ok, sorry, ich dachte das Log reicht bis dahin...
hier also der hoffentlich korrekt und relevante Rest.
Woher weiß ich genau wo das relevante Ende ist?
2021.08.27 12:07:23.941 5: ZWDongle_Write 004a050a ()
2021.08.27 12:07:23.942 5: DevIo_SimpleWrite ZBoard: 0105004a050abf
2021.08.27 12:07:23.970 2: ZWAVE Starting secure init for ZWave_ENTRY_CONTROL_33
2021.08.27 12:07:23.971 5: ZWDongle_Write 001321039804002526 (caf65990)
2021.08.27 12:07:23.973 5: ACK received, removing 0105004a050abf from dongle sendstack
2021.08.27 12:07:23.974 5: DevIo_SimpleWrite ZBoard: 010a0013210398040025265b
2021.08.27 12:07:23.977 5: ACK received, WaitForAck=>2 for 010a0013210398040025265b
2021.08.27 12:07:23.983 4: ZWDongle_Read ZBoard: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2021.08.27 12:07:23.983 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:23.985 5: ZBoard: dispatch 011301
2021.08.27 12:07:23.996 4: ZWDongle_Read ZBoard: rcvd 004a0a062100 (request ZW_ADD_NODE_TO_NETWORK), sending ACK
2021.08.27 12:07:23.996 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:23.997 5: ZBoard: dispatch 004a0a062100
2021.08.27 12:07:23.998 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:06 ARG:2100 CB:0a
2021.08.27 12:07:24.002 4: ZBoard ZW_ADD_NODE_TO_NETWORK done
2021.08.27 12:07:24.008 4: ZWDongle_Read ZBoard: rcvd 00132600000300be7f7f7f7f0001040000000002010000 (request ZW_SEND_DATA), sending ACK
2021.08.27 12:07:24.008 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:24.009 5: device ack reveived, removing 010a0013210398040025265b from dongle sendstack
2021.08.27 12:07:24.010 5: ZBoard: dispatch 00132600000300be7f7f7f7f0001040000000002010000
2021.08.27 12:07:24.010 4: CMD:ZW_SEND_DATA ID:00 ARG:000300be7f7f7f7f0001040000000002010000 CB:26
2021.08.27 12:07:24.010 4: ZBoard transmit OK for CB 26, target ZWave_ENTRY_CONTROL_33
2021.08.27 12:07:24.010 5: ZWave_ENTRY_CONTROL_33: timeToCb:0.03 repeaters:0 rssi0:-66 dBm ackCh:0 lastCh:1 scheme:NextToLastWorkingRoute rep:at 40kbps routeTries:1 lastFailed:
2021.08.27 12:07:24.040 4: ZWDongle_Read ZBoard: rcvd 0004002103980500be00 (request APPLICATION_COMMAND_HANDLER), sending ACK
2021.08.27 12:07:24.041 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:24.042 5: ZBoard: dispatch 0004002103980500be00
2021.08.27 12:07:24.043 4: CMD:APPLICATION_COMMAND_HANDLER ID:21 ARG:03980500be00 CB:00
2021.08.27 12:07:24.043 5: ZWDongle_Write 0013210298402527 (caf65990)
2021.08.27 12:07:24.043 5: DevIo_SimpleWrite ZBoard: 010900132102984025271c
2021.08.27 12:07:24.046 5: ACK received, WaitForAck=>2 for 010900132102984025271c
2021.08.27 12:07:24.052 4: ZWDongle_Read ZBoard: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2021.08.27 12:07:24.052 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:24.053 5: ZBoard: dispatch 011301
2021.08.27 12:07:24.076 4: ZWDongle_Read ZBoard: rcvd 00132700000300be7f7f7f7f0001030000000002010000 (request ZW_SEND_DATA), sending ACK
2021.08.27 12:07:24.076 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:24.077 5: device ack reveived, removing 010900132102984025271c from dongle sendstack
2021.08.27 12:07:24.078 5: ZBoard: dispatch 00132700000300be7f7f7f7f0001030000000002010000
2021.08.27 12:07:24.078 4: CMD:ZW_SEND_DATA ID:00 ARG:000300be7f7f7f7f0001030000000002010000 CB:27
2021.08.27 12:07:24.078 4: ZBoard transmit OK for CB 27, target ZWave_ENTRY_CONTROL_33
2021.08.27 12:07:24.078 5: ZWave_ENTRY_CONTROL_33: timeToCb:0.03 repeaters:0 rssi0:-66 dBm ackCh:0 lastCh:1 scheme:LastWorkingRoute rep:at 40kbps routeTries:1 lastFailed:
2021.08.27 12:07:24.100 4: ZWDongle_Read ZBoard: rcvd 000400210a9880644eb92b3b39e71fbc00 (request APPLICATION_COMMAND_HANDLER), sending ACK
2021.08.27 12:07:24.100 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:24.101 5: ZBoard: dispatch 000400210a9880644eb92b3b39e71fbc00
2021.08.27 12:07:24.102 4: CMD:APPLICATION_COMMAND_HANDLER ID:21 ARG:0a9880644eb92b3b39e71fbc00 CB:00
2021.08.27 12:07:24.103 5: ZWDongle_Write 001321269881ccc1d9b6ec48ce44156a385ddc8af13dd64c1811c17472fc06d6a06455defd699a6b4fee2528 (caf65990)
2021.08.27 12:07:24.103 5: DevIo_SimpleWrite ZBoard: 012d001321269881ccc1d9b6ec48ce44156a385ddc8af13dd64c1811c17472fc06d6a06455defd699a6b4fee2528ed
