Sonos steuern
Begonnen von Will, 05 Januar 2013, 15:51:12
Cybers
#2805
ich habe in meinem Log alle 3-5 Minuten diese Einträge:
Can't call method "kill" on an undefined value at ./FHEM/00_SONOS.pm line 8799.
2017.04.04 04:50:17 2: SONOS7: Error during UPnP-Handling:
2017.04.04 04:50:17 1: SONOS9: Restore-Thread wurde beendet.
2017.04.04 04:50:17 1: SONOS8: IsAlive-Thread wurde beendet.
2017.04.04 04:50:17 0: SONOS0: No Answer from Subprocess. Restart Sonos-Subprocess...
2017.04.04 04:50:17 2: SONOS7: DeviceProperties-Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000021337
2017.04.04 04:50:17 2: SONOS7: ZoneGroupTopology-Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000021336
2017.04.04 04:50:17 2: SONOS7: Alarm-Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000021335
2017.04.04 04:50:17 2: SONOS7: ContentDirectory-Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000021334
2017.04.04 04:50:17 2: SONOS7: GroupRendering-Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000021333
2017.04.04 04:50:17 2: SONOS7: Rendering-Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000021332
2017.04.04 04:50:17 2: SONOS7: Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000021331
2017.04.04 04:50:17 2: SONOS7: SonosPlayer 'Schlafzimmer' is now updated
2017.04.04 04:50:16 2: SONOS7: SonosPlayer 'Schlafzimmer' (S12) with ID 'RINCON_949F3E07EBC801400_MR' is already defined (as 'Sonos_Schlafzimmer') and will only be updated
2017.04.04 04:50:14 2: SONOS7: Discover Sonosplayer 'Schlafzimmer' (S12) Software Revision 7.1 with ID 'RINCON_949F3E07EBC801400_MR'
und so ist das Sonos bei mir angelegt:
define Sonos SONOS localhost:4711 10 4 5
attr Sonos pingType syn
attr Sonos room Sonos
attr Sonos verbose 2
und so der einzelne Speaker:
define Sonos_Schlafzimmer SONOSPLAYER RINCON_949F3E07EBC801400_MR
attr Sonos_Schlafzimmer alias Schlafzimmer
attr Sonos_Schlafzimmer generateInfoSummarize1 <NormalAudio><Artist prefix="(" suffix=")"/><Title prefix=" '" suffix="'" ifempty="[Keine Musikdatei]"/><Album prefix=" vom Album '" suffix="'"/></NormalAudio> <StreamAudio><Sender suffix=":"/><SenderCurrent prefix=" '" suffix="' -"/><SenderInfo prefix=" "/></StreamAudio>
attr Sonos_Schlafzimmer generateInfoSummarize2 <TransportState/><InfoSummarize1 prefix=" => "/>
attr Sonos_Schlafzimmer generateInfoSummarize3 <Volume prefix="Lautstärke: "/><Mute instead=" ~ Kein Ton" ifempty=" ~ Ton An" emptyval="0"/> ~ Balance: <Balance ifempty="Mitte" emptyval="0"/><HeadphoneConnected instead=" ~ Kopfhörer aktiv" ifempty=" ~ Kein Kopfhörer" emptyval="0"/>
attr Sonos_Schlafzimmer generateVolumeSlider 1
attr Sonos_Schlafzimmer getAlarms 1
attr Sonos_Schlafzimmer group Schlafzimmer
attr Sonos_Schlafzimmer minVolume 0
attr Sonos_Schlafzimmer model Sonos_S12
attr Sonos_Schlafzimmer room Sonos
attr Sonos_Schlafzimmer sortby 1
attr Sonos_Schlafzimmer stateVariable Presence
attr Sonos_Schlafzimmer userReadings Favourites:LastActionResult.*?GetFavouritesWithCovers.* { if (ReadingsVal("Sonos_Schlafzimmer", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }, Radios:LastActionResult.*?GetRadiosWithCovers.* { if (ReadingsVal("Sonos_Schlafzimmer", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }, Playlists:LastActionResult.*?GetPlaylistsWithCovers.* { if (ReadingsVal("Sonos_Schlafzimmer", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }, currentTrackPosition:LastActionResult.*?GetCurrentTrackPosition.* { if (ReadingsVal("Sonos_Schlafzimmer", "LastActionResult", "") =~ m/.*?: (.*)/) { return $1;; } }
Kann mir einer erklären wo diese Logeinträge alle paar Minuten herkommen?
Gruß, Sascha
FHEM 6.3 auf Raspberry PI 4 / Smartvisu
Eltako Serie 14: FAM14, FGW14-USB, FSB14, FSR14-4x, FSR14-2x, FDG14, FTS14-EM in Kombination mit Jung F50 24V Tastern
1-Wire Temperatursensoren
aus alter Zeit:
Gott sei Dank nur noch 3 Homematic Jalousie- & Schaltaktoren! Wer sich mit Funk auskennt, legt Kabel
Reinerlein
Hi Sascha,
kannst du mal Verbose auf min. 4 setzen, damit wir sehen können, was die letzte Aktion des SubProzesses war?
Ich habe gerade in meiner Entwicklung auch einen Absturz des SubProzesses beseitigt (und teste das gerade im laufenden Betrieb), vielleicht fällt dein Problem ja mit darunter...
EDIT: Welche Sonos-Player hast du?
Reiner
Cybers
#2807
Hallo Reiner,
ich habe einen Sonos Play:1.
Hier die Log-Einträge mit Verbose 4:
2017.04.04 21:50:23 4: SONOS20: 192.168.1.243 is alive
2017.04.04 21:50:23 4: SONOS20: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, location, ) -> http://192.168.1.243:1400/xml/device_description.xml
2017.04.04 21:50:23 4: SONOS20: IsAlive-Event UDN=RINCON_949F3E07EBC801400_MR
2017.04.04 21:50:21 4: SONOS0: Got correct Answer from Subprocess...
2017.04.04 21:50:21 3: SONOS0: Connection accepted from localhost:48840
2017.04.04 21:50:21 4: SONOS0: Transport-Event: CoverArt konnte nicht gefunden werden. Verwende FHEM-Logo. Bilder-Download: SONOS_DownloadReplaceIfChanged('./FHEM/lib/UPnP/sonos_empty.jpg', './www/images/default/SONOSPLAYER/Sonos_Schlafzimmer_NextAlbumArt.png');
2017.04.04 21:50:21 4: SONOS0: Identical filecontent for './www/images/default/SONOSPLAYER/Sonos_Schlafzimmer_AlbumArt.gif'!
2017.04.04 21:50:20 4: SONOS0: Transport-Event: Bilder-Download: SONOS_DownloadReplaceIfChanged('http://192.168.1.243:1400/getaa?s=1&u=x-sonosapi-stream%3as42824%3fsid%3d254%26flags%3d8224%26sn%3d0', './www/images/default/SONOSPLAYER/Sonos_Schlafzimmer_AlbumArt.gif');
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, presence, disappeared) -> appeared
2017.04.04 21:50:20 3: SONOS19: Event: End of GroupRendering-Event for Zone "Sonos_Schlafzimmer".
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, GroupMute, ~~) -> 0
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, GroupVolume, ~~) -> 33
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, attr, generateVolumeEvent, 0) -> DEFAULT
2017.04.04 21:50:20 4: SONOS19: GroupRendering-Event: All correct with this service-call till now. UDN='uuid:RINCON_949F3E07EBC801400_MR'
2017.04.04 21:50:20 3: SONOS19: Event: Received GroupRendering-Event for Zone "Sonos_Schlafzimmer".
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, attr, disable, 0) -> DEFAULT
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, def, NAME, RINCON_949F3E07EBC801400_MR) -> Sonos_Schlafzimmer
2017.04.04 21:50:20 3: SONOS19: Event: End of Transport-Event for Zone "Sonos_Schlafzimmer".
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, TransportState, -) -> STOPPED
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(SONOS, reading, ZoneGroupState, ) -> <ZoneGroups><ZoneGroup Coordinator="RINCON_949F3E07EBC801400" ID="RINCON_949F3E07EBC801400:0"><ZoneGroupMember UUID="RINCON_949F3E07EBC801400" Location="http://192.168.1.243:1400/xml/device_description.xml" ZoneName="Schlafzimmer" Icon="x-rincon-roomicon:masterbedroom" Configuration="1" SoftwareVersion="34.16-37101" MinCompatibleVersion="33.0-00000" LegacyCompatibleVersion="25.0-00000" BootSeq="21" WirelessMode="1" WirelessLeafOnly="0" HasConfiguredSSID="1" ChannelFreq="2412" BehindWifiExtender="0" WifiEnabled="1" Orientation="0" RoomCalibrationState="1" SecureRegState="2"/></ZoneGroup></ZoneGroups>
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, QueueHash, ) -> 9a1c7ee2c7ce38d4bbbaf29ab9f2ac1e
2017.04.04 21:50:20 4: SONOS19: Transport-Event: NextTrackMetaData:
2017.04.04 21:50:20 4: SONOS19: Transport-Event: Stream erkannt!
