FHEM mit configDB startet nach Neuinstallation nicht - Diverse Probleme
Begonnen von Spezialtrick, 15 Juni 2016, 12:07:34
Spezialtrick
Offenbar habe ich den Übeltäter gefunden. Es war der USB-Hub selbst. Nun sind alle Geräte sofort nach dem Neustart da:
root@cubietruck:~# dmesg
[    0.000000] Booting Linux on physical CPU 0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 3.4.112-sun7i (root@pluton) (gcc version 5.3.1 20160413 (Ubuntu/Linaro 5.3.1-14ubuntu2) ) #7 SMP PREEMPT Mon May 23 22:09:19 CEST 2016
[    0.000000] CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: sun7i
[    0.000000] Memory Reserved:
[    0.000000] SYS  : 0x43000000 - 0x4300ffff  (  64 kB)
[    0.000000] LCD  : 0x44000000 - 0x44ffffff  (  16 MB)
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] sunxi: Allwinner A20 (AW1651/sun7i) detected.
[    0.000000] On node 0 totalpages: 524288
[    0.000000] free_area_init_node: node 0, pgdat c0a89440, node_mem_map d0000000
[    0.000000]   DMA zone: 512 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 65024 pages, LIFO batch:15
[    0.000000]   Normal zone: 1008 pages used for memmap
[    0.000000]   Normal zone: 128016 pages, LIFO batch:31
[    0.000000]   HighMem zone: 2576 pages used for memmap
[    0.000000]   HighMem zone: 327152 pages, LIFO batch:31
[    0.000000] PERCPU: Embedded 8 pages/cpu @d100e000 s8256 r8192 d16320 u32768
[    0.000000] pcpu-alloc: s8256 r8192 d16320 u32768 alloc=8*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 520192
[    0.000000] Kernel command line: console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 cgroup_enable=memory swapaccount=1 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 enforcing=0 loglevel=1
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] allocated 4194304 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Memory: 2048MB = 2048MB total
[    0.000000] Memory: 2043020k/2043020k available, 54132k reserved, 1318912K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc09dfe98   (10080 kB)
[    0.000000]       .init : 0xc09e0000 - 0xc0a18040   ( 225 kB)
[    0.000000]       .data : 0xc0a1a000 - 0xc0a91d68   ( 480 kB)
[    0.000000]        .bss : 0xc0a91d8c - 0xc0c66f78   (1877 kB)
[    0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[    0.000000] Additional per-CPU info printed with stalls.
[    0.000000] NR_IRQS:192
[    0.000000] Architected local timer running at 24.00MHz.
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] start_kernel(): bug: interrupts were enabled early
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty1] enabled
[    0.013310] Calibrating delay loop... 1816.98 BogoMIPS (lpj=9084928)
[    0.076004] pid_max: default: 32768 minimum: 301
[    0.079661] Mount-cache hash table entries: 512
[    0.083886] Initializing cgroup subsys cpuacct
[    0.087206] Initializing cgroup subsys memory
[    0.090628] Initializing cgroup subsys devices
[    0.094068] Initializing cgroup subsys freezer
[    0.097294] Initializing cgroup subsys blkio
[    0.100968] Initializing cgroup subsys perf_event
[    0.104549] CPU: Testing write buffer coherency: ok
[    0.109760] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.116868] hw perfevents: enabled with ARMv7 Cortex-A7 PMU driver, 5 counters available
[    0.122410] Setting up static identity map for 0x40724a18 - 0x40724a70
[    0.239148] CPU1: Booted secondary processor
[    0.297311] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.299320] Brought up 2 CPUs
[    0.304631] SMP: Total of 2 processors activated (3640.52 BogoMIPS).
[    0.307864] devtmpfs: initialized
[    0.313902] dummy:
[    0.317582] NET: Registered protocol family 16
[    0.324023] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.331944] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.336758] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.339910] [ccu-inf] aw clock manager init
[    0.342182] [ccu-inf] aw_ccu_init
[    0.346156] [ccu-inf] script config pll3 to 297MHz
[    0.349907] [ccu-inf] script config pll4 to 300MHz
[    0.353655] [ccu-inf] script config pll6 to 600MHz
[    0.357418] [ccu-inf] script config pll7 to 297MHz
[    0.361166] [ccu-inf] script config pll8 to 336MHz
[    0.363936] Init eGon pin module V2.0
[    0.373544] bio: create slab <bio-0> at 0
[    0.377123] sunxi_gpio driver init ver 1.3
[    0.383437] sunxi_gpio_probe script_parser_fetch '[gpio_para]' 'gpio_pin_3' err
[    0.389036] gpiochip_add: registered GPIOs 1 to 4 on device: A1X_GPIO
[    0.392235] SCSI subsystem initialized
[    0.395094] libata version 3.00 loaded.
