X10 turns lamp "misterious" on
Begonnen von Pret, 14 Januar 2013, 20:34:05
Pret
Dear all,
I've installed Fhem (5.3.deb 2012-10-28) and use a CM11 device to control my X10 lamp modules (A1 to A6). Everything seems to work perfect, except 1 thing: in the middle of the night lamp A4 turns on!
I have checked and double check all the timers, nothing wrong there. In the log files I found two X10 commands that seem to appear out of nothing (one around 03:01 and the other around 03:13) and this is also the moment that lamp A4 turns on. See the relevant lines of two recent days. The "mysterious" command seems to include "X10:A;3" however it is indeed A4 that is switched on!
Can somebody help me with:
1)   Why and how is command is executed?
2)   Why A4 is turned on?
3)   How to stop it?
Thx! Pret
#################### FIRST DAY #####################################
2013.01.12 03:01:19 5: CM11 device myCM11: read   1: 5b
2013.01.12 03:01:19 5: CM11 device myCM11: Data: 5b80245b
2013.01.12 03:01:19 5: CM11 device myCM11: read   2: 801f
2013.01.12 03:01:19 5: CM11 device myCM11: Data: 5b80245b801f
2013.01.12 03:13:35 5: CM11 device myCM11: read   1: 5a
2013.01.12 03:13:35 5: CM11 device myCM11: Data: 5b80245b801f5a
2013.01.12 03:13:35 5: CM11 device myCM11: start of message
2013.01.12 03:13:35 5: CM11 device myCM11: write  1: c3
2013.01.12 03:13:37 5: CM11 device myCM11: read   1: 5a
2013.01.12 03:13:37 5: CM11 device myCM11: Data: 5a
2013.01.12 03:13:37 5: CM11 device myCM11: start of message
2013.01.12 03:13:37 5: CM11 device myCM11: write  1: c3
2013.01.12 03:13:37 5: CM11 device myCM11: read   1: 03
2013.01.12 03:13:37 5: CM11 device myCM11: Data: 03
2013.01.12 03:13:37 5: CM11 device myCM11: Data: 0303
2013.01.12 03:13:37 5: CM11 device myCM11: read   2: 696e
2013.01.12 03:13:37 5: CM11 device myCM11: Data: 0303696e
2013.01.12 03:13:37 5: CM11 device myCM11: message complete (length 2, mask 00000011, data 696e)
2013.01.12 03:13:37 5: CM11 device myCM11: A_FUNC: HAIL_ACK
2013.01.12 03:13:37 5: myCM11 dispatch X10:A;3;HAIL_ACK
2013.01.12 03:13:37 5: Triggering myCM11 (1 changes)
2013.01.12 03:13:37 5: myCM11 trigger: Checking Logfile for notify
2013.01.12 03:13:37 5: myCM11 trigger: Checking WEB for notify
2013.01.12 03:13:37 5: myCM11 trigger: Checking WEBphone for notify
2013.01.12 03:13:37 5: myCM11 trigger: Checking WEBtablet for notify
2013.01.12 03:13:37 5: myCM11 trigger: Checking autocreate for notify
2013.01.12 03:13:37 5: myCM11 trigger: Checking initialUsbCheck for notify
2013.01.12 03:13:37 5: myCM11 trigger: Checking telnetPort for notify
2013.01.12 03:13:37 3: myCM11: Unknown code X10:A;3;HAIL_ACK, help me!
2013.01.12 03:13:37 5: CM11 device myCM11: A_FUNC: STATUS_OFF
2013.01.12 03:13:37 5: myCM11 dispatch X10:A;3;STATUS_OFF
2013.01.12 03:13:37 3: myCM11: Unknown code X10:A;3;STATUS_OFF, help me!