2017.04.04 21:50:20 4: SONOS19: Transport-Event: CurrentTrackMetaData: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"><item id="-1" parentID="-1" restricted="true"><res protocolInfo="sonos.com-http:*:application/octet-stream:*">x-sonosapi-stream:s42824?sid=254&amp;flags=8224&amp;sn=0</res><r:streamContent></r:streamContent><r:radioShowMd></r:radioShowMd><upnp:albumArtURI>/getaa?s=1&amp;u=x-sonosapi-stream%3as42824%3fsid%3d254%26flags%3d8224%26sn%3d0</upnp:albumArtURI><dc:title>x-sonosapi-stream:s42824?sid=254&amp;flags=8224&amp;sn=0</dc:title><upnp:class>object.item</upnp:class></item></DIDL-Lite>
2017.04.04 21:50:20 4: SONOS19: ProxyObject exists: UPnP::ControlPoint::ControlProxy=HASH(0x743d45c8)
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, SleepTimerVersion, ) ->
2017.04.04 21:50:20 4: SONOS19: Transport-Event: LastChange: <Event xmlns="urn:schemas-upnp-org:metadata-1-0/AVT/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/"><InstanceID val="0"><TransportState val="STOPPED"/><CurrentPlayMode val="NORMAL"/><CurrentCrossfadeMode val="0"/><NumberOfTracks val="2"/><CurrentTrack val="1"/><CurrentSection val="0"/><CurrentTrackURI val="aac://mp3channels.webradio.antenne.de/antenne.aac"/><CurrentTrackDuration val="0:00:00"/><CurrentTrackMetaData val="&lt;DIDL-Lite xmlns:dc=&quot;http://purl.org/dc/elements/1.1/&quot; xmlns:upnp=&quot;urn:schemas-upnp-org:metadata-1-0/upnp/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot; xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&quot;&gt;&lt;item id=&quot;-1&quot; parentID=&quot;-1&quot; restricted=&quot;true&quot;&gt;&lt;res protocolInfo=&quot;sonos.com-http:*:application/octet-stream:*&quot;&gt;x-sonosapi-stream:s42824?sid=254&amp;amp;flags=8224&amp;amp;sn=0&lt;/res&gt;&lt;r:streamContent&gt;&lt;/r:streamContent&gt;&lt;r:radioShowMd&gt;&lt;/r:radioShowMd&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonosapi-stream%3as42824%3fsid%3d254%26flags%3d8224%26sn%3d0&lt;/upnp:albumArtURI&gt;&lt;dc:title&gt;x-sonosapi-stream:s42824?sid=254&amp;amp;flags=8224&amp;amp;sn=0&lt;/dc:title&gt;&lt;upnp:class&gt;object.item&lt;/upnp:class&gt;&lt;/item&gt;&lt;/DIDL-Lite&gt;"/><r:NextTrackURI val=""/><r:NextTrackMetaData val=""/><r:EnqueuedTransportURI val="x-sonosapi-stream:s42824?sid=254&amp;flags=8224&amp;sn=0"/><r:EnqueuedTransportURIMetaData val="&lt;DIDL-Lite xmlns:dc=&quot;http://purl.org/dc/elements/1.1/&quot; xmlns:upnp=&quot;urn:schemas-upnp-org:metadata-1-0/upnp/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot; xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&quot;&gt;&lt;item id=&quot;-1&quot; parentID=&quot;-1&quot; restricted=&quot;true&quot;&gt;&lt;dc:title&gt;ANTENNE BAYERN&lt;/dc:title&gt;&lt;upnp:class&gt;object.item.audioItem.audioBroadcast&lt;/upnp:class&gt;&lt;desc id=&quot;cdudn&quot; nameSpace=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot;&gt;SA_RINCON65031_&lt;/desc&gt;&lt;/item&gt;&lt;/DIDL-Lite&gt;"/><PlaybackStorageMedium val="NETWORK"/><AVTransportURI val="x-sonosapi-stream:s42824?sid=254&amp;flags=8224&amp;sn=0"/><AVTransportURIMetaData val="&lt;DIDL-Lite xmlns:dc=&quot;http://purl.org/dc/elements/1.1/&quot; xmlns:upnp=&quot;urn:schemas-upnp-org:metadata-1-0/upnp/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot; xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&quot;&gt;&lt;item id=&quot;-1&quot; parentID=&quot;-1&quot; restricted=&quot;true&quot;&gt;&lt;dc:title&gt;ANTENNE BAYERN&lt;/dc:title&gt;&lt;upnp:class&gt;object.item.audioItem.audioBroadcast&lt;/upnp:class&gt;&lt;desc id=&quot;cdudn&quot; nameSpace=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot;&gt;SA_RINCON65031_&lt;/desc&gt;&lt;/item&gt;&lt;/DIDL-Lite&gt;"/><NextAVTransportURI val=""/><NextAVTransportURIMetaData val=""/><CurrentTransportActions val="Set, Stop, Play"/><r:CurrentValidPlayModes val=""/><r:MuseSessions val=""/><r:DirectControlClientID val=""/><r:DirectControlIsSuspended val="0"/><r:DirectControlAccountID val=""/><TransportStatus val="OK"/><r:SleepTimerGeneration val="0"/><r:AlarmRunning val="0"/><r:SnoozeRunning val="0"/><r:RestartPending val="0"/><TransportPlaySpeed val="NOT_IMPLEMENTED"/><CurrentMediaDuration val="NOT_IMPLEMENTED"/><RecordStorageMedium val="NOT_IMPLEMENTED"/><PossiblePlaybackStorageMedia val="NONE, NETWORK"/><PossibleRecordStorageMedia val="NOT_IMPLEMENTED"/><RecordMediumWriteStatus val="NOT_IMPLEMENTED"/><CurrentRecordQualityMode val="NOT_IMPLEMENTED"/><PossibleRecordQualityModes val="NOT_IMPLEMENTED"/></InstanceID></Event>
2017.04.04 21:50:20 4: SONOS19: Transport-Event: GroundURL: http://192.168.1.243:1400
2017.04.04 21:50:20 4: SONOS19: Transport-Event: All correct with this service-call till now. UDN='uuid:RINCON_949F3E07EBC801400_MR'
2017.04.04 21:50:20 3: SONOS19: Event: Received Transport-Event for Zone "Sonos_Schlafzimmer".
2017.04.04 21:50:20 3: SONOS19: Event: End of Rendering-Event for Zone "Sonos_Schlafzimmer".
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, attr, buttonEvents, ) -> DEFAULT
2017.04.04 21:50:20 4: SONOS19: Rendering-Event: Current Borders for 'Sonos_Schlafzimmer' ~ minVolume: 0, maxVolume: 100
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, attr, maxVolume, 100) -> DEFAULT
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, attr, minVolume, 0) -> 0
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, Mute, 0) -> 0
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, HeadphoneConnected, 0) -> 0
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, Volume, 0) -> 33
2017.04.04 21:50:20 4: SONOS19: Rendering-Event: Current Values for 'Sonos_Schlafzimmer' ~ Volume: 33, HeadphoneConnected: 0, Bass: -2, Treble: 0, Balance: 0, Loudness: 1, Mute: 0
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, OutputFixed, 0) -> 0
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, DialogLevel, 0) -> DEFAULT
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, NightMode, 0) -> DEFAULT
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, AudioDelayRightRear, 0) -> DEFAULT
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, AudioDelayLeftRear, 0) -> DEFAULT
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, AudioDelay, 0) -> DEFAULT
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, SubPolarity, 0) -> 0
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, SubGain, 0) -> 0
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, SubEnable, 0) -> 1
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, SurroundLevel, 0) -> DEFAULT
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, SurroundEnable, 0) -> DEFAULT
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, TruePlay, 0) -> 1
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, Treble, 0) -> 0
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, Bass, 0) -> -2
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, Loudness, 0) -> 1
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, Balance, 0) -> 0
2017.04.04 21:50:20 4: SONOS19: Rendering-Event: LastChange: <Event xmlns="urn:schemas-upnp-org:metadata-1-0/RCS/"><InstanceID val="0"><Volume channel="Master" val="33"/><Volume channel="LF" val="100"/><Volume channel="RF" val="100"/><Mute channel="Master" val="0"/><Mute channel="LF" val="0"/><Mute channel="RF" val="0"/><Bass val="-2"/><Treble val="0"/><Loudness channel="Master" val="1"/><OutputFixed val="0"/><HeadphoneConnected val="0"/><SpeakerSize val="5"/><SubGain val="0"/><SubCrossover val="0"/><SubPolarity val="0"/><SubEnabled val="1"/><SonarEnabled val="1"/><SonarCalibrationAvailable val="1"/><PresetNameList val="FactoryDefaults"/></InstanceID></Event>
2017.04.04 21:50:20 4: SONOS19: Rendering-Event: All correct with this service-call till now. UDN='uuid:RINCON_949F3E07EBC801400_MR'
2017.04.04 21:50:20 3: SONOS19: Event: Received Rendering-Event for Zone "Sonos_Schlafzimmer".
2017.04.04 21:50:20 3: SONOS19: Event: End of ContentDirectory-Event for Zone "Sonos_Schlafzimmer".
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, PlaylistsVersion, ~~) -> RINCON_949F3E07EBC801400,0
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(SONOS, reading, ShareIndexInProgress, ~~) -> 0
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, QueueVersion, ~~) ->
2017.04.04 21:50:20 4: SONOS19: ContentDirectory-Event: All correct with this service-call till now. UDN='uuid:RINCON_949F3E07EBC801400_MR'
2017.04.04 21:50:20 3: SONOS19: Event: Received ContentDirectory-Event for Zone "Sonos_Schlafzimmer".
2017.04.04 21:50:20 3: SONOS19: Event: End of DeviceProperties-Event for Zone "Sonos_Schlafzimmer".
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, roomIcon, ) -> masterbedroom
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, fieldType, ) ->
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, roomName, ) -> Schlafzimmer
2017.04.04 21:50:20 4: SONOS19: DeviceProperties-Event: All correct with this service-call till now. UDN='uuid:RINCON_949F3E07EBC801400_MR'
2017.04.04 21:50:20 3: SONOS19: Event: Received DeviceProperties-Event for Zone "Sonos_Schlafzimmer".
2017.04.04 21:50:20 3: SONOS19: Event: End of ZoneGroupTopology-Event for Zone "Sonos_Schlafzimmer".
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, ZoneGroupName, ) -> Schlafzimmer
2017.04.04 21:50:20 4: SONOS19: Retrieved TopoType:
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, ZoneGroupID, ) -> RINCON_949F3E07EBC801400:__
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, ZonePlayerUUIDsInGroup, ) -> RINCON_949F3E07EBC801400
2017.04.04 21:50:20 4: SONOS19: ZoneGroupTopology-Event: All correct with this service-call till now. UDN='uuid:RINCON_949F3E07EBC801400_MR'
2017.04.04 21:50:20 3: SONOS19: Event: Received ZoneGroupTopology-Event for Zone "Sonos_Schlafzimmer".
2017.04.04 21:50:20 3: SONOS19: Event: End of Alarm-Event for Zone "Sonos_Schlafzimmer".
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, AlarmListVersion, ~~) -> RINCON_949F3E07EBC801400:0
2017.04.04 21:50:20 4: SONOS19: Alarm-Event: All correct with this service-call till now. UDN='uuid:RINCON_949F3E07EBC801400_MR'
2017.04.04 21:50:20 3: SONOS19: Event: Received Alarm-Event for Zone "Sonos_Schlafzimmer".
2017.04.04 21:50:20 3: SONOS19: Discover: End of discover-event for "Schlafzimmer".
2017.04.04 21:50:20 2: SONOS19: DeviceProperties-Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000023800
2017.04.04 21:50:20 2: SONOS19: ZoneGroupTopology-Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000023799
2017.04.04 21:50:20 2: SONOS19: Alarm-Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000023798
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, attr, getAlarms, 0) -> 1
2017.04.04 21:50:20 2: SONOS19: ContentDirectory-Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000023797
2017.04.04 21:50:20 2: SONOS19: GroupRendering-Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000023796
2017.04.04 21:50:20 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, attr, minVolume, -1) -> 0
2017.04.04 21:50:20 2: SONOS19: Rendering-Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000023795
2017.04.04 21:50:20 2: SONOS19: Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000023794
2017.04.04 21:50:19 2: SONOS19: SonosPlayer 'Schlafzimmer' is now updated
2017.04.04 21:50:19 4: SONOS19: ProxyObject exists: UPnP::ControlPoint::ControlProxy=HASH(0x743d45c8)
2017.04.04 21:50:19 2: SONOS19: SonosPlayer 'Schlafzimmer' (S12) with ID 'RINCON_949F3E07EBC801400_MR' is already defined (as 'Sonos_Schlafzimmer') and will only be updated
2017.04.04 21:50:19 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, def, NAME, RINCON_949F3E07EBC801400_MR) -> Sonos_Schlafzimmer
2017.04.04 21:50:19 4: SONOS19: Retrieve Current Volumelevels. Master: "33", Balance: "0"
2017.04.04 21:50:19 4: SONOS19: Retrieved TopoType:
2017.04.04 21:50:19 4: SONOS19: ControlProxies wurden gesichert
2017.04.04 21:50:18 4: SONOS19: SubDevice found: uuid:RINCON_949F3E07EBC801400_MR
2017.04.04 21:50:18 4: SONOS19: SubDevice found: uuid:RINCON_949F3E07EBC801400_MS
2017.04.04 21:50:18 4: SONOS0: Transport-Event: CoverArt konnte nicht gefunden werden. Verwende FHEM-Logo. Bilder-Download: SONOS_DownloadReplaceIfChanged('./FHEM/lib/UPnP/sonos_empty.jpg', './www/images/default/SONOSPLAYER/Sonos_Schlafzimmer_NextAlbumArt.png');
2017.04.04 21:50:18 4: SONOS0: Identical filecontent for './www/images/default/SONOSPLAYER/Sonos_Schlafzimmer_AlbumArt.gif'!
