[GELÖST]SMAInverter zeigt falsche Werte
Begonnen von Kaspi, 27 Januar 2020, 10:42:07
Kaspi
Hallo
Die Stromwerte vom STP 6.0-40 werden mittels SMAInverter nicht richtig ausgelesen.
SPOT_IAC1 40.797 sollte 0.408
SPOT_IAC2 40.878 sollte 0.409
SPOT_IAC3 40.761 sollte 0.408
anzeigen.
Kaspi  ;)
DS_Starter
Kaspi
#2
2020.01.27 11:42:53 4: SMA_STP_6 - ###############################################################
2020.01.27 11:42:53 4: SMA_STP_6 - ##########  Begin of new SMAInverter get data cycle  ##########
2020.01.27 11:42:53 5: SMA_STP_6 - Data identifier 33310
2020.01.27 11:42:53 5: SMA_STP_6 - Found Data CLASS=8001 and TYPE=9346
2020.01.27 11:42:53 3: SMA_STP_6 - Send request 0002005400012600FF222600 to 192.168.178.88 on port 9522
2020.01.27 11:42:53 5: SMA_STP_6 - send: 534D4100000402A00000000100260010606509A07A01D4E73CB30000E90023BB590700000000000003800002005400012600FF22260000000000
2020.01.27 11:42:53 5: SMA_STP_6 - Received: 534d4100000402a0000000010036001060650da0e90023bb590700a07a01d4e73cb3000000000000038001020054000000000000000001012600acbe2e5e2f2f00000000000000000000
2020.01.27 11:42:53 5: SMA_STP_6 - Data identifier 9729
2020.01.27 11:42:53 3: SMA_STP_6 - ETODAY wasn't delivered from inverter, try to calculate it ...
2020.01.27 11:42:53 3: SMA_STP_6 - ETODAY calculated successfully !
2020.01.27 11:42:53 5: SMA_STP_6 - Data SPOT_ETOTAL=12079 and SPOT_ETODAY=502
2020.01.27 11:42:53 3: SMA_STP_6 - Send request 00028053001E2500FF1E2500 to 192.168.178.88 on port 9522
2020.01.27 11:42:53 5: SMA_STP_6 - send: 534D4100000402A00000000100260010606509A07A01D4E73CB30000E90023BB5907000000000000048000028053001E2500FF1E250000000000
2020.01.27 11:42:53 5: SMA_STP_6 - Received: 534d4100000402a000000001005e0010606517a0e90023bb590700a07a01d4e73cb30000000000000480010280530000000001000000011e2540acbe2e5e9e0000009e0000009e0000009e00000001000000021e2540acbe2e5e9c0000009c0000009c0000009c0000000100000000000000
2020.01.27 11:42:53 5: SMA_STP_6 - Data identifier 9502
2020.01.27 11:42:53 5: SMA_STP_6 - Found Data SPOT_PDC1=158 and SPOT_PDC2=156
2020.01.27 11:42:53 3: SMA_STP_6 - Send request 0002005100404600FF424600 to 192.168.178.88 on port 9522
2020.01.27 11:42:53 5: SMA_STP_6 - send: 534D4100000402A00000000100260010606509A07A01D4E73CB30000E90023BB590700000000000005800002005100404600FF42460000000000
2020.01.27 11:42:53 5: SMA_STP_6 - Received: 534d4100000402a000000001007a001060651ea0e90023bb590700a07a01d4e73cb3000000000000058001020051080000000a00000001404640acbe2e5e610000006100000061000000610000000100000001414640acbe2e5e630000006300000063000000630000000100000001424640acbe2e5e620000006200000062000000620000000100000000000000
2020.01.27 11:42:53 5: SMA_STP_6 - Data identifier 17984
2020.01.27 11:42:53 5: SMA_STP_6 - Found Data SPOT_PAC1=97 and SPOT_PAC2=99 and SPOT_PAC3=98
2020.01.27 11:42:53 3: SMA_STP_6 - Send request 00020051003F2600FF3F2600 to 192.168.178.88 on port 9522
