[ERLEDIGT] Alexa-Fhem - FHEM Connector findet keine Geräte nach Skill deaktiv.
Begonnen von hene42, 17 September 2019, 15:54:15
justme1968
wenn das update nicht hilft:
bitte schau mal im log ob die länge der zurück gemeldeten strings begrenzt ist wie es jetzt sein sollte.
hene42
hier wird es gefunden.....
{"endpointId":"CUL_HM_5F96ED04","manufacturerName":"FHEMCUL_HM","modelName":"FHEMHM-CC-RT-DN","version":"<unknown>","friendlyName":"wohnzimmer","description":"n: Heizung_Wohnen_Balkon_Clima, r: 2000_wohnzimmer,9000_heizung,9010_heizung_plot,9972_homematic,googleassistant","actions":[],"capabilities":[{"type":"AlexaInterface","interface":"Alexa.ThermostatController","version":"3","properties":{"supported":[{"name":"targetSetpoint"}],"configuration":{"supportsScheduling":false},"proactivelyReported":false,"retrievable":true}},{"type":"AlexaInterface","interface":"Alexa.TemperatureSensor","version":"3","properties":{"supported":[{"name":"temperature"}],"proactivelyReported":false,"retrievable":true}}],"displayCategories":["THERMOSTAT"],"cookie":{"device":"Heizung_Wohnen_Balkon_Clima","fuuid":"5c84568c-f33f-f879-04d1-884f27e3a35b4c5d"}},
hier wird es nicht gefunden...
{"endpointId":"CUL_HM_5F96ED04","manufacturerName":"FHEMCUL_HM","modelName":"FHEMHM-CC-RT-DN","version":"<unknown>","friendlyName":"wohnzimmer","description":"n: Heizung_Wohnen_Balkon_Clima, r: 2000_wohnzimmer,2010_wohnzimmer_plot,9000_heizung,9010_heizung_plot,9972_homematic,googleassistant","actions":[],"capabilities":[{"type":"AlexaInterface","interface":"Alexa.ThermostatController","version":"3","properties":{"supported":[{"name":"targetSetpoint"}],"configuration":{"supportsScheduling":false},"proactivelyReported":false,"retrievable":true}},{"type":"AlexaInterface","interface":"Alexa.TemperatureSensor","version":"3","properties":{"supported":[{"name":"temperature"}],"proactivelyReported":false,"retrievable":true}}],"displayCategories":["THERMOSTAT"],"cookie":{"device":"Heizung_Wohnen_Balkon_Clima","fuuid":"5c84568c-f33f-f879-04d1-884f27e3a35b4c5d"}},
mfg
Henri
justme1968
arg. war mein fehler. ich hatte die v2 response repariert und die aktuelle v3 nicht.
jetzt sollte es gehen.
ich glaube so langsam könnte man den v2 code mal rausschmeissen.
gvzdus
Deal: Du schmeisst den v2-Code raus, und ich die Kommandozeilen-Unterstützung?  :-*
justme1968
hene42
habe Update auf alexa-fhem@0.5.31 gemacht, alles neu gestartet, immer noch das selbe bei vielen Räumen findet er das Thermostat nicht.
Lösche ich wieder einen raus, wird es sofort gefunden.
mfg
Henri
justme1968
hene42
Kannst du mir bitte sagen was du alles aus dem log benötigst?
Komplett Endpoint oder nur die eine Zeile?
justme1968
die version am anfang und die discovery response reicht. die description in der responded sollte maximal 128 zeichen lang und bei bedarf angeschnitten und mit ... ergänzt sein.
hene42
So, das ganze ist mir ein wenig zu Hoch...
Habe einfach mal gestoppt, log gelöscht, gestartet und gesucht....
hier ist das komplette log wenn er das Thermostat nicht findet.
[2019-9-26 11:10:53] using config from ./alexa-fhem.cfg
*** CONFIG: parsed completely
[2019-9-26 11:10:53] os.homedir()=/opt/fhem
[2019-9-26 11:10:53] this is alexa-fhem 0.5.24
[2019-9-26 11:10:53] connecting to FHEM ...
[2019-9-26 11:10:54] [FHEM] trying longpoll to listen for fhem events
[2019-9-26 11:10:54] [FHEM] starting longpoll: http://127.0.0.1:8083/fhem?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON×tamp=1569489054194
[2019-9-26 11:10:54] [FHEM] got csrfToken: csrf_658904290216912
[2019-9-26 11:10:54] [FHEM] Checking devices and attributes...