2017.04.04 21:50:17 2: SONOS19: Discover Sonosplayer 'Schlafzimmer' (S12) Software Revision 7.1 with ID 'RINCON_949F3E07EBC801400_MR'
2017.04.04 21:50:17 4: SONOS19: RoomName: 'Schlafzimmer', SaveRoomName: 'Schlafzimmer', ModelNumber: 'S12', DisplayVersion: '7.1', SerialNum: '94-9F-3E-07-EB-C8:B', IconURI: '/img/icon-S12.png', IconOrigPath: 'http://192.168.1.243:1400/img/icon-S12.png', IconPath: 'icoSONOSPLAYER_icon-S12.png'
</root>
  </device>
    </deviceList>
      </device>
        </iconList>
          </icon>
            <url>/img/icon-S12.png</url>
            <depth>24</depth>
            <height>48</height>
            <width>48</width>
            <mimetype>image/png</mimetype>
          <icon>
        <iconList>
        <qq:X_QPlay_SoftwareCapability xmlns:qq="http://www.tencent.com">QPlay:2</qq:X_QPlay_SoftwareCapability>
        </X_Rhapsody-Extension>
            </deviceCapabilities>
              <interactionPattern type="real-rhapsody-upnp-1-0"/>
            <deviceCapabilities>
          <deviceID>urn:rhapsody-real-com:device-id-1-0:sonos_1:RINCON_949F3E07EBC801400</deviceID>
        <X_Rhapsody-Extension xmlns="http://www.real.com/rhapsody/xmlns/upnp-1-0">
</serviceList>
          </service>
            <SCPDURL>/xml/GroupRenderingControl1.xml</SCPDURL>
            <eventSubURL>/MediaRenderer/GroupRenderingControl/Event</eventSubURL>
            <controlURL>/MediaRenderer/GroupRenderingControl/Control</controlURL>
            <serviceId>urn:upnp-org:serviceId:GroupRenderingControl</serviceId>
            <serviceType>urn:schemas-upnp-org:service:GroupRenderingControl:1</serviceType>
          <service>
  </service>
    <SCPDURL>/xml/Queue1.xml</SCPDURL>
    <eventSubURL>/MediaRenderer/Queue/Event</eventSubURL>
    <controlURL>/MediaRenderer/Queue/Control</controlURL>
    <serviceId>urn:sonos-com:serviceId:Queue</serviceId>
    <serviceType>urn:schemas-sonos-com:service:Queue:1</serviceType>
  <service>
  </service>
    <SCPDURL>/xml/AVTransport1.xml</SCPDURL>
    <eventSubURL>/MediaRenderer/AVTransport/Event</eventSubURL>
    <controlURL>/MediaRenderer/AVTransport/Control</controlURL>
    <serviceId>urn:upnp-org:serviceId:AVTransport</serviceId>
    <serviceType>urn:schemas-upnp-org:service:AVTransport:1</serviceType>
  <service>
  </service>
    <SCPDURL>/xml/ConnectionManager1.xml</SCPDURL>
    <eventSubURL>/MediaRenderer/ConnectionManager/Event</eventSubURL>
    <controlURL>/MediaRenderer/ConnectionManager/Control</controlURL>
    <serviceId>urn:upnp-org:serviceId:ConnectionManager</serviceId>
    <serviceType>urn:schemas-upnp-org:service:ConnectionManager:1</serviceType>
  <service>
  </service>
    <SCPDURL>/xml/RenderingControl1.xml</SCPDURL>
    <eventSubURL>/MediaRenderer/RenderingControl/Event</eventSubURL>
    <controlURL>/MediaRenderer/RenderingControl/Control</controlURL>
    <serviceId>urn:upnp-org:serviceId:RenderingControl</serviceId>
    <serviceType>urn:schemas-upnp-org:service:RenderingControl:1</serviceType>
  <service>
<serviceList>
<UDN>uuid:RINCON_949F3E07EBC801400_MR</UDN>
  <modelURL>http://www.sonos.com/products/zoneplayers/S12</modelURL>
  <modelName>Sonos PLAY:1</modelName>
  <modelDescription>Sonos PLAY:1 Media Renderer</modelDescription>
  <modelNumber>S12</modelNumber>
  <manufacturerURL>http://www.sonos.com</manufacturerURL>
  <manufacturer>Sonos, Inc.</manufacturer>
  <friendlyName>Schlafzimmer - Sonos PLAY:1 Media Renderer</friendlyName>
<deviceType>urn:schemas-upnp-org:device:MediaRenderer:1</deviceType>
      <device>
      </device>
</serviceList>
  </service>
    <eventSubURL>/MediaServer/ConnectionManager/Event</eventSubURL>
    <controlURL>/MediaServer/ConnectionManager/Control</controlURL>
    <service>
    </service>
      <SCPDURL>/xml/ContentDirectory1.xml</SCPDURL>
      <eventSubURL>/MediaServer/ContentDirectory/Event</eventSubURL>
      <controlURL>/MediaServer/ContentDirectory/Control</controlURL>
      <serviceId>urn:upnp-org:serviceId:ContentDirectory</serviceId>
      <serviceType>urn:schemas-upnp-org:service:ContentDirectory:1</serviceType>
    <service>
  <serviceList>
  <UDN>uuid:RINCON_949F3E07EBC801400_MS</UDN>
  <modelDescription>Sonos PLAY:1 Media Server</modelDescription>
  <friendlyName>192.168.1.243 - Sonos PLAY:1 Media Server</friendlyName>
  <deviceType>urn:schemas-upnp-org:device:MediaServer:1</deviceType>
      <device>
    <deviceList>
    </serviceList>
      </service>
        <SCPDURL>/xml/QPlay1.xml</SCPDURL>
        <eventSubURL>/QPlay/Event</eventSubURL>
        <controlURL>/QPlay/Control</controlURL>
        <serviceId>urn:tencent-com:serviceId:QPlay</serviceId>
        <serviceType>urn:schemas-tencent-com:service:QPlay:1</serviceType>
      <service>
      </service>
        <SCPDURL>/xml/GroupManagement1.xml</SCPDURL>
        <eventSubURL>/GroupManagement/Event</eventSubURL>
        <controlURL>/GroupManagement/Control</controlURL>
        <serviceId>urn:upnp-org:serviceId:GroupManagement</serviceId>
        <serviceType>urn:schemas-upnp-org:service:GroupManagement:1</serviceType>
      <service>
      </service>
        <SCPDURL>/xml/ZoneGroupTopology1.xml</SCPDURL>
        <eventSubURL>/ZoneGroupTopology/Event</eventSubURL>
        <controlURL>/ZoneGroupTopology/Control</controlURL>
        <serviceId>urn:upnp-org:serviceId:ZoneGroupTopology</serviceId>
        <serviceType>urn:schemas-upnp-org:service:ZoneGroupTopology:1</serviceType>
      <service>
      </service>
        <SCPDURL>/xml/SystemProperties1.xml</SCPDURL>
        <eventSubURL>/SystemProperties/Event</eventSubURL>
        <controlURL>/SystemProperties/Control</controlURL>
        <serviceId>urn:upnp-org:serviceId:SystemProperties</serviceId>
        <serviceType>urn:schemas-upnp-org:service:SystemProperties:1</serviceType>
      <service>
      </service>
        <SCPDURL>/xml/DeviceProperties1.xml</SCPDURL>
        <eventSubURL>/DeviceProperties/Event</eventSubURL>
        <controlURL>/DeviceProperties/Control</controlURL>
        <serviceId>urn:upnp-org:serviceId:DeviceProperties</serviceId>
        <serviceType>urn:schemas-upnp-org:service:DeviceProperties:1</serviceType>
      <service>
      </service>
        <SCPDURL>/xml/MusicServices1.xml</SCPDURL>
        <eventSubURL>/MusicServices/Event</eventSubURL>
        <controlURL>/MusicServices/Control</controlURL>
        <serviceId>urn:upnp-org:serviceId:MusicServices</serviceId>
        <serviceType>urn:schemas-upnp-org:service:MusicServices:1</serviceType>
      <service>
      </service>
        <SCPDURL>/xml/AlarmClock1.xml</SCPDURL>
        <eventSubURL>/AlarmClock/Event</eventSubURL>
        <controlURL>/AlarmClock/Control</controlURL>
        <serviceId>urn:upnp-org:serviceId:AlarmClock</serviceId>
        <serviceType>urn:schemas-upnp-org:service:AlarmClock:1</serviceType>
      <service>
    <serviceList>
    <ampOnTime>10</ampOnTime>
    <flash>256</flash>
    <memory>256</memory>
    <satGainOffset>6.000</satGainOffset>
    <bassExtension>75.000</bassExtension>
    <internalSpeakerSize>5</internalSpeakerSize>
    <variant>1</variant>
    <feature3>0x0001000e</feature3>
    <feature2>0x00403332</feature2>
    <feature1>0x00000000</feature1>
    <zoneType>14</zoneType>
    <displayName>PLAY:1</displayName>
    <roomName>Schlafzimmer</roomName>
    <extraVersion></extraVersion>
    <displayVersion>7.1</displayVersion>
    <legacyCompatibleVersion>25.0-00000</legacyCompatibleVersion>
    <minCompatibleVersion>33.0-00000</minCompatibleVersion>
    </iconList>
      </icon>
        <depth>24</depth>
        <height>48</height>
        <width>48</width>
        <id>0</id>
      <icon>
    <iconList>
    <UDN>uuid:RINCON_949F3E07EBC801400</UDN>
    <serialNum>94-9F-3E-07-EB-C8:B</serialNum>
    <hardwareVersion>1.20.1.6-2</hardwareVersion>
    <softwareVersion>34.16-37101</softwareVersion>
    <modelDescription>Sonos PLAY:1</modelDescription>
    <friendlyName>192.168.1.243 - Sonos PLAY:1</friendlyName>
    <deviceType>urn:schemas-upnp-org:device:ZonePlayer:1</deviceType>
  <device>
  </specVersion>
    <minor>0</minor>
    <major>1</major>
  <specVersion>
<root xmlns="urn:schemas-upnp-org:device-1-0">
2017.04.04 21:50:17 4: SONOS19: Discover-Event: Description-Document: <?xml version="1.0" encoding="utf-8" ?>
2017.04.04 21:50:17 4: SONOS0: Transport-Event: Bilder-Download: SONOS_DownloadReplaceIfChanged('http://192.168.1.243:1400/getaa?s=1&u=x-sonosapi-stream%3as42824%3fsid%3d254%26flags%3d8224%26sn%3d0', './www/images/default/SONOSPLAYER/Sonos_Schlafzimmer_AlbumArt.gif');
2017.04.04 21:50:17 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, presence, disappeared) -> appeared
2017.04.04 21:50:17 3: SONOS19: Event: End of Transport-Event for Zone "Sonos_Schlafzimmer".