[    0.399756] usbcore: registered new interface driver usbfs
[    0.404121] usbcore: registered new interface driver hub
[    0.408287] usbcore: registered new device driver usb
[    0.411404] Linux media interface: v0.10
[    0.415014] Linux video capture interface: v2.00
[    0.420632] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.426168] Switching to clocksource arch_sys_counter
[    0.428276] FS-Cache: Loaded
[    0.430489] CacheFiles: Loaded
[    0.441571] cfg80211: Calling CRDA to update world regulatory domain
[    0.442890] [usb_manager]: CONFIG_USB_SW_SUNXI_USB0_OTG
[    0.446689] [sw_hcd0]: usb host driver initialize........
[    0.450932] [sw_hcd0]: open_usb_clock
[    0.475188] [sw_hcd0]: host_init_state = 1
[    0.476160] [sw_hcd0]: platform is usb host
[    0.479083] [sw_hcd0]: sw_hcd_host0: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx (X), HB-ISO Tx (X), SoftConn)
[    0.490267] [sw_hcd0]: sw_hcd_init_controller: sw_hcd_host0: USB Host mode controller at f1c13000 using PIO, IRQ 70
[    0.502806] sw_hcd_host0 sw_hcd_host0: sw_hcd host driver
[    0.509507] sw_hcd_host0 sw_hcd_host0: new USB bus registered, assigned bus number 1
[    0.512957] hub 1-0:1.0: USB hub found
[    0.515851] hub 1-0:1.0: 1 port detected
[    0.519703] wrn: hcd is not enable, need not start hcd
[    0.521105] [sw_hcd0]: sw_usb_host0_disable start
[    0.527118] -------sw_hcd0_soft_disconnect---------
[    0.530101] is_on = 0, hcd0_set_vbus_cnt = 0
[    0.533152] [sw_hcd_host0]: Set USB Power Off
[    0.536898] wrn: hcd is not enable, need not stop hcd
[    0.537966] [sw_hcd0]: close_usb_clock
[    0.540430] [sw_hcd0]: sw_usb_host0_disable end
[    0.543614] [sw_udc]: udc_init: version 20080411
[    0.550038] NET: Registered protocol family 2
[    0.566600] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.573528] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.581024] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[    0.587788] TCP: Hash tables configured (established 131072 bind 65536)
[    0.589989] TCP: reno registered
[    0.594868] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.600205] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.603816] NET: Registered protocol family 1
[    0.609042] RPC: Registered named UNIX socket transport module.
[    0.612789] RPC: Registered udp transport module.
[    0.616448] RPC: Registered tcp transport module.
[    0.621914] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.626491] Trying to unpack rootfs image as initramfs...
[    0.877489] Freeing initrd memory: 3580K
[    0.883200] audit: initializing netlink socket (disabled)
[    0.886913] type=2000 audit(0.870:1): initialized
[    0.891431] highmem bounce pool size: 64 pages
[    0.903398] VFS: Disk quotas dquot_6.5.2
[    0.908873] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.916199] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.921820] NFS: Registering the id_resolver key type
[    0.926356] NTFS driver 2.1.30 [Flags: R/W].
[    0.929684] fuse init (API version 7.18)
[    0.934321] JFS: nTxBlock = 8192, nTxLock = 65536
[    0.953836] SGI XFS with ACLs, security attributes, large block/inode numbers, no debug enabled
[    0.958266] Btrfs loaded
[    0.961087] msgmni has been set to 1421
[    0.968624] alg: No test for stdrng (krng)
[    0.975376] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    0.978266] io scheduler noop registered
[    0.981533] io scheduler deadline registered
[    0.985222] io scheduler cfq registered (default)
[    0.990098] sunxi disp driver loaded (/dev/disp api 1.0)
[    0.995683] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    1.000441] [uart]: used uart info.: 0x05
[    1.005135] [uart]: serial probe 0 irq 33 mapbase 0x01c28000
[    1.031408] sunxi-uart.0: ttyS0 at MMIO 0x1c28000 (irq = 33) is a U6_16550A
[    1.036315] [uart]: serial probe 2 irq 35 mapbase 0x01c28800
[    1.062540] sunxi-uart.2: ttyS1 at MMIO 0x1c28800 (irq = 35) is a U6_16550A
[    1.065139] G2D: drv_g2d_init
[    1.068481] G2D: Module initialized.major:250
[    1.077731] brd: module loaded
[    1.083716] loop: module loaded
[    1.087070] [NAND] nand driver version: 0x2 0x9
[    1.151392] Dev Sunxi softw311 nand magic does not match for MBR 1: softw411
[    1.157464] Dev Sunxi softw311 nand magic does not match for MBR 2:
[    1.163483] Dev Sunxi softw311 nand magic does not match for MBR 3:
[    1.169484] Dev Sunxi softw311 nand magic does not match for MBR 4:
[    1.177230] Dev Sunxi softw311 nand header bad for all MBR copies, MBR corrupted or not present.
