[73_AutoShuttersControl.pm] Rolllos automatisiert steuern - Version 0.8.x
Begonnen von CoolTux, 15 November 2019, 12:51:08
Kai-Alfonso
Zitat von: CoolTux am 16 November 2019, 14:14:14
Wie genau war die Fehlermeldung mit der 57er
Kannst Du bitte angehängte Version testen
Ich teste mal deine angehängte Version.
Fehler war
2019.11.16 13:55:25.425 1: PERL WARNING: Use of ?PATTERN? without explicit operator is deprecated at ./FHEM/73_AutoShuttersControl.pm line 5223, <$fh> line 1818.
2019.11.16 13:55:25.428 1: PERL WARNING: Scalar found where operator expected at ./FHEM/73_AutoShuttersControl.pm line 5240, near "$val =~ /^\d+(\.\d+)?$/"
2019.11.16 13:55:25.429 1: PERL WARNING:        (Missing operator before $/?)
2019.11.16 13:55:25.431 1: PERL WARNING: "my" variable $self masks earlier declaration in same statement at ./FHEM/73_AutoShuttersControl.pm line 5250, <$fh> line 1818.
2019.11.16 13:55:25.434 1: reload: Error:Modul 73_AutoShuttersControl deactivated:
Global symbol "$val" requires explicit package name at ./FHEM/73_AutoShuttersControl.pm line 5231, <$fh> line 1818.
Global symbol "$val" requires explicit package name at ./FHEM/73_AutoShuttersControl.pm line 5235, <$fh> line 1818.
Global symbol "$val" requires explicit package name at ./FHEM/73_AutoShuttersControl.pm line 5236, <$fh> line 1818.
Global symbol "$val" requires explicit package name at ./FHEM/73_AutoShuttersControl.pm line 5240, <$fh> line 1818.
syntax error at ./FHEM/73_AutoShuttersControl.pm line 5241, near "$val =~ /^\d+(\.\d+)?$/
Global symbol "$val" requires explicit package name at ./FHEM/73_AutoShuttersControl.pm line 5242, <$fh> line 1818.
Global symbol "$self" requires explicit package name at ./FHEM/73_AutoShuttersControl.pm line 5243, <$fh> line 1818.
syntax error at ./FHEM/73_AutoShuttersControl.pm line 5244, near ")"
syntax error at ./FHEM/73_AutoShuttersControl.pm line 5251, near "}"
./FHEM/73_AutoShuttersControl.pm has too many errors.
2019.11.16 13:55:25.435 0: Global symbol "$val" requires explicit package name at ./FHEM/73_AutoShuttersControl.pm line 5231, <$fh> line 1818.
Raspi2|nanoCul433|nanoCul868|CCU2
Energie-USBZähler|homebrew HM Devices
DBLog|DBRep|Homematic|Baumarktsteckdosen
Hue|Webcams mit DS-Station (Synology)|Bewegungsmelder|Rollladen|Schalter (IT|HM)
Kai-Alfonso
die angehängte Version ging v0.8.1
CoolTux
Kannst Du bitte kurz noch die Version aus dem Github testen? Einfach die Develversion nehmen bitte.
Einfach dann hier noch mal melden dann leite ich die 0.8.1 zum SVN
Das TuxNet Wiki:
https://www.cooltux.net
Kai-Alfonso
die aktuellste aus dem Github geht nicht. Grade getestet
CoolTux
ok super. Dann nimm die 0.8.1. Ich schiebe sie auch gleich ins Git und bereite den FHEM Update für morgen vor.
Das TuxNet Wiki:
Kai-Alfonso
ok, dann nehme ich jetzt produktiv die vorhin angehängte. Die ist dann ab morgen im regulären SVN?
Danke für deine Hilfe
CoolTux
Ja ist sie. Habe sie soeben ins SVN kopiert.
Das TuxNet Wiki:
eurofinder
@CoolTux:
ZitatDanke für die Anmerkungen. Das mit den Beispielen ist in der Tat eine gute Idee. Werde ich demnächst machen. Eventuell kommt ja ein User mit einem Patch oder Github pull request zuvor  ;D
In der Tat ist es so das am Abend bei konfigurierter Sleep_Pos diese statt der Closed_Pos angefahren wird.