2017.04.04 21:50:17 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, TransportState, -) -> STOPPED
2017.04.04 21:50:17 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, def, NAME, RINCON_949F3E07EBC801400_MR) -> Sonos_Schlafzimmer
2017.04.04 21:50:17 4: SONOS19: SONOS_Client_Data_Retreive(SONOS, reading, ZoneGroupState, ) -> <ZoneGroups><ZoneGroup Coordinator="RINCON_949F3E07EBC801400" ID="RINCON_949F3E07EBC801400:0"><ZoneGroupMember UUID="RINCON_949F3E07EBC801400" Location="http://192.168.1.243:1400/xml/device_description.xml" ZoneName="Schlafzimmer" Icon="x-rincon-roomicon:masterbedroom" Configuration="1" SoftwareVersion="34.16-37101" MinCompatibleVersion="33.0-00000" LegacyCompatibleVersion="25.0-00000" BootSeq="21" WirelessMode="1" WirelessLeafOnly="0" HasConfiguredSSID="1" ChannelFreq="2412" BehindWifiExtender="0" WifiEnabled="1" Orientation="0" RoomCalibrationState="1" SecureRegState="2"/></ZoneGroup></ZoneGroups>
2017.04.04 21:50:17 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, QueueHash, ) -> 9a1c7ee2c7ce38d4bbbaf29ab9f2ac1e
2017.04.04 21:50:17 4: SONOS19: Transport-Event: NextTrackMetaData:
2017.04.04 21:50:17 4: SONOS19: Transport-Event: Stream erkannt!
2017.04.04 21:50:17 4: SONOS19: Transport-Event: CurrentTrackMetaData: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"><item id="-1" parentID="-1" restricted="true"><res protocolInfo="sonos.com-http:*:application/octet-stream:*">x-sonosapi-stream:s42824?sid=254&amp;flags=8224&amp;sn=0</res><r:streamContent></r:streamContent><r:radioShowMd></r:radioShowMd><upnp:albumArtURI>/getaa?s=1&amp;u=x-sonosapi-stream%3as42824%3fsid%3d254%26flags%3d8224%26sn%3d0</upnp:albumArtURI><dc:title>x-sonosapi-stream:s42824?sid=254&amp;flags=8224&amp;sn=0</dc:title><upnp:class>object.item</upnp:class></item></DIDL-Lite>
2017.04.04 21:50:17 4: SONOS19: ProxyObject exists: UPnP::ControlPoint::ControlProxy=HASH(0x743b8c58)
2017.04.04 21:50:17 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, SleepTimerVersion, ) ->
2017.04.04 21:50:17 4: SONOS19: Transport-Event: LastChange: <Event xmlns="urn:schemas-upnp-org:metadata-1-0/AVT/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/"><InstanceID val="0"><TransportState val="STOPPED"/><CurrentPlayMode val="NORMAL"/><CurrentCrossfadeMode val="0"/><NumberOfTracks val="2"/><CurrentTrack val="1"/><CurrentSection val="0"/><CurrentTrackURI val="aac://mp3channels.webradio.antenne.de/antenne.aac"/><CurrentTrackDuration val="0:00:00"/><CurrentTrackMetaData val="&lt;DIDL-Lite xmlns:dc=&quot;http://purl.org/dc/elements/1.1/&quot; xmlns:upnp=&quot;urn:schemas-upnp-org:metadata-1-0/upnp/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot; xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&quot;&gt;&lt;item id=&quot;-1&quot; parentID=&quot;-1&quot; restricted=&quot;true&quot;&gt;&lt;res protocolInfo=&quot;sonos.com-http:*:application/octet-stream:*&quot;&gt;x-sonosapi-stream:s42824?sid=254&amp;amp;flags=8224&amp;amp;sn=0&lt;/res&gt;&lt;r:streamContent&gt;&lt;/r:streamContent&gt;&lt;r:radioShowMd&gt;&lt;/r:radioShowMd&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonosapi-stream%3as42824%3fsid%3d254%26flags%3d8224%26sn%3d0&lt;/upnp:albumArtURI&gt;&lt;dc:title&gt;x-sonosapi-stream:s42824?sid=254&amp;amp;flags=8224&amp;amp;sn=0&lt;/dc:title&gt;&lt;upnp:class&gt;object.item&lt;/upnp:class&gt;&lt;/item&gt;&lt;/DIDL-Lite&gt;"/><r:NextTrackURI val=""/><r:NextTrackMetaData val=""/><r:EnqueuedTransportURI val="x-sonosapi-stream:s42824?sid=254&amp;flags=8224&amp;sn=0"/><r:EnqueuedTransportURIMetaData val="&lt;DIDL-Lite xmlns:dc=&quot;http://purl.org/dc/elements/1.1/&quot; xmlns:upnp=&quot;urn:schemas-upnp-org:metadata-1-0/upnp/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot; xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&quot;&gt;&lt;item id=&quot;-1&quot; parentID=&quot;-1&quot; restricted=&quot;true&quot;&gt;&lt;dc:title&gt;ANTENNE BAYERN&lt;/dc:title&gt;&lt;upnp:class&gt;object.item.audioItem.audioBroadcast&lt;/upnp:class&gt;&lt;desc id=&quot;cdudn&quot; nameSpace=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot;&gt;SA_RINCON65031_&lt;/desc&gt;&lt;/item&gt;&lt;/DIDL-Lite&gt;"/><PlaybackStorageMedium val="NETWORK"/><AVTransportURI val="x-sonosapi-stream:s42824?sid=254&amp;flags=8224&amp;sn=0"/><AVTransportURIMetaData val="&lt;DIDL-Lite xmlns:dc=&quot;http://purl.org/dc/elements/1.1/&quot; xmlns:upnp=&quot;urn:schemas-upnp-org:metadata-1-0/upnp/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot; xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&quot;&gt;&lt;item id=&quot;-1&quot; parentID=&quot;-1&quot; restricted=&quot;true&quot;&gt;&lt;dc:title&gt;ANTENNE BAYERN&lt;/dc:title&gt;&lt;upnp:class&gt;object.item.audioItem.audioBroadcast&lt;/upnp:class&gt;&lt;desc id=&quot;cdudn&quot; nameSpace=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot;&gt;SA_RINCON65031_&lt;/desc&gt;&lt;/item&gt;&lt;/DIDL-Lite&gt;"/><NextAVTransportURI val=""/><NextAVTransportURIMetaData val=""/><CurrentTransportActions val="Set, Stop, Play"/><r:CurrentValidPlayModes val=""/><r:MuseSessions val=""/><r:DirectControlClientID val=""/><r:DirectControlIsSuspended val="0"/><r:DirectControlAccountID val=""/><TransportStatus val="OK"/><r:SleepTimerGeneration val="0"/><r:AlarmRunning val="0"/><r:SnoozeRunning val="0"/><r:RestartPending val="0"/><TransportPlaySpeed val="NOT_IMPLEMENTED"/><CurrentMediaDuration val="NOT_IMPLEMENTED"/><RecordStorageMedium val="NOT_IMPLEMENTED"/><PossiblePlaybackStorageMedia val="NONE, NETWORK"/><PossibleRecordStorageMedia val="NOT_IMPLEMENTED"/><RecordMediumWriteStatus val="NOT_IMPLEMENTED"/><CurrentRecordQualityMode val="NOT_IMPLEMENTED"/><PossibleRecordQualityModes val="NOT_IMPLEMENTED"/></InstanceID></Event>
2017.04.04 21:50:17 4: SONOS19: Transport-Event: GroundURL: http://192.168.1.243:1400
2017.04.04 21:50:17 4: SONOS19: Transport-Event: All correct with this service-call till now. UDN='uuid:RINCON_949F3E07EBC801400_MR'
2017.04.04 21:50:17 3: SONOS19: Event: Received Transport-Event for Zone "Sonos_Schlafzimmer".
2017.04.04 21:50:17 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, attr, disable, 0) -> DEFAULT
2017.04.04 21:50:17 3: SONOS19: Discover: End of discover-event for "Schlafzimmer".
2017.04.04 21:50:17 2: SONOS19: DeviceProperties-Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000023793
2017.04.04 21:50:17 2: SONOS19: ZoneGroupTopology-Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000023792
2017.04.04 21:50:17 2: SONOS19: Alarm-Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000023791
2017.04.04 21:50:17 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, attr, getAlarms, 0) -> 1
2017.04.04 21:50:17 2: SONOS19: ContentDirectory-Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000023790
2017.04.04 21:50:17 2: SONOS19: GroupRendering-Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000023789
2017.04.04 21:50:17 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, attr, minVolume, -1) -> 0
2017.04.04 21:50:17 2: SONOS19: Rendering-Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000023788
2017.04.04 21:50:17 2: SONOS19: Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000023787
2017.04.04 21:50:17 2: SONOS19: SonosPlayer 'Schlafzimmer' is now updated
2017.04.04 21:50:16 4: SONOS19: ProxyObject exists: UPnP::ControlPoint::ControlProxy=HASH(0x743b8c58)
2017.04.04 21:50:16 2: SONOS19: SonosPlayer 'Schlafzimmer' (S12) with ID 'RINCON_949F3E07EBC801400_MR' is already defined (as 'Sonos_Schlafzimmer') and will only be updated
2017.04.04 21:50:16 4: SONOS19: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, def, NAME, RINCON_949F3E07EBC801400_MR) -> Sonos_Schlafzimmer
2017.04.04 21:50:16 4: SONOS19: Retrieve Current Volumelevels. Master: "33", Balance: "0"
2017.04.04 21:50:16 4: SONOS19: Retrieved TopoType:
2017.04.04 21:50:16 4: SONOS19: ControlProxies wurden gesichert
2017.04.04 21:50:15 4: SONOS19: SubDevice found: uuid:RINCON_949F3E07EBC801400_MR
2017.04.04 21:50:15 4: SONOS19: SubDevice found: uuid:RINCON_949F3E07EBC801400_MS
2017.04.04 21:50:14 2: SONOS19: Discover Sonosplayer 'Schlafzimmer' (S12) Software Revision 7.1 with ID 'RINCON_949F3E07EBC801400_MR'
2017.04.04 21:50:14 4: SONOS19: RoomName: 'Schlafzimmer', SaveRoomName: 'Schlafzimmer', ModelNumber: 'S12', DisplayVersion: '7.1', SerialNum: '94-9F-3E-07-EB-C8:B', IconURI: '/img/icon-S12.png', IconOrigPath: 'http://192.168.1.243:1400/img/icon-S12.png', IconPath: 'icoSONOSPLAYER_icon-S12.png'
</root>
  </device>
    </deviceList>
      </device>
        </iconList>
          </icon>
            <depth>24</depth>
            <height>48</height>
            <width>48</width>
          <icon>
        <iconList>
</serviceList>
          </service>
          <service>
  </service>
  <service>
  </service>
  <service>
  </service>
  <service>
  </service>
  <service>
<serviceList>
      <device>
      </device>
</serviceList>
  </service>
    <service>
    </service>
    <service>
  <serviceList>
      <device>
    <deviceList>
    </serviceList>
      </service>
      <service>
      </service>
      <service>
      </service>
      <service>
      </service>
      <service>
      </service>
      <service>
      </service>
aus alter Zeit:
Reinerlein
Hi Sascha,
da ist jetzt aber der Fehler vom letzten mal nicht enthalten, oder?
