Neues Device wo kommt es her und welche templates brauch wer
Begonnen von masterpete23, 08 April 2020, 20:19:40
masterpete23
bisher hatte ich eine ältere Version von zigbee2MQTT auf einem anderen Raspberry installiert.
Dafür gab es dann schon dies Gerät:
   CID        RASPI5
   DEF        RASPI5
   DEVICETOPIC MQTT2_RASPI5
   FUUID      5c49df8f-f33f-a3b0-cd49-62a7f04197a6de76
   IODev      m2s
   LASTInputDev m2s
   MSGCNT     24
   NAME       MQTT2_RASPI5
   NR         608
   STATE      online
   TYPE       MQTT2_DEVICE
   m2s_MSGCNT 24
   m2s_TIME   2020-04-07 14:56:45
     2020-01-13 13:45:25   devices         {"type":"devices","message":[{"ieeeAddr":"0x000b57fffe9a1211","type":"Router","model":"LED1649C5","friendly_name":"IKEA01"}]}
     2020-01-13 13:45:21   graphviz        digraph G {
node[shape=record];
  "0x00124b001b7b29dd" [label="{0x00124b001b7b29dd|Coordinator|No model information available|online}"];
  "0x00124b001b7b29dd" -> "0x000b57fffe9a1211" [label="141"]
  "0x000b57fffe9a1211" [label="{IKEA01|Router|IKEA TRADFRI LED bulb E12/E14/E17 400 lumen, dimmable warm white, chandelier opal (LED1649C5)|online}"];
  "0x000b57fffe9a1211" -> "0x00124b001b7b29dd" [label="82"]
     2020-04-07 14:56:45   log             {"type":"pairing","message":"interview_successful","meta":{"friendly_name":"AQARA2","model":"WSDCGQ11LM","vendor":"Xiaomi","description":"Aqara temperature, humidity and pressure sensor","supported":true}}
     2019-01-18 16:58:12   rename_new      'IKEA_01'
     2019-01-18 16:58:12   rename_old      IKEA_01
     2020-04-07 14:51:17   state           online
     2020-04-07 14:50:11   subscriptions   zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/+/get zigbee2mqtt/+/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/+/set zigbee2mqtt/+/+/+/+/+/set/+ zigbee2mqtt/+/+/+/+/get zigbee2mqtt/+/+/+/+/get/+ zigbee2mqtt/+/+/+/+/set zigbee2mqtt/+/+/+/+/set/+ zigbee2mqtt/+/+/+/get zigbee2mqtt/+/+/+/get/+ zigbee2mqtt/+/+/+/set zigbee2mqtt/+/+/+/set/+ zigbee2mqtt/+/+/get zigbee2mqtt/+/+/get/+ zigbee2mqtt/+/+/set zigbee2mqtt/+/+/set/+ zigbee2mqtt/+/get zigbee2mqtt/+/get/+ zigbee2mqtt/+/set zigbee2mqtt/+/set/+ zigbee2mqtt/bridge/bind/# zigbee2mqtt/bridge/config/+ zigbee2mqtt/bridge/config/+/+ zigbee2mqtt/bridge/configure zigbee2mqtt/bridge/device/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/+/+/+/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/+/+/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/+/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/+/get_group_membership zigbee2mqtt/bridge/device/+/+/get_group_membership zigbee2mqtt/bridge/device/+/get_group_membership zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/+/add zigbee2mqtt/bridge/group/+/+/+/remove zigbee2mqtt/bridge/group/+/+/+/remove_all zigbee2mqtt/bridge/group/+/+/add zigbee2mqtt/bridge/group/+/+/remove zigbee2mqtt/bridge/group/+/+/remove_all zigbee2mqtt/bridge/group/+/add zigbee2mqtt/bridge/group/+/remove zigbee2mqtt/bridge/group/+/remove_all zigbee2mqtt/bridge/group/remove_all zigbee2mqtt/bridge/networkmap zigbee2mqtt/bridge/networkmap/routes zigbee2mqtt/bridge/ota_update/check zigbee2mqtt/bridge/ota_update/update zigbee2mqtt/bridge/unbind/#
   IODev      m2s
   bridgeRegexp zigbee2mqtt/([A-Za-z0-9]*)[/]?.*:.* "zigbee_$1"
   getList    devicelist:noArg log zigbee2mqtt/bridge/config/devices
  networkmap_raw:noArg raw zigbee2mqtt/bridge/networkmap raw
  networkmap_graphviz:noArg graphviz zigbee2mqtt/bridge/networkmap graphviz
   model      L_01_zigbee2mqtt_bridge
   readingList zigbee2mqtt/bridge/state:.* state
  zigbee2mqtt/bridge/config/devices:.* {}