[    1.184474] Dev Sunxi softw411 nand mbr number does not match for MBR 2: 0
[    1.189482] Dev Sunxi softw411 nand header: CRC bad for MBR 2
[    1.196393] Dev Sunxi softw411 nand mbr number does not match for MBR 3: 0
[    1.201431] Dev Sunxi softw411 nand header: CRC bad for MBR 3
[    1.208243] Dev Sunxi softw411 nand mbr number does not match for MBR 4: 0
[    1.213287] Dev Sunxi softw411 nand header: CRC bad for MBR 4
[    1.218688] Dev Sunxi softw411 nand: part 1, start 32768, size 131072
[    1.224287] Dev Sunxi softw411 nand: part 2, start 163840, size 4194304
[    1.230029] Dev Sunxi softw411 nand: part 3, start 4358144, size 10682368
[    1.232576]  nand: nand1 nand2 nand3
[    1.235766] [NAND]nand driver, ok.
[    1.241972] pwm-sunxi: pwm0 configured - period: 20, duty_percent: 50, duty: 10
[    1.248363] sw_ahci sw_ahci.0: controller can't do PMP, turning off CAP_PMP
[    1.252871] ahci: SSS flag set, parallel bus scan disabled
[    1.260282] sw_ahci sw_ahci.0: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[    1.267179] sw_ahci sw_ahci.0: flags: ncq sntf stag pm led clo only pio slum part ccc
[    1.270666] scsi0 : sw_ahci_platform
[    1.277897] ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 88
[    1.281900] [spi-err] Get spi devices number failed
[    1.286602] [spi-err] register spi devices board info failed
[    1.296097] spi: cannot find any using configuration for                     all 4 spi controllers, return directly!
[    1.302187] bonding: Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
[    1.307011] Fixed MDIO Bus: probed
[    1.311599] emac_init fetch emac using configuration failed
[    1.314045] emac driver is disabled
[    1.317558] gmac: use mac address from chipid
[    1.321685] gmac: device MAC address 02:04:07:40:c1:5c
[    1.327308] [gmac]: sun6i_gmac platform driver registration completed
[    1.330615] PPP generic driver version 2.4.2
[    1.334556] PPP BSD Compression module registered
[    1.338563] PPP Deflate Compression module registered
[    1.345833] PPP MPPE Compression module registered
[    1.349244] NET: Registered protocol family 24
[    1.355480] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.360687] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.363174] [sw-ehci1]: open clock
[    1.385859] [sw-ehci1]: Set USB Power ON
[    1.392298] sw-ehci sw-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.398577] sw-ehci sw-ehci.1: new USB bus registered, assigned bus number 2
[    1.403015] sw-ehci sw-ehci.1: irq 71, io mem 0x01c14000
[    1.420598] sw-ehci sw-ehci.1: USB 2.0 started, EHCI 1.00
[    1.423223] ehci_irq: port change detect
[    1.426465] hub 2-0:1.0: USB hub found
[    1.429401] hub 2-0:1.0: 1 port detected
[    1.432021] [sw-ohci1]: open clock
[    1.458173] sw-ohci sw-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.464467] sw-ohci sw-ohci.1: new USB bus registered, assigned bus number 3
[    1.468771] sw-ohci sw-ohci.1: irq 96, io mem 0x01c14400
[    1.533609] hub 3-0:1.0: USB hub found
[    1.536493] hub 3-0:1.0: 1 port detected
[    1.539170] [sw-ehci2]: open clock
[    1.561857] [sw-ehci2]: Set USB Power ON
[    1.568292] sw-ehci sw-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.574527] sw-ehci sw-ehci.2: new USB bus registered, assigned bus number 4
[    1.578915] sw-ehci sw-ehci.2: irq 72, io mem 0x01c1c000
[    1.600589] sw-ehci sw-ehci.2: USB 2.0 started, EHCI 1.00
[    1.603938] hub 4-0:1.0: USB hub found
[    1.606830] hub 4-0:1.0: 1 port detected
[    1.609526] [sw-ohci2]: open clock
[    1.631497] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    1.637584] sw-ohci sw-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.643852] sw-ohci sw-ohci.2: new USB bus registered, assigned bus number 5
[    1.648466] ata1.00: ATA-7: ST9160821AS, 3.ALB, max UDMA/133
[    1.654145] ata1.00: 312581808 sectors, multi 0: LBA48 NCQ (depth 31/32)
[    1.658411] sw-ohci sw-ohci.2: irq 97, io mem 0x01c1c400
[    1.662763] ata1.00: configured for UDMA/133
[    1.670350] scsi 0:0:0:0: Direct-Access     ATA      ST9160821AS      3.AL PQ: 0 ANSI: 5
[    1.677563] sd 0:0:0:0: [sda] 312581808 512-byte logical blocks: (160 GB/149 GiB)
[    1.681629] sd 0:0:0:0: [sda] Write Protect is off
[    1.685641] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.693732] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.696373] ehci_irq: port change detect
[    1.699021] ehci_irq: port change detect
[    1.723700] hub 5-0:1.0: USB hub found
[    1.726597] hub 5-0:1.0: 1 port detected
[    1.729214]  sda: sda1 sda2 sda3 sda4
[    1.733537] Initializing USB Mass Storage driver...