Das einzige Problem war, dass irgendein Cover nicht geladen weden konnte, was aber kein Problem an sich ist (da steht ja auch, dass er ein Standardcover verwendet)...
Versuch auf jeden Fall erstmal das Update von heute. Sonst haben wir verschiedene Versionsstände...
Reiner
Nobby1805
Warum werden denn da so viele Threads erzeugt ... Sonos19, Sonos20 ?
FHEM-Featurelevel: 6.2   (fhem.pl:28227/2023-11-29) auf Windows 10 Pro mit Strawberry Perl 5.32.1.1-32bit
TabletUI: 2.7.15
IO: 2xHMLAN(0.965)|HMUSB2(0.967)
Reinerlein
Hi Nobby1805,
da sterben ein paar Threads, und wenn neue erzeugt werden, geht die Nummerierung zunächst mal weiter :)
Das Problem ist, herauszufinden, warum die keinen Bock mehr haben. Ich hoffe ja irgendwas im Log dazu zu finden...
Reiner
Masterfunk
Hallo Reiner,
nach dem Update werden die Gruppen nun auch schön angezeigt, wenn ein Stereopärchen dabei ist. :-)
Allerdings ist die readingsgroup für die Gruppenkonstellation jetzt komplett leer.
Ich habe das Beispiel aus de Wiki genommen.
Was ich noch beobachte, die Aktualisierung in FTUI (speziel bei Änderungen der Gruppenkonstellation) scheint stark verzögert bis gar nicht zu kommen.
Gruß Detlef
Reinerlein
Hi Detlef,
das Aufbauen einer Gruppe dauert immer ein paar Sekunden, aber nach ca. 6 Sekunden sollte das durch sein (gerade nochmal getestet).
Die mitgelieferte ReadingsGroup hatte ich ja angepasst. Das Wiki ziehe ich noch nach, bis dahin kannst du dir ja das im Quellcode anschauen. Das Wiki ist ja direkt von dort abgeschrieben...
Reiner
Masterfunk
Mit der im Modul integrierten Funktion gehts.
Nur das Beispiel im Wiki zeigt eine leere Readingsgroup.
Für mich eh der bessere Weg.
Gruß Detlef
Cybers
#2814
anbei mal das Log-File aus den letzten Stunden mit Verbose 4. Kann es gerne auch mal auf Verbose 5 stellen.
Gruß, Sascha
2017.04.06 00:32:56 4: SONOS13: RoomName: 'Schlafzimmer', SaveRoomName: 'Schlafzimmer', ModelNumber: 'S12', DisplayVersion: '7.1', SerialNum: '94-9F-3E-07-EB-C8:B', IconURI: '/img/icon-S12.png', IconOrigPath: 'http://192.168.1.243:1400/img/icon-S12.png', IconPath: 'icoSONOSPLAYER_icon-S12.png'
2017.04.06 00:32:56 2: SONOS13: Discover Sonosplayer 'Schlafzimmer' (S12) Software Revision 7.1 with ID 'RINCON_949F3E07EBC801400_MR'
2017.04.06 00:32:57 4: SONOS13: SubDevice found: uuid:RINCON_949F3E07EBC801400_MS
2017.04.06 00:32:57 4: SONOS13: SubDevice found: uuid:RINCON_949F3E07EBC801400_MR
2017.04.06 00:32:58 4: SONOS13: ControlProxies wurden gesichert
2017.04.06 00:32:58 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, def, NAME, RINCON_949F3E07EBC801400_MR) -> Sonos_Schlafzimmer
2017.04.06 00:32:58 4: SONOS13: Retrieved TopoType:
2017.04.06 00:32:58 4: SONOS14: IsAlive-Event UDN=RINCON_949F3E07EBC801400_MR
2017.04.06 00:32:58 4: SONOS14: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, location, ) -> http://192.168.1.243:1400/xml/device_description.xml
2017.04.06 00:32:58 4: SONOS14: 192.168.1.243 is alive
2017.04.06 00:32:58 4: SONOS13: Retrieve Current Volumelevels. Master: "33", Balance: "0"
2017.04.06 00:32:58 4: SONOS13: SONOS_Client_Data_Refresh(, udn, Sonos_Schlafzimmer, RINCON_949F3E07EBC801400_MR)
2017.04.06 00:32:58 2: SONOS13: SonosPlayer 'Schlafzimmer' (S12) with ID 'RINCON_949F3E07EBC801400_MR' is already defined (as 'Sonos_Schlafzimmer') and will only be updated
2017.04.06 00:32:58 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, presence, appeared)
2017.04.06 00:32:58 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, Volume, 33)
2017.04.06 00:32:58 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, Balance, 0)
2017.04.06 00:32:58 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, roomName, Schlafzimmer)
2017.04.06 00:32:58 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, roomNameAlias, Schlafzimmer)
2017.04.06 00:32:58 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, saveRoomName, Schlafzimmer)
2017.04.06 00:32:58 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, playerType, S12)
2017.04.06 00:32:58 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, location, http://192.168.1.243:1400/xml/device_description.xml)
2017.04.06 00:32:58 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, softwareRevision, 7.1)
2017.04.06 00:32:58 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, serialNum, 94-9F-3E-07-EB-C8:B)
2017.04.06 00:32:58 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, fieldType, )
2017.04.06 00:32:58 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, IsBonded, 0)
2017.04.06 00:32:58 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, IsMaster, 1)
2017.04.06 00:32:58 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, MasterPlayer, Sonos_Schlafzimmer)
2017.04.06 00:32:58 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, SlavePlayer, [])
2017.04.06 00:32:58 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, SlavePlayerNotBonded, [])
2017.04.06 00:32:58 4: SONOS13: SONOS_Client_Data_Retreive(SONOS, attr, getListsDirectlyToReadings, 0) -> DEFAULT
2017.04.06 00:32:58 4: SONOS13: ProxyObject exists: UPnP::ControlPoint::ControlProxy=HASH(0x744d7f48)
2017.04.06 00:32:58 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, transportState, STOPPED)
2017.04.06 00:32:58 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, currentTrackURI, aac://mp3channels.webradio.antenne.de/antenne.aac)
2017.04.06 00:32:58 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, currentTrackProvider, Radio)
2017.04.06 00:32:58 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, currentTrackDuration, 0:00:00)
2017.04.06 00:32:58 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, currentTrackPosition, 0:00:00)
2017.04.06 00:32:58 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, currentTrackPositionSec, 1)
2017.04.06 00:32:58 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, currentTrack, 1)
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, numberOfTracks, 2)
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, currentStreamAudio, 1)
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, currentNormalAudio, )
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(, RINCON_949F3E07EBC801400_MR, LastSubscriptionsRenew, 2017-04-06 00:32:59)
2017.04.06 00:32:59 2: SONOS13: SonosPlayer 'Schlafzimmer' is now updated
2017.04.06 00:32:59 2: SONOS13: Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000028326
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, attr, minVolume, -1) -> 0
2017.04.06 00:32:59 2: SONOS13: Rendering-Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000028327
2017.04.06 00:32:59 2: SONOS13: GroupRendering-Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000028328
2017.04.06 00:32:59 2: SONOS13: ContentDirectory-Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000028329
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, attr, getAlarms, 0) -> 1
2017.04.06 00:32:59 2: SONOS13: Alarm-Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000028330
2017.04.06 00:32:59 2: SONOS13: ZoneGroupTopology-Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000028331
2017.04.06 00:32:59 2: SONOS13: DeviceProperties-Service-subscribing successful with SID=uuid:RINCON_949F3E07EBC801400_sub0000028332
2017.04.06 00:32:59 3: SONOS13: Discover: End of discover-event for "Schlafzimmer".
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, def, NAME, RINCON_949F3E07EBC801400_MR) -> Sonos_Schlafzimmer
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, attr, disable, 0) -> DEFAULT
2017.04.06 00:32:59 3: SONOS13: Event: Received Transport-Event for Zone "Sonos_Schlafzimmer".