  zigbee2mqtt/bridge/config/log_level:.* log_level
  zigbee2mqtt/bridge/config/permit_join:.* permit_join
  zigbee2mqtt/bridge/config/rename:.* { json2nameValue($EVENT, 'rename_') }
  zigbee2mqtt/bridge/log:.*\"type\".\"devices\".\"message\".* devices
  zigbee2mqtt/bridge/log:.* log
  zigbee2mqtt/bridge/networkmap:.* {}
  zigbee2mqtt/bridge/networkmap/graphviz:.* graphviz
  zigbee2mqtt/bridge/networkmap/raw:.* raw
   room       MQTT2_DEVICE
   setList    log_level:debug,info,warn,error zigbee2mqtt/bridge/config/log_level $EVTPART1
  permit_join:true,false zigbee2mqtt/bridge/config/permit_join $EVTPART1
  remove:textField zigbee2mqtt/bridge/config/remove $EVTPART1
  rename:textField zigbee2mqtt/bridge/config/rename  {"old":"$EVTPART1","new":"$EVTPART2"}
   setStateList on off
Die Configuration dort war:
mqtt:
  base_topic: zigbee2mqtt
  server: 'mqtt://192.168.0.20:11883'
  client_id: RASPI5
advanced:
  rtscts: false
  include_device_information: true
serial:
  port: >-
    /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001-if00-port0
Nun habe ich das zigbee2MQTT aktualisiert. Es kam dabei dies Gerät dazu:
   CFGFN
   CID        zigbee_bridge
   DEF        zigbee_bridge
   DEVICETOPIC MQTT2_zigbee_bridge
   FUUID      5e8b528e-f33f-a3b0-729d-bdf74fa4768d051d
   IODev      m2s
   LASTInputDev m2s
   MSGCNT     1
   NAME       MQTT2_zigbee_bridge
   NR         15096
   STATE      ???
   TYPE       MQTT2_DEVICE
   m2s_MSGCNT 1
   m2s_TIME   2020-04-07 14:51:18
     2020-04-06 18:02:22   associatedWith  MQTT2_RASPI5
     2020-04-07 14:51:18   commit          840b9d9
     2020-04-07 14:51:18   coordinator_meta_maintrel 0
     2020-04-07 14:51:18   coordinator_meta_majorrel 2
     2020-04-07 14:51:18   coordinator_meta_minorrel 0
     2020-04-07 14:51:18   coordinator_meta_product 0
     2020-04-07 14:51:18   coordinator_meta_revision
     2020-04-07 14:51:18   coordinator_meta_transportrev 2
     2020-04-07 14:51:18   coordinator_type zStack12
     2020-04-07 14:51:18   log_level       info
     2020-04-07 14:51:18   permit_join     true
     2020-04-07 14:51:18   version         1.12.0
   IODev      m2s
   readingList zigbee2mqtt/bridge/config:.* { json2nameValue($EVENT) }
   room       MQTT2_DEVICE
Nun habe ich sogar 2 Geräte, bei denen ich nicht weiß, ob das so richtig ist, was ich damit anfange und welche templates ich denen zuweise.
Könnte mir jemand einen Tip geben?
Die reinen Nutzgeräte von IKEA und XIAOMI funktionieren perfekt.
joelinux
Der Update deines zigbee2MQTT liefert zusätzliche und verbesserte Informationen an den MQTT2 Server und daher
hat der MQTT2 Server die neuen Informationen einem neuem Gerät MQTT2_zigbee_bridge zugewiesen.
Eigentlich hast du schon ein zigbee Brücken Gerät, das bei dir MQTT2_RASPI5 heißt. Die zusätzlichen Informationen
die jetzt MQTT2_zigbee_bridge zugewiesen sind gehören bei dir eigentlich zu MQTT2_RASPI5.
Mein Vorschlag ist dein MQTT2_RASPI5 Gerät auf das aktuelle Template zigbee2mqtt_bridge zu migrieren.
Eventuell vorher mit update check, update und shutdown restart dein FHEM auf den neuesten Stand bringen.
Im Bereich zigbee2mqtt Templates hat es einiges getan.
Anschließend wäre das neue Gerät MQTT2_zigbee_bridge überflüssig und daher dann auch gelöscht werden.
Mit freundlichem Gruß
joelinux
FHem on RPi2 Buster, Duofern Rollladen, ZWave Rolllade + Steckdosen, ZigBee (Philips, Tradfri), Tasmota (diverse Steckdosen, GU10 und E14 LSC Leds von Action, Sonoff RF Bridge), InterTechno Dimmer Steckdose ITLR-200
masterpete23
Danke dir.
Habe ich umgesetzt und nun schaue ich nach (negativen) Effekten