Das freut mich, dass die Anregung Zuspruch findet:-)
Noch eine Verständnisfrage:
Müssen Positionangaben (z.B.  ASC_Shading_Pos, ASC_PrivacyDown_Pos etc.) alle andere Werte aufweisen, damit ASC einwandfrei funktioniert, oder können diese auch identische Werte aufweisen?
eurofinder
RPI3+; Raspbian Buster Lite; RPI-RF-MOD; piVCCU3, HMIP-eTRV-2, HmIP-SWDO, HmIP-SRH, HmIP-STHO, HmIP-SLO
CoolTux
Zitat von: eurofinder am 16 November 2019, 16:32:50
@CoolTux:Das freut mich, dass die Anregung Zuspruch findet:-)
eurofinder
Es sollten alle unterschiedliche Werte ausweisen damit ASC ohne Probleme läuft.
Das TuxNet Wiki:
eurofinder
@CoolTux:
Ok, war mir auch so:-) Ist vielleicht für die Commandref auch nicht ganz unwichtig.
Gruß und schönes Wochenende
eurofinder
CoolTux
Zitat von: eurofinder am 17 November 2019, 08:52:48
@CoolTux:
eurofinder
Ich will sehen das ich in zukünftige Versionen diesbezüglich eine Prüfung ein baue. Mal schauen.
Das TuxNet Wiki:
hubiuwe
Hallo!
Ich habe ein Problem: Beim morgendlichen Öffnen nach Brigthness  wird der schlafende Roommate nicht beachtet.
Ich schließe abends mein Rollo im Schlafzimmer nur mit der SleepPosition.
Das morgendliche öffnen findet über Brigthness statt.
Allerdings sollte das Rollo nach erreichen der Helligkeit erst hochfahren wenn Roommate aufgestanden ist.
Ich bin der Meinung das hat in der 0.6 mal funktioniert, mit V122 habe ich auf devel gewechselt da ging es auch noch.
Aktuelle ASC Version ist 0.8.1
Zur Zeit dess Öffnens stand Roommate noch auf "asleep" (Testweise natürlich :-))
Mein List:
   DEF        XXXxxxxx
   FUUID      5ce12af4-f33f-e2e1-2c07-daf294fe5cdfeb61
   IODev      TCM_ESP3_0
   NAME       AK_SZ_ROL
   NR         98
   NTFY_ORDER 50-AK_SZ_ROL
   STATE      0
   TYPE       EnOcean
     2019-10-06 10:01:28   ASC_Enable      on
     2019-11-17 07:31:28   ASC_ShuttersLastDrive maximum brightness threshold exceeded
     2019-11-17 12:59:16   ASC_Time_DriveDown 17.11.2019 - 22:00
     2019-11-17 12:59:16   ASC_Time_DriveUp 18.11.2019 - 08:00
     2019-11-17 07:31:27   anglePos        -90
     2019-11-17 12:59:13   associatedWith  Rollosteuerung
     2019-11-16 21:38:08   block           unlock
     2019-11-17 07:31:27   endPosition     open_ack
     2019-11-17 07:31:27   position        0
     2019-11-17 07:31:27   state           open_ack
     2019-05-19 12:08:13   teach           4BS teach-in sent
   ASC        1
   ASC_BrightnessSensor SonnSens
   ASC_Closed_Pos 100
   ASC_ComfortOpen_Pos 45
   ASC_Down   brightness
   ASC_DriveUpMaxDuration 45
   ASC_Mode_Down off
   ASC_Mode_Up always
   ASC_Pos_Reading position
   ASC_Roommate_Device rr_Uwe
   ASC_Self_Defense_Mode off
   ASC_Shading_InOutAzimuth 63:223
   ASC_Shading_MinMax_Elevation 15.0:100.0
   ASC_Shading_Min_OutsideTemperature 15
   ASC_Shading_Mode always
   ASC_Shading_Pos {(ReadingsVal('KS300','temperature',0) >= 29 ? 100 : 70)}
   ASC_Shading_StateChange_SunnyCloudy 25000:12000
   ASC_ShuttersPlace terrace
   ASC_Sleep_Pos 50
   ASC_TempSensor Alpha2:Ist-Temperatur-5