2017.04.06 00:32:59 4: SONOS13: Transport-Event: All correct with this service-call till now. UDN='uuid:RINCON_949F3E07EBC801400_MR'
2017.04.06 00:32:59 4: SONOS13: Transport-Event: GroundURL: http://192.168.1.243:1400
2017.04.06 00:32:59 4: SONOS13: Transport-Event: LastChange: <Event xmlns="urn:schemas-upnp-org:metadata-1-0/AVT/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/"><InstanceID val="0"><TransportState val="STOPPED"/><CurrentPlayMode val="NORMAL"/><CurrentCrossfadeMode val="0"/><NumberOfTracks val="2"/><CurrentTrack val="1"/><CurrentSection val="0"/><CurrentTrackURI val="aac://mp3channels.webradio.antenne.de/antenne.aac"/><CurrentTrackDuration val="0:00:00"/><CurrentTrackMetaData val="&lt;DIDL-Lite xmlns:dc=&quot;http://purl.org/dc/elements/1.1/&quot; xmlns:upnp=&quot;urn:schemas-upnp-org:metadata-1-0/upnp/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot; xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&quot;&gt;&lt;item id=&quot;-1&quot; parentID=&quot;-1&quot; restricted=&quot;true&quot;&gt;&lt;res protocolInfo=&quot;sonos.com-http:*:application/octet-stream:*&quot;&gt;x-sonosapi-stream:s42824?sid=254&amp;amp;flags=8224&amp;amp;sn=0&lt;/res&gt;&lt;r:streamContent&gt;&lt;/r:streamContent&gt;&lt;r:radioShowMd&gt;&lt;/r:radioShowMd&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonosapi-stream%3as42824%3fsid%3d254%26flags%3d8224%26sn%3d0&lt;/upnp:albumArtURI&gt;&lt;dc:title&gt;x-sonosapi-stream:s42824?sid=254&amp;amp;flags=8224&amp;amp;sn=0&lt;/dc:title&gt;&lt;upnp:class&gt;object.item&lt;/upnp:class&gt;&lt;/item&gt;&lt;/DIDL-Lite&gt;"/><r:NextTrackURI val=""/><r:NextTrackMetaData val=""/><r:EnqueuedTransportURI val="x-sonosapi-stream:s42824?sid=254&amp;flags=8224&amp;sn=0"/><r:EnqueuedTransportURIMetaData val="&lt;DIDL-Lite xmlns:dc=&quot;http://purl.org/dc/elements/1.1/&quot; xmlns:upnp=&quot;urn:schemas-upnp-org:metadata-1-0/upnp/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot; xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&quot;&gt;&lt;item id=&quot;-1&quot; parentID=&quot;-1&quot; restricted=&quot;true&quot;&gt;&lt;dc:title&gt;ANTENNE BAYERN&lt;/dc:title&gt;&lt;upnp:class&gt;object.item.audioItem.audioBroadcast&lt;/upnp:class&gt;&lt;desc id=&quot;cdudn&quot; nameSpace=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot;&gt;SA_RINCON65031_&lt;/desc&gt;&lt;/item&gt;&lt;/DIDL-Lite&gt;"/><PlaybackStorageMedium val="NETWORK"/><AVTransportURI val="x-sonosapi-stream:s42824?sid=254&amp;flags=8224&amp;sn=0"/><AVTransportURIMetaData val="&lt;DIDL-Lite xmlns:dc=&quot;http://purl.org/dc/elements/1.1/&quot; xmlns:upnp=&quot;urn:schemas-upnp-org:metadata-1-0/upnp/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot; xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&quot;&gt;&lt;item id=&quot;-1&quot; parentID=&quot;-1&quot; restricted=&quot;true&quot;&gt;&lt;dc:title&gt;ANTENNE BAYERN&lt;/dc:title&gt;&lt;upnp:class&gt;object.item.audioItem.audioBroadcast&lt;/upnp:class&gt;&lt;desc id=&quot;cdudn&quot; nameSpace=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot;&gt;SA_RINCON65031_&lt;/desc&gt;&lt;/item&gt;&lt;/DIDL-Lite&gt;"/><NextAVTransportURI val=""/><NextAVTransportURIMetaData val=""/><CurrentTransportActions val="Set, Stop, Play"/><r:CurrentValidPlayModes val=""/><r:MuseSessions val=""/><r:DirectControlClientID val=""/><r:DirectControlIsSuspended val="0"/><r:DirectControlAccountID val=""/><TransportStatus val="OK"/><r:SleepTimerGeneration val="0"/><r:AlarmRunning val="0"/><r:SnoozeRunning val="0"/><r:RestartPending val="0"/><TransportPlaySpeed val="NOT_IMPLEMENTED"/><CurrentMediaDuration val="NOT_IMPLEMENTED"/><RecordStorageMedium val="NOT_IMPLEMENTED"/><PossiblePlaybackStorageMedia val="NONE, NETWORK"/><PossibleRecordStorageMedia val="NOT_IMPLEMENTED"/><RecordMediumWriteStatus val="NOT_IMPLEMENTED"/><CurrentRecordQualityMode val="NOT_IMPLEMENTED"/><PossibleRecordQualityModes val="NOT_IMPLEMENTED"/></InstanceID></Event>
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, QueueHash, ) -> 9a1c7ee2c7ce38d4bbbaf29ab9f2ac1e
2017.04.06 00:32:59 4: SONOS13: ProxyObject exists: UPnP::ControlPoint::ControlProxy=HASH(0x744d7f48)
2017.04.06 00:32:59 3: SONOS0: Connection accepted from localhost:47626
2017.04.06 00:32:59 4: SONOS0: Got correct Answer from Subprocess...
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, SleepTimerVersion, ) ->
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsSingleUpdateIfChanged, RINCON_949F3E07EBC801400_MR, SleepTimerVersion, )
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, currentTransportState, ) -> DEFAULT
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, IsMaster, 0) -> 1
2017.04.06 00:32:59 4: SONOS13: Transport-Event: CurrentTrackMetaData: <DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"><item id="-1" parentID="-1" restricted="true"><res protocolInfo="sonos.com-http:*:application/octet-stream:*">x-sonosapi-stream:s42824?sid=254&amp;flags=8224&amp;sn=0</res><r:streamContent></r:streamContent><r:radioShowMd></r:radioShowMd><upnp:albumArtURI>/getaa?s=1&amp;u=x-sonosapi-stream%3as42824%3fsid%3d254%26flags%3d8224%26sn%3d0</upnp:albumArtURI><dc:title>x-sonosapi-stream:s42824?sid=254&amp;flags=8224&amp;sn=0</dc:title><upnp:class>object.item</upnp:class></item></DIDL-Lite>
2017.04.06 00:32:59 4: SONOS13: Transport-Event: Stream erkannt!
2017.04.06 00:32:59 4: SONOS13: Transport-Event: NextTrackMetaData:
2017.04.06 00:32:59 4: SONOS13: ProxyObject exists: UPnP::ControlPoint::ControlProxy=HASH(0x7448c568)
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, def, NAME, ~~~DELETE~~~) -> Sonos_Schlafzimmer
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, TransportState, -) -> STOPPED
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, IsBonded, 0) -> 0
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, undef, AllPlayer, ['Sonos_Schlafzimmer'])
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, undef, AllPlayerCount, 1)
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, undef, AllPlayerNotBonded, ['Sonos_Schlafzimmer'])
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, undef, AllPlayerNotBondedCount, 1)
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(udn, udn, Sonos_Schlafzimmer, Sonos_Schlafzimmer) -> RINCON_949F3E07EBC801400_MR
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, LineInConnected, 0) -> DEFAULT
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, undef, LineInPlayer, [])
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(SONOS, attr, getListsDirectlyToReadings, 0) -> DEFAULT
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, undef, MasterPlayerPlaying, [])
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, undef, MasterPlayerPlayingCount, 0)
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, undef, MasterPlayerNotPlaying, ['Sonos_Schlafzimmer'])
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, undef, MasterPlayerNotPlayingCount, 1)
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, undef, MasterPlayer, ['Sonos_Schlafzimmer'])
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, undef, MasterPlayerCount, 1)
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, def, NAME, ) -> Sonos_Schlafzimmer
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, MasterPlayer, Sonos_Schlafzimmer)
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, AvailablePlayer, [])
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, SlavePlayer, [])
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, SlavePlayerNotBonded, [])
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, ZoneGroupNameDetails, )
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, SlavePlayer, ) -> []
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, attr, stopSleeptimerInAction, 0) -> DEFAULT
2017.04.06 00:32:59 3: SONOS13: Event: End of Transport-Event for Zone "Sonos_Schlafzimmer".
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, presence, disappeared) -> appeared
2017.04.06 00:32:59 3: SONOS13: Event: Received GroupRendering-Event for Zone "Sonos_Schlafzimmer".
2017.04.06 00:32:59 4: SONOS13: GroupRendering-Event: All correct with this service-call till now. UDN='uuid:RINCON_949F3E07EBC801400_MR'
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, attr, generateVolumeEvent, 0) -> DEFAULT
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, GroupVolume, ~~) -> 33
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, GroupMute, ~~) -> 0
2017.04.06 00:32:59 3: SONOS13: Event: End of GroupRendering-Event for Zone "Sonos_Schlafzimmer".
2017.04.06 00:32:59 3: SONOS13: Event: Received Alarm-Event for Zone "Sonos_Schlafzimmer".
2017.04.06 00:32:59 4: SONOS13: Alarm-Event: All correct with this service-call till now. UDN='uuid:RINCON_949F3E07EBC801400_MR'
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, AlarmListVersion, ~~) -> RINCON_949F3E07EBC801400:0
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsSingleUpdateIfChanged, RINCON_949F3E07EBC801400_MR, DailyIndexRefreshTime, )
2017.04.06 00:32:59 3: SONOS13: Event: End of Alarm-Event for Zone "Sonos_Schlafzimmer".
2017.04.06 00:32:59 3: SONOS13: Event: Received ZoneGroupTopology-Event for Zone "Sonos_Schlafzimmer".
2017.04.06 00:32:59 4: SONOS13: ZoneGroupTopology-Event: All correct with this service-call till now. UDN='uuid:RINCON_949F3E07EBC801400_MR'
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsSingleUpdateIfChanged, undef, ZoneGroupState, <ZoneGroups><ZoneGroup Coordinator="RINCON_949F3E07EBC801400" ID="RINCON_949F3E07EBC801400:0"><ZoneGroupMember UUID="RINCON_949F3E07EBC801400" Location="http://192.168.1.243:1400/xml/device_description.xml" ZoneName="Schlafzimmer" Icon="x-rincon-roomicon:masterbedroom" Configuration="1" SoftwareVersion="34.16-37101" MinCompatibleVersion="33.0-00000" LegacyCompatibleVersion="25.0-00000" BootSeq="21" WirelessMode="1" WirelessLeafOnly="0" HasConfiguredSSID="1" ChannelFreq="2412" BehindWifiExtender="0" WifiEnabled="1" Orientation="0" RoomCalibrationState="1" SecureRegState="2"/></ZoneGroup></ZoneGroups>)
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, ZonePlayerUUIDsInGroup, ) -> RINCON_949F3E07EBC801400
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, ZoneGroupID, ) -> RINCON_949F3E07EBC801400:__
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, fieldType, ) ->
2017.04.06 00:32:59 4: SONOS13: Retrieved TopoType:
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, roomName, ) -> Schlafzimmer
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, roomNameAlias, Schlafzimmer)
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, ZoneGroupID, RINCON_949F3E07EBC801400:__)
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, fieldType, )
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, IsBonded, 0)
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, IsMaster, 1)
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, ZoneGroupName, ) -> Schlafzimmer
2017.04.06 00:32:59 4: SONOS0: Transport-Event: Bilder-Download: SONOS_DownloadReplaceIfChanged('http://192.168.1.243:1400/getaa?s=1&u=x-sonosapi-stream%3as42824%3fsid%3d254%26flags%3d8224%26sn%3d0', './www/images/default/SONOSPLAYER/Sonos_Schlafzimmer_AlbumArt.gif');
2017.04.06 00:32:59 3: SONOS13: Event: End of ZoneGroupTopology-Event for Zone "Sonos_Schlafzimmer".
2017.04.06 00:32:59 3: SONOS13: Event: Received DeviceProperties-Event for Zone "Sonos_Schlafzimmer".
2017.04.06 00:32:59 4: SONOS13: DeviceProperties-Event: All correct with this service-call till now. UDN='uuid:RINCON_949F3E07EBC801400_MR'
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, roomName, Schlafzimmer)
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, saveRoomName, Schlafzimmer)
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, roomIcon, ) -> masterbedroom
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, roomIcon, masterbedroom)
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, ButtonState, ) -> DEFAULT
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, ButtonLockState, ) -> DEFAULT
2017.04.06 00:32:59 3: SONOS13: Event: End of DeviceProperties-Event for Zone "Sonos_Schlafzimmer".
2017.04.06 00:32:59 3: SONOS13: Event: Received ContentDirectory-Event for Zone "Sonos_Schlafzimmer".
2017.04.06 00:32:59 4: SONOS13: ContentDirectory-Event: All correct with this service-call till now. UDN='uuid:RINCON_949F3E07EBC801400_MR'
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, FavouritesVersion, RINCON_949F3E07EBC801400,20)
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, RadiosVersion, RINCON_949F3E07EBC801400,20)
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, PlaylistsVersion, ~~) -> RINCON_949F3E07EBC801400,0
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, QueueVersion, ~~) ->
2017.04.06 00:32:59 4: SONOS13: SONOS_Client_Data_Retreive(SONOS, reading, ShareIndexInProgress, ~~) -> 0
2017.04.06 00:32:59 3: SONOS13: Event: End of ContentDirectory-Event for Zone "Sonos_Schlafzimmer".
