[gelöst] HILFE: Fhem hängt sich auf..
Begonnen von kotaro, 09 Mai 2020, 09:54:18
kotaro
Hallo
irgendwie scheint sich mein FHEM aufzuhängen.
Leider weiß ich nicht direkt, wo das problem ist, und da FHEMWEB nicht aufgerufen werden kann, kann ich auch nicht probieren, wo der fehler liegt.
Anhand von Portainer-Log habe ich zumindest folgende Nachricht:
Edit: nochmal der komplette log
:2020.05.09 13:13:46 1: PERL WARNING: Deep recursion on subroutine "main::CallFn" at fhem.pl line 1900.
2020.05.09 13:13:46 1: stacktrace:
2020.05.09 13:13:46 1:     main::__ANON__                      called by fhem.pl (1900)
2020.05.09 13:13:46 1:     main::CallFn                        called by fhem.pl (1900)
2020.05.09 13:13:46 1:     main::DoSet                         called by fhem.pl (1932)
2020.05.09 13:13:46 1:     main::CommandSet                    called by fhem.pl (1243)
2020.05.09 13:13:46 1:     main::AnalyzeCommand                called by fhem.pl (1096)
2020.05.09 13:13:46 1:     main::AnalyzeCommandChain           called by ./FHEM/98_DOIF.pm (1727)
2020.05.09 13:13:46 1:     main::ParseCommandsDoIf             called by ./FHEM/98_DOIF.pm (2161)
2020.05.09 13:13:46 1:     main::DOIF_cmd                      called by ./FHEM/98_DOIF.pm (2415)
2020.05.09 13:13:46 1:     main::DOIF_Trigger                  called by ./FHEM/98_DOIF.pm (3536)
2020.05.09 13:13:46 1:     main::DOIF_Set                      called by fhem.pl (3772)
2020.05.09 13:13:46 1: PERL WARNING: Deep recursion on subroutine "main::AnalyzeCommandChain" at ./FHEM/98_DOIF.pm line 1727.
2020.05.09 13:13:46 1:     main::__ANON__                      called by ./FHEM/98_DOIF.pm (1727)
2020.05.09 13:13:46 1: PERL WARNING: Deep recursion on subroutine "main::AnalyzeCommand" at fhem.pl line 1096.
2020.05.09 13:13:46 1:     main::__ANON__                      called by fhem.pl (1096)
2020.05.09 13:13:46 1: PERL WARNING: Deep recursion on subroutine "main::CommandSet" at fhem.pl line 1243.
2020.05.09 13:13:46 1:     main::__ANON__                      called by fhem.pl (1243)
2020.05.09 13:13:46 1: PERL WARNING: Deep recursion on subroutine "main::DoSet" at fhem.pl line 1932.
2020.05.09 13:13:46 1:     main::__ANON__                      called by fhem.pl (1932)
2020.05.09 13:13:46 1: PERL WARNING: Deep recursion on subroutine "main::DOIF_Trigger" at ./FHEM/98_DOIF.pm line 3536.
2020.05.09 13:13:46 1:     main::__ANON__                      called by ./FHEM/98_DOIF.pm (3536)
2020.05.09 13:13:46 1: PERL WARNING: Deep recursion on subroutine "main::DOIF_cmd" at ./FHEM/98_DOIF.pm line 2415.
2020.05.09 13:13:46 1:     main::__ANON__                      called by ./FHEM/98_DOIF.pm (2415)
kotaro
weiter gehts:
2020.05.09 13:13:46 1: PERL WARNING: Deep recursion on subroutine "main::ParseCommandsDoIf" at ./FHEM/98_DOIF.pm line 2161.
2020.05.09 13:13:46 1:     main::__ANON__                      called by ./FHEM/98_DOIF.pm (2161)
2020.05.09 13:13:46 1: PERL WARNING: Deep recursion on subroutine "main::DOIF_Set" at fhem.pl line 3772.
2020.05.09 13:13:46 1:     main::__ANON__                      called by fhem.pl (3772)
Wie kann ich herausfinden, welches DOIF den Fehler hat?
moskito
Funktioniert FHEM denn nach einem Neustart erstmal?
Dann könntest Du in der Eingabzeile der Oberfläche
attr TYPE=DOIF disable 1
eingeben. Damit werden dann erstmal alle DOIFs abgeschaltet.
Dann gibt es mehrere Optionen:
- nach und nach wieder einschalten der DOIFs bis der Fehler wiederkommt
- die nachschauen die zuletzt geändert wurden
- evtl. hast Du ja schon ein bestimmtes DOIF in Verdacht
Danny
FHEM auf Intel NUC/Proxmox & Debian 12 + HM-CFG-USB + zigbee2mqtt + Zwave + Enocean
Damian
Die Meldung besagt, dass du dir eine Endlosschleife eingebaut hast. Du müsstest schauen, welche Einträge kurz vorher geloggt werden, um Rückschlüsse auf das betroffene DOIF zu ziehen. Ansonsten bleibt dir nichts anders übrig, als alles zu deaktivieren und nacheinander wieder aktivieren, bis der Fehler eindeutig eingekreist wird.
kotaro
Danke für eure Hinweise.
Der Hinweis mit dem disable ist etwas. wonach ich gesucht habe.
Danke euch