[2019-9-26 11:10:54] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7BAttrVal(%22global%22%2C%22userattr%22%2C%22%22)%7D&fwcsrf=csrf_658904290216912&XHR=1
[2019-9-26 11:10:54] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20TYPE%3Dalexa&fwcsrf=csrf_658904290216912&XHR=1
[2019-9-26 11:10:54] [FHEM] waiting for events ...
[2019-9-26 11:10:54] [FHEM] Fetching FHEM devices...
[2019-9-26 11:10:54] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20alexaName=..*&fwcsrf=csrf_658904290216912&XHR=1
[2019-9-26 11:10:54] [FHEM] alexa device is alexa
[2019-9-26 11:10:54] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22alexa-fhem%20version%22%7D%20%3D%20%220.5.24%22%7D%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_658904290216912&XHR=1
[2019-9-26 11:10:54] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bget%20alexa%20proxyToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_658904290216912&XHR=1
[2019-9-26 11:10:54] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Blist%20alexa%20.eventToken%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_658904290216912&XHR=1
[2019-9-26 11:10:54] Server listening on: http://127.0.0.1:45727 for proxy connections
[2019-9-26 11:10:54] *** SSH: checking proxy configuration
[2019-9-26 11:10:54] sshautoconf: home=/opt/fhem, spath=/opt/fhem/.alexa, cpath=./alexa-fhem.cfg, sshpath=/opt/fhem/.ssh
[2019-9-26 11:10:54] Passed config: {"connections":[{"webname":"fhem","server":"127.0.0.1","port":"8083","uid":999,"name":"FHEM","filter":"alexaName=..*"}],"sshproxy":{"description":"FHEM Connector","ssh":"/usr/bin/ssh","options":["-i","/opt/fhem/.ssh/id_rsa","-p",58824,"fhem-va.fhem.de"],"bind-ip":"127.0.0.1","port":45727}}
[2019-9-26 11:10:54] sshautoconf: SSH key seems to exist
[2019-9-26 11:10:55] sshautoconf: Our SSH key is known at the reverse proxy, good!
[2019-9-26 11:10:55] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bjsonlist2%20alexa%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_658904290216912&XHR=1
*** FHEM: connected
[2019-9-26 11:10:55] [FHEM] got: 15 results
[2019-9-26 11:10:55] [FHEM] FL_Bewegungsmelder_AnAus is switch
[2019-9-26 11:10:55] [FHEM] FL_Bewegungsmelder_AnAus has
[2019-9-26 11:10:55] [FHEM]   On [state;on,off]
  2019-09-26 11:10:55 caching: FL_Bewegungsmelder_AnAus-state: on
[2019-9-26 11:10:55] [FHEM] FL_Temperatursensor_1 is thermostat
[2019-9-26 11:10:55] [FHEM] FL_Temperatursensor_1 is NOT a thermostat. set command for target temperature missing:
[2019-9-26 11:10:55] [FHEM] FL_Temperatursensor_1 has
[2019-9-26 11:10:55] [FHEM]   BatteryLevel [battery]
[2019-9-26 11:10:55] [FHEM]   StatusLowBattery [battery]
[2019-9-26 11:10:55] [FHEM]   CurrentTemperature [temperature]
[2019-9-26 11:10:55] [FHEM]   CurrentHeatingCoolingState [undefined]
  2019-09-26 11:10:55 caching: FL_Temperatursensor_1-battery: 85
  2019-09-26 11:10:55 caching: FL_Temperatursensor_1-temperature: 19.19
[2019-9-26 11:10:55] [FHEM] Gosund_001 is switch
[2019-9-26 11:10:55] [FHEM] Gosund_001 has
  2019-09-26 11:10:55 caching: Gosund_001-state: on
[2019-9-26 11:10:55] [FHEM] Heizung_Bad_Clima is thermostat
[2019-9-26 11:10:55] [FHEM] Heizung_Bad_Clima has
[2019-9-26 11:10:55] [FHEM]   TargetTemperature [desired-temp]
[2019-9-26 11:10:55] [FHEM]   Custom Actuation [ValvePosition]
