fhem log error: Bad name after default' at (eval 111328) line 1.
Begonnen von riker1, 23 November 2019, 17:40:53
riker1
ich bekomme folgenden Fehler den ich nicht zuordnen kann.
Ubuntu 18.04
Fhem akutell
PERL ERROR: Bad name after default' at (eval 111328) line 1.
2019.11.23 15:20:58.024 1 : stacktrace:
2019.11.23 15:20:58.024 1 :     main::__ANON__                      called by (eval 111328) (1)
2019.11.23 15:20:58.024 1 :     (eval)                              called by ./FHEM/98_DOIF.pm (1143)
2019.11.23 15:20:58.024 1 :     main::EvalAllDoIf                   called by ./FHEM/98_DOIF.pm (1642)
2019.11.23 15:20:58.024 1 :     main::ParseCommandsDoIf             called by ./FHEM/98_DOIF.pm (2085)
2019.11.23 15:20:58.024 1 :     main::DOIF_cmd                      called by ./FHEM/98_DOIF.pm (3021)
2019.11.23 15:20:58.024 1 :     main::DOIF_SleepTrigger             called by fhem.pl (3297)
2019.11.23 15:20:58.024 1 :     main::HandleTimeout                 called by fhem.pl (677)
version:
Latest Revision: 20510
File                 Rev   Last Change
fhem.pl              20460 2019-11-05 19:06:03Z rudolfkoenig
96_allowed.pm        20069 2019-08-27 08:36:02Z rudolfkoenig
90_at.pm             17561 2018-10-18 14:45:30Z rudolfkoenig
98_autocreate.pm     19372 2019-05-11 15:13:59Z rudolfkoenig
57_Calendar.pm       20418 2019-10-28 18:31:49Z neubert
98_cmdalias.pm       16300 2018-03-01 08:48:21Z rudolfkoenig
00_CUL.pm            17559 2018-10-18 07:45:07Z rudolfkoenig
10_CUL_HM.pm         20292 2019-10-03 08:35:49Z martinp876
18_CUL_HOERMANN.pm   15510 2017-11-27 16:52:44Z rudolfkoenig
14_CUL_MAX.pm        12440 2016-10-26 20:24:45Z mgehre
14_CUL_WS.pm         20008 2019-08-17 10:24:14Z rudolfkoenig
70_DENON_AVR.pm         10 2018-03-21 00:00:00Z raman
98_DOIF.pm           20500 2019-11-12 17:54:48Z Damian
98_dummy.pm          19585 2019-06-09 08:04:48Z rudolfkoenig
66_ECMD.pm           16372 2018-03-10 13:09:24Z neubert
34_ESPEasy.pm        18608 2019-02-16 09:03:52Z dev0
91_eventTypes.pm     14888 2017-08-13 12:07:12Z rudolfkoenig
98_expandJSON.pm     17324 2018-09-11 06:48:31Z dev0
00_FBAHAHTTP.pm      19019 2019-03-24 17:39:43Z rudolfkoenig
72_FB_CALLMONITOR.pm 20486 2019-11-10 08:06:06Z markusbloch
01_FHEMWEB.pm        20400 2019-10-23 17:50:05Z rudolfkoenig
92_FileLog.pm        20435 2019-11-01 14:23:30Z rudolfkoenig
98_freezemon.pm      18762 2019-02-28 22:29:15Z KernSani
72_FRITZBOX.pm       17437 2018-09-30 18:24:58Z tupol
10_FS20.pm           14888 2017-08-13 12:07:12Z rudolfkoenig
20_GUEST.pm          19533 2019-06-02 19:33:11Z loredo
98_help.pm           19915 2019-07-29 20:01:16Z betateilchen
98_HMinfo.pm         19495 2019-05-30 09:17:45Z martinp876
95_holiday.pm        20290 2019-10-02 20:46:32Z rudolfkoenig
98_HTTPMOD.pm        19978 2019-08-10 12:51:48Z StefanStrobel
02_HTTPSRV.pm        20110 2019-09-05 17:30:20Z neubert
98_IF.pm             12944 2017-01-03 12:56:17Z Damian
Hat da jemand eine Idee?
stacktrace
1
  attribut ist gesetzt.
FHEM    5.26.1 Ubuntu 18, FHEM    5.26.1 RPI 3 , Actoren: IT ,Tasmota, ESPEasy,
MAX CUBE, MAX HT, MAX WT, Selbstbau nanoCULs, FS 20,Tasmota, Homematic, FTK, SW. DIM, Smoke,KODI,Squeezebox
amenomade
#1
Du hast vermutlich ein DOIF, das "default" im Befehl enthält.
list DEF=.*default.*:FILTER=TYPE=DOIFkönnte helfen
riker1
ja , hatte ein default in dem readingsval ....
aber warum wirft er dann den Fehler?
habe das nun mal ausgebaut.
Was wird denn erwartet oder wie gehe ich am besten vor?
Wenn der Readingsval nicht da ist,?
Danke T
amenomade
Ohne zu sehen, was Du gemacht hattest, kann man keinen Vorschlag zur Korrektur/Verbesserung machen
