Ansage bei Müllabfuhr fehlerhaft nach Calendarupdate
Begonnen von raspklaus, 14 Februar 2016, 10:30:47
raspklaus
das folgende Modul lief bis zum neuen Calendarmodul ohne Probleme und ich habe es deshalb auch nie verändert:
RemovalCheck {
my $RemovalBlack = "off";
my $RemovalBrown = "off";
my $RemovalBlue = "off";
my $RemovalYellow = "off";
my $RemovalToxic = "off";
my $RemovalPaper = "off";
my $RemovalGreen = "off";
my $rcal= fhem("get Abfall text all 4");
my @@events = split ("\n", $rcal);
my $tomorrow = strftime "%d.%m.%y", localtime(time + 86400);
foreach my $event (@events)
my @values = split(" ", $event);
if ($values[0] eq $tomorrow)
  if ($values[3] eq "Restmüll") {$RemovalBlack = "on"}
  elsif ($values[3] eq "Biomüllabfuhr") {$RemovalBrown = "on"}
  elsif ($values[3] eq "Papiertonne") {$RemovalBlue = "on"}
  elsif ($values[3] eq "Gelber") {$RemovalYellow = "on"}
  elsif ($values[3] eq "Schadstoffsammlung") {$RemovalToxic = "on"}
  elsif ($values[3] eq "Papiersammlung") {$RemovalPaper = "on"}
  elsif ($values[3] eq "Grünabfallsammlung") {$RemovalGreen = "on"}
fhem("set RemovalBlack $RemovalBlack");
fhem("set RemovalBrown $RemovalBrown");
fhem("set RemovalBlue $RemovalBlue");
fhem("set RemovalYellow $RemovalYellow");
fhem("set RemovalToxic $RemovalToxic");
fhem("set RemovalPaper $RemovalPaper");
fhem("set RemovalGreen $RemovalGreen");
return;
Problem ist das :
das habe ich an das neue Calendarmodul angepasst:
get Abfall text next 4
Nun wird keine Auswertung mehr durchgeführt, mit folgender Fehlermeldung:
2016.02.14 10:22:17 3: RemovalCheck return value: No such class RemovalCheckevents at (eval 29576) line 11, near ";
my RemovalCheckevents"
syntax error at (eval 29576) line 11, near "my RemovalCheckevents ="
No such class RemovalCheckvalues at (eval 29576) line 16, near "{
my RemovalCheckvalues"
syntax error at (eval 29576) line 16, near "my RemovalCheckvalues ="
Global symbol "@values" requires explicit package name at (eval 29576) line 18.
Global symbol "@values" requires explicit package name at (eval 29576) line 20.
Global symbol "@values" requires explicit package name at (eval 29576) line 21.
Global symbol "@values" requires explicit package name at (eval 29576) line 22.
Global symbol "@values" requires explicit package name at (eval 29576) line 23.
Global symbol "@values" requires explicit package name at (eval 29576) line 24.
Global symbol "@values" requires explicit package name at (eval 29576) line 25.
Global symbol "@values" requires explicit package name at (eval 29576) line 26.
Bareword "RemovalCheckevents" not allowed while "strict subs" in use at (eval 29576) line 14.
Eingelesen werden die Einträge wie vorher:
15.02.16 06:00 Abfuhrtermin Biomüllabfuhr am 15.02.2016
22.02.16 06:00 Abfuhrtermin Restmüll am 22.02.2016
23.02.16 06:00 Abfuhrtermin Papiertonne am 23.02.2016
29.02.16 06:00 Abfuhrtermin Biomüllabfuhr am 29.02.2016
Ich habe leider keinen Ansatzpunkt weshalb das Ganze nun nicht mehr läuft und wäre euch sehr dankbar wenn ihr mich dabei unterstützen könntet
Icinger
Da gehört nur ein @, oder????
lg, Stefan
Verwende deine Zeit nicht mit Erklärungen. Die Menschen hören (lesen) nur, was sie hören (lesen) wollen. (c) Paulo Coelho
Icinger
Argh........Sag jetzt nicht, du arbeitest in der fhem.cfg mit sowas rum?
Jetzt ins gar kein @ mehr da und lauter doppelte ;;
raspklaus
#3
Nein, ich arbeite natürlich nicht in der cfg sondern über das Webinterface. In der Beziehung bin ich ja kein Änfanger mehr.
Im Webinterface siehrt es so aus:
RemovalCheck {
my $rcal= fhem("get Abfall text next 1");
my @events = split ("\n", $rcal);
return;
Das @ wird doch durch den Namen des Notifys ersetzt, deshalb die Logausgabe
In der cfg stehen zwei ;;
Sorry, merke gerade, der letzte Logauszug war aus der Testumgebung. War noch im Buffer
Hier die aktuelle Logausgabe:
2016.02.14 14:16:02 4: RemovalCheck exec {
my $RemovalBlack = "off";;
my $RemovalBrown = "off";;
my $RemovalBlue = "off";;
my $RemovalYellow = "off";;
my $RemovalToxic = "off";;
my $RemovalPaper = "off";;
my $RemovalGreen = "off";;
my $rcal= fhem("get Abfall text next 4");;
my RemovalCheckevents = split ("\n", $rcal);;
my $tomorrow = strftime "d.m.y", localtime(time + 86400);;
foreach my $event (RemovalCheckevents)
my RemovalCheckvalues = split(" ", $event);;
fhem("set RemovalBlack $RemovalBlack");;
fhem("set RemovalBrown $RemovalBrown");;
fhem("set RemovalBlue $RemovalBlue");;
fhem("set RemovalYellow $RemovalYellow");;
fhem("set RemovalToxic $RemovalToxic");;
fhem("set RemovalPaper $RemovalPaper");;
fhem("set RemovalGreen $RemovalGreen");;
return;;
2016.02.14 14:16:02 3: RemovalCheck return value: No such class RemovalCheckevents at (eval 1499) line 11, near ";
syntax error at (eval 1499) line 11, near "my RemovalCheckevents ="
No such class RemovalCheckvalues at (eval 1499) line 16, near "{
syntax error at (eval 1499) line 16, near "my RemovalCheckvalues ="
Global symbol "@values" requires explicit package name at (eval 1499) line 18.