2020.01.27 11:42:53 5: SMA_STP_6 - send: 534D4100000402A00000000100260010606509A07A01D4E73CB30000E90023BB5907000000000000068000020051003F2600FF3F260000000000
2020.01.27 11:42:53 5: SMA_STP_6 - Received: 534d4100000402a00000000100420010606510a0e90023bb590700a07a01d4e73cb30000000000000680010200510000000000000000013f2640acbe2e5e260100002601000026010000260100000100000000000000
2020.01.27 11:42:53 5: SMA_STP_6 - Data identifier 9791
2020.01.27 11:42:53 5: SMA_STP_6 - Found Data SPOT_PACTOT=294
2020.01.27 11:42:53 3: SMA_STP_6 - Send request 00020051005A2900FF5A2900 to 192.168.178.88 on port 9522
2020.01.27 11:42:53 5: SMA_STP_6 - send: 534D4100000402A00000000100260010606509A07A01D4E73CB30000E90023BB5907000000000000078000020051005A2900FF5A290000000000
2020.01.27 11:42:53 5: SMA_STP_6 - Received: 534d4100000402a00000000100260010606509a0e90023bb590700e07a01d4e73cb3000015000000078001020051005a2900ff5a290000000000
2020.01.27 11:42:53 3: SMA_STP_6 - Format of inverter response does not fit.
2020.01.27 11:42:53 3: SMA_STP_6 - Send request 00028053001F4500FF214500 to 192.168.178.88 on port 9522
2020.01.27 11:42:53 5: SMA_STP_6 - send: 534D4100000402A00000000100260010606509A07A01D4E73CB30000E90023BB5907000000000000088000028053001F4500FF21450000000000
2020.01.27 11:42:54 5: SMA_STP_6 - Received: 534d4100000402a00000000100960010606525a0e90023bb590700a07a01d4e73cb30000000000000880010280530200000005000000011f4540acbe2e5e0e7200000e7200000e7200000e72000001000000021f4540acbe2e5e3c7200003c7200003c7200003c7200000100000001214540acbe2e5e210200002102000021020000210200000100000002214540acbe2e5e180200001802000018020000180200000100000000000000
2020.01.27 11:42:54 5: SMA_STP_6 - Data identifier 17695
2020.01.27 11:42:54 5: SMA_STP_6 - Found Data SPOT_UDC1=291.98 and SPOT_UDC2=292.44 and SPOT_IDC1=0.545 and SPOT_IDC2=0.536
2020.01.27 11:42:54 3: SMA_STP_6 - Send request 0002005100484600FF554600 to 192.168.178.88 on port 9522
2020.01.27 11:42:54 5: SMA_STP_6 - send: 534D4100000402A00000000100260010606509A07A01D4E73CB30000E90023BB590700000000000009800002005100484600FF55460000000000
2020.01.27 11:42:54 5: SMA_STP_6 - Received: 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
2020.01.27 11:42:54 5: SMA_STP_6 - Data identifier 17992
2020.01.27 11:42:54 5: SMA_STP_6 - Found Data SPOT_UAC1=234.34 and SPOT_UAC2=235.12 and SPOT_UAC3=235.56 and SPOT_IAC1=40.708 and SPOT_IAC2=40.753 and SPOT_IAC3=40.647
2020.01.27 11:42:54 3: SMA_STP_6 - Send request 00020051001E4900FF5D4900 to 192.168.178.88 on port 9522
2020.01.27 11:42:54 5: SMA_STP_6 - send: 534D4100000402A00000000100260010606509A07A01D4E73CB30000E90023BB59070000000000000A8000020051001E4900FF5D490000000000
2020.01.27 11:42:54 5: SMA_STP_6 - Received: 534d4100000402a00000000100260010606509a0e90023bb590700e07a01d4e73cb30000150000000a8001020051001e4900ff5d490000000000
2020.01.27 11:42:54 3: SMA_STP_6 - Format of inverter response does not fit.
