New door lock: ABUS HomeTec Pro CFA3010 Z-Wave S2
Begonnen von TomekWaw, 29 Oktober 2019, 06:00:25
TomekWaw
Turns out that ABUS has released a new version if its HomeTec Pro Lock, now with Z-Wave module.
Here's the press release:
https://www.abus.com/content/download/55801/4818206/file/Press%20release_ABUS_HomeTecPro_Z-Wave.pdf
Seems it's available already for ~190 EUR
https://www.ebay.de/itm/ABUS-HomeTec-Pro-CFA3010-Z-Wave-plus-Turschlossantrieb-Turantrieb-Turschloss/143397550345
I'm not an expert on Z-wave, but it says Z-Wave S2 security.
Would this technically work on Aeotec Z-stick / ZWDongle ?
If yes, would it need a new FHEM module or rather new device definition, that doesn't exist yet?
ZitatWould this technically work on Aeotec Z-stick / ZWDongle ?
As far as I know, yes.
ZitatIf yes, would it need a new FHEM module or rather new device definition, that doesn't exist yet?
S2 does not necessary mean a new FHEM module, but definitely an implementation, and to my knowledge nobody is working on it right now.
If I interpret the document from the Z-Wave alliance correctly, S2 devices have to be backwards compatible with the older version of the security class.
subseven
I bought this Lock,
you have to switch vom S2-Security to S0 as it is described in the manual.
After that it work with Z-Wave. I use the Dongle UZB1
baschtlwaschtl
@rudolfkoenig: is there any plans to implement s2 security into FHEM?
thanks for infos :)
basti