[    1.737124] sd 0:0:0:0: [sda] Attached SCSI disk
[    1.742342] usbcore: registered new interface driver usb-storage
[    1.745916] USB Mass Storage support registered.
[    1.750839] usbcore: registered new interface driver ums-alauda
[    1.755895] usbcore: registered new interface driver ums-cypress
[    1.758513] The port change to OHCI now!
[    1.763541] usbcore: registered new interface driver ums-datafab
[    1.768716] usbcore: registered new interface driver ums_eneub6250
[    1.773738] usbcore: registered new interface driver ums-freecom
[    1.778652] usbcore: registered new interface driver ums-isd200
[    1.783766] usbcore: registered new interface driver ums-jumpshot
[    1.788590] usbcore: registered new interface driver ums-karma
[    1.793691] usbcore: registered new interface driver ums-onetouch
[    1.798716] usbcore: registered new interface driver ums-realtek
[    1.803649] usbcore: registered new interface driver ums-sddr09
[    1.808569] usbcore: registered new interface driver ums-sddr55
[    1.813414] usbcore: registered new interface driver ums-usbat
[    1.818176] mousedev: PS/2 mouse device common for all mice
[    1.823843] ===========================hv_keypad_init=====================
[    1.827243] ========HV Inital ===================
[    1.831228] tkey_fetch_sysconfig_para: tkey_unused.
[    1.838442] hv_keypad_init: after fetch_sysconfig_para:  normal_i2c: 0x0. normal_i2c[1]: 0x0
[    1.844219] sunxi-rtc sunxi-rtc: rtc core: registered rtc as rtc0
[    1.846723] i2c /dev entries driver
[    1.850354] config i2c gpio with gpio_config api
[    1.855996] axp_mfd 0-0034: AXP (CHIP ID: 0x41) detected
[    1.861816] axp_mfd 0-0034: AXP internal temperature monitoring enabled
[    1.866541] i2c i2c-0: Invalid probe address 0x00
[    1.869643] I2C: i2c-0: AW16XX I2C adapter
[    1.873689] [cedar dev]: not installed! ve_mem_reserve=0
[    1.877087] [tt]----- avs_dev driver load... ----
[    1.880693] [tt]-----      register iomem      ----
[    1.883489] Cannot reserve region for ccmu
[    1.887199] [tt]--- avs_dev driver load ok!! -----
[    1.888979] [ace_drv] start!!!
[    1.891392] [ace_drv] init end!!!
[    1.893059] [pa_drv] start!!!
[    1.895310] [pa_drv] init end!!!