[2019-9-26 11:10:55] [FHEM]   CurrentTemperature [measured-temp]
  2019-09-26 11:10:55 caching: Heizung_Bad_Clima-desired-temp: off
  2019-09-26 11:10:55 caching: Heizung_Bad_Clima-ValvePosition: 0
[2019-9-26 11:10:55] [FHEM]     caching: Custom Actuation: 0 (as number; from '0')
  2019-09-26 11:10:55 caching: Heizung_Bad_Clima-measured-temp: 21.9
[2019-9-26 11:10:55] [FHEM] Heizung_Wohnen_Balkon_Clima is thermostat
[2019-9-26 11:10:55] [FHEM] Heizung_Wohnen_Balkon_Clima has
  2019-09-26 11:10:55 caching: Heizung_Wohnen_Balkon_Clima-desired-temp: off
  2019-09-26 11:10:55 caching: Heizung_Wohnen_Balkon_Clima-ValvePosition: 0
  2019-09-26 11:10:55 caching: Heizung_Wohnen_Balkon_Clima-measured-temp: 20.8
[2019-9-26 11:10:55] [FHEM] HomeMatic_Steckdose is switch
[2019-9-26 11:10:55] [FHEM] HomeMatic_Steckdose has
[2019-9-26 11:10:55] [FHEM]   FirmwareRevision [D-firmware]
  2019-09-26 11:10:55 caching: HomeMatic_Steckdose-D-firmware: 2.6
  2019-09-26 11:10:55 caching: HomeMatic_Steckdose-state: on
[2019-9-26 11:10:55] [FHEM] KI_1_FritzBox_GWLAN is switch
[2019-9-26 11:10:55] [FHEM] KI_1_FritzBox_GWLAN has
  2019-09-26 11:10:55 caching: KI_1_FritzBox_GWLAN-state: off
[2019-9-26 11:10:55] [FHEM] KL_FritzBox_2_GWLAN is switch
[2019-9-26 11:10:55] [FHEM] KL_FritzBox_2_GWLAN has
  2019-09-26 11:10:55 caching: KL_FritzBox_2_GWLAN-state: off
[2019-9-26 11:10:55] [FHEM] KL_Synology_WOL is switch
[2019-9-26 11:10:55] [FHEM] KL_Synology_WOL has
  2019-09-26 11:10:55 caching: KL_Synology_WOL-state: off
[2019-9-26 11:10:55] [FHEM] MQTT2_McLighting01 is light
[2019-9-26 11:10:55] [FHEM] MQTT2_McLighting01 has
[2019-9-26 11:10:55] [FHEM]   Hue [rgb;rgb;0-359]
[2019-9-26 11:10:55] [FHEM]   Saturation [rgb;rgb;0-100]
[2019-9-26 11:10:55] [FHEM]   Brightness [rgb]
  2019-09-26 11:10:55 caching: MQTT2_McLighting01-state: off
[2019-9-26 11:10:55] [FHEM] SD_WS37_TH_1 is thermostat
[2019-9-26 11:10:55] [FHEM] SD_WS37_TH_1 is NOT a thermostat. set command for target temperature missing:
[2019-9-26 11:10:55] [FHEM] SD_WS37_TH_1 has
[2019-9-26 11:10:55] [FHEM]   CurrentRelativeHumidity [humidity]
  2019-09-26 11:10:55 caching: SD_WS37_TH_1-temperature: 18.9
  2019-09-26 11:10:55 caching: SD_WS37_TH_1-humidity: 70
[2019-9-26 11:10:55] [FHEM] SD_WS37_TH_2 is thermometer
[2019-9-26 11:10:55] [FHEM] SD_WS37_TH_2 has
  2019-09-26 11:10:55 caching: SD_WS37_TH_2-temperature: 21.8
  2019-09-26 11:10:55 caching: SD_WS37_TH_2-humidity: 54
[2019-9-26 11:10:55] [FHEM] SZ_Bewegungsmelder is switch
[2019-9-26 11:10:55] [FHEM] SZ_Bewegungsmelder has
  2019-09-26 11:10:55 caching: SZ_Bewegungsmelder-state: off
[2019-9-26 11:10:55] [FHEM] SonOff_001 is switch
[2019-9-26 11:10:55] [FHEM] SonOff_001 has
  2019-09-26 11:10:55 caching: SonOff_001-state: off
[2019-9-26 11:10:55] [FHEM] WZ_FritzBox_GWLAN is switch
[2019-9-26 11:10:55] [FHEM] WZ_FritzBox_GWLAN has
  2019-09-26 11:10:55 caching: WZ_FritzBox_GWLAN-state: off
[2019-9-26 11:10:55] BearerToken '...A8F81' read from alexa
[2019-9-26 11:10:55] 39_alexa.pm is new version: true
[2019-9-26 11:10:55] sshautoconf: completed successfully
[2019-9-26 11:10:55] *** SSH: proxy configuration set up done
[2019-9-26 11:10:55] Reading alexaFHEM.ProxyConnection set to starting;; starting SSH