#################### NEXT DAY #####################################
2013.01.13 03:01:25 5: CM11 device myCM11: read   1: 5b
2013.01.13 03:01:25 5: CM11 device myCM11: Data: 5b
2013.01.13 03:01:25 5: CM11 device myCM11: read   2: 801f
2013.01.13 03:01:25 5: CM11 device myCM11: Data: 5b801f
2013.01.13 03:13:41 5: CM11 device myCM11: read   1: 5a
2013.01.13 03:13:41 5: CM11 device myCM11: Data: 5b801f5a
2013.01.13 03:13:41 5: CM11 device myCM11: start of message
2013.01.13 03:13:41 5: CM11 device myCM11: write  1: c3
2013.01.13 03:13:41 5: CM11 device myCM11: read   1: 02
2013.01.13 03:13:41 5: CM11 device myCM11: Data: 02
2013.01.13 03:13:41 5: CM11 device myCM11: read   1: 01
2013.01.13 03:13:41 5: CM11 device myCM11: Data: 0201
2013.01.13 03:13:41 5: CM11 device myCM11: read   1: 69
2013.01.13 03:13:41 5: CM11 device myCM11: Data: 020169
2013.01.13 03:13:41 5: CM11 device myCM11: message complete (length 1, mask 00000001, data 69)
2013.01.13 03:13:41 5: CM11 device myCM11: A_FUNC: HAIL_ACK
2013.01.13 03:13:41 5: myCM11 dispatch X10:A;;HAIL_ACK
2013.01.13 03:13:41 3: X10 No unit selected for housecode A, command HAIL_ACK
2013.01.13 03:13:41 5: Triggering global (1 changes)
2013.01.13 03:13:41 5: global trigger: Checking Logfile for notify
2013.01.13 03:13:41 5: global trigger: Checking WEB for notify
2013.01.13 03:13:41 5: global trigger: Checking WEBphone for notify
2013.01.13 03:13:41 5: global trigger: Checking WEBtablet for notify
2013.01.13 03:13:41 5: global trigger: Checking autocreate for notify
2013.01.13 03:13:41 2: autocreate: define X10_A X10 lm15 A ?
2013.01.13 03:13:41 1: define: Define X10_A: wrong unitcode format: specify a value from 1 to 16
2013.01.13 03:13:41 1: ERROR: Define X10_A: wrong unitcode format: specify a value from 1 to 16
2013.01.13 03:13:41 5: global trigger: Checking initialUsbCheck for notify
2013.01.13 03:13:41 5: global trigger: Checking telnetPort for notify
2013.01.13 03:13:42 5: CM11 device myCM11: read   1: 5a
2013.01.13 03:13:42 5: CM11 device myCM11: Data: 5a
2013.01.13 03:13:42 5: CM11 device myCM11: start of message
2013.01.13 03:13:42 5: CM11 device myCM11: write  1: c3
2013.01.13 03:13:42 5: CM11 device myCM11: read   1: 02
2013.01.13 03:13:42 5: CM11 device myCM11: Data: 02
2013.01.13 03:13:42 5: CM11 device myCM11: read   1: 01
2013.01.13 03:13:42 5: CM11 device myCM11: Data: 0201
2013.01.13 03:13:42 5: CM11 device myCM11: read   1: 6e
2013.01.13 03:13:42 5: CM11 device myCM11: Data: 02016e
2013.01.13 03:13:42 5: CM11 device myCM11: message complete (length 1, mask 00000001, data 6e)
2013.01.13 03:13:42 5: CM11 device myCM11: A_FUNC: STATUS_OFF
2013.01.13 03:13:42 5: myCM11 dispatch X10:A;;STATUS_OFF
2013.01.13 03:13:42 3: X10 No unit selected for housecode A, command STATUS_OFF
2013.01.13 03:13:42 5: Triggering global (1 changes)
2013.01.13 03:13:42 5: global trigger: Checking Logfile for notify
2013.01.13 03:13:42 5: global trigger: Checking WEB for notify
2013.01.13 03:13:42 5: global trigger: Checking WEBphone for notify
2013.01.13 03:13:42 5: global trigger: Checking WEBtablet for notify
2013.01.13 03:13:42 5: global trigger: Checking autocreate for notify
2013.01.13 03:13:42 2: autocreate: define X10_A X10 lm15 A ?
2013.01.13 03:13:42 1: define: Define X10_A: wrong unitcode format: specify a value from 1 to 16
2013.01.13 03:13:42 1: ERROR: Define X10_A: wrong unitcode format: specify a value from 1 to 16
2013.01.13 03:13:42 5: global trigger: Checking initialUsbCheck for notify
2013.01.13 03:13:42 5: global trigger: Checking telnetPort for notify
Pret
3)   How to stop it?
Thx! Pret
WiKa
Hello Pret,
maybe someone else in your neigbourhood uses the same code.
Shutdown your FHEM several days at 1:00 and have a look on your lamp.
If it swiches on - change your X10-code.
WiKa
FB7390 FW:FRITZ!OS 05.50 / RFXTRX433 FW:433_64 / ELRO AB440R (modified to IT-Code) - AB440S (IT-Code) - AB440IS (IT-Code) / Oregon THGN132N - THN132N - THGR122N / Intertechno PAR-1000 - PAR1500