[    1.897695] axp20_ldo1: 1300 mV
[    1.902951] axp20_ldo2: 1800 <--> 3300 mV at 3000 mV
[    1.908237] axp20_ldo3: 700 <--> 3500 mV at 2800 mV
[    1.913660] axp20_ldo4: 1250 <--> 3300 mV at 2800 mV
[    1.919017] axp20_buck2: 700 <--> 2275 mV at 1450 mV
[    1.925591] somebody is trying to set dcdc3 range to (1300000, 1300000) uV
[    1.930618] but we keep dcdc3 = 1250000 uV from the bootloader
[    1.934913] axp20_buck3: 700 <--> 3500 mV at 1250 mV
[    1.939797] axp20_ldoio0: 1800 <--> 3300 mV at 2800 mV
[    1.949407] input: axp20-supplyer as /devices/platform/sunxi-i2c.0/i2c-0/0-0034/axp20-supplyer.28/input/input0
[    1.967776] axp20_ldo2: Failed to create debugfs directory
[    1.970945] incomplete xfer (0x20)
[    1.973204] incomplete xfer (0x20)
[    1.975457] incomplete xfer (0x20)
[    1.977708] incomplete xfer (0x20)
[    1.979975] incomplete xfer (0x20)
[    1.982225] incomplete xfer (0x20)
[    1.984474] incomplete xfer (0x20)
[    1.986723] incomplete xfer (0x20)
[    1.988987] incomplete xfer (0x20)
[    1.992982] device-mapper: uevent: version 1.0.3
[    2.000764] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[    2.005723] device-mapper: multipath: version 1.3.2 loaded
[    2.011206] device-mapper: multipath round-robin: version 1.0.0 loaded
[    2.016810] device-mapper: multipath queue-length: version 0.1.0 loaded
[    2.022435] device-mapper: multipath service-time: version 0.2.0 loaded
[    2.025903] cpuidle: using governor ladder
[    2.028784] cpuidle: using governor menu
[    2.031138] [mmc-msg] sw_mci_init
[    2.036910] [mmc-msg] MMC host used card: 0x9, boot card: 0x0, io_card 8
[    2.042267] [mmc-msg] sdc0 set round clock 400000, src 24000000
[    2.050535] [mmc-msg] sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.058800] [mmc-msg] sdc0 Probe: base:0xf0618000 irq:64 sg_cpu:f061a000(4fc00000) ret 0.
[    2.063811] [mmc-msg] sdc3 set round clock 400000, src 24000000
[    2.072011] [mmc-msg] sdc3 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.080199] [mmc-msg] sdc3 Probe: base:0xf061c000 irq:67 sg_cpu:f061e000(4fc01000) ret 0.
[    2.084785] [mmc_pm]: failed to fetch sdio card configuration!
[    2.087217] sunxi_leds driver init
[    2.091276] Registered led device: blue:ph21:led1
[    2.095198] Registered led device: orange:ph20:led2
[    2.099042] Registered led device: white:ph11:led3
[    2.104439] usb 3-1: new full-speed USB device number 2 using sw-ohci
[    2.108332] Registered led device: green:ph07:led4
[    2.113439] ledtrig-cpu: registered to indicate activity on CPUs
[    2.118671] usbcore: registered new interface driver usbhid
[    2.121496] usbhid: USB HID core driver
[    2.124244] ashmem: initialized
[    2.127892] logger: created 256K log 'log_main'
[    2.131776] logger: created 256K log 'log_events'
[    2.135493] logger: created 256K log 'log_radio'
[    2.139291] logger: created 256K log 'log_system'
[    2.147119] asoc: sndspdif <-> sunxi-spdif.0 mapping ok
[    2.150942] [I2S-0] Entered sunxi_i2s_init
[    2.155133] [I2S-0] sunxi_i2s_init I2S used in master mode
[    2.158569] [I2S-0] Entered sunxi_i2s_dev_probe
[    2.163375] [I2S-0] sndi2s_codec_init I2S used in master mode
[    2.168046] [I2S-0] sndi2s_codec_probe I2S used in master mode
[    2.171161] [I2S-0] Entered sunxi_sndi2s_init
[    2.175605] [I2S-0] sunxi_sndi2s_init I2S used in master mode
[    2.180365] asoc: sndi2s <-> sunxi-i2s.0 mapping ok
[    2.184711] IPv4 over IPv4 tunneling driver
[    2.187501] TCP: bic registered
[    2.189836] TCP: cubic registered
[    2.192366] TCP: westwood registered
[    2.194983] TCP: highspeed registered
[    2.197252] TCP: hybla registered
[    2.199449] TCP: htcp registered
[    2.201719] TCP: vegas registered
[    2.203902] TCP: veno registered
[    2.206431] TCP: scalable registered
[    2.208453] TCP: lp registered
[    2.210637] TCP: yeah registered
[    2.213166] TCP: illinois registered
[    2.216389] Initializing XFRM netlink socket
[    2.220474] NET: Registered protocol family 10
[    2.225086] NET: Registered protocol family 17
[    2.228522] NET: Registered protocol family 15
[    2.233213] [mmc_pm]: No sdio card, please check your config !!
