Fehler beim Start von gassistant und alexa - FHEM stürzt nach einigen Minuten ab
Begonnen von dlehmann69, 09 Juni 2019, 21:10:19
dlehmann69
ich habe heute mein FHEM aktualisiert. Seit dem habe ich für gassistant und alexa folgende Fehler im Log. Bis zum Update liefen beide Assistenten fehlerfrei. Ich habe die Logs so engestellt, das die neueste Zeile oben steht, also bitte nicht wundern.
at Function.Module._load (module.js:497:3
at tryModuleLoad (module.js:505:12)
at Module.load (module.js:565:32)
at Object.Module._extensions..js (module.js:663:10)
at Module._compile (module.js:652:30)
at Object.<anonymous> (/usr/local/lib/node_modules/gassistant-fhem/lib/cli.js:16:18)
at getModule (/usr/local/lib/node_modules/gassistant-fhem/lib/cli.js:10:13)
at request (/usr/local/lib/node_modules/gassistant-fhem/node_modules/sync-request/lib/index.js:28:15)
at /usr/local/lib/node_modules/gassistant-fhem/node_modules/sync-rpc/lib/index.js:159:12
at extractValue (/usr/local/lib/node_modules/gassistant-fhem/node_modules/sync-rpc/lib/index.js:149:19)
Error: getaddrinfo EAI_AGAIN fhem-ga-connector.firebaseapp.com:443
[9.6.2019, 20:34:47] [FHEM] got: 8 results
*** FHEM: connected
[9.6.2019, 20:34:47] *** SSH: proxy configuration failed: Reverse Proxy replied with neither registered nor unregistered status: out:  err:ssh: Could not resolve hostname fhem-va.fhem.de: Temporary failure in name resolution
[9.6.2019, 20:34:47] sshautoconf: aborted with Reverse Proxy replied with neither registered nor unregistered status: out:  err:ssh: Could not resolve hostname fhem-va.fhem.de: Temporary failure in name resolution
[9.6.2019, 20:34:47] sshautoconf: SSH key seems to exist
[9.6.2019, 20:34:47] Passed config: {"connections":[{"filter":"alexaName=..*","name":"FHEM","uid":999,"port":"8083","server":"127.0.0.1","webname":"fhem"}],"sshproxy":{"description":"FHEM Connector","ssh":"/usr/bin/ssh","options":["-i","/opt/fhem/.ssh/id_rsa","-p",58824,"fhem-va.fhem.de"],"bind-ip":"127.0.0.1","port":44573}}
[9.6.2019, 20:34:47] sshautoconf: home=/opt/fhem, spath=/opt/fhem/.alexa, cpath=./alexa-fhem.cfg, sshpath=/opt/fhem/.ssh
[9.6.2019, 20:34:47] *** SSH: checking proxy configuration
[9.6.2019, 20:34:47] Server listening on: http://127.0.0.1:44573 for proxy connections
Habt ihr eine Idee, wo ich suchen kann?
FHEM stürzt zwar auch ab, das sieht aber laut CPU Auslastung nach einem mysql Problem aus. Erst als ich FHEM gekillt habe (auf einen normalen Stop des Dienstes reagierte FHEM nicht), ging die Auslastung der CPU runter.
FHEM 6.0 Development auf Ubuntu 20.04 GIGABYTE GB-BACE mit Intel(R) Celeron(R) CPU N3150
CUL 3.4 FW 1.53 868 MHz für FS20, FHT
CUL 3.4 FW 1.66 868 MHz für HM
configDB; DbLog
FHT80, FS20, HMS, EM1000WZ, FHTTF, HM-LC-Sw1-DR; Lightify; HM-CC-RT-DN; HM-TC-IT-WM-W-EU; HM-SEC-SCO
Problem #1 wird laut Meldung von einem Netzwer/Google-Firebase Problem verursacht (hatte Google nicht neutlich Serverprobleme?)
Problem #2 kann man mit "perl fhem.pl -d fhem.cfg" in der Konsole eingrenzen.
CoolTux
Eventuell ein generelles Problem bei Dir mit der Namensauflösung?
Kannst Du das bitte einmal testen?
Das TuxNet Wiki:
https://www.cooltux.net
dlehmann69
Danke Jungs.
Der Tipp von CoolTux war es. Ich hatte an den DNS Einstellungen des Servers etwas geändert. Nach dem Neustart des Servers haben die komplett gegriffen. Damit hatte der Server keinen Zugriff mehr auf das Internet. Läuft jetzt nach Anpassungen an den DNS Einstellungen wieder.
Das der Fehler aber dazu führt, das FHEM 100% CPU Last braucht, hätte ich nicht gedacht.
Danke noch mal für die Tipps.
configDB; DbLog