[2019-9-26 11:10:55] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20starting%3B%3B%20starting%20SSH%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_658904290216912&XHR=1
[2019-9-26 11:10:55] Starting SSH with -R 1234:127.0.0.1:45727 -oServerAliveInterval=90 -i /opt/fhem/.ssh/id_rsa -p 58824 fhem-va.fhem.de
[2019-9-26 11:10:55] [FHEM] got .eventToken
[2019-9-26 11:10:55] refreshing token
[2019-9-26 11:10:55] failed to refresh token: invalid_grant: 'The request has an invalid grant parameter : refresh_token'
[2019-9-26 11:10:56] Reading alexaFHEM.ProxyConnection set to running;; SSH connected
[2019-9-26 11:10:56] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%201%3B%3Bundef%7D%3Bsetreading%20alexa%20alexaFHEM.ProxyConnection%20running%3B%3B%20SSH%20connected%3B%7B%24defs%7Balexa%7D-%3E%7B%22active%22%7D%20%3D%200%3B%3Bundef%7D&fwcsrf=csrf_658904290216912&XHR=1
[2019-9-26 11:10:56] *** SSH: proxy connection established
[2019-9-26 11:10:56] SSH: Welcome at the reverse proxy!  This pseudoshell does not react to any input - do not get irritated.
  2019-09-26 11:11:04 caching: FL_Temperatursensor_1-temperature: 19.05
[2019-9-26 11:11:04] [FHEM]     caching: CurrentTemperature: 19.05 (as number; from '19.05')
[2019-9-26 11:11:05] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.Discovery","name":"Discover","payloadVersion":"3","messageId":"e260aa94-a297-4643-940d-2f1d6853ab46"},"payload":{"scope":{"type":"BearerToken","token":"F511FFF8-0BA33749093A8F81"}}}}
[2019-9-26 11:11:05] found 15 device(s)
[2019-9-26 11:11:05] <<<< [ssh] {"event":{"header":{"namespace":"Alexa.Discovery","name":"Discover.Response","payloadVersion":"3","messageId":"d8e20ac0-5d4a-4306-ae79-687a36d8a4a0"},"payload":{"endpoints":[{"endpointId":"5d628ce8-f33f-f879-6087-c0b8eb80d71a7453","manufacturerName":"FHEMdummy","modelName":"FHEM<unknown>","version":"<unknown>","friendlyName":"bewegung flur","description":"n: FL_Bewegungsmelder_AnAus, r: flur","actions":[],"capabilities":[{"type":"AlexaInterface","interface":"Alexa.PowerController","version":"3","properties":{"supported":[{"name":"powerState"}],"proactivelyReported":false,"retrievable":true}}],"displayCategories":["SWITCH"],"cookie":{"device":"FL_Bewegungsmelder_AnAus","fuuid":"5d628ce8-f33f-f879-6087-c0b8eb80d71a7453"}},{"endpointId":"00:17:88:01:03:28:74:f3-02-0402","manufacturerName":"FHEMHUEDevice","modelName":"FHEM<unknown>","version":"<unknown>","friendlyName":"flur","description":"n: FL_Temperatursensor_1, r: 1000_flur,1010_flur_plot,9960_sensoren,googleassistant","actions":[],"capabilities":[{"type":"AlexaInterface","interface":"Alexa.TemperatureSensor","version":"3","properties":{"supported":[{"name":"temperature"}],"proactivelyReported":false,"retrievable":true}}],"displayCategories":["TEMPERATURE_SENSOR"],"cookie":{"device":"FL_Temperatursensor_1","fuuid":"5c4e123f-f33f-f879-3f42-c9695d78ed211ef2"}},{"endpointId":"5c502d82-f33f-f879-a3a2-4f6f6aaf18899ed0","manufacturerName":"FHEMMQTT2_DEVICE","modelName":"FHEM<unknown>","version":"<unknown>","friendlyName":"ladegeräte","description":"n: Gosund_001, r: