Autor Thema: [Fehler nicht reproduzierbar] dpt1.015 wird nicht richtig dargestellt  (Gelesen 451 mal)
Offline abc2006
  • Sr. Member
ich habe ein Device mit dem DPT 1.015 defininert:
define KNX50.O01_Aktor_PV_out KNX
2/0/0:dpt1:steuern:set:nosuffix
2/0/1:dpt1:status:get:nosuffix
2/0/2:dpt14.056:active_power:get:nosuffix
2/0/3:dpt14.019:active_current:get:nosuffix
2/0/4:dpt14.027:voltage:get:nosuffix
2/0/5:dpt14.056:appearent_power:get:nosuffix
2/0/6:dpt13.010:active_work:get:nosuffix
2/0/7:dpt1.015:active_work_reset:set:nosuffix
2/0/8:dpt12:operating_seconds:get:nosuffix
2/0/9:dpt1.015:operating_seconds_reset:set:nosuffix
nternals:
   CFGFN
   DEF        2/0/0:dpt1:steuern:set:nosuffix  2/0/1:dpt1:status:get:nosuffix  2/0/2:dpt14.056:active_power:get:nosuffix 2/0/3:dpt14.019:active_current:get:nosuffix 2/0/4:dpt14.027:voltage:get:nosuffix 2/0/5:dpt14.056:appearent_power:get:nosuffix  2/0/6:dpt13.010:active_work:get:nosuffix  2/0/7:dpt1.015:active_work_reset:set:nosuffix 2/0/8:dpt12:operating_seconds:get:nosuffix 2/0/9:dpt1.015:operating_seconds_reset:set:nosuffix
   DEVNAME    KNX50.O01_Aktor_PV_out
   FIRSTGADNAME steuern
   FUUID      5e3ee553-f33f-4040-ddeb-e77a6ca23bad1ef5
   GETSTRING  active_work_reset:noArg operating_seconds_reset:noArg active_work:noArg appearent_power:noArg status:noArg voltage:noArg operating_seconds:noArg steuern:noArg active_power:noArg active_current:noArg
   IODev      tul
   NR         1740175
   NTFY_ORDER 50-KNX50.O01_Aktor_PV_out
   SETSTRING  active_work_reset:no action,reset operating_seconds_reset:no action,reset steuern:off,on
   STATE      ???
   TYPE       KNX
   GADDETAILS:
     active_current:
       CODE       02003
       GROUP      2/0/3
       MODEL      dpt14.019
       NO         4
       OPTION     get
       RDNAMEGET  active_current
       RDNAMEPUT  active_current
       RDNAMESET
       SETLIST
     active_power:
       CODE       02002
       GROUP      2/0/2
       MODEL      dpt14.056
       NO         3
       OPTION     get
       RDNAMEGET  active_power
       RDNAMEPUT  active_power
       RDNAMESET
       SETLIST
     active_work:
       CODE       02006
       GROUP      2/0/6
       MODEL      dpt13.010
       NO         7
       OPTION     get
       RDNAMEGET  active_work
       RDNAMEPUT  active_work
       RDNAMESET
       SETLIST    :slider,-2147483647,42949672,2147483647
     active_work_reset:
       CODE       02007
       GROUP      2/0/7
       MODEL      dpt1.015
       NO         8
       OPTION     set
       RDNAMEGET
       RDNAMEPUT
       RDNAMESET  active_work_reset
       SETLIST    :no action,reset
     appearent_power:
       CODE       02005
       GROUP      2/0/5
       MODEL      dpt14.056
       NO         6
       OPTION     get
       RDNAMEGET  appearent_power
       RDNAMEPUT  appearent_power
       RDNAMESET
       SETLIST
     operating_seconds:
       CODE       02008
       GROUP      2/0/8
       MODEL      dpt12
       NO         9
       OPTION     get
       RDNAMEGET  operating_seconds
       RDNAMEPUT  operating_seconds
       RDNAMESET
       SETLIST    :slider,0,42949672,4294967295
       CODE       02009
       GROUP      2/0/9
       MODEL      dpt1.015
       NO         10
       OPTION     set
       RDNAMEGET
       RDNAMEPUT
       RDNAMESET  operating_seconds_reset
     status:
       CODE       02001
       GROUP      2/0/1
       MODEL      dpt1
       NO         2
       OPTION     get
       RDNAMEGET  status
       RDNAMEPUT  status
       RDNAMESET
       SETLIST    :off,on
     steuern:
       CODE       02000
       GROUP      2/0/0
       MODEL      dpt1
       NO         1
       OPTION     set
       RDNAMEGET
       RDNAMEPUT
       RDNAMESET  steuern
       SETLIST    :off,on
     voltage:
       CODE       02004
       GROUP      2/0/4
       MODEL      dpt14.027
       NO         5
       OPTION     get
       RDNAMEGET  voltage
       RDNAMEPUT  voltage
       RDNAMESET
       SETLIST
   GADTABLE:
     02000      steuern
     02001      status
     02002      active_power
     02003      active_current
     02004      voltage
     02005      appearent_power
     02006      active_work
     02007      active_work_reset
     02008      operating_seconds
     02009      operating_seconds_reset
   IODev      tul
Leider wird die Option "reset" nicht richtig dargestellt.
Grüße,
Stephan
« Letzte Änderung: 08 Februar 2020, 18:00:50 von abc2006 »
FHEM nightly auf Intel Atom (lubuntu) mit VDSL 50000 ;-)
Nutze zur Zeit OneWire und KNX
Offline abc2006
  • Sr. Member
Antw:dpt1.015 wird nicht richtig dargestellt
« Antwort #1 am: 08 Februar 2020, 17:52:08 »
Oh ... ich hatte dazu schonmal was gepostet:
https://forum.fhem.de/index.php/topic,100298.0.html
Sorry, hatte ich nicht mehr im Kopf...
Grüße,
Stephan
Offline abc2006
  • Sr. Member
« Antwort #2 am: 08 Februar 2020, 18:00:27 »
Habe noch ein bisschen rumprobiert, um den Fehler einzugrenzen.
Dazu habe ich die einzelnen GAD's aus der DEF entfernt. Nachdem ich die 2/0/0 entfernt hatte, verschwand dieser Fehler und ist auch nach dem Hinzufügen nicht wieder aufgetaucht.
Falls er doch wiederkommt, melde ich mich.
Danke trotzdem,
Stephan
Offline abc2006
  • Sr. Member
Okay, dafür bekomme ich die Fehlermeldung
invalid value: reset
wenn ich versuche, den Kanal zu resetten...
decade-submarginal
