal mit my deklariert - das sagt auch ein Teil der Meldung.
raspklaus
#17
@Puschel,
ich sitze gerade direkt vor der Maschine. Ich hatte vorher das gesammte Log gelöscht, damit nur die richtige Ausgabe drin ist und wie soll die Logausgabe nicht zum Notify passen ?
Am Anfang des Logs steht doch der auslösende Trigger
Dazu der passende Screenshot
Puschel74
#18
Ich hab dir die Unterschiede gezeigt.
Wenn die Logausgabe zum notify unterschiedliche Codes zeigt passen die beiden einfach nicht zusammen.
Der auslösende Trigger ist kein Beweis das es anders ist.
Edith: Aber extra für dich nochmal das "Fehler-Suchbild":
Logausgabe:
Notify:
Wer findet als erster den Unterschied  8)
raspklaus
Ich habe mal das rcal entfernt und values in werte geändert. Hier das Ergebnis:
Webinterface:
RemovalCheck {
my @werte = split(" ", $event);
if ($werte[0] eq $tomorrow)
  if ($werte[3] eq "Restmüll") {$RemovalBlack = "on"}
  elsif ($werte[3] eq "Biomüllabfuhr") {$RemovalBrown = "on"}
  elsif ($werte[3] eq "Papiertonne") {$RemovalBlue = "on"}
  elsif ($werte[3] eq "Gelber") {$RemovalYellow = "on"}
  elsif ($werte[3] eq "Schadstoffsammlung") {$RemovalToxic = "on"}
  elsif ($werte[3] eq "Papiersammlung") {$RemovalPaper = "on"}
  elsif ($werte[3] eq "Grünabfallsammlung") {$RemovalGreen = "on"}
return;
Log:
2016.02.15 10:17:54 5: Triggering RemovalCheck
2016.02.15 10:17:54 4: RemovalCheck exec {
my RemovalCheckevents = split ("\n", $rcal);;
foreach my $event (RemovalCheckevents)
my RemovalCheckwerte = split(" ", $event);;
return;;
2016.02.15 10:17:54 3: RemovalCheck return value: No such class RemovalCheckevents at (eval 12614) line 11, near ";
my RemovalCheckevents"
syntax error at (eval 12614) line 11, near "my RemovalCheckevents ="
No such class RemovalCheckwerte at (eval 12614) line 16, near "{
my RemovalCheckwerte"
syntax error at (eval 12614) line 16, near "my RemovalCheckwerte ="
Global symbol "@werte" requires explicit package name at (eval 12614) line 18.
Global symbol "@werte" requires explicit package name at (eval 12614) line 20.
Global symbol "@werte" requires explicit package name at (eval 12614) line 21.
Global symbol "@werte" requires explicit package name at (eval 12614) line 22.
Global symbol "@werte" requires explicit package name at (eval 12614) line 23.
Global symbol "@werte" requires explicit package name at (eval 12614) line 24.
Global symbol "@werte" requires explicit package name at (eval 12614) line 25.
Global symbol "@werte" requires explicit package name at (eval 12614) line 26.
Bareword "RemovalCheckevents" not allowed while "strict subs" in use at (eval 12614) line 14.
Puschel74
Tja, so wie es aussieht wird das @ durch RemovalCheck ersetzt.
raspklaus
dev0
Benutzt Du noch Featurelevel 5.6, das würde das Verhalten auf den ersten Blick erklären.
Lager den Code in die 99_myUtils aus.
Puschel74
Das wäre jetzt auch meine Vermutung gewesen.
raspklaus
Danke Euch beiden, genau das war es. Ich hatte das Attribut Featurelevel auf 5.6 wegen einem anderen Problem gesetzt und es einfach vergessen zu löschen. Mein Fehler   :(