2020.01.27 11:42:54 3: SMA_STP_6 - Send request 0002005400674900FF674900 to 192.168.178.88 on port 9522
2020.01.27 11:42:54 5: SMA_STP_6 - send: 534D4100000402A00000000100260010606509A07A01D4E73CB30000E90023BB59070000000000000B800002005400674900FF67490000000000
2020.01.27 11:42:54 5: SMA_STP_6 - Received: 534d4100000402a00000000100260010606509a0e90023bb590700e07a01d4e73cb30000150000000b800102005400674900ff67490000000000
2020.01.27 11:42:54 3: SMA_STP_6 - Send request 0002005100574600FF574600 to 192.168.178.88 on port 9522
2020.01.27 11:42:54 5: SMA_STP_6 - send: 534D4100000402A00000000100260010606509A07A01D4E73CB30000E90023BB59070000000000000C800002005100574600FF57460000000000
2020.01.27 11:42:54 5: SMA_STP_6 - Received: 534d4100000402a00000000100420010606510a0e90023bb590700a07a01d4e73cb30000000000000c8001020051150000001500000001574600acbe2e5e881300008813000088130000881300000100000000000000
2020.01.27 11:42:54 5: SMA_STP_6 - Data identifier 18007
2020.01.27 11:42:54 5: SMA_STP_6 - Found Data SPOT_FREQ=50
2020.01.27 11:42:54 3: SMA_STP_6 - Send request 00020054002E4600FF2F4600 to 192.168.178.88 on port 9522
2020.01.27 11:42:54 5: SMA_STP_6 - send: 534D4100000402A00000000100260010606509A07A01D4E73CB30000E90023BB59070000000000000D8000020054002E4600FF2F460000000000
2020.01.27 11:42:54 5: SMA_STP_6 - Received: 534d4100000402a00000000100460010606511a0e90023bb590700a07a01d4e73cb30000000000000d80010200540300000004000000012e4600acbe2e5e1601020000000000012f4600acbe2e5e11cc01000000000000000000
2020.01.27 11:42:54 5: SMA_STP_6 - Data identifier 17966
2020.01.27 11:42:54 5: SMA_STP_6 - Found Data SPOT_OPERTM=36.48 and SPOT_FEEDTM=32.71
2020.01.27 11:42:54 3: SMA_STP_6 - Send request 0002005200772300FF772300 to 192.168.178.88 on port 9522
2020.01.27 11:42:54 5: SMA_STP_6 - send: 534D4100000402A00000000100260010606509A07A01D4E73CB30000E90023BB59070000000000000E800002005200772300FF77230000000000
2020.01.27 11:42:54 5: SMA_STP_6 - Received: 534d4100000402a00000000100260010606509a0e90023bb590700e07a01d4e73cb30000150000000e800102005200772300ff77230000000000
2020.01.27 11:42:54 3: SMA_STP_6 - Send request 00020051001E4100FF204100 to 192.168.178.88 on port 9522
2020.01.27 11:42:54 5: SMA_STP_6 - send: 534D4100000402A00000000100260010606509A07A01D4E73CB30000E90023BB59070000000000000F8000020051001E4100FF20410000000000
2020.01.27 11:42:54 5: SMA_STP_6 - Received: 534d4100000402a000000001007a001060651ea0e90023bb590700a07a01d4e73cb30000000000000f80010200510100000003000000011e4100a8be2e5e7017000070170000701700007017000001000000011f4100a8be2e5e000000000000000000000000000000000000000001204100a8be2e5e000000000000000000000000000000000000000000000000
2020.01.27 11:42:54 5: SMA_STP_6 - Data identifier 16670
2020.01.27 11:42:54 5: SMA_STP_6 - Found Data INV_PACMAX1=6000 and INV_PACMAX2=0 and INV_PACMAX3=0