[    2.236884] Registering the dns_resolver key type
[    2.239160] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4
[    2.247715] Registering SWP/SWPB emulation handler
[    2.252357] axp20_buck2: Failed to create debugfs directory
[    2.258519] [cpu_freq] INF:-------------------V-F Table-------------------
[    2.263590] [cpu_freq] INF: voltage = 1450mv frequency = 1008MHz
[    2.268636] [cpu_freq] INF: voltage = 1425mv frequency =  912MHz
[    2.273693] [cpu_freq] INF: voltage = 1350mv frequency =  864MHz
[    2.278739] [cpu_freq] INF: voltage = 1250mv frequency =  720MHz
[    2.283795] [cpu_freq] INF: voltage = 1150mv frequency =  528MHz
[    2.288840] [cpu_freq] INF: voltage = 1100mv frequency =  312MHz
[    2.293945] [cpu_freq] INF: voltage = 1050mv frequency =  144MHz
[    2.298998] [cpu_freq] INF: voltage = 1000mv frequency =    0MHz
[    2.304841] [cpu_freq] INF:-----------------------------------------------
[    2.314578] [cpu_freq] INF:sunxi_cpufreq_initcall, get cpu frequency from sysconfig, max freq: 912MHz, min freq: 720MHz
[    2.318552] registered taskstats version 1
[    2.323474] I2C: i2c-1: HDMI I2C adapter
[    2.341179] hub 3-1:1.0: USB hub found
[    2.345274] hub 3-1:1.0: 4 ports detected
[    2.352938] disp clks: lcd 148500000 pre_scale 1 hdmi 148500000 pll 297000000 2x 0
[    2.418868] ehci_irq: port change detect
[    2.478896] The port change to OHCI now!
[    2.821644] usb 5-1: new full-speed USB device number 2 using sw-ohci
[    3.045200] [mmc-msg] mmc 0 detect change, present 1
[    3.141841] usb 3-1.1: new full-speed USB device number 3 using sw-ohci
[    3.361819] usb 3-1.2: new full-speed USB device number 4 using sw-ohci
[    3.544185] [mmc-msg] sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.546676] [mmc-msg] sdc0 power on
[    3.574611] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.579581] [mmc-msg] sdc0 set round clock 400000, src 24000000
[    3.585206] usb 3-1.3: new full-speed USB device number 5 using sw-ohci
[    3.616070] Console: switching to colour frame buffer device 240x67
[    3.661935] [mmc-err] smc 0 err, cmd 52,  RTO
[    3.666085] [mmc-err] smc 0 err, cmd 52,  RTO
[    3.674479] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.679010] axp20_buck3: incomplete constraints, leaving on
[    3.683882] axp20_buck2: incomplete constraints, leaving on
[    3.688589] axp20_ldo4: incomplete constraints, leaving on
[    3.696934] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.701677] axp20_ldo3: incomplete constraints, leaving on
[    3.706382] axp20_ldo2: incomplete constraints, leaving on
[    3.709670] [mmc-err] smc 0 err, cmd 5,  RTO
[    3.714363] axp20_ldo1: incomplete constraints, leaving on
[    3.717600] [mmc-err] smc 0 err, cmd 5,  RTO
[    3.720681] console [netcon0] enabled
[    3.723913] [mmc-err] smc 0 err, cmd 5,  RTO
[    3.727401] netconsole: network logging started
[    3.730629] [mmc-err] smc 0 err, cmd 5,  RTO
[    3.734858] otg_wakelock_init: No USB transceiver found
[    3.743204] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.751608] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.753535] ALSA device list:
[    3.756611]   #0: sunxi-CODEC  Audio Codec
[    3.764956] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.767162]   #1: sunxi-sndspdif
[    3.769245]   #2: sunxi-sndi2s
[    3.772412] Freeing init memory: 224K
[    3.841799] systemd-udevd[90]: starting version 215
[    3.850068] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    3.858643] [mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    3.871485] [mmc-msg] sdc0 set round clock 42857143, src 600000000
[    3.934897] [mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
[    3.939377] mmc0: new high speed SDHC card at address aaaa
[    3.979925] mmcblk0: mmc0:aaaa SU32G 29.7 GiB
[    3.983300]  mmcblk0: p1
[    4.031893] usb 3-1.4: new full-speed USB device number 6 using sw-ohci
[    4.079239] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    4.173946] generic-usb 0003:1B1F:C00F.0001: hiddev0,hidraw0: USB HID v1.10 Device [eQ-3 HM-CFG-USB] on usb-sw-ohci-1.4/input0
[    5.370725] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[    5.871677] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    5.876271] systemd[1]: Detected architecture 'arm'.
[    5.904079] systemd[1]: Set hostname to <cubietruck>.
[    6.421988] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[    6.433077] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    6.440318] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    6.445191] systemd[1]: Expecting device dev-ttyS0.device...
[    6.450625] systemd[1]: Starting Remote File Systems (Pre).
[    6.456443] systemd[1]: Reached target Remote File Systems (Pre).
[    6.464479] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[    6.474263] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    6.478372] systemd[1]: Starting Encrypted Volumes.
