Fhem startet nicht mehr
Begonnen von hurray, 09 Februar 2020, 17:23:24
hurray
Moin seitdem ich heute von MQTT auf MQTT2 umsteigen wollte und MQTT vom Pi3 gelöscht habe und danach neugestartet habe geht FHEM nicht mehr. Ich hab MQTT schon wieder installiert aber ohne erfolg
anbei der Debug log
[left]2020.02.09 17:15:32 2: eventTypes: loaded 240 events from ./log/eventTypes.txt
2020.02.09 17:15:32 1: PERL WARNING: Constant subroutine MQTT::MQTT_UNSUBACK red        efined at /usr/local/share/perl/5.24.1/Net/MQTT/Constants.pm line 44, <$fh> line        31.
2020.02.09 17:15:32 1: PERL WARNING: Constant subroutine MQTT::MQTT_PUBREC redef        ined at /usr/local/share/perl/5.24.1/Net/MQTT/Constants.pm line 44, <$fh> line 3        1.
2020.02.09 17:15:32 1: PERL WARNING: Constant subroutine MQTT::MQTT_CONNACK rede        fined at /usr/local/share/perl/5.24.1/Net/MQTT/Constants.pm line 44, <$fh> line        31.
2020.02.09 17:15:32 1: PERL WARNING: Constant subroutine MQTT::MQTT_PUBLISH rede        fined at /usr/local/share/perl/5.24.1/Net/MQTT/Constants.pm line 44, <$fh> line        31.
2020.02.09 17:15:32 1: PERL WARNING: Constant subroutine MQTT::MQTT_SUBACK redef        ined at /usr/local/share/perl/5.24.1/Net/MQTT/Constants.pm line 44, <$fh> line 3        1.
2020.02.09 17:15:32 1: PERL WARNING: Constant subroutine MQTT::MQTT_UNSUBSCRIBE        redefined at /usr/local/share/perl/5.24.1/Net/MQTT/Constants.pm line 44, <$fh> l        ine 31.
2020.02.09 17:15:32 1: PERL WARNING: Constant subroutine MQTT::MQTT_CONNECT rede        fined at /usr/local/share/perl/5.24.1/Net/MQTT/Constants.pm line 44, <$fh> line        31.
2020.02.09 17:15:32 1: PERL WARNING: Constant subroutine MQTT::MQTT_DISCONNECT r        edefined at /usr/local/share/perl/5.24.1/Net/MQTT/Constants.pm line 44, <$fh> li        ne 31.
2020.02.09 17:15:32 1: PERL WARNING: Constant subroutine MQTT::MQTT_CONNECT_REFU        SED_NOT_AUTHORIZED redefined at /usr/local/share/perl/5.24.1/Net/MQTT/Constants.        pm line 44, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Constant subroutine MQTT::MQTT_CONNECT_REFU        SED_IDENTIFIER_REJECTED redefined at /usr/local/share/perl/5.24.1/Net/MQTT/Const        ants.pm line 44, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Constant subroutine MQTT::MQTT_PUBCOMP rede        fined at /usr/local/share/perl/5.24.1/Net/MQTT/Constants.pm line 44, <$fh> line        31.
2020.02.09 17:15:32 1: PERL WARNING: Constant subroutine MQTT::MQTT_CONNECT_REFU        SED_BAD_USER_NAME_OR_PASSWORD redefined at /usr/local/share/perl/5.24.1/Net/MQTT        /Constants.pm line 44, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Constant subroutine MQTT::MQTT_PUBREL redef        ined at /usr/local/share/perl/5.24.1/Net/MQTT/Constants.pm line 44, <$fh> line 3        1.
2020.02.09 17:15:32 1: PERL WARNING: Constant subroutine MQTT::MQTT_PUBACK redef        ined at /usr/local/share/perl/5.24.1/Net/MQTT/Constants.pm line 44, <$fh> line 3        1.
2020.02.09 17:15:32 1: PERL WARNING: Constant subroutine MQTT::MQTT_CONNECT_REFU        SED_UNACCEPTABLE_PROTOCOL_VERSION redefined at /usr/local/share/perl/5.24.1/Net/        MQTT/Constants.pm line 44, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Constant subroutine MQTT::MQTT_QOS_AT_MOST_        ONCE redefined at /usr/local/share/perl/5.24.1/Net/MQTT/Constants.pm line 44, <$        fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Constant subroutine MQTT::MQTT_QOS_AT_LEAST        _ONCE redefined at /usr/local/share/perl/5.24.1/Net/MQTT/Constants.pm line 44, <        $fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Constant subroutine MQTT::MQTT_CONNECT_REFU        SED_SERVER_UNAVAILABLE redefined at /usr/local/share/perl/5.24.1/Net/MQTT/Consta        nts.pm line 44, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Constant subroutine MQTT::MQTT_PINGREQ rede        fined at /usr/local/share/perl/5.24.1/Net/MQTT/Constants.pm line 44, <$fh> line        31.
