Sonoff RF-Bridge Mosquitto und FHEM [gelöst]
Begonnen von eisi, 21 August 2019, 17:44:34
eisi
#15
Da es jetzt schneller ist, gehe ich mal davon aus, dass das "delete myDbLog" geholfen hat.
m2s_192.168.0.70_1627                    MQTT2_SERVER_Read                      143       19     962.23    50.64     0.00     0.00 31.08. 11:35:41 HASH(m2s_192.168.0.70_1627)
m2s_192.168.0.52_10073                   MQTT2_SERVER_Read                       57       47     557.00    11.85     0.00     0.00 31.08. 11:32:56 HASH(m2s_192.168.0.52_10073)
m2s_192.168.0.55_25115                   MQTT2_SERVER_Read                       64       30     501.73    16.72     0.00     0.00 31.08. 11:35:30 HASH(m2s_192.168.0.55_25115)
WEB_192.168.0.1_61566                    FW_Read                                333        7     465.25    66.46     0.00     0.00 31.08. 11:35:32 HASH(WEB_192.168.0.1_61566)
m2s_192.168.0.71_3053                    MQTT2_SERVER_Read                      114       19     435.56    22.92     0.00     0.00 31.08. 11:32:10 HASH(m2s_192.168.0.71_3053)
telnetPort                               telnet_Read                              7       83     401.87     4.84     0.00     0.00 31.08. 11:32:38 HASH(telnetPort)
nice-__ANON__        19       32     352.62    11.02     1.72     0.45 31.08. 11:32:52 (undef)
MQTT2_Wlan_Bridge_01_notify_1            notify_Exec                             62        9     340.77    37.86     0.00     0.00 31.08. 11:33:14 HASH(MQTT2_Wlan_Bridge_01_notify_1); HASH(MQTT2_Wlan_Bridge_01)
Motion_Detect_1                          dummy_Set                               58       10     313.76    31.38     0.00     0.00 31.08. 11:33:14 HASH(Motion_Detect_1); Motion_Detect_1; motion
tmr-CUL_MAX_SendQueueHandler             HASH(0x38db598)                         36       65     259.91     4.00    68.00     4.07 31.08. 11:33:29 HASH(CULMAX0)
cul_oben                                 CUL_Get                                 80       10     250.42    25.04     0.00     0.00 31.08. 11:32:47 HASH(cul_oben); cul_oben; credit10ms
Motion_light                             dummy_Set                              108        7     243.25    34.75     0.00     0.00 31.08. 11:33:11 HASH(Motion_light); Motion_light; off
Motion_Detect_1_notify_1                 notify_Exec                             42        8     204.33    25.54     0.00     0.00 31.08. 11:33:14 HASH(Motion_Detect_1_notify_1); HASH(Motion_Detect_1)
Kodi.WoZi                                XBMC_Read                               47        7     171.93    24.56     0.00     0.00 31.08. 11:32:56 HASH(Kodi.WoZi)
m2s_192.168.0.53_1493                    MQTT2_SERVER_Read                       69       11     127.59    11.60     0.00     0.00 31.08. 11:35:27 HASH(m2s_192.168.0.53_1493)
m2s_192.168.0.63_18027                   MQTT2_SERVER_Read                      113       21     123.16     5.86     0.00     0.00 31.08. 11:32:21 HASH(m2s_192.168.0.63_18027)
3 x Rasp mit fhem 5.8 | 1 Rasp mit Kodi |1x Cube | 15 x MaxLan Thermostate und 18 Fensterschalter | 30 WLAN Schalter Sonoff | Diverse Sensoren mit Arduino | Tablet mit FTUI 2.6
Für die Verzögerung dürfte das Löschen des DBLog-Eventhandlers (.... ;) ) wohl geholfen haben, aber hast du dann noch die erforderlichen Infos für Plots?
Wenn du das je wieder in Betrieb nehmen solltest: Nicht alles loggen (die Zahl der verarbeiteten Events klingt danach), und v.a. auf dem Pi darauf achten, dass mehr gepuffert wird, die für die Hardware passende DB-Lösung gewählt ist usw.. Sonst hast du schnell noch weitere Probleme (kaputte SD-Karte, um mal was "willkürliches" zu wählen...).
Was sagt apptime eigentlich jetzt, nachdem es eine gewisse Zeit gelaufen ist? (Vielleicht finden sich noch weitere "Klopper").
(Wenn du die Infos nicht mehr brauchst/laufend weiter aufzeichnen willst, kannst du apptime auf pause setzen oder mußt FHEM neu starten).
eisi
name                                     function                               max    count      total  average   maxDly   avgDly TS Max call     param Max call
m2s_192.168.0.55_25115                   MQTT2_SERVER_Read                       92      969   15566.52    16.06     0.00     0.00 31.08. 13:12:33 HASH(m2s_192.168.0.55_25115)
telnetPort                               telnet_Read                             10     2756   12806.65     4.65     0.00     0.00 31.08. 14:00:00 HASH(telnetPort)
m2s_192.168.0.71_3053                    MQTT2_SERVER_Read                      125      413    7943.68    19.23     0.00     0.00 31.08. 13:41:10 HASH(m2s_192.168.0.71_3053)
Kodi.WoZi                                XBMC_Read                               96      422    6946.76    16.46     0.00     0.00 31.08. 11:36:56 HASH(Kodi.WoZi)
m2s_192.168.0.70_1627                    MQTT2_SERVER_Read                      143      425    6767.19    15.92     0.00     0.00 31.08. 11:35:41 HASH(m2s_192.168.0.70_1627)
m2s_192.168.0.53_1493                    MQTT2_SERVER_Read                      136      387    3880.94    10.03     0.00     0.00 31.08. 11:55:27 HASH(m2s_192.168.0.53_1493)
tmr-Spotify_poll                         HASH(0x3a1b3d0)                        681       33    3566.33   108.07     3.25     2.32 31.08. 12:57:33 HASH(Spotify1)
m2s_192.168.0.60_22737                   MQTT2_SERVER_Read                       93      387    3557.38     9.19     0.00     0.00 31.08. 14:10:15 HASH(m2s_192.168.0.60_22737)
m2s_192.168.0.56_17559                   MQTT2_SERVER_Read                       68      714    3557.10     4.98     0.00     0.00 31.08. 13:33:26 HASH(m2s_192.168.0.56_17559)
m2s_192.168.0.52_10073                   MQTT2_SERVER_Read                       72      733    3320.99     4.53     0.00     0.00 31.08. 14:03:08 HASH(m2s_192.168.0.52_10073)
m2s_192.168.0.58_20190                   MQTT2_SERVER_Read                       75      387    3314.79     8.57     0.00     0.00 31.08. 13:19:58 HASH(m2s_192.168.0.58_20190)
tmr-PRESENCE_StartLocalScan              HASH(0x38e3a00)                         27      153    3306.90    21.61    21.17     3.45 31.08. 13:16:53 HASH(Cam_r)
Da ist nichts mehr großes drin :-)
Danke dir!
Setzt du den Thread dann bitte noch auf [gelöst]?
(1. Beitrag editieren)
