Configuration tool
Begonnen von dk3572, 29 April 2020, 13:44:29
dk3572
ich habe diesen Rauchmelder über Phoscon verbunden und in fhem angelegt.
   DEF        sensor 16 1 IODev=deCONZ
   FUUID      5ea7f74b-f33f-cd72-6b03-5ed30b451f050dfb
   FVERSION   31_HUEDevice.pm:0.217030/2020-04-16
   ID         S16
   INTERVAL   1
   IODev      deCONZ
   NAME       Rauchmelder_KG_2
   NR         407
   STATE      nofire
   TYPE       HUEDevice
   lastupdated 2020-04-28 13:26:29
   lastupdated_local 2020-04-28 15:26:29
   manufacturername Heiman
   modelid    SMOK_YDLV10
   name       Rauchmelder
   on         1
   reachable  1
   swversion  20150330
   type       ZHAFire
   uniqueid   00:50:43:c9:03:35:12:72-01-0500
     2020-04-29 13:21:27   battery         100
     2020-04-29 13:21:27   batteryPercent  100
     2020-04-28 15:26:29   batteryState    ok
     2020-04-28 15:26:29   fire            0
     2020-04-29 13:21:27   reachable       1
     2020-04-28 15:26:29   state           nofire
     2020-04-28 15:26:29   tampered        0
   helper:
     devtype    S
     reachable  0
     update_timeout 1
     configList:
     json:
       ep         1
       etag       eec52a3f62d0e23b80576c9f2012e2c8
       modelid    SMOK_YDLV10
       name       Rauchmelder
       swversion  20150330
       type       ZHAFire
       config:
         battery    100
       state:
         lastupdated 2020-04-28T13:26:29
     setList:
   IODev      deCONZ
   devStateIcon nofire:general_ok@green fire:fire@red
   group      smokeDetector
   icon       secur_smoke_detector
   model      SMOK_YDLV10
   room       Alarme,HUEDevice
   webCmd     statusRequest
Seit dem habe ich in fhem folgendes Device:
   CFGFN
   DEF        16  IODev=deCONZ
   FUUID      5ea9115a-f33f-cd72-9d28-3aa42e493123ef54
   ID         16
   INTERVAL
   IODev      deCONZ
   NAME       deCONZ_HUEDevice16
   NR         410
   STATE      on
   TYPE       HUEDevice
   manufacturername dresden elektronik
   modelid    ConBee
   name       Configuration tool 16
   swversion  0x260b0500
   type       Configuration tool
   uniqueid   00:21:2e:ff:ff:03:b4:56-01
     2020-04-29 07:32:21   pct             100
     2020-04-29 07:32:21   reachable       1
     2020-04-29 07:32:21   state           on
   helper:
     alert
     battery    -1
     bri        -1
     colormode
     ct         -1
     devtype
     effect
     hue        -1
     mode
     on         -1
     pct        100
     reachable  1
     rgb
     sat        -1
     update_timeout -1
     xy
     json:
       etag       115f643349ceeb6235abb3e1ff94442a
       modelid    ConBee
       state:
   IODev      deCONZ
   alias      Configuration tool 16
   color-icons 2
   devStateIcon {(HUEDevice_devStateIcon($name),"toggle")}
   group      HUEDevice
   model      ConBee
   room       HUEDevice
In der Phoscon App taucht der Rauchmelder auch nicht auf.
Woran kann das liegen?
Für Hilfe und Infos dankbar.
VG Dieter
sledge
Es handelt sich um einen bekannten Fehler in der Phoscon App, dass einige Sensoren nicht auftauchen.
Gleiches gilt auch für den Xiaomi Aqara SmokeSensor... funktioniert einwandfrei mit FHEM, taucht in der App aber nicht auf. Wenn Du nach dem Xiaomi Sensor + Phoscon / Conbee suchst, findest Du auch einen sehr langen Diskussionsthread zu dem Thema...
Tom
FHEM: debian Intel-NUC / 25 x MAX!, 15 x HM-bidcos, MQTT, 3 x 1wire, 20 x Shelly, 20 x Tasmota, 12 x Yeelight, Opentherm-GW, Espeasy, alexa-fhem, kodi, unifi, musiccast, ...
dk3572
Danke für die Rückmeldung.
Meintest du das hier?
https://forum.fhem.de/index.php/topic,108130.msg1021060.html#msg1021060
Den hatte ich nämlich bereits gelesen. Dachte aber hier wäre das Problem nach einem Update gelöst.
sinus61
Viele Sensoren, vor allem neuere, erscheinen ja nach dem anlernen nicht in Phoscon. Das gilt hier auch für den Heiman/Schwaiger Rauchmelder. Die meisten sind ja aber über die Api in FHEM verfügbar. Phoscon fragt im Prinzip ja auch die Api ab, zeigt dann aber nur das an was es kennt. Ist natürlich irgendwie eine Schwäche von Phoscon solche Sensoren nicht wenigstens lesend anzuzeigen auch wenn es damit nichts anfangen kann.
dk3572
Danke für die ausführliche Antwort.
Was hat es mit dem Configuration tool auf sich?
Ich bin der Meinung es ist erst seit Anlegen des Rauchmelders mit angelegt worden und hat die gleiche Sensor Nr. (16)
Hatte das tool auch gelöscht, wurde aber nach Neustart wieder angelegt.
Danke und VG Dieter
sledge
ich meinte diesen Thread hier (außerhalb von FHEM):
https://github.com/dresden-elektronik/deconz-rest-plugin/issues/152
Zu dem Punkt mit dem "configuration Tool" kann ich Dir leider nichts sagen - das tritt bei meinem Rauchmelder nicht auf...
VG Tom
rcmcronny
Das Configuration Tool kommt seit der .74 (und auch bei .75) mit und ist wohl beabsichtigt, am besten einfach angelegt lassen und voerst ignorieren. Da gibt es auch Beitrage zu hier und auch bei Deconz Github ;)
Ronny