[    6.483434] systemd[1]: Reached target Encrypted Volumes.
[    6.490607] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[    6.497959] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    6.501430] systemd[1]: Starting Root Slice.
[    6.505887] systemd[1]: Created slice Root Slice.
[    6.510336] systemd[1]: Starting User and Session Slice.
[    6.515965] systemd[1]: Created slice User and Session Slice.
[    6.521713] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[    6.528616] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    6.533211] systemd[1]: Starting Delayed Shutdown Socket.
[    6.538721] systemd[1]: Listening on Delayed Shutdown Socket.
[    6.543469] systemd[1]: Starting Journal Socket (/dev/log).
[    6.549182] systemd[1]: Listening on Journal Socket (/dev/log).
[    6.553452] systemd[1]: Starting udev Control Socket.
[    6.558577] systemd[1]: Listening on udev Control Socket.
[    6.562770] systemd[1]: Starting udev Kernel Socket.
[    6.567767] systemd[1]: Listening on udev Kernel Socket.
[    6.571648] systemd[1]: Starting Journal Socket.
[    6.576432] systemd[1]: Listening on Journal Socket.
[    6.580226] systemd[1]: Starting System Slice.
[    6.584978] systemd[1]: Created slice System Slice.
[    6.590306] systemd[1]: Started File System Check on Root Device.
[    6.594446] systemd[1]: Starting system-getty.slice.
[    6.599865] systemd[1]: Created slice system-getty.slice.
[    6.604889] systemd[1]: Starting system-serial\x2dgetty.slice.
[    6.611108] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    6.616606] systemd[1]: Starting Increase datagram queue length...
[    6.772814] systemd[1]: Starting Restore / save the current clock...
[    6.792246] systemd[1]: Mounting Debug File System...
[    6.827363] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    6.852091] systemd[1]: Mounted Huge Pages File System.
[    6.868490] systemd[1]: Started Set Up Additional Binary Formats.
[    6.873570] systemd[1]: Starting udev Coldplug all Devices...
[    6.897667] systemd[1]: Starting Load Kernel Modules...
[    6.911114] systemd[1]: Mounting POSIX Message Queue File System...
[    6.950837] systemd[1]: Starting LSB: Set keymap...
[    6.971428] lp: driver loaded but no devices found
[    6.976689] systemd[1]: Starting Slices.
[    6.980927] systemd[1]: Reached target Slices.
[    6.990105] systemd[1]: Mounted POSIX Message Queue File System.
[    6.995745] ppdev: user-space parallel port driver
[    7.002696] systemd[1]: Mounted Debug File System.
[    7.017721] systemd[1]: Started Increase datagram queue length.
[    7.027186] systemd[1]: Started Restore / save the current clock.
[    7.033495] Bluetooth: Core ver 2.16
[    7.036983] NET: Registered protocol family 31
[    7.042389] Bluetooth: HCI device and connection manager initialized
[    7.046230] Bluetooth: HCI socket layer initialized
[    7.050373] Bluetooth: L2CAP socket layer initialized
[    7.054236] Bluetooth: SCO socket layer initialized
[    7.064099] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    7.079283] Bluetooth: HCI UART driver ver 2.2
[    7.083147] Bluetooth: HCI H4 protocol initialized
[    7.087089] Bluetooth: HCI BCSP protocol initialized
[    7.090840] Bluetooth: HCILL protocol initialized
[    7.094787] Bluetooth: HCIATH3K protocol initialized
[    7.109708] Bluetooth: RFCOMM TTY layer initialized
[    7.113944] Bluetooth: RFCOMM socket layer initialized
[    7.116679] Bluetooth: RFCOMM ver 1.11
[    7.127861] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    7.132180] systemd[1]: Started LSB: Set keymap.
[    7.141243] input: sunxi-ir as /devices/virtual/input/input1
[    7.144654] systemd[1]: Time has been changed
[    7.151315] systemd[1]: Starting Create Static Device Nodes in /dev...
[    7.157785] IR Initial OK
[    7.171459] systemd[1]: Starting Syslog Socket.
[    7.176933] systemd[1]: Listening on Syslog Socket.
[    7.181310] systemd[1]: Starting Journal Service...
[    7.192059] systemd[1]: Started Journal Service.
[    7.240518] [ap6210] select wifi ap6210
[    7.243829] [ap6210] Initializing ap6210.
[    7.250158] [ap6210] platform device registered successfully.
[    7.254289] [ap6210] Using ap6210 configuration.
