Autor Thema: Home Connect: Perl Warnungen beim Start  (Gelesen 3641 mal)
Offline Schlimbo
  • Sr. Member
« am: 11 August 2019, 02:37:28 »
Hallo Stefan,
beim Start von FHEM bekomme ich folgende Log Einträge:
2019.08.11 02:07:57.589 1: PERL WARNING: Unescaped left brace in regex is deprecated here (and will be fatal in Perl 5.30), passed through in regex; marked by <-- HERE in m/^{ <-- HERE .*}$/ at ./FHEM/48_HomeConnectConnection.pm line 189, <$fh> line 3801.
2019.08.11 02:07:57.589 1: stacktrace:
2019.08.11 02:07:57.589 1:     main::__ANON__                      called by ./FHEM/48_HomeConnectConnection.pm (189)
2019.08.11 02:07:57.589 1:     (eval)                              called by fhem.pl (2605)
2019.08.11 02:07:57.589 1:     (eval)                              called by fhem.pl (2604)
2019.08.11 02:07:57.589 1:     main::CommandReload                 called by fhem.pl (1992)
2019.08.11 02:07:57.589 1:     main::LoadModule                    called by fhem.pl (2049)
2019.08.11 02:07:57.589 1:     main::CommandDefine                 called by fhem.pl (1236)
2019.08.11 02:07:57.589 1:     main::AnalyzeCommand                called by fhem.pl (1089)
2019.08.11 02:07:57.589 1:     main::AnalyzeCommandChain           called by fhem.pl (1377)
2019.08.11 02:07:57.589 1:     main::CommandInclude                called by fhem.pl (601)
2019.08.11 02:07:57.589 1: PERL WARNING: Unescaped left brace in regex is deprecated here (and will be fatal in Perl 5.30), passed through in regex; marked by <-- HERE in m/^{ <-- HERE .*}$/ at ./FHEM/48_HomeConnectConnection.pm line 283, <$fh> line 3801.
2019.08.11 02:07:57.589 1:     main::__ANON__                      called by ./FHEM/48_HomeConnectConnection.pm (283)
2019.08.11 02:07:57.590 1:     (eval)                              called by fhem.pl (2605)
2019.08.11 02:07:57.590 1:     (eval)                              called by fhem.pl (2604)
2019.08.11 02:07:57.590 1:     main::CommandReload                 called by fhem.pl (1992)
2019.08.11 02:07:57.590 1:     main::LoadModule                    called by fhem.pl (2049)
2019.08.11 02:07:57.590 1:     main::CommandDefine                 called by fhem.pl (1236)
2019.08.11 02:07:57.590 1:     main::AnalyzeCommand                called by fhem.pl (1089)
2019.08.11 02:07:57.590 1:     main::AnalyzeCommandChain           called by fhem.pl (1377)
2019.08.11 02:07:57.590 1:     main::CommandInclude                called by fhem.pl (601)
2019.08.11 02:07:57 1: FHEM::Meta::__GetUpdatedata: ERROR: Invalid datetime range in FHEM/controls_homeconnect.txt:
  UPD 2018-08-22_11:09:90 31134 FHEM/48_HomeConnect.pm
Könntest du dir das bitte mal anschauen?
Offline hoppel118
Antw:Home Connect: Perl Warnungen beim Start
« Antwort #1 am: 24 Oktober 2019, 15:54:20 »
die Perl Warnings sehe ich nicht. Aber die folgende Meldung ist übrig geblieben:
2019.10.24 15:47:17 1: FHEM::Meta::__GetUpdatedata: ERROR: Invalid datetime range in FHEM/controls_homeconnect.txt:
Was hat es damit auf sich?
Danke und Gruß Hoppel
Server: Openmediavault, XEON E3-1240L-v5, Supermicro X11SSH-CTF, 64GB ECC RAM, SSD, RAID-Z2
Homebridge | Alexa | Yowsup
Homematic: VCCU 2xHMUSB, 1xWLGW | HomeConnect | Philips Hue | Sonos | Unifi: UDM-Pro, USW, U6-Pro | Xiaomi: S50, Smart Fan | vbus: Vitosolic 200SD4 | MQTT: Worx, Fröling
Offline weini
  • Full Member
« Antwort #2 am: 19 Februar 2020, 19:22:25 »
Habe die Meldung bei mir auch.
Habt ihr die irgendwie wegbekommen?
Offline hoppel118
« Antwort #3 am: 19 Februar 2020, 19:54:07 »
Habe gerade nicht das Gefühl, dass das Modul noch weiterentwickelt wird. Zumindest reagiert hier kein Entwickler. Aber grundsätzlich funktioniert ja auch alles. ;) Die Meldung ist bei mir noch vorhanden. Spüre dadurch aber keine Einschränkungen.
Gruß Hoppel
Offline swhome
  • Moderator
  • Full Member
« Antwort #4 am: 03 März 2020, 19:16:56 »
Hallo, ich muss mich vielmals entschuldigen... habe keine Ahnung wie ich das Problem seit August übersehen konnte!
Auch wenn gerade nichts neues dazukommt so soll das bestehende eigentlich schon gepflegt werden. Bitte schreibt mir notfalls eine PN wenn ich wieder mal was übersehen sollte. Habe das Problem nun hoffentlich behoben.
Im Einsatz: FHEM auf Raspberry Pi mit 350 devices, hauptsächlich Homematic Wired und HM-Heizungsregler, dazu diverse Eigenbauten für Fussbodenheizung und LED Beleuchtung. Und jetzt mit Alexa!