   ASC_Time_Down_Early 17:00
   ASC_Time_Down_Late 22:00
   ASC_Time_Up_Early 05:30
   ASC_Time_Up_Late 08:00
   ASC_Time_Up_WE_Holiday 07:00
   ASC_Up     brightness
   ASC_Ventilate_Pos 60
   ASC_WindowRec DU_Fenster_SZ
   ASC_WindowRec_subType threestate
   DbLogExclude .*
   DbLogInclude .*
   IODev      TCM_ESP3_0
   alias      Rollo Schlafzimmer
   calAtEndpoints yes
   comMode    confirm
   devStateIcon 100:fts_shutter_100 1\d.*:fts_shutter_10 2\d.*:fts_shutter_20 3\d.*:fts_shutter_30 4\d.*:fts_shutter_40 5\d.*:fts_shutter_50 6\d.*:fts_shutter_60 7\d.*:fts_shutter_70 8\d.*:fts_shutter_80 9\d.*:fts_shutter_90 \d.*:fts_shutter_10 open_ack:fts_window_2w closed:fts_shutter_100
   eep        A5-3F-7F
   group      Rollos
   icon       fts_shutter_100
   manufID    00D
   model      Eltako_FSB_ACK
   room       40_Schlafzimmer,90_Devices
   settingAccuracy high
   shutTime   25
   shutTimeCloses 35
   stateFormat position
   subDef     FFB45106
   subType    manufProfile
   userattr   ASC_Adv:on,off ASC_Antifreeze:off,soft,hard,am,pm ASC_Antifreeze_Pos:5,10,15,20,25,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100 ASC_AutoAstroModeEvening:REAL,CIVIL,NAUTIC,ASTRONOMIC,HORIZON ASC_AutoAstroModeEveningHorizon:-9,-8,-7,-6,-5,-4,-3,-2,-1,0,1,2,3,4,5,6,7,8,9 ASC_AutoAstroModeMorning:REAL,CIVIL,NAUTIC,ASTRONOMIC,HORIZON ASC_AutoAstroModeMorningHorizon:-9,-8,-7,-6,-5,-4,-3,-2,-1,0,1,2,3,4,5,6,7,8,9 ASC_BlockingTime_afterManual ASC_BlockingTime_beforDayOpen ASC_BlockingTime_beforNightClose ASC_BrightnessSensor ASC_Closed_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_ComfortOpen_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_Down:time,astro,brightness,roommate ASC_DriveUpMaxDuration ASC_Drive_Delay ASC_Drive_DelayStart ASC_ExternalTrigger ASC_GuestRoom:on,off ASC_LockOut:soft,hard,off ASC_LockOut_Cmd:inhibit,blocked,protection ASC_Mode_Down:absent,always,off,home ASC_Mode_Up:absent,always,off,home ASC_Open_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_Partymode:on,off ASC_Pos_Reading ASC_PrivacyDownValue_beforeNightClose ASC_PrivacyDown_Pos ASC_PrivacyUpValue_beforeDayOpen ASC_PrivacyUp_Pos ASC_RainProtection:on,off ASC_Roommate_Device ASC_Roommate_Reading ASC_Self_Defense_AbsentDelay ASC_Self_Defense_Mode:absent,gone,off ASC_Shading_InOutAzimuth ASC_Shading_MinMax_Elevation ASC_Shading_Min_OutsideTemperature ASC_Shading_Mode:absent,always,off,home ASC_Shading_Pos:10,20,30,40,50,60,70,80,90,100 ASC_Shading_StateChange_SunnyCloudy ASC_Shading_WaitingPeriod ASC_Shutter_IdleDetection ASC_ShuttersPlace:window,terrace ASC_Sleep_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_TempSensor ASC_Time_Down_Early ASC_Time_Down_Late ASC_Time_Up_Early ASC_Time_Up_Late ASC_Time_Up_WE_Holiday ASC_Up:time,astro,brightness,roommate ASC_Ventilate_Pos:10,20,30,40,50,60,70,80,90,100 ASC_Ventilate_Window_Open:on,off ASC_WiggleValue ASC_WindParameters ASC_WindProtection:on,off ASC_WindowRec ASC_WindowRec_PosAfterDayClosed:open,lastManual ASC_WindowRec_subType:twostate,threestate
