Revision 20839: 10_IT: add tamper switch for model itswitch_CHN Fix ...
Begonnen von System, 28 Dezember 2019, 11:15:38
System
                   Fix ...
                   Fix ITv3 Dim0%
               userV1setCodes used for receive
14_CUL_TCM97001:   Add new attribute max-diff-rain, with 0 (default) the
               query of the rain difference between 2 measured values ​​is deactivated
               Correction of the calculation of windSpeed, windGuest and
               windDirection.
               New attribute windDirectionInverse if the anemometer was installed
               the wrong way round.
               New model "Auriol_IAN" (NC-3982, ADE WS 1503, Tchibo 65 722) added,
               New model "TCM218943" added - New attribute "negation-batt",
               so that battery reading can be inverted
               Some checksum routines optimized and Log outputs standardized
               and optimized.
               There is now an alternative device code (DEF) for the Prologue
               protocol in which the 2nd and 3rd hex digits are used as longID.
               For example, with s916001A0A000 (Prologue) the DEF CUL_TCM97001_9_22
               and with s5DEA06615000 (NC_WS) the DEF CUL_TCM97001_5_222
               model Auriol Z31743B added
Source: Revision 20839: 10_IT: add tamper switch for model itswitch_CHN
                   Fix ...