googleassistant,8000_keller,8010_keller_plot,9300_schaltsteckdosen,mqtt2_device","actions":[],"capabilities":[{"type":"AlexaInterface","interface":"Alexa.PowerController","version":"3","properties":{"supported":[{"name":"powerState"}],"proactivelyReported":false,"retrievable":true}}],"displayCategories":["SWITCH"],"cookie":{"device":"Gosund_001","fuuid":"5c502d82-f33f-f879-a3a2-4f6f6aaf18899ed0"}},{"endpointId":"CUL_HM_63896704","manufacturerName":"FHEMCUL_HM","modelName":"FHEMHM-CC-RT-DN","version":"<unknown>","friendlyName":"bad","description":"n: Heizung_Bad_Clima, r: 6000_bad,6010_bad_plot,9000_heizung,9010_heizung_plot,9972_homematic,googleassistant","actions":[],"capabilities":[{"type":"AlexaInterface","interface":"Alexa.ThermostatController","version":"3","properties":{"supported":[{"name":"targetSetpoint"}],"configuration":{"supportsScheduling":false},"proactivelyReported":false,"retrievable":true}},{"type":"AlexaInterface","interface":"Alexa.TemperatureSensor","version":"3","properties":{"supported":[{"name":"temperature"}],"proactivelyReported":false,"retrievable":true}}],"displayCategories":["THERMOSTAT"],"cookie":{"device":"Heizung_Bad_Clima","fuuid":"5c845835-f33f-f879-f875-d4b8a8a82b89670d"}},{"endpointId":"CUL_HM_5F96ED04","manufacturerName":"FHEMCUL_HM","modelName":"FHEMHM-CC-RT-DN","version":"<unknown>","friendlyName":"wohnzimmer","description":"n: Heizung_Wohnen_Balkon_Clima, r: 2000_wohnzimmer,2010_wohnzimmer_plot,9000_heizung,9010_heizung_plot,9972_homematic,googleassistant","actions":[],"capabilities":[{"type":"AlexaInterface","interface":"Alexa.ThermostatController","version":"3","properties":{"supported":[{"name":"targetSetpoint"}],"configuration":{"supportsScheduling":false},"proactivelyReported":false,"retrievable":true}},{"type":"AlexaInterface","interface":"Alexa.TemperatureSensor","version":"3","properties":{"supported":[{"name":"temperature"}],"proactivelyReported":false,"retrievable":true}}],"displayCategories":["THERMOSTAT"],"cookie":{"device":"Heizung_Wohnen_Balkon_Clima","fuuid":"5c84568c-f33f-f879-04d1-884f27e3a35b4c5d"}},{"endpointId":"OEQ0817521","manufacturerName":"FHEMCUL_HM","modelName":"FHEMHM-LC-SW1-PL-DN-R1","version":"<unknown>","friendlyName":"notebooksteckdosen","description":"n: HomeMatic_Steckdose, r: 2000_wohnzimmer,9300_schaltsteckdosen,9972_homematic,googleassistant","actions":[],"capabilities":[{"type":"AlexaInterface","interface":"Alexa.PowerController","version":"3","properties":{"supported":[{"name":"powerState"}],"proactivelyReported":false,"retrievable":true}}],"displayCategories":["SWITCH"],"cookie":{"device":"HomeMatic_Steckdose","fuuid":"5c8511ba-f33f-f879-d1e3-8c762881a3ae5f94"}},{"endpointId":"5c52ddd5-f33f-f879-7db9-300770ff3477dd6f","manufacturerName":"FHEMreadingsProxy","modelName":"FHEM<unknown>","version":"<unknown>","friendlyName":"gäste wlan kevin","description":"n: KI_1_FritzBox_GWLAN, r: 4000_kevin_1,9971_fritzbox,googleassistant","actions":[],"capabilities":[{"type":"AlexaInterface","interface":"Alexa.PowerController","version":"3","properties":{"supported":[{"name":"powerState"}],"proactivelyReported":false,"retrievable":true}}],"displayCategories":["SWITCH"],"cookie":{"device":"KI_1_FritzBox_GWLAN","fuuid":"5c52ddd5-f33f-f879-7db9-300770ff3477dd6f"}},{"endpointId":"5c52d697-f33f-f879-7869-da117cb13b49b7b2","manufacturerName":"FHEMreadingsProxy","modelName":"FHEM<unknown>","version":"<unknown>","friendlyName":"gäste wlan keller","description":"n: KL_FritzBox_2_GWLAN, r: 