[FUIP] Fehlermeldungen, ausgeloest durch FUIP
Begonnen von Wolfgang Hochweller, 03 April 2020, 14:11:54
Wolfgang Hochweller
Das sehe ich im Log :
2020.04.03 14:04:07 1: PERL WARNING: "my" variable $fields masks earlier declaration in same scope at ./FHEM/42_FUIP.pm line 3679, <$fh> line 1302.
2020.04.03 14:04:07 1: stacktrace:
2020.04.03 14:04:07 1:     main::__ANON__                      called by ./FHEM/42_FUIP.pm (3679)
2020.04.03 14:04:07 1:     (eval)                              called by fhem.pl (2609)
2020.04.03 14:04:07 1:     (eval)                              called by fhem.pl (2608)
2020.04.03 14:04:07 1:     main::CommandReload                 called by fhem.pl (2000)
2020.04.03 14:04:07 1:     main::LoadModule                    called by fhem.pl (2057)
2020.04.03 14:04:07 1:     main::CommandDefine                 called by fhem.pl (1247)
2020.04.03 14:04:07 1:     main::AnalyzeCommand                called by fhem.pl (1100)
2020.04.03 14:04:07 1:     main::AnalyzeCommandChain           called by fhem.pl (1385)
2020.04.03 14:04:07 1:     main::CommandInclude                called by fhem.pl (610)
2020.04.03 14:04:07 3: FUIP: Registering ui for URL /ui
2020.04.03 14:04:07 1: PERL WARNING: Use of uninitialized value in lc at fhem.pl line 5400, <$fh> line 1302.
2020.04.03 14:04:07 1:     main::__ANON__                      called by fhem.pl (5400)
2020.04.03 14:04:07 1:     main::FileRead                      called by ./FHEM/42_FUIP.pm (2632)
2020.04.03 14:04:07 1:     FUIP::load                          called by ./FHEM/42_FUIP.pm (223)
2020.04.03 14:04:07 1:     FUIP::Define                        called by fhem.pl (3772)
2020.04.03 14:04:07 1:     main::CallFn                        called by fhem.pl (2082)
2020.04.03 14:04:07 1:     main::FileRead                      called by ./FHEM/42_FUIP.pm (2637)
Rewe2000
#1
Hallo Wolfgang,
da häng ich mich mal an, auch bei mir kommen ähnliche Fehler in Zusammenhang mit FUIP.
Ich hoffe Thorsten liest hier mit und prüft mal ob der Fehler eventuell bei uns liegt.
2020.04.05 19:20:47 1: PERL WARNING: "my" variable $fields masks earlier declaration in same scope at ./FHEM/42_FUIP.pm line 3679, <$fh> line 4859.
2020.04.05 19:20:48 3: FUIP: Registering ui for URL /ui
2020.04.05 19:20:48 1: PERL WARNING: Use of uninitialized value in lc at fhem.pl line 5403, <$fh> line 4859.
Hinweis:
Wolfgang, du solltest noch im Betreff [FUIP] als erstes mit anhängen, damit Thorsten auf den Beitrag aufmerksam wird.
Gruß Reinhard
Fhem 6.3 auf Raspberry Pi4 SSD mit Raspbian Bookworm, Homematic, Homematic IP, CCU3 mit RapberryMatic, WAGO 750-880, E3DC S10E Hauskraftwerk, E3DC Wallbox, my-PV AC ELWA-E Heizstab, Fritz!Box 7590, KIA Bluelinky
mbr89
smuckl
Dank der Antwort von mbr89, habe ich mich noch mal an das Ganze Thema mit dem Fehler gesetzt und einfach mal das "my" vor dem "fields" in Zeile 3769 entfernt und seit drei Tagen ist der Fehler im log verschwunden und FPUI funktioniert weiterhin einwandfrei  ;)