2020.01.27 11:42:54 3: SMA_STP_6 - Send request 00020051002A8300FF2A8300 to 192.168.178.88 on port 9522
2020.01.27 11:42:54 5: SMA_STP_6 - send: 534D4100000402A00000000100260010606509A07A01D4E73CB30000E90023BB5907000000000000108000020051002A8300FF2A830000000000
2020.01.27 11:42:54 5: SMA_STP_6 - Received: 534d4100000402a00000000100260010606509a0e90023bb590700e07a01d4e73cb3000015000000108001020051002a8300ff2a830000000000
2020.01.27 11:42:54 3: SMA_STP_6 - Send request 0002805100644100FF644100 to 192.168.178.88 on port 9522
2020.01.27 11:42:54 5: SMA_STP_6 - send: 534D4100000402A00000000100260010606509A07A01D4E73CB30000E90023BB590700000000000011800002805100644100FF64410000000000
2020.01.27 11:42:54 5: SMA_STP_6 - Received: 534d4100000402a000000001004e0010606513a0e90023bb590700a07a01d4e73cb30000000000001180010280510a0000000a00000001644108acbe2e5e3300000137010000fdffff00feffff000000000000000000000000000000000000000000
2020.01.27 11:42:54 5: SMA_STP_6 - Data identifier 16740
2020.01.27 11:42:54 5: SMA_STP_6 - Found Data INV_GRIDRELAY=51
2020.01.27 11:42:54 3: SMA_STP_6 - Send request 0002805100482100FF482100 to 192.168.178.88 on port 9522
2020.01.27 11:42:54 5: SMA_STP_6 - send: 534D4100000402A00000000100260010606509A07A01D4E73CB30000E90023BB590700000000000012800002805100482100FF48210000000000
2020.01.27 11:42:54 5: SMA_STP_6 - Received: 534d4100000402a000000001004e0010606513a0e90023bb590700a07a01d4e73cb3000000000000128001028051000000000000000001482108adbe2e5e33010001feffff0000000000000000000000000000000000000000000000000000000000
2020.01.27 11:42:54 5: SMA_STP_6 - Data identifier 8520
2020.01.27 11:42:54 5: SMA_STP_6 - Found Data inv_STATUS=307
2020.01.27 11:42:54 4: SMA_STP_6 - Send logout to 192.168.178.88 on Port 9522
2020.01.27 11:42:54 5: SMA_STP_6 - Send: 534D4100000402A00000000100220010606508A07A01D4E73CB30003E90023BB590700030000000013800E01FDFFFFFFFFFF00000000
2020.01.27 11:42:54 4: SMA_STP_6 - logged out now from inverter serial: xxxxx, susyid: xxxxx
2020.01.27 11:42:54 5: SMA_STP_6 - CNT05: 5 SUM05: 1670
2020.01.27 11:42:54 5: SMA_STP_6 - CNT10: 10 SUM10: 3531
2020.01.27 11:42:54 5: SMA_STP_6 - CNT15: 15 SUM15: 4941
2020.01.27 11:42:54 5: SMA_STP_6 - Content of Averagebuffer:
2020.01.27 11:42:54 5: SMA_STP_6 - 294,252,227,256,301,340,388,382,357,372,362,309,269,282,278,272,290
2020.01.27 11:42:54 5: SMA_STP_6 - avg_power_lastminutes_05 = 278, avg_power_lastminutes_10 = 321, avg_power_lastminutes_15 = 308
2020.01.27 11:42:54 5: SMA_STP_6 -> row_array before encoding:
2020.01.27 11:42:54 5: SMA_STP_6 -> modulstate normal
2020.01.27 11:42:54 5: SMA_STP_6 -> opertime_start 27.01.2020 07:41:51
2020.01.27 11:42:54 5: SMA_STP_6 -> opertime_stop 27.01.2020 17:50:37
2020.01.27 11:42:54 5: SMA_STP_6 -> avg_power_lastminutes_05 278
2020.01.27 11:42:54 5: SMA_STP_6 -> avg_power_lastminutes_10 321