8000_keller,9971_fritzbox,googleassistant","actions":[],"capabilities":[{"type":"AlexaInterface","interface":"Alexa.PowerController","version":"3","properties":{"supported":[{"name":"powerState"}],"proactivelyReported":false,"retrievable":true}}],"displayCategories":["SWITCH"],"cookie":{"device":"KL_FritzBox_2_GWLAN","fuuid":"5c52d697-f33f-f879-7869-da117cb13b49b7b2"}},{"endpointId":"5c4e26a7-f33f-f879-fb17-e005aace1f643f7b","manufacturerName":"FHEMWOL","modelName":"FHEM<unknown>","version":"<unknown>","friendlyName":"server","description":"n: KL_Synology_WOL, r: 8000_keller,8010_keller_plot,googleassistant","actions":[],"capabilities":[{"type":"AlexaInterface","interface":"Alexa.PowerController","version":"3","properties":{"supported":[{"name":"powerState"}],"proactivelyReported":false,"retrievable":true}}],"displayCategories":["SWITCH"],"cookie":{"device":"KL_Synology_WOL","fuuid":"5c4e26a7-f33f-f879-fb17-e005aace1f643f7b"}},{"endpointId":"5d1d8aee-f33f-f879-c5d9-458fc6705f0919c4","manufacturerName":"FHEMMQTT2_DEVICE","modelName":"FHEM<unknown>","version":"<unknown>","friendlyName":"arbeitsplatte","description":"n: MQTT2_McLighting01, r: 7000_küche,9150_mclighting,googleassistant","actions":[],"capabilities":[{"type":"AlexaInterface","interface":"Alexa.BrightnessController","version":"3","properties":{"supported":[{"name":"brightness"}],"proactivelyReported":false,"retrievable":true}},{"type":"AlexaInterface","interface":"Alexa.ColorController","version":"3","properties":{"supported":[{"name":"color"}],"proactivelyReported":false,"retrievable":false}},{"type":"AlexaInterface","interface":"Alexa.PowerController","version":"3","properties":{"supported":[{"name":"powerState"}],"proactivelyReported":false,"retrievable":true}}],"displayCategories":["LIGHT"],"cookie":{"device":"MQTT2_McLighting01","fuuid":"5d1d8aee-f33f-f879-c5d9-458fc6705f0919c4"}},{"endpointId":"5c533aaf-f33f-f879-cae8-be54b1cda56ed9ba","manufacturerName":"FHEMSD_WS","modelName":"FHEM<unknown>","version":"<unknown>","friendlyName":"balkon","description":"n: SD_WS37_TH_1, r: balkon","actions":[],"capabilities":[{"type":"AlexaInterface","interface":"Alexa.TemperatureSensor","version":"3","properties":{"supported":[{"name":"temperature"}],"proactivelyReported":false,"retrievable":true}}],"displayCategories":["TEMPERATURE_SENSOR"],"cookie":{"device":"SD_WS37_TH_1","fuuid":"5c533aaf-f33f-f879-cae8-be54b1cda56ed9ba"}},{"endpointId":"5c533b44-f33f-f879-f677-a4c905ab5e236570","manufacturerName":"FHEMSD_WS","modelName":"FHEM<unknown>","version":"<unknown>","friendlyName":"schlafzimmer","description":"n: SD_WS37_TH_2, r: 3000_schlafzimmer,3010_schlafzimmer_plot,9960_sensoren","actions":[],"capabilities":[{"type":"AlexaInterface","interface":"Alexa.TemperatureSensor","version":"3","properties":{"supported":[{"name":"temperature"}],"proactivelyReported":false,"retrievable":true}}],"displayCategories":["TEMPERATURE_SENSOR"],"cookie":{"device":"SD_WS37_TH_2","fuuid":"5c533b44-f33f-f879-f677-a4c905ab5e236570"}},{"endpointId":"5d4ae259-f33f-f879-ab94-5e0cb84a2af7a78c","manufacturerName":"FHEMdummy","modelName":"FHEM<unknown>","version":"<unknown>","friendlyName":"bewegung schlafzimmer","description":"n: SZ_Bewegungsmelder, r: 