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, def, NAME, RINCON_949F3E07EBC801400_MR) -> Sonos_Schlafzimmer
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, attr, disable, 0) -> DEFAULT
2017.04.06 00:33:00 3: SONOS13: Event: Received Rendering-Event for Zone "Sonos_Schlafzimmer".
2017.04.06 00:33:00 4: SONOS13: Rendering-Event: All correct with this service-call till now. UDN='uuid:RINCON_949F3E07EBC801400_MR'
2017.04.06 00:33:00 4: SONOS13: Rendering-Event: LastChange: <Event xmlns="urn:schemas-upnp-org:metadata-1-0/RCS/"><InstanceID val="0"><Volume channel="Master" val="33"/><Volume channel="LF" val="100"/><Volume channel="RF" val="100"/><Mute channel="Master" val="0"/><Mute channel="LF" val="0"/><Mute channel="RF" val="0"/><Bass val="-2"/><Treble val="0"/><Loudness channel="Master" val="1"/><OutputFixed val="0"/><HeadphoneConnected val="0"/><SpeakerSize val="5"/><SubGain val="0"/><SubCrossover val="0"/><SubPolarity val="0"/><SubEnabled val="1"/><SonarEnabled val="1"/><SonarCalibrationAvailable val="1"/><PresetNameList val="FactoryDefaults"/></InstanceID></Event>
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, attr, generateVolumeEvent, 0) -> DEFAULT
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, Mute, 0) -> 0
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsSingleUpdateIfChangedNoTrigger, RINCON_949F3E07EBC801400_MR, Mute, 0)
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, HeadphoneConnected, 0) -> 0
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsSingleUpdateIfChangedNoTrigger, RINCON_949F3E07EBC801400_MR, HeadphoneConnected, 0)
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, Balance, 0) -> 0
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsSingleUpdateIfChangedNoTrigger, RINCON_949F3E07EBC801400_MR, Balance, 0)
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, Volume, 0) -> 33
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsSingleUpdateIfChangedNoTrigger, RINCON_949F3E07EBC801400_MR, Volume, 33)
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, Loudness, 0) -> 1
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsSingleUpdateIfChangedNoTrigger, RINCON_949F3E07EBC801400_MR, Loudness, 1)
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, Bass, 0) -> -2
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsSingleUpdateIfChangedNoTrigger, RINCON_949F3E07EBC801400_MR, Bass, -2)
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, Treble, 0) -> 0
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsSingleUpdateIfChangedNoTrigger, RINCON_949F3E07EBC801400_MR, Treble, 0)
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, TruePlay, 0) -> 1
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsSingleUpdateIfChangedNoTrigger, RINCON_949F3E07EBC801400_MR, TruePlay, 1)
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, SurroundEnable, 0) -> DEFAULT
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, SurroundLevel, 0) -> DEFAULT
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, SubEnable, 0) -> 1
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsSingleUpdateIfChangedNoTrigger, RINCON_949F3E07EBC801400_MR, SubEnable, 1)
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, SubGain, 0) -> 0
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsSingleUpdateIfChangedNoTrigger, RINCON_949F3E07EBC801400_MR, SubGain, 0)
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, SubPolarity, 0) -> 0
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsSingleUpdateIfChangedNoTrigger, RINCON_949F3E07EBC801400_MR, SubPolarity, 0)
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, AudioDelay, 0) -> DEFAULT
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, AudioDelayLeftRear, 0) -> DEFAULT
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, AudioDelayRightRear, 0) -> DEFAULT
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, NightMode, 0) -> DEFAULT
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, DialogLevel, 0) -> DEFAULT
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, OutputFixed, 0) -> 0
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsSingleUpdateIfChangedNoTrigger, RINCON_949F3E07EBC801400_MR, OutputFixed, 0)
2017.04.06 00:33:00 4: SONOS13: Rendering-Event: Current Values for 'Sonos_Schlafzimmer' ~ Volume: 33, HeadphoneConnected: 0, Bass: -2, Treble: 0, Balance: 0, Loudness: 1, Mute: 0
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, attr, minVolume, 0) -> 0
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, attr, maxVolume, 100) -> DEFAULT
2017.04.06 00:33:00 4: SONOS13: Rendering-Event: Current Borders for 'Sonos_Schlafzimmer' ~ minVolume: 0, maxVolume: 100
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, attr, buttonEvents, ) -> DEFAULT
2017.04.06 00:33:00 3: SONOS13: Event: End of Rendering-Event for Zone "Sonos_Schlafzimmer".
2017.04.06 00:33:00 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, presence, disappeared) -> appeared
2017.04.06 00:33:00 4: SONOS0: Identical filecontent for './www/images/default/SONOSPLAYER/Sonos_Schlafzimmer_AlbumArt.gif'!
2017.04.06 00:33:00 4: SONOS0: Transport-Event: CoverArt konnte nicht gefunden werden. Verwende FHEM-Logo. Bilder-Download: SONOS_DownloadReplaceIfChanged('./FHEM/lib/UPnP/sonos_empty.jpg', './www/images/default/SONOSPLAYER/Sonos_Schlafzimmer_NextAlbumArt.png');
2017.04.06 00:33:08 4: SONOS14: IsAlive-Event UDN=RINCON_949F3E07EBC801400_MR
2017.04.06 00:33:08 4: SONOS14: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, location, ) -> http://192.168.1.243:1400/xml/device_description.xml
2017.04.06 00:33:08 4: SONOS14: 192.168.1.243 is alive
2017.04.06 00:33:09 3: SONOS0: Connection accepted from localhost:47638
2017.04.06 00:33:09 4: SONOS0: Got correct Answer from Subprocess...
2017.04.06 00:33:18 4: SONOS14: IsAlive-Event UDN=RINCON_949F3E07EBC801400_MR
2017.04.06 00:33:18 4: SONOS14: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, location, ) -> http://192.168.1.243:1400/xml/device_description.xml
2017.04.06 00:33:18 4: SONOS14: 192.168.1.243 is alive
2017.04.06 00:33:19 3: SONOS0: Connection accepted from localhost:47660
2017.04.06 00:33:19 4: SONOS0: Got correct Answer from Subprocess...
2017.04.06 00:33:28 4: SONOS14: IsAlive-Event UDN=RINCON_949F3E07EBC801400_MR
2017.04.06 00:33:28 4: SONOS14: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, location, ) -> http://192.168.1.243:1400/xml/device_description.xml
2017.04.06 00:33:28 4: SONOS14: 192.168.1.243 is alive
2017.04.06 00:33:29 3: SONOS0: Connection accepted from localhost:47664
2017.04.06 00:33:29 4: SONOS0: Got correct Answer from Subprocess...
2017.04.06 00:33:38 4: SONOS14: IsAlive-Event UDN=RINCON_949F3E07EBC801400_MR
2017.04.06 00:33:38 4: SONOS14: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, location, ) -> http://192.168.1.243:1400/xml/device_description.xml
2017.04.06 00:33:38 4: SONOS14: 192.168.1.243 is alive
2017.04.06 00:33:39 3: SONOS0: Connection accepted from localhost:47668
2017.04.06 00:33:39 4: SONOS0: Got correct Answer from Subprocess...
2017.04.06 00:33:48 4: SONOS14: IsAlive-Event UDN=RINCON_949F3E07EBC801400_MR
2017.04.06 00:33:48 4: SONOS14: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, location, ) -> http://192.168.1.243:1400/xml/device_description.xml
2017.04.06 00:33:48 4: SONOS14: 192.168.1.243 is alive
2017.04.06 00:33:49 3: SONOS0: Connection accepted from localhost:47674
2017.04.06 00:33:49 4: SONOS0: Got correct Answer from Subprocess...
2017.04.06 00:33:58 4: SONOS14: IsAlive-Event UDN=RINCON_949F3E07EBC801400_MR
2017.04.06 00:33:58 4: SONOS14: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, location, ) -> http://192.168.1.243:1400/xml/device_description.xml
2017.04.06 00:33:58 4: SONOS14: 192.168.1.243 is alive
2017.04.06 00:33:59 3: SONOS0: Connection accepted from localhost:47678
2017.04.06 00:33:59 4: SONOS0: Got correct Answer from Subprocess...
2017.04.06 00:34:08 4: SONOS14: IsAlive-Event UDN=RINCON_949F3E07EBC801400_MR
2017.04.06 00:34:08 4: SONOS14: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, location, ) -> http://192.168.1.243:1400/xml/device_description.xml
2017.04.06 00:34:08 4: SONOS14: 192.168.1.243 is alive
2017.04.06 00:34:09 3: SONOS0: Connection accepted from localhost:47686
2017.04.06 00:34:09 4: SONOS0: Got correct Answer from Subprocess...
2017.04.06 00:34:18 4: SONOS14: IsAlive-Event UDN=RINCON_949F3E07EBC801400_MR
2017.04.06 00:34:18 4: SONOS14: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, location, ) -> http://192.168.1.243:1400/xml/device_description.xml
2017.04.06 00:34:18 4: SONOS14: 192.168.1.243 is alive
2017.04.06 00:34:20 3: SONOS0: Connection accepted from localhost:47706
2017.04.06 00:34:20 4: SONOS0: Got correct Answer from Subprocess...
2017.04.06 00:34:28 4: SONOS14: IsAlive-Event UDN=RINCON_949F3E07EBC801400_MR
2017.04.06 00:34:28 4: SONOS14: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, location, ) -> http://192.168.1.243:1400/xml/device_description.xml
2017.04.06 00:34:28 4: SONOS14: 192.168.1.243 is alive
2017.04.06 00:34:30 3: SONOS0: Connection accepted from localhost:47710
2017.04.06 00:34:30 4: SONOS0: Got correct Answer from Subprocess...
2017.04.06 00:34:39 4: SONOS14: IsAlive-Event UDN=RINCON_949F3E07EBC801400_MR
2017.04.06 00:34:39 4: SONOS14: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, location, ) -> http://192.168.1.243:1400/xml/device_description.xml
2017.04.06 00:34:39 4: SONOS14: 192.168.1.243 is alive
2017.04.06 00:34:40 3: SONOS0: Connection accepted from localhost:47714
2017.04.06 00:34:40 4: SONOS0: Got correct Answer from Subprocess...
2017.04.06 00:34:49 4: SONOS14: IsAlive-Event UDN=RINCON_949F3E07EBC801400_MR
2017.04.06 00:34:49 4: SONOS14: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, location, ) -> http://192.168.1.243:1400/xml/device_description.xml
2017.04.06 00:34:49 4: SONOS14: 192.168.1.243 is alive
2017.04.06 00:34:50 3: SONOS0: Connection accepted from localhost:47722
2017.04.06 00:34:50 4: SONOS0: Got correct Answer from Subprocess...
2017.04.06 00:34:59 4: SONOS14: IsAlive-Event UDN=RINCON_949F3E07EBC801400_MR
2017.04.06 00:34:59 4: SONOS14: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, location, ) -> http://192.168.1.243:1400/xml/device_description.xml
2017.04.06 00:34:59 4: SONOS14: 192.168.1.243 is alive
2017.04.06 00:35:00 3: SONOS0: Connection accepted from localhost:47728
2017.04.06 00:35:00 4: SONOS0: Got correct Answer from Subprocess...