Global symbol "@values" requires explicit package name at (eval 1499) line 20.
Global symbol "@values" requires explicit package name at (eval 1499) line 21.
Global symbol "@values" requires explicit package name at (eval 1499) line 22.
Global symbol "@values" requires explicit package name at (eval 1499) line 23.
Global symbol "@values" requires explicit package name at (eval 1499) line 24.
Global symbol "@values" requires explicit package name at (eval 1499) line 25.
Global symbol "@values" requires explicit package name at (eval 1499) line 26.
Bareword "RemovalCheckevents" not allowed while "strict subs" in use at (eval 1499) line 14.
raspklaus
Habe jetzt mal versucht wenigstens den ersten Eintrag ins Log zu bringen
{Log 1,"Zeile".$event;
aber da kommt nichts
Icinger
WIE genau hast du das denn definiert?
Bei dieser Länge wäre es mAn sinnvoll, das ganze Konstrukt in die 99_myUtils zu legen.
raspklaus
#6
Du es hat aber bis letzte Woche funktioniert. Die letzte Müllabfuhr ist noch richtig angesagt worden und auch der Dummy gesetzt.
Durch das Notify werden ja nur die Dummys zur visuellen Kontrolle auf on gesetzt und der Befehl für die Sprachausgabe erzeugt
Ich komme mit dem angeblichen Syntaxerror nicht klar
Das Ganze in die 99_myUtils zu legen wäre zwar schön, aber das kann ich leider noch nicht
Gruss
Klaus
raspklaus
chris1284
schau dir mal das abfall-modul (http://forum.fhem.de/index.php?topic=48237.0) oder calview an. beide extrahieren aus dem calendar erfolgreich werte
dev0
1. Fehler: Arrays werden mit einem @ vor dem Namen deklariert.
2. Fehler: Wenn du Variablen umbenennst (values), dann bitte auch an allen Stellen im Code.
3. Fehler: Du hast kein einziges Kapitel eines x-beliebigen Perl-Buchs gelesen oder verstanden, fragst stattdessen lieber im Forum nach...
raspklaus
Hallo Dev0,
Dann er klär mir doch aber bitte war ich nicht verstanden habe:
zu Fehler 1:
Mit dem Array meinst Du sicherlich my @events
Das ist mit einem @ deklariert
Die vormals als test eingebenen doppel @ stammen aus der Befehlsreferenz  unter Perl Spezials
zu Fehler 2:
Wo benenne ich Variablen um ?
Meinst Du $values[0) und $values[3)
Das ist keine Umbenennung sondern die Position in der Variablen
Bei
ist $values[0]  gleich 15.02.2016
und
$values[3)  gleich Biomüllabfuhr
also wo liegt das der Fehler ?
Ich habe gelesen
DerJens
auf die Schnelle 3 Dinge:
- Ich hab vor wenigen Wochen mein FHEM auf eine aktuelle Version gebracht und die Abfuhrtermine aus 2016 eingepflegt. Der folgende Codeschnipsel funktioniert bislang problemlos in einem Notify:
RemovalCheck {
my $rcal = "";
$rcal = fhem("get RemovalCalendar text modeUpcoming 4",1);
  if ($values[2] eq "Restmülltonne") {$RemovalBlack = "on"}
  elsif ($values[2] eq "Biotonne") {$RemovalBrown = "on"}
  elsif ($values[2] eq "Papiertonne") {$RemovalGreen = "on"}
  elsif ($values[2] eq "Gelber") {$RemovalYellow = "on"}
return;
- Das neue Calendarmodul hab ich wohl verpasst - was ist denn da anders?
- Deine Ausgabe vom Log sieht anders aus als dein Code im Notify. Woher kommt z.B. foreach my $event (RemovalCheckevents)??
Lass mal 1. dein Code aus dem Notify sehen und 2. die PASSENDE Logausgabe, wenn du das Notify triggerst. Vielleicht kann ich ja helfen.
Liebe Grüße
DerJens
dev0
Zitat von: raspklaus am 14 Februar 2016, 19:48:49
zu Fehler 1:
Nein, sondern:
zu Fehler 2:
Das war ursprünglich @values und darauf wird später mit $values[] zugegriffen.
raspklaus
#13
Hallo Dev0,
Du verwechselst die Logausgabe  mit den Einträgen in der FHEM Config:
Hier die Logausgabe:
my $rcal = "";;
return;;
und hier das Notify aus dem Webinterface:
RemovalCheck {
my $rcal = "";
return;
Die Logausgabe bezieht sich auf verbose 5
Puschel74
Das gezeigte Log bezieht sich NICHT auf das gezeigte notify.
Diese 2 Zeilen
fehlen im gezeigten notify und sind in der Logausgabe aber vorhanden.
Weiters ist auch diese Zeile im Log
und diese im notify
unterschiedlich.
Es wäre für die helfenden mit Sicherheit einfacher wenn du selbst die Logausgaben dem richtigen notify zuordnen könntest.
Ratespiele machen mit der Zeit nämlich keinen Spaß mehr.