3000_schlafzimmer,9905_logik,googleassistant","actions":[],"capabilities":[{"type":"AlexaInterface","interface":"Alexa.PowerController","version":"3","properties":{"supported":[{"name":"powerState"}],"proactivelyReported":false,"retrievable":true}}],"displayCategories":["SWITCH"],"cookie":{"device":"SZ_Bewegungsmelder","fuuid":"5d4ae259-f33f-f879-ab94-5e0cb84a2af7a78c"}},{"endpointId":"5ce81d8e-f33f-f879-2041-1d868824a9649d0d","manufacturerName":"FHEMMQTT2_DEVICE","modelName":"FHEM<unknown>","version":"<unknown>","friendlyName":"kommode","description":"n: SonOff_001, r: 3000_schlafzimmer,3010_schlafzimmer_plot,9300_schaltsteckdosen,googleassistant,mqtt2_device","actions":[],"capabilities":[{"type":"AlexaInterface","interface":"Alexa.PowerController","version":"3","properties":{"supported":[{"name":"powerState"}],"proactivelyReported":false,"retrievable":true}}],"displayCategories":["SWITCH"],"cookie":{"device":"SonOff_001","fuuid":"5ce81d8e-f33f-f879-2041-1d868824a9649d0d"}},{"endpointId":"5c52e298-f33f-f879-38f4-be32717b17c85a3c","manufacturerName":"FHEMreadingsProxy","modelName":"FHEM<unknown>","version":"<unknown>","friendlyName":"gäste wlan wohnzimmer","description":"n: WZ_FritzBox_GWLAN, r: 2000_wohnzimmer,9971_fritzbox,googleassistant","actions":[],"capabilities":[{"type":"AlexaInterface","interface":"Alexa.PowerController","version":"3","properties":{"supported":[{"name":"powerState"}],"proactivelyReported":false,"retrievable":true}}],"displayCategories":["SWITCH"],"cookie":{"device":"WZ_FritzBox_GWLAN","fuuid":"5c52e298-f33f-f879-38f4-be32717b17c85a3c"}}]}}}
EDIT: es get um "Heizung_Wohnen_Balkon_Clima"
justme1968
Zitat[2019-9-26 11:10:53] this is alexa-fhem 0.5.24
das ist die alte version ohne den fix. du solltest per update inzwischen die 0.5.31 bekommen. wenn es per update nicht geht: einfach noch mal drüber installieren. -g nicht vergessen.
hene42
Jetzt ist die Frage was mache ich verkehrt....
Zitatalexa-fhem über FHEM anhalten:
set alexa stop
Auf der Konsole wie anfangs bei der Installation:
sudo npm update -g alexa-fhem
Manchmal hat npm Probleme mit einem Update. Dann einfach die aktuelle Version noch mal drüber Installieren:
sudo npm install -g alexa-fhem
alexa-fhem über FHEM wieder starten:
set alexa start
so gehe ich vor, als Antwort kommt... sieh Bild
und nun? Wo ist jetzt schon wieder mein Fehler....
Danke.
justme1968
vermutlich hast du aus irgend einem grund zwei versionen installiert und fhem findet/verwendet die falsche.
schau mal im fhem log welche fhem genau startet und vergleiche den pfad mit der per update installierten,
hene42
Ja, im Fhemlog steht...
2019.09.26 11:22:16 2: alexa: starting alexa-fhem: /usr/local/bin/alexa-fhem -c ./alexa-fhem.cfg -a xx:xx
2019.09.26 11:22:33 2: alexa: starting alexa-fhem: /usr/local/bin/alexa-fhem -c ./alexa-fhem.cfg -a xx:xx
2019.09.26 11:22:35 2: alexa: starting alexa-fhem: /usr/local/bin/alexa-fhem -c ./alexa-fhem.cfg -a xx:xx
2019.09.26 11:23:03 2: alexa: starting alexa-fhem: /usr/local/bin/alexa-fhem -c ./alexa-fhem.cfg -a xx:xx
2019.09.26 11:23:05 2: alexa: starting alexa-fhem: /usr/local/bin/alexa-fhem -c ./alexa-fhem.cfg -a xx:xx
wie kann ich das ändern? Sorry aber habe da jetzt keinen Plan.
Danke.
gvzdus
Ich würde erst mal löschen:
rm /usr/local/bin/alexa-fhem
Wie Dein Screenshot weiter oben zeigt, wurde die aktuelle Version unter /usr/bin/alexa-fhem verlinkt.
Du hast aber zusätzlich auch noch eine veraltete Node-Version.
