[FUIP] Meldungen währen Update. Normal?
Begonnen von SouzA, 16 Juni 2019, 12:01:12
SouzA
heite habe ich mal wieder ein Update von fhem durchgeführt.
Hier wird auch das Update für FUIP mit gemacht.
Folgende Meldungen waren danach im Log:
2019.06.16 11:52:38 1 : New entries in the CHANGED file:
2019.06.16 11:52:38 1 : -
2019.06.16 11:52:38 1 : - See https://github.com/ThorstenPferdekaemper/FHEM-FUIP
2019.06.16 11:52:38 1 : - for the change history of FUIP.
2019.06.16 11:52:38 1 : Calling /usr/bin/perl ./contrib/commandref_join.pl -noWarnings, this may take a while
2019.06.16 11:53:50 1 : *** EN FHEM/42_FUIP.pm: No document text found
2019.06.16 11:53:50 1 : *** EN FHEM/52_I2C_GY30_BH1750FVI.pm: =end html: there are too many
2019.06.16 11:53:50 1 : *** EN FHEM/52_I2C_HDC1008.pm: =end html: there are too many
2019.06.16 11:53:50 1 : *** EN FHEM/46_PW_Circle.pm: =end html: there are too many
2019.06.16 11:53:50 1 : *** EN FHEM/46_PW_Scan.pm: =end html: there are too many
2019.06.16 11:53:50 1 : *** EN FHEM/46_PW_Sense.pm: =end html: there are too many
2019.06.16 11:53:50 1 : *** EN FHEM/46_PW_Switch.pm: =end html: there are too many
2019.06.16 11:53:50 1 : *** EN FHEM/45_Plugwise.pm: =end html: there are too many
2019.06.16 11:53:50 1 : *** EN FHEM/72_TA_CMI_JSON.pm: =end html: there are too many
2019.06.16 11:53:50 1 : *** EN FHEM/10_UNIRoll.pm: =end html: missing
2019.06.16 11:53:50 1 : *** DE FHEM/52_I2C_GY30_BH1750FVI.pm: =end html_DE: missing
2019.06.16 11:53:50 1 : *** DE FHEM/52_I2C_HDC1008.pm: =end html_DE: missing
2019.06.16 11:53:50 1 : *** DE FHEM/45_Plugwise.pm: =end html_DE: missing
2019.06.16 11:53:50 1 : *** DE FHEM/44_S7_AWrite.pm: =end html_DE: missing
2019.06.16 11:53:50 1 : *** DE FHEM/72_TA_CMI_JSON.pm: =end html_DE: missing
2019.06.16 11:53:50 1 : update finished, "shutdown restart" is needed to activate the changes.
Prinzipiell liest sich das für mich wie Fehlermeldungen...
Was ist passiert?
Das ui funktioniert noch.
Thx & bis denn
SouzA
Raspi 4, EnOcean TCM310 USB, HM-MOD-UART-USB, Jeelink, hue, AMAD, fully, FRITZBOX, Signalbot, VIERA, Presence BT/Mac, TPLink, Gassistant, Shelly, fhempy, ZigBee
DasQ
Fhem in Proxmox on MacMini
Absoluter Befürworter der Konsequenten-Kleinschreibung https://de.wikipedia.org/wiki/Kleinschreibung
Infos zu Klimawandel http://www.globalcarbonatlas.org
SouzA
Danke für den Link. Ich glaube, die reden über diese Meldungen.
Was die da reden erschließt sich mir nicht...
Aus dem jetzigen letzten Post entnehme ich, dass die Meldungen eher kosmetischer Natur sind. Denke ich...  :o
Bis denn
SouzA
Thorsten Pferdekaemper
von FUIP sind da nur zwei Einträge:
Das ist so gemeint, wie es dasteht. Vielleicht könnte ich noch einen Verweis auf die FUIP-News dazumachen.
Das stimmt auch: Es gibt keine Doku im Modul. Es funktioniert aber auch ohne Doku.
   Thorsten
FUIP