2021.08.27 12:07:24.108 5: ACK received, WaitForAck=>2 for 012d001321269881ccc1d9b6ec48ce44156a385ddc8af13dd64c1811c17472fc06d6a06455defd699a6b4fee2528ed
2021.08.27 12:07:24.116 4: ZWDongle_Read ZBoard: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2021.08.27 12:07:24.116 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:24.118 5: ZBoard: dispatch 011301
2021.08.27 12:07:24.147 4: ZWDongle_Read ZBoard: rcvd 00132800000300be7f7f7f7f0001030000000002010000 (request ZW_SEND_DATA), sending ACK
2021.08.27 12:07:24.147 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:24.148 5: device ack reveived, removing 012d001321269881ccc1d9b6ec48ce44156a385ddc8af13dd64c1811c17472fc06d6a06455defd699a6b4fee2528ed from dongle sendstack
2021.08.27 12:07:24.149 5: ZBoard: dispatch 00132800000300be7f7f7f7f0001030000000002010000
2021.08.27 12:07:24.149 4: CMD:ZW_SEND_DATA ID:00 ARG:000300be7f7f7f7f0001030000000002010000 CB:28
2021.08.27 12:07:24.149 4: ZBoard transmit OK for CB 28, target ZWave_ENTRY_CONTROL_33
2021.08.27 12:07:24.150 5: ZWave_ENTRY_CONTROL_33: timeToCb:0.03 repeaters:0 rssi0:-66 dBm ackCh:0 lastCh:1 scheme:LastWorkingRoute rep:at 40kbps routeTries:1 lastFailed:
2021.08.27 12:07:24.188 4: ZWDongle_Read ZBoard: rcvd 00040021029840bc00 (request APPLICATION_COMMAND_HANDLER), sending ACK
2021.08.27 12:07:24.188 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:24.189 5: ZBoard: dispatch 00040021029840bc00
2021.08.27 12:07:24.190 4: CMD:APPLICATION_COMMAND_HANDLER ID:21 ARG:029840bc00 CB:00
2021.08.27 12:07:24.190 5: ZWDongle_Write 0013210a988014968009a35d22612529 (caf65990)
2021.08.27 12:07:24.191 5: DevIo_SimpleWrite ZBoard: 01110013210a988014968009a35d2261252974
2021.08.27 12:07:24.194 5: ACK received, WaitForAck=>2 for 01110013210a988014968009a35d2261252974
2021.08.27 12:07:24.199 4: ZWDongle_Read ZBoard: rcvd 011301 (answer ZW_SEND_DATA), sending ACK
2021.08.27 12:07:24.200 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:24.201 5: ZBoard: dispatch 011301
2021.08.27 12:07:24.226 4: ZWDongle_Read ZBoard: rcvd 00132900000300bc7f7f7f7f0001030000000002010000 (request ZW_SEND_DATA), sending ACK
2021.08.27 12:07:24.226 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:24.227 5: device ack reveived, removing 01110013210a988014968009a35d2261252974 from dongle sendstack
2021.08.27 12:07:24.228 5: ZBoard: dispatch 00132900000300bc7f7f7f7f0001030000000002010000
2021.08.27 12:07:24.228 4: CMD:ZW_SEND_DATA ID:00 ARG:000300bc7f7f7f7f0001030000000002010000 CB:29
2021.08.27 12:07:24.228 4: ZBoard transmit OK for CB 29, target ZWave_ENTRY_CONTROL_33
2021.08.27 12:07:24.229 5: ZWave_ENTRY_CONTROL_33: timeToCb:0.03 repeaters:0 rssi0:-68 dBm ackCh:0 lastCh:1 scheme:LastWorkingRoute rep:at 40kbps routeTries:1 lastFailed:
2021.08.27 12:07:24.257 4: ZWDongle_Read ZBoard: rcvd 000400211698816d700e0d84f4439fba7db614723308919437926ebe00 (request APPLICATION_COMMAND_HANDLER), sending ACK
2021.08.27 12:07:24.257 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:24.259 5: ZBoard: dispatch 000400211698816d700e0d84f4439fba7db614723308919437926ebe00
2021.08.27 12:07:24.259 4: CMD:APPLICATION_COMMAND_HANDLER ID:21 ARG:1698816d700e0d84f4439fba7db614723308919437926ebe00 CB:00
2021.08.27 12:07:24.260 4: CMD:APPLICATION_COMMAND_HANDLER ID:21 ARG:029807 CB:00
2021.08.27 12:07:24.261 3: ZWave_ENTRY_CONTROL_33: SECURITY enabled, networkkey was verified
2021.08.27 12:07:41.421 4: ZWDongle_Read ZBoard: rcvd 0004001e03400301c600 (request APPLICATION_COMMAND_HANDLER), sending ACK
2021.08.27 12:07:41.421 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:41.423 5: ZBoard: dispatch 0004001e03400301c600
2021.08.27 12:07:41.424 4: CMD:APPLICATION_COMMAND_HANDLER ID:1e ARG:03400301c600 CB:00
2021.08.27 12:07:41.703 4: ZWDongle_Read ZBoard: rcvd 00040010097105000000ff070800ad00 (request APPLICATION_COMMAND_HANDLER), sending ACK
2021.08.27 12:07:41.704 5: DevIo_SimpleWrite ZBoard: 06
2021.08.27 12:07:41.705 5: ZBoard: dispatch 00040010097105000000ff070800ad00
2021.08.27 12:07:41.706 4: CMD:APPLICATION_COMMAND_HANDLER ID:10 ARG:097105000000ff070800ad00 CB:00