2020.02.09 17:15:32 1: PERL WARNING: Constant subroutine MQTT::MQTT_SUBSCRIBE re        defined at /usr/local/share/perl/5.24.1/Net/MQTT/Constants.pm line 44, <$fh> lin        e 31.
2020.02.09 17:15:32 1: PERL WARNING: Constant subroutine MQTT::MQTT_CONNECT_ACCE        PTED redefined at /usr/local/share/perl/5.24.1/Net/MQTT/Constants.pm line 44, <$        fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Constant subroutine MQTT::MQTT_QOS_EXACTLY_        ONCE redefined at /usr/local/share/perl/5.24.1/Net/MQTT/Constants.pm line 44, <$        fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Constant subroutine MQTT::MQTT_PINGRESP red        efined at /usr/local/share/perl/5.24.1/Net/MQTT/Constants.pm line 44, <$fh> line        31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine Define redefined at ./FHEM/00_MQ        TT.pm line 106, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine Undef redefined at ./FHEM/00_MQT        T.pm line 135, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine Delete redefined at ./FHEM/00_MQ        TT.pm line 141, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine Shutdown redefined at ./FHEM/00_        MQTT.pm line 148, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine onConnect redefined at ./FHEM/00        _MQTT.pm line 156, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine onDisconnect redefined at ./FHEM        /00_MQTT.pm line 163, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine onTimeout redefined at ./FHEM/00        _MQTT.pm line 170, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine isConnected redefined at ./FHEM/        00_MQTT.pm line 179, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine process_event redefined at ./FHE        M/00_MQTT.pm line 186, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine Set redefined at ./FHEM/00_MQTT.        pm line 207, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine parseParams redefined at ./FHEM/        00_MQTT.pm line 254, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine parsePublishCmdStr redefined at        ./FHEM/00_MQTT.pm line 341, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine parsePublishCmd redefined at ./F        HEM/00_MQTT.pm line 350, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine Notify redefined at ./FHEM/00_MQ        TT.pm line 392, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine Attr redefined at ./FHEM/00_MQTT        .pm line 400, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine Start redefined at ./FHEM/00_MQT        T.pm line 433, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine Stop redefined at ./FHEM/00_MQTT        .pm line 450, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine Ready redefined at ./FHEM/00_MQT        T.pm line 464, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine Rename redefined at ./FHEM/00_MQ        TT.pm line 469, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine Init redefined at ./FHEM/00_MQTT        .pm line 479, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine Timer redefined at ./FHEM/00_MQT        T.pm line 488, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine Read redefined at ./FHEM/00_MQTT        .pm line 501, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine send_connect redefined at ./FHEM        /00_MQTT.pm line 647, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine send_publish redefined at ./FHEM        /00_MQTT.pm line 660, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine send_subscribe redefined at ./FH        EM/00_MQTT.pm line 672, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine send_unsubscribe redefined at ./        FHEM/00_MQTT.pm line 679, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine send_ping redefined at ./FHEM/00        _MQTT.pm line 686, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine send_disconnect redefined at ./F        HEM/00_MQTT.pm line 690, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine send_message redefined at ./FHEM        /00_MQTT.pm line 697, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine topic_to_regexp redefined at ./F        HEM/00_MQTT.pm line 712, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine client_subscribe_topic redefined        at ./FHEM/00_MQTT.pm line 723, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine client_unsubscribe_topic redefin        ed at ./FHEM/00_MQTT.pm line 742, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine Client_Define redefined at ./FHE        M/00_MQTT.pm line 759, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine Client_Undefine redefined at ./F        HEM/00_MQTT.pm line 778, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine client_attr redefined at ./FHEM/        00_MQTT.pm line 783, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine notify_client_connected redefine        d at ./FHEM/00_MQTT.pm line 897, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine notify_client_disconnected redef        ined at ./FHEM/00_MQTT.pm line 902, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine notify_client_connection_timeout        redefined at ./FHEM/00_MQTT.pm line 907, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine client_start redefined at ./FHEM        /00_MQTT.pm line 912, <$fh> line 31.
2020.02.09 17:15:32 1: PERL WARNING: Subroutine client_stop redefined at ./FHEM/        00_MQTT.pm line 944, <$fh> line 31.
Undefined subroutine &MQTT::DEVICE::client_attr called at ./FH[/left]
KernSani
was heisst denn du hast MQTT vom Pi3 gelöscht und wieder installiert? Hast du die Modul-Dateien von der Platte gelöscht? Falls das der Fall ist, hast du 00_MQTT.pm und 10_MQTT_DEVICE.pm wieder zurück kopiert?
Grüße,
Oli
