Revision 21983: 98_RandomTimer.pm: Add perl syntax check to disableCond attribute; ...
Begonnen von System, 21 Mai 2020, 06:30:08
System
98_RandomTimer.pm: Add perl syntax check to disableCond attribute; remove unused function; perltidy patch
Source: Revision 21983: 98_RandomTimer.pm: Add perl syntax check to disableCond attribute; ...