   webCmd     opens:stop:closes
edit: ich habe ja noch ein debug von heute Morgen:
ASC_DEBUG!!! 2019.11.17 07:30:52 - EventProcessingBrightness: AK_SZ_ROL - Event von einem Helligkeitssensor erkannt. Verarbeitung läuft. Sollten keine weitere Meldungen aus der Funktion kommen, so befindet sich die aktuelle Zeit nicht innerhalb der Verarbeitungszeit für Sunset oder Sunrise
ASC_DEBUG!!! 2019.11.17 07:30:52 - EventProcessingBrightness: AK_SZ_ROL - Die aktuelle Zeit befindet sich innerhalb der Sunset/Sunrise Brightness Verarbeitungszeit. Also zwischen Time Early und Time Late
ASC_DEBUG!!! 2019.11.17 07:30:52 - EventProcessingBrightness: AK_SZ_ROL - Es wird geprüft ob Sunset oder Sunrise gefahren werden soll und der aktuelle übergebene Brightness-Wert: 27 Größer dem eingestellten Sunrise-Wert: 25 oder kleiner dem eingestellten Sunset-Wert: 50 ist. Werte für weitere Parameter - getUp ist: brightness getDown ist: brightness getSunrise ist: 0 getSunset ist: 1
ASC_DEBUG!!! 2019.11.17 07:30:52 - EventProcessingBrightness: AK_SZ_ROL - Verarbeitungszeit für Sunrise wurd erkannt. Prüfe Status der Roommates
ASC_DEBUG!!! 2019.11.17 07:30:52 - FnSetCmdFn: AK_SZ_ROL - Rollo wird gefahren, aktuelle Position: 50, Zielposition: 0. Grund der Fahrt: maximum brightness threshold exceeded
ASC_DEBUG!!! 2019.11.17 07:30:52 - Notify:  ASC_Pos_Reading Event vom Rollo wurde erkannt  - RECEIVED EVENT: [
  'position: 0'
ASC_DEBUG!!! 2019.11.17 07:30:52 - EventProcessingShutters:  Fn wurde durch Notify aufgerufen da ASC_Pos_Reading Event erkannt wurde  - RECEIVED EVENT: 'position: 0'
ASC_DEBUG!!! 2019.11.17 07:30:52 - EventProcessingShutters: AK_SZ_ROL - Event vom Rollo erkannt. Es wird nun eine etwaige manuelle Fahrt ausgewertet. Int von gettimeofday: 1573972252 Last Position Timestamp: 1573972252 Drive Up Max Duration: 45 Last Position: 50 aktuelle Position: 0
ASC_DEBUG!!! 2019.11.17 07:30:52 - EventProcessingShutters: eine automatisierte Fahrt durch ASC wurde erkannt! Es werden nun die LastDriveReading und StateReading Werte gesetzt!
ASC_DEBUG!!! 2019.11.17 07:30:52 - EventProcessingShutters:  Fn wurde durlaufen und es sollten Debugausgaben gekommen sein.  !!!Wenn nicht!!! wurde der Event nicht korrekt als Nummerisch erkannt.
ASC_DEBUG!!! 2019.11.17 07:30:52 - FnSetDriveCmd: AK_SZ_ROL - NICHT versetztes fahren
ASC_DEBUG!!! 2019.11.17 07:30:52 - FnSetDriveCmd: AK_SZ_ROL - NoDelay: NEIN
ASC_DEBUG!!! 2019.11.17 07:30:52 - FnShuttersCommandSet: AK_SZ_ROL - Das Rollo wird gefahren. Kein Partymodus aktiv und das zugordnete Fenster ist entweder nicht offen oder keine Terassentür
ASC_DEBUG!!! 2019.11.17 07:30:52 - EventProcessingBrightness: AK_SZ_ROL - Verarbeitung für Sunrise. Roommatestatus korrekt zum fahren. Fahrbefehl wird an die Funktion FnShuttersCommandSet gesendet. Grund des fahrens: maximum brightness threshold exceeded
Gruß Uwe
Die beste Automatik ist die, die man abschalten kann!
CoolTux
Das TuxNet Wiki:
hubiuwe
Hallo CoolTux
ZitatHast Du SelfDefense aktiv?
Im ASC Device Ja.