2017.04.06 00:35:09 4: SONOS14: IsAlive-Event UDN=RINCON_949F3E07EBC801400_MR
2017.04.06 00:35:09 4: SONOS14: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, reading, location, ) -> http://192.168.1.243:1400/xml/device_description.xml
2017.04.06 00:35:09 4: SONOS14: 192.168.1.243 is alive
2017.04.06 00:35:11 3: SONOS0: Connection accepted from localhost:47732
2017.04.06 00:35:11 4: SONOS0: Got correct Answer from Subprocess...
2017.04.06 00:35:15 4: SONOS13: Discover-Event: Description-Document: <?xml version="1.0" encoding="utf-8" ?>
  <specVersion>
    <major>1</major>
    <minor>0</minor>
  </specVersion>
  <device>
    <iconList>
      <icon>
        <id>0</id>
        <width>48</width>
        <height>48</height>
        <depth>24</depth>
      </icon>
    </iconList>
    <flash>256</flash>
    <serviceList>
      <service>
      </service>
      <service>
      </service>
      <service>
      </service>
      <service>
      </service>
      <service>
      </service>
      <service>
      </service>
      <service>
      </service>
    </serviceList>
    <deviceList>
      <device>
  <serviceList>
    <service>
    </service>
    <service>
  </service>
</serviceList>
      </device>
      <device>
<serviceList>
  <service>
  </service>
  <service>
  </service>
  <service>
  </service>
  <service>
  </service>
          <service>
          </service>
</serviceList>
        <iconList>
          <icon>
            <width>48</width>
            <height>48</height>
            <depth>24</depth>
          </icon>
        </iconList>
      </device>
    </deviceList>
  </device>
</root>
2017.04.06 00:35:15 4: SONOS13: RoomName: 'Schlafzimmer', SaveRoomName: 'Schlafzimmer', ModelNumber: 'S12', DisplayVersion: '7.1', SerialNum: '94-9F-3E-07-EB-C8:B', IconURI: '/img/icon-S12.png', IconOrigPath: 'http://192.168.1.243:1400/img/icon-S12.png', IconPath: 'icoSONOSPLAYER_icon-S12.png'
2017.04.06 00:35:15 2: SONOS13: Discover Sonosplayer 'Schlafzimmer' (S12) Software Revision 7.1 with ID 'RINCON_949F3E07EBC801400_MR'
2017.04.06 00:35:16 4: SONOS13: SubDevice found: uuid:RINCON_949F3E07EBC801400_MS
2017.04.06 00:35:16 4: SONOS13: SubDevice found: uuid:RINCON_949F3E07EBC801400_MR
2017.04.06 00:35:17 4: SONOS13: ControlProxies wurden gesichert
2017.04.06 00:35:17 4: SONOS13: SONOS_Client_Data_Retreive(RINCON_949F3E07EBC801400_MR, def, NAME, RINCON_949F3E07EBC801400_MR) -> Sonos_Schlafzimmer
2017.04.06 00:35:17 4: SONOS13: Retrieved TopoType:
2017.04.06 00:35:17 4: SONOS13: Retrieve Current Volumelevels. Master: "33", Balance: "0"
2017.04.06 00:35:17 4: SONOS13: SONOS_Client_Data_Refresh(, udn, Sonos_Schlafzimmer, RINCON_949F3E07EBC801400_MR)
2017.04.06 00:35:17 2: SONOS13: SonosPlayer 'Schlafzimmer' (S12) with ID 'RINCON_949F3E07EBC801400_MR' is already defined (as 'Sonos_Schlafzimmer') and will only be updated
2017.04.06 00:35:17 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, presence, appeared)
2017.04.06 00:35:17 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, Volume, 33)
2017.04.06 00:35:17 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, Balance, 0)
2017.04.06 00:35:17 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, roomName, Schlafzimmer)
2017.04.06 00:35:17 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, roomNameAlias, Schlafzimmer)
2017.04.06 00:35:17 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, saveRoomName, Schlafzimmer)
2017.04.06 00:35:17 4: SONOS13: SONOS_Client_Data_Refresh(ReadingsBulkUpdateIfChanged, RINCON_949F3E07EBC801400_MR, playerType, S12)
FHEM 6.3 auf Raspberry PI 4 / Smartvisu
Eltako Serie 14: FAM14, FGW14-USB, FSB14, FSR14-4x, FSR14-2x, FDG14, FTS14-EM in Kombination mit Jung F50 24V Tastern
1-Wire Temperatursensoren
aus alter Zeit:
Gott sei Dank nur noch 3 Homematic Jalousie- & Schaltaktoren! Wer sich mit Funk auskennt, legt Kabel
Cybers
#2815
da man mit den Zeilen in der Antwort sehr begrenzt ist, und mein Log-File zu groß war, habe ich es jetzt mal als RAR-File angehangen.
Log-File wie gehabt mit Verbose 4.
Ist es auch normal das all 10 Sekunden folgendes kommt:
2017.04.07 08:09:43 4 : SONOS0: Got correct Answer from Subprocess...
2017.04.07 08:09:53 4 : SONOS0: Got correct Answer from Subprocess...
2017.04.07 08:10:03 4 : SONOS0: Got correct Answer from Subprocess...
2017.04.07 08:10:13 4 : SONOS0: Got correct Answer from Subprocess...
2017.04.07 08:10:23 4 : SONOS0: Got correct Answer from Subprocess...
2017.04.07 08:10:33 4 : SONOS0: Got correct Answer from Subprocess...
2017.04.07 08:10:43 4 : SONOS0: Got correct Answer from Subprocess...
2017.04.07 08:10:53 4 : SONOS0: Got correct Answer from Subprocess...
2017.04.07 08:11:03 4 : SONOS0: Got correct Answer from Subprocess...
2017.04.07 08:11:13 4 : SONOS0: Got correct Answer from Subprocess...
2017.04.07 08:11:23 4 : SONOS0: Got correct Answer from Subprocess...
2017.04.07 08:11:33 4 : SONOS0: Got correct Answer from Subprocess...
2017.04.07 08:11:43 4 : SONOS0: Got correct Answer from Subprocess...
2017.04.07 08:11:53 4 : SONOS0: Got correct Answer from Subprocess...
2017.04.07 08:12:03 4 : SONOS0: Got correct Answer from Subprocess...
Gruß, Sascha
aus alter Zeit:
Reinerlein
Hallo Sascha,
für mich sieht das danach aus, als würde da ein Nicht-Sonos-Player auf die UPnP-Broadcastanfrage reagieren, und sich dann auch noch mit einem ungültigen bzw. nicht vollständigen Beschreibungsdokument melden.
Leider sieht man deswegen nicht, von welcher IP-Adresse es kommt.
Als ersten Lösungsansatz, um das Problem erstmal loszuwerden, bietet sich bei dir das Attribut "usedonlyIPs" am Sonos-Device an.
Dort schreibst du einfach die IP Adresse deines Players rein, und dann schau mal, ob der Prozess immer noch unerwartet beendet wird...
Und, ja, diese Ausgaben sind auf Level 4 Normal. Es ist der Heartbeat zwischen Fhem und SubProzess...
Reiner
Cybers
Danke erstmal. Werde es testen.
Kannst du mir folgendes erklären:
2017.04.07 08:18:48 1: localhost:4711 reappeared (Sonos)
2017.04.07 08:18:47 1: SONOS0: ./FHEM/00_SONOS.pm is listening to Port 4711
2017.04.07 08:18:17 0: SONOS0: Retries left (wait 30s): 8
2017.04.07 08:18:17 0: SONOS0: Can't bind Port 4711: Bind failed: Address already in use at ./FHEM/00_SONOS.pm line 9071.
2017.04.07 08:18:00 1: OWX: 1-Wire devices found on bus OneWire_Master (Temp_EG_Kueche,Temp_EG_Terrassentuer,Temp_OG_Schlafzimmer,Temp_EG_Wohnzimmer,Temp_OG_Bad,Temp_EG_Flur,Temp_OG_Flur,Temp_EG_Arbeitszimmer,Temp_OG_KinderzimmerMiko)
2017.04.07 08:17:47 0: SONOS0: Retries left (wait 30s): 9
2017.04.07 08:17:47 0: SONOS0: Can't bind Port 4711: Bind failed: Address already in use at ./FHEM/00_SONOS.pm line 9071.
2017.04.07 08:17:44 1: SONOS0: Kein UPnP-Server gefunden... Starte selber einen und warte 4 Sekunde(n) darauf...
Das habe ich nach einem Neustart von Fhem in meinem Log.
Gruß, Sascha
aus alter Zeit:
Reinerlein
Hallo Sascha,
wenn man Prozesse tötet (oder auch normal beenden läßt) liegt es am Betriebssystem die verwendeten Ressourcen wieder freizugeben.
Zu diesen verwendeten Ressourcen gehören auch Netzwerkressourcen wie Ports. Das bedeutet, dass man manchmal nicht direkt nach dem Beenden eines Prozesses den Port wiederverwenden darf (bzw. kann). Es gibt dabei auch keine zugesicherte Zeit. Irgendwann wird diese belegte Ressource vom Betriebssystem wieder freigegeben.
Da der SubProzess aber auffindbar sein muss (also als Server fungiert), wird ihm beim Starten mitgegeben, welchen Port er verwenden muss. Wenn dieser Port noch nicht wieder freigegeben wurde, kann er nicht verwendet werden. Damit das nicht sofort zu einem Abbruch führt, habe ich mehrere Versuche eingebaut, die nach jeweils 30 Sekunden gemacht werden.
Erst wenn alle diese Versuche fehlschlagen, wird der Prozess mit einer Fehlermeldung beendet werden.
Das wird entsprechend auch im Log vermerkt...
Reiner
Wichtel
Ich habe nun endlich mal meine Sonos-Problemchen sortiert.
Das schlimmste war dass sich der Subprozess nicht beenden konnte.
Selbst beim shutdown Restart des einwandfrei laufenden fhem blieb der Subprozess immer übrig, und konnte sich natürlich erst recht nicht selbst Neustarten.
Nach Update des perl 5.16.0 auf 5.24.1 (auf OS X 10.11.6 auf Mac mini Anfang 2009) klappt das jetzt.
Weiter beschwerte der Restore-Thread sich beharrlich über Error creating SSDP multicast listen socket: Address already in use und schmierte grundsätzlich gleich wieder ab.
Dieser Beitrag hier:
https://github.com/openframeworks/openFrameworks/issues/2937
brachte mich zu folgender Änderung an der fhem/FHEM/lib/UPnP/ControlPoint.pm(Ausschnitt ab Zeile 80 der aktuellen Version 13971):
# Create the socket on which we'll listen for SSDP Notifications.
$self->{_ssdpMulticastSocket} = IO::Socket::INET->new(
Proto => 'udp',
Reuse => 1,
ReusePort => 1,
LocalPort => SSDP_PORT) ||
Und jetzt flutscht es, durch den restore-thread natürlich auch jetzt erst die Sprachausgaben als Temporärwiedergabe.
Vielleicht hilft das auch in anderen Situationen, klingt nach so einem "hilft-immer-Parameter". :)