[    7.366025] [mmc-msg] sdc3 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    7.368482] [mmc-msg] sdc3 power on
[    7.404654] [mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    7.409590] [mmc-msg] sdc3 set round clock 400000, src 24000000
[    7.479130] [ap6210] WLAN placed in POWER ON
[    7.485208] systemd-udevd[174]: starting version 215
[    7.496141] [mmc-err] smc 3 err, cmd 52,  RTO
[    7.500325] [mmc-err] smc 3 err, cmd 52,  RTO
[    7.508766] [mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    7.519941] [mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    7.525834] [mmc-err] smc 3 err, cmd 8,  RTO
[    7.534667] [mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    7.558695] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    7.564891] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    7.578338] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    7.590449] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    7.626035] [mmc-msg] sdc3 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    7.634554] [mmc-msg] sdc3 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    7.639866] [mmc-msg] sdc3 set round clock 42857143, src 600000000
[    7.703576] [mmc-msg] sdc3 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
[    7.723318] mmc1: new high speed SDIO card at address 0001
[    7.729420] [ap6210] Linux Kernel SDIO/MMC Driver
[    7.754610] [ap6210] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33
[    8.121214] [ap6210] WLAN placed in RESET
[    8.162323] [ap6210] wl_event_handler was terminated
[    8.502700] usbcore: registered new interface driver btusb
[    8.596402] usbcore: registered new interface driver usbserial
[    8.646906] usbcore: registered new interface driver usbserial_generic
[    8.651059] USB Serial support registered for generic
[    8.654533] usbserial: USB Serial Driver core
[    8.660399] usbcore: registered new interface driver ftdi_sio
[    8.679536] USB Serial support registered for FTDI USB Serial Device
[    8.686524] ftdi_sio 3-1.1:1.0: FTDI USB Serial Device converter detected
[    8.690687] usb 3-1.1: Detected FT232RL
[    8.700569] usb 3-1.1: Number of endpoints 2
[    8.712550] usb 3-1.1: Endpoint 1 MaxPacketSize 64
[    8.716331] usb 3-1.1: Endpoint 2 MaxPacketSize 64
[    8.720090] usb 3-1.1: Setting MaxPacketSize 64
[    8.740565] usb 3-1.1: FTDI USB Serial Device converter now attached to ttyUSB0
[    8.758593] ftdi_sio 3-1.2:1.0: FTDI USB Serial Device converter detected
[    8.792214] usb 3-1.2: Detected FT232RL
[    8.795474] usb 3-1.2: Number of endpoints 2
[    8.799257] usb 3-1.2: Endpoint 1 MaxPacketSize 64
[    8.884234] usb 3-1.2: Endpoint 2 MaxPacketSize 64
[    8.887749] usb 3-1.2: Setting MaxPacketSize 64
[    8.933089] usb 3-1.2: FTDI USB Serial Device converter now attached to ttyUSB1
[    8.972124] ftdi_sio 3-1.3:1.0: FTDI USB Serial Device converter detected
[    8.975236] usb 3-1.3: Detected FT232RL
[    8.978500] usb 3-1.3: Number of endpoints 2
[    9.049253] usb 3-1.3: Endpoint 1 MaxPacketSize 64
[    9.071200] usb 3-1.3: Endpoint 2 MaxPacketSize 64
[    9.074715] usb 3-1.3: Setting MaxPacketSize 64
[    9.109534] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
[    9.125136] usb 3-1.3: FTDI USB Serial Device converter now attached to ttyUSB2
[    9.142744] ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
[    9.510918] ap6211: exports duplicate symbol bcmsdh_probe (owned by ap6210)
[    9.527192] ap6211: exports duplicate symbol bcmsdh_probe (owned by ap6210)
[    9.771068] [ap6210] Using ap6210 configuration.
[    9.894243] Adding 131068k swap on /var/swap.  Priority:-1 extents:2 across:139260k SS
[   10.687277] systemd-journald[173]: Received request to flush runtime journal from PID 1
[   11.316065] sunxi_gmac: probed
[   11.321475] eth0: PHY ID 001cc915 at 0 IRQ 0 (sunxi_gmac-0:00) active
[   11.327583] eth0: PHY ID 001cc915 at 1 IRQ 0 (sunxi_gmac-0:01)
[   13.329448] PHY: sunxi_gmac-0:00 - Link is Up - 1000/Full
[   20.349317] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   20.354760] Bluetooth: BNEP filters: protocol multicast
[   21.769245] eth0: no IPv6 routers present
Vielen Dank!  :)
Sind die anderen Fehler zu vernachlässigen?
FHEM - Debmatic - Zigbee2MQTT - Homekit
papa
Perfekt ... Keine Ahnung. Wenn irgendwas mal wieder nicht so wie erwartet funktioniert, kann man ja nochmal nach den Fehlern sehen.