2020.01.27 11:42:54 5: SMA_STP_6 -> avg_power_lastminutes_15 308
2020.01.27 11:42:54 5: SMA_STP_6 -> SPOT_ETOTAL 12079
2020.01.27 11:42:54 5: SMA_STP_6 -> SPOT_ETODAY 502
2020.01.27 11:42:54 5: SMA_STP_6 -> SPOT_PDC1 158
2020.01.27 11:42:54 5: SMA_STP_6 -> SPOT_PDC2 156
2020.01.27 11:42:54 5: SMA_STP_6 -> SPOT_PAC1 97
2020.01.27 11:42:54 5: SMA_STP_6 -> SPOT_PAC2 99
2020.01.27 11:42:54 5: SMA_STP_6 -> SPOT_PAC3 98
2020.01.27 11:42:54 5: SMA_STP_6 -> SPOT_PACTOT 294
2020.01.27 11:42:54 5: SMA_STP_6 -> state 294
2020.01.27 11:42:54 5: SMA_STP_6 -> SPOT_UDC1 291.98
2020.01.27 11:42:54 5: SMA_STP_6 -> SPOT_UDC2 292.44
2020.01.27 11:42:54 5: SMA_STP_6 -> SPOT_IDC1 0.545
2020.01.27 11:42:54 5: SMA_STP_6 -> SPOT_IDC2 0.536
2020.01.27 11:42:54 5: SMA_STP_6 -> SPOT_UAC1 234.34
2020.01.27 11:42:54 5: SMA_STP_6 -> SPOT_UAC2 235.12
2020.01.27 11:42:54 5: SMA_STP_6 -> SPOT_UAC3 235.56
2020.01.27 11:42:54 5: SMA_STP_6 -> SPOT_IAC1 40.708
2020.01.27 11:42:54 5: SMA_STP_6 -> SPOT_IAC2 40.753
2020.01.27 11:42:54 5: SMA_STP_6 -> SPOT_IAC3 40.647
2020.01.27 11:42:54 5: SMA_STP_6 -> SPOT_FREQ 50
2020.01.27 11:42:54 5: SMA_STP_6 -> INV_TYPE STP6.0-3AV-40 (Sunny Tripower 6.0)
2020.01.27 11:42:54 5: SMA_STP_6 -> INV_CLASS Solar Inverters
2020.01.27 11:42:54 5: SMA_STP_6 -> SUSyID xxxxx
2020.01.27 11:42:54 5: SMA_STP_6 -> Serialnumber xxxxx
2020.01.27 11:42:54 5: SMA_STP_6 -> INV_PACMAX1 6000
2020.01.27 11:42:54 5: SMA_STP_6 -> INV_PACMAX2 0
2020.01.27 11:42:54 5: SMA_STP_6 -> INV_PACMAX3 0
2020.01.27 11:42:54 5: SMA_STP_6 -> SPOT_FEEDTM 32.71
2020.01.27 11:42:54 5: SMA_STP_6 -> SPOT_OPERTM 36.48
2020.01.27 11:42:54 5: SMA_STP_6 -> INV_GRIDRELAY Closed
2020.01.27 11:42:54 5: SMA_STP_6 -> INV_STATUS Ok
2020.01.27 11:42:54 4: SMA_STP_6 -> BlockingCall SMAInverter_getstatusDoParse finished
2020.01.27 11:42:54 4: SMA_STP_6 -> Start BlockingCall SMAInverter_getstatusParseDone
2020.01.27 11:42:54 5: SMA_STP_6 -> row_array after decoding:
2020.01.27 11:42:54 5: SMA_STP_6 -> SUSyID xxxxxxx
2020.01.27 11:42:54 5: SMA_STP_6 -> Serialnumber xxxxxxx
2020.01.27 11:42:54 4: SMA_STP_6 -> BlockingCall SMAInverter_getstatusParseDone finished
Muß ich dann selbst ändern.
Kaspi
DS_Starter
Ja,
Also wenn es sich herausstellt, dass ALLE STP6 einen Faktor 100 bei IAC haben, könnte ich das typabhängig korrigieren.
Trotzdem für mich unverständlich, Faktor 1000 ist für mich noch logisch, aber 100 ?
Vielleicht hilfreich wenn wir uns in dem anderen Thread mit anderen STP 6 Nutzern austauschen um eine Strategie zu finden. Vllt. hat SMA ja auch einen Firmwarebug ausgeliefert. So neu ist der STP ja nicht mit dem Modul im Einsatz.
Grüße,
Heiko
Kaspi
Faktor 100 hat mich auch irritiert  :o
Kann man das irgendwie in den anderen Thread verschieben?
Kaspi
DS_Starter
ZitatKann man das irgendwie in den anderen Thread verschieben?
Nein, nur als neuen Beitrag dort reinkopieren.