   FUUID      5d998c16-f33f-e2e1-02db-975a526970674d10
   FVERSION   73_AutoShuttersControl.pm:v0.8.1-s20518/2019-11-16 UNDER DEVELOP
   MID        da39a3ee5e6b4b0d3255bfef95601890afd80709
   NAME       Rollosteuerung
   NOTIFYDEV  global,Rollosteuerung,AK_BD_ROL,AK_KU_ROL,AK_SZ_ROL,AK_WZ_ROL,rr_Uwe,DU_Fenster_BD,DU_Fenster_WZ,DU_Fenster_SZ,Sonnenstand,SonnSens,rgr_Bewohner
   NR         147
   NTFY_ORDER 51-Rollosteuerung
   STATE      created new drive timer
   TYPE       AutoShuttersControl
   VERSION    v0.8.1
   Helper:
     DBLOG:
       AK_BD_ROL_nextAstroTimeEvent:
         DBLogging:
           TIME       1573991956.14009
           VALUE      17.11.2019 - 22:00
       AK_KU_ROL_nextAstroTimeEvent:
         DBLogging:
           TIME       1573991956.16032
       AK_SZ_ROL_nextAstroTimeEvent:
         DBLogging:
           TIME       1573991956.17919
       AK_WZ_ROL_nextAstroTimeEvent:
         DBLogging:
           TIME       1573991956.19784
       state:
         DBLogging:
           TIME       1573991956.21018
           VALUE      created new drive timer
   OLDREADINGS:
     2019-11-17 07:31:20   AK_BD_ROL_PosValue 0
     2019-11-17 07:30:52   AK_BD_ROL_lastPosValue 100
     2019-11-17 12:59:16   AK_BD_ROL_nextAstroTimeEvent 17.11.2019 - 22:00
     2019-11-17 07:31:18   AK_KU_ROL_PosValue 0
     2019-11-17 07:30:52   AK_KU_ROL_lastPosValue 100
     2019-11-17 12:59:16   AK_KU_ROL_nextAstroTimeEvent 17.11.2019 - 22:00
     2019-11-17 07:31:27   AK_SZ_ROL_PosValue 0
     2019-11-11 22:13:04   AK_SZ_ROL_lastDelayPosValue 60
     2019-11-17 08:01:33   AK_SZ_ROL_lastPosValue 50
     2019-11-17 12:59:16   AK_SZ_ROL_nextAstroTimeEvent 17.11.2019 - 22:00
     2019-11-17 07:31:33   AK_WZ_ROL_PosValue 0
     2019-10-11 18:52:45   AK_WZ_ROL_lastDelayPosValue 10
     2019-11-17 07:30:52   AK_WZ_ROL_lastPosValue 100
     2019-11-17 12:59:16   AK_WZ_ROL_nextAstroTimeEvent 17.11.2019 - 22:00
     2019-10-06 08:39:19   ascEnable       on
     2019-10-06 10:14:43   controlShading  on
     2019-10-06 08:39:19   hardLockOut     off
     2019-11-17 12:59:12   room_10_Wohnzimmer_90_Devices AK_WZ_ROL
     2019-11-17 12:59:12   room_20_Kueche_90_Devices AK_KU_ROL
     2019-11-17 12:59:12   room_30_Bad_90_Devices AK_BD_ROL
     2019-11-17 12:59:12   room_40_Schlafzimmer_90_Devices AK_SZ_ROL
     2019-10-06 10:14:58   selfDefense     on
     2019-11-17 12:59:16   state           created new drive timer
     2019-10-06 10:15:17   sunriseTimeWeHoliday on
     2019-11-17 12:59:12   userAttrList    rolled out
   helper:
     shuttersList:
       AK_BD_ROL
       AK_KU_ROL
       AK_SZ_ROL
       AK_WZ_ROL
   monitoredDevs:
     AK_WZ_ROL:
     DU_Fenster_BD:
       AK_BD_ROL  ASC_WindowRec
     DU_Fenster_SZ:
       AK_SZ_ROL  ASC_WindowRec
     DU_Fenster_WZ:
       AK_WZ_ROL  ASC_WindowRec
     SonnSens:
       AK_BD_ROL  ASC_BrightnessSensor
       AK_KU_ROL  ASC_BrightnessSensor
       AK_SZ_ROL  ASC_BrightnessSensor
       AK_WZ_ROL  ASC_BrightnessSensor
     Sonnenstand:
       Rollosteuerung ASC_twilightDevice
     rgr_Bewohner:
       Rollosteuerung ASC_residentsDev
     rr_Uwe:
       AK_SZ_ROL  ASC_Roommate_Device
   ASC_autoAstroModeEvening CIVIL
   ASC_autoAstroModeMorning CIVIL
   ASC_autoShuttersControlComfort on
   ASC_autoShuttersControlEvening on
   ASC_autoShuttersControlMorning on
   ASC_blockAscDrivesAfterManual 0
   ASC_brightnessDriveUpDown 25:50
   ASC_expert 1
   ASC_residentsDev rgr_Bewohner
   ASC_tempSensor KS300
   ASC_twilightDevice Sonnenstand
   DbLogExclude .*
   DbLogInclude .*
   devStateIcon selfDefense.terrace:fts_door_tilt created.new.drive.timer:clock .*asleep:scene_sleeping roommate.(awoken|home):user_available residents.(home|awoken):status_available manual:fts_shutter_manual selfDefense.active:status_locked selfDefense.inactive:status_open day.open:scene_day night.close:scene_night shading.in:weather_sun shading.out:weather_cloudy
   group      Wohnung
   icon       fts_shutter_automatic
   room       01_Wohnung
Gruß Uwe
CoolTux
Ok dann denke ich habe ich das Problem gefunden.
Interessanter Weise hat es dann aber schon immer so "falsch" funktioniert. Zu mindest mit den letzten 0.6er Versionen.
Das TuxNet Wiki:
