57_SSCal - Modul für den Synology Kalender
Begonnen von DS_Starter, 03 Januar 2020, 09:54:09
Cobra
Okay, so liefert er es jetzt richtig an für den Urlaub aber den ersten Termin verschiebt er wieder:
2021.05.23 12:45:06 5: SynCal2 - Calendar selection for add queue: Urlaubstage
2021.05.23 12:45:06 5: SynCal2 - Add Item to queue - Index 94:
  'opmode' => 'eventlist',
  'api' => 'EVENT',
  'params' => '&cal_id_list=["/Cobra/ptadnk/"]&start=1621634400&end=1629583200&list_repeat=true',
  'retryCount' => 0,
  'method' => 'list'
2021.05.23 12:45:06 4: SynCal2 - ####################################################
2021.05.23 12:45:06 4: SynCal2 - ###      start Calendar operation eventlist
2021.05.23 12:45:06 4: SynCal2 - Time selection start: 2021-05-22 00:00:00
2021.05.23 12:45:06 4: SynCal2 - Time selection end: 2021-08-22 00:00:00
2021.05.23 12:45:06 4: SynCal2 - API hash values already set - ignore get apisites
2021.05.23 12:45:06 4: SynCal2 - start SendQueue entry index "94" (eventlist) for operation.
2021.05.23 12:45:06 5: SynCal2 - HTTP-Call will be done with timeout: 20 s
2021.05.23 12:45:06 4: SynCal2 - Call-Out: http://192.168.178.10:5000/webapi/entry.cgi?api=SYNO.Cal.Event&version=3&method=list&cal_id_list=["/Cobra/ptadnk/"]&start=1621634400&end=1629583200&list_repeat=true&_sid=<secret>
2021.05.23 12:45:06 5: SynCal2 - JSON returned: {
  'success' => bless( do{\(my $o = 1)}, 'JSON::PP::Boolean' ),
  'data' => {
              '/Cobra/ptadnk/' => [
                                      'tz_id' => undef,
                                      'owner' => 1027,
                                      'is_repeat_evt' => bless( do{\(my $o = 0)}, 'JSON::PP::Boolean' ),
                                      'description' => '',
                                      'location' => '',
                                      'percent_complete' => undef,
                                      'evt_color' => '',
                                      'dav_etag' => 'xfivnybjhhkkvjzmuvyloqwrgrxygwje',
                                      'status' => undef,
                                      'priority' => undef,
                                      'owner_name' => 'Cobra',
                                      'modify_time2' => '1621766659.1723',
                                      'class' => 'PUBLIC',
                                      'from_syno_app_url' => undef,
                                      'summary' => 'Test',
                                      'priority_order' => 10,
                                      'transp' => 'OPAQUE',
                                      'dtstart' => '20210610T000000',
                                      'dtend' => '20210611T020000',
                                      'evt_id' => 1029,
                                      'gps' => undef,
                                      'is_all_day' => $VAR1->{'success'},
                                      'create_time' => '1621766329.01902',
                                      'evt_repeat_setting' => {
        'repeat_rule' => undef
                                      'ical_uid' => '20210523T123849-1b98436f@169.254.181.151',
                                      'original_cal_id' => '/Cobra/ptadnk/'
                                      'dtstart' => '20210614T000000',
                                      'evt_id' => 1031,
                                      'dtend' => '20210619T000000',
                                      'create_time' => '1621766670.63052',
                                      'gps' => undef,
                                      'ical_uid' => '20210523T124430-cafa1c1b@169.254.181.151',
                                      'original_cal_id' => '/Cobra/ptadnk/',
                                      'modify_time2' => '1621766684.25804',
                                      'summary' => 'Urlaub Juni',
                                      'priority_order' => 12,
                                      'evt_color' => '',
                                      'dav_etag' => 'ftbdlynvwaywikosjdhuioyfwffjkvxu',
                                      'status' => undef,
                                      'tz_id' => undef,
                                      'is_repeat_evt' => $VAR1->{'data'}{'/Cobra/ptadnk/'}[0]{'is_repeat_evt'},
                                      'owner' => 1027,
                                      'location' => '',
2021.05.23 12:45:06 4: SynCal2 - Event parse mode: asynchronous
2021.05.23 12:45:06 5: SynCal2 - VCALENDAR extract of UID "20210523T123849-1b98436f@169.254.181.151":
undef
2021.05.23 12:45:06 5: SynCal2 - Single event Begin: 2021-06-10, End: 2021-06-11
2021.05.23 12:45:06 5: SynCal2 - VCALENDAR extract of UID "20210523T124430-cafa1c1b@169.254.181.151":
undef
2021.05.23 12:45:06 5: SynCal2 - Single event Begin: 2021-06-14, End: 2021-06-18
2021.05.23 12:45:06 4: SynCal2 - Argument list for SSCalWriteHoliday:
2021.05.23 12:45:06 4: SynCal2 - 4 06-14 06-18 Urlaub Juni
2021.05.23 12:45:06 4: SynCal2 - add line: 1 01-01 Neujahr
2021.05.23 12:45:06 4: SynCal2 - add line: 1 01-06 Heilige Drei Koenige
2021.05.23 12:45:06 4: SynCal2 - add line: 1 05-01 Tag der Arbeit
2021.05.23 12:45:06 4: SynCal2 - add line: 1 10-03 Tag der deutschen Einheit
2021.05.23 12:45:06 4: SynCal2 - add line: 1 11-01 Allerheiligen
2021.05.23 12:45:06 4: SynCal2 - add line: 1 12-25 1. Weihnachtstag
2021.05.23 12:45:06 4: SynCal2 - add line: 1 12-26 2. Weihnachtstag
2021.05.23 12:45:06 4: SynCal2 - add line: 2 -2 Karfreitag
2021.05.23 12:45:06 4: SynCal2 - add line: 2  1 Ostermontag
2021.05.23 12:45:06 4: SynCal2 - add line: 2 39 Christi Himmelfahrt
2021.05.23 12:45:06 4: SynCal2 - add line: 2 50 Pfingsten
2021.05.23 12:45:06 4: SynCal2 - add line: 2 60 Fronleichnam
2021.05.23 12:45:06 4: SynCal2 - add line: #####Urlaub#####
2021.05.23 12:45:06 4: SynCal2 - -> Start new list write into ./FHEM/FeiertageBW.holiday <-
2021.05.23 12:45:06 4: SynCal2 - 1 01-01 Neujahr
2021.05.23 12:45:06 4: SynCal2 - 1 01-06 Heilige Drei Koenige
2021.05.23 12:45:06 4: SynCal2 - 1 05-01 Tag der Arbeit
2021.05.23 12:45:06 4: SynCal2 - 1 10-03 Tag der deutschen Einheit
2021.05.23 12:45:06 4: SynCal2 - 1 11-01 Allerheiligen
2021.05.23 12:45:06 4: SynCal2 - 1 12-25 1. Weihnachtstag
2021.05.23 12:45:06 4: SynCal2 - 1 12-26 2. Weihnachtstag
2021.05.23 12:45:06 4: SynCal2 - 2 -2 Karfreitag
2021.05.23 12:45:06 4: SynCal2 - 2  1 Ostermontag
2021.05.23 12:45:06 4: SynCal2 - 2 39 Christi Himmelfahrt
2021.05.23 12:45:06 4: SynCal2 - 2 50 Pfingsten
2021.05.23 12:45:06 4: SynCal2 - 2 60 Fronleichnam
2021.05.23 12:45:06 4: SynCal2 - #####Urlaub#####
2021.05.23 12:45:06 4: SynCal2 - # Time of absence from Calendar SynCal2, updated: 2021-05-23 12:45:06
2021.05.23 12:45:06 4: SynCal2 - # End Time of absence from Calendar SynCal2
2021.05.23 12:45:06 4: SynCal2 - -> End new list <-
2021.05.23 12:45:06 4: SynCal2 - Opmode "eventlist" finished successfully, Sendqueue index "94" deleted.
FHEM in Docker auf Synology, CCU3,
Diverse HM-Komponenten, Netatmo, Hue, Sonos, Nuki
DS_Starter
Jo, ziemlich eindeutig ein Bug. Scheint mir dass beim ersten JSON Eintrag bei dtend die Zeitzone nicht richtig berücksichtigt wird.
Werde ich Syno mal melden.
DS_Starter
Was ist wenn du den Dummy auf einen Nicht-Ganztagstermin umänderst ?
Cobra
Da kommt die Zeit dann korrekt an, hab den Termin in der Syno von 8-9 Uhr eingetragen:
2021.05.23 12:54:14 5: SynCal2 - Calendar selection for add queue: Urlaubstage
2021.05.23 12:54:14 5: SynCal2 - Add Item to queue - Index 96:
  'api' => 'EVENT',
  'retryCount' => 0,
  'method' => 'list'
2021.05.23 12:54:14 4: SynCal2 - ####################################################
2021.05.23 12:54:14 4: SynCal2 - ###      start Calendar operation eventlist
2021.05.23 12:54:14 4: SynCal2 - Time selection start: 2021-05-22 00:00:00
2021.05.23 12:54:14 4: SynCal2 - Time selection end: 2021-08-22 00:00:00
2021.05.23 12:54:14 4: SynCal2 - API hash values already set - ignore get apisites
2021.05.23 12:54:14 4: SynCal2 - start SendQueue entry index "96" (eventlist) for operation.
2021.05.23 12:54:14 5: SynCal2 - HTTP-Call will be done with timeout: 20 s
2021.05.23 12:54:14 4: SynCal2 - Call-Out: http://192.168.178.10:5000/webapi/entry.cgi?api=SYNO.Cal.Event&version=3&method=list&cal_id_list=["/Cobra/ptadnk/"]&start=1621634400&end=1629583200&list_repeat=true&_sid=<secret>
2021.05.23 12:54:15 5: SynCal2 - JSON returned: {
  'data' => {
                                      'tz_id' => 'Europe/Berlin',
                                      'location' => '',
                                      'owner' => 1027,
                                      'evt_color' => '',
                                      'dav_etag' => 'bhxhzijpuokaaewwtlreokqnglxzmrza',
                                      'status' => undef,
                                      'modify_time2' => '1621767233.87235',
                                      'dtend' => 'TZID=Europe/Berlin:20210610T090000',
                                      'evt_id' => 1029,
                                      'gps' => undef,
                                      'is_all_day' => $VAR1->{'data'}{'/Cobra/ptadnk/'}[0]{'is_repeat_evt'},
                                      'dtstart' => 'TZID=Europe/Berlin:20210610T080000',
                                      'location' => '',
                                      'owner' => 1027,
                                      'tz_id' => undef,
                                      'status' => undef,
                                      'evt_color' => '',
                                      'gps' => undef,
                                      'is_all_day' => bless( do{\(my $o = 1)}, 'JSON::PP::Boolean' ),
                                      'evt_id' => 1031,
  'success' => $VAR1->{'data'}{'/Cobra/ptadnk/'}[1]{'is_all_day'}
2021.05.23 12:54:15 4: SynCal2 - Event parse mode: asynchronous
2021.05.23 12:54:15 5: SynCal2 - VCALENDAR extract of UID "20210523T123849-1b98436f@169.254.181.151":
undef
2021.05.23 12:54:15 5: SynCal2 - Single event Begin: 2021-06-10, End: 2021-06-10
2021.05.23 12:54:15 5: SynCal2 - VCALENDAR extract of UID "20210523T124430-cafa1c1b@169.254.181.151":
undef
2021.05.23 12:54:15 5: SynCal2 - Single event Begin: 2021-06-14, End: 2021-06-18
2021.05.23 12:54:15 4: SynCal2 - Argument list for SSCalWriteHoliday:
2021.05.23 12:54:15 4: SynCal2 - 4 06-14 06-18 Urlaub Juni
2021.05.23 12:54:15 4: SynCal2 - add line: 1 01-01 Neujahr
2021.05.23 12:54:15 4: SynCal2 - add line: 1 01-06 Heilige Drei Koenige
2021.05.23 12:54:15 4: SynCal2 - add line: 1 05-01 Tag der Arbeit
2021.05.23 12:54:15 4: SynCal2 - add line: 1 10-03 Tag der deutschen Einheit
2021.05.23 12:54:15 4: SynCal2 - add line: 1 11-01 Allerheiligen
2021.05.23 12:54:15 4: SynCal2 - add line: 1 12-25 1. Weihnachtstag
2021.05.23 12:54:15 4: SynCal2 - add line: 1 12-26 2. Weihnachtstag
2021.05.23 12:54:15 4: SynCal2 - add line: 2 -2 Karfreitag
2021.05.23 12:54:15 4: SynCal2 - add line: 2  1 Ostermontag
2021.05.23 12:54:15 4: SynCal2 - add line: 2 39 Christi Himmelfahrt
2021.05.23 12:54:15 4: SynCal2 - add line: 2 50 Pfingsten
2021.05.23 12:54:15 4: SynCal2 - add line: 2 60 Fronleichnam
2021.05.23 12:54:15 4: SynCal2 - add line: #####Urlaub#####
2021.05.23 12:54:15 4: SynCal2 - -> Start new list write into ./FHEM/FeiertageBW.holiday <-
2021.05.23 12:54:15 4: SynCal2 - 1 01-01 Neujahr
2021.05.23 12:54:15 4: SynCal2 - 1 01-06 Heilige Drei Koenige
2021.05.23 12:54:15 4: SynCal2 - 1 05-01 Tag der Arbeit
2021.05.23 12:54:15 4: SynCal2 - 1 10-03 Tag der deutschen Einheit
2021.05.23 12:54:15 4: SynCal2 - 1 11-01 Allerheiligen
2021.05.23 12:54:15 4: SynCal2 - 1 12-25 1. Weihnachtstag
2021.05.23 12:54:15 4: SynCal2 - 1 12-26 2. Weihnachtstag
2021.05.23 12:54:15 4: SynCal2 - 2 -2 Karfreitag
2021.05.23 12:54:15 4: SynCal2 - 2  1 Ostermontag
2021.05.23 12:54:15 4: SynCal2 - 2 39 Christi Himmelfahrt
2021.05.23 12:54:15 4: SynCal2 - 2 50 Pfingsten
2021.05.23 12:54:15 4: SynCal2 - 2 60 Fronleichnam
2021.05.23 12:54:15 4: SynCal2 - #####Urlaub#####
2021.05.23 12:54:15 4: SynCal2 - # Time of absence from Calendar SynCal2, updated: 2021-05-23 12:54:15
2021.05.23 12:54:15 4: SynCal2 - # End Time of absence from Calendar SynCal2
2021.05.23 12:54:15 4: SynCal2 - -> End new list <-
2021.05.23 12:54:15 4: SynCal2 - Opmode "eventlist" finished successfully, Sendqueue index "96" deleted.
DS_Starter
Interessant, deswegen fällt sowas nur auf wenn der erste Termin in der JSON-Liste ein Ganztagstermin ist.  :o
Na ob ich das den Synokollegen begreiflich rüber bringen kann  :) .. mal schauen.
Cobra
Danke dir auf jeden Fall für deine Mühe, schauen wir mal was die Kollegen rausfinden.
Wünsch dir noch schöne Pfingst-Feiertage.
Cobra
DS_Starter
DS_Starter
Habe eine Mitteilung an Synology erstellt. Jetzt heißt es warten ...
juergen012
nachdem ich mich heute 2 stunden mit dem Modul rumgeärgert habe, musste ich feststellen, das die 2FA nicht unterstützt wird..Ich wollte von GOOgle Calendar zu diesem Modul wechseln. Kalender Sync etc. funktioniert einwandfrei. Nur der Zugriff aus FHEM nicht tolle Wurst...
Beste Grüße
Jürgen K.
Fhem unter Proxmox
DS_Starter
2FA wird von der API zur Zeit nicht unterstützt. Vllt. baut Syno es später noch ein, wer weiß.
ZitatNur der Zugriff aus FHEM nicht tolle Wurst...
Was fehlt dir denn ?
juergen012
Danke für die superschnelle Antwort.
Ich meinte, nachdem ich alles eingerichtet hatte, wollte ich das Modul in FHEM aktivieren..was ja leider mit 2FA nicht klappt. Der User muss ja in der Admin Gruppe sein. Somit kann ich das Modul nicht verwenden, da ich meine Sicherheitsstufe nicht ändern möchte .SCHADE!!
Beste Grüße
Jürgen K.
Fhem unter Proxmox
DS_Starter
Hallo Jürgen,
ja das tut mir leid. Wenn Syno diese Möglichkeit bietet, baue ich sie mit ein.
Dass der User Mitglied der Admin-Gruppe sein muß, habe ich bei Synology auch schon moniert weil mir der Sinn dessen nicht aufgegangen war. Muß man sehen was sich da tut.
LG,
Heiko
juergen012
Alles klar. Ich bleibe am Ball.. Vielen Dank!!
Fhem unter Proxmox
DS_Starter
Hallo Cobra, @all,
die Synology Kollegen haben sich sehr zügig des Problems mit dem "dtend" angenommen. Sonntag Abend hatte ich die Meldung aufgegeben und die deutschen Kollegen haben die Sache auch sofort nach Taiwan ins Development Team gegeben.
Die Taiwanesischen Developer haben es sich auf meiner Syno angeschaut (ich hatte extra einen Testkalender erstellt) und bereits heute kam die Antwort:
Dear User,
Thank you for waiting.
Our developer has confirmed the issue was due to 'dtned' got converted to local time, but 'dtstart' was converted UTC time.
Please convert 'dtend' back to UTC time before the issue is fixed.
Hope this helps and please let us know if further assistance is needed.
Yours Truly,
Technical Support
Wayne
Das Syno Team hat die Sache als Fehler aufgenommen und wird es sicherlich bald lösen. Mal schauen ob ich den vorgeschlagenen Workaround zwischenzeitlich einbaue oder ob wir einfach warten bis die Kollegen es gefixt haben.
Wenn die genauso schnell mit dem Fixen sind wie bei der Untersuchung kann ich mir den Workaround wohl sparen.  ;)
Top Support insgesamt von Synology, ich bin wirklich begeistert.  :)
Grüße,
Heiko
DS_Starter
Syno hat vor einigen Tagen (zwei Wochen?) die neue Version 2.4.1-0817 veröffentlicht.
Nach meinen Tests besteht der Issue aber weiterhin.
Habe Syno darüber informiert.
Grüße,
Heiko
