Autor Thema: maxfakewallthermostat question  (Gelesen 1604 mal)
Offline kroonen
  • Full Member
    • http://www.kroonen.eu/mobile
« am: 06 Juni 2020, 22:11:39 »
medling
I have an max thermostat basic, that works, but I want to use an other temperature sensor for it.
So i decided to use my oregon temperature sensor (slaapkamertemp)
Slaapkamertemp
     2020-06-06 19:54:19   humidity        36.00
     2020-06-06 19:54:19   temperature     19.40
     2020-06-06 19:54:19   temperatuur     19.4
the max thermostat basic is MAX_130261
This is in
# $Id: myUtilsTemplate.pm 21509 2020-03-25 11:20:51Z rudolfkoenig $
# Save this file as 99_myUtils.pm, and create your own functions in the new
# file. They are then available in every Perl expression.
package main;
use strict;
use warnings;
sub
myUtils_Initialize($$)
  my ($hash) = @_;
# Enter you functions below _this_ line.
sub MaxFakeWallThermostat($$)
 my ($heizung, $aktTemp)    = @_;
 my $CULMAX     = $defs{$heizung}{LASTInputDev};
 my $desiredTemp   = ReadingsVal($heizung, "desiredTemperature", undef);
 my $windowOpenTemp = ReadingsVal($heizung, "windowOpenTemperature", undef);
 my $lastTemp    = ReadingsVal($heizung, "LastExtTemperature", 0);
 my $lastSet     = ReadingsTimestamp($heizung, "LastExtTemperature", 0);
 if($desiredTemp && $windowOpenTemp &&
 $desiredTemp != $windowOpenTemp &&
 (time()-time_str2num($lastSet) >= 600 || abs($aktTemp-$lastTemp)>=0.2 )) {
  Log 3, "set $CULMAX fakeWT $heizung $desiredTemp $aktTemp";
  readingsSingleUpdate($defs{$heizung}, "LastExtTemperature", $aktTemp, 0);
  fhem("set $CULMAX fakeWT $heizung $desiredTemp $aktTemp");
and did a notify
define SendExtTemp notify Slaapkamertemp:temperatuur.* {\
 MaxFakeWallThermostat("MAX_130261", $EVTPART1);;\
I ony get an error
2020.06.06 22:06:17 3: CM_Parse, unhandled message WakeUp from MAX_130261 to MAX_111111, groupid : 0 , payload : 03 - ignoring !
2020.06.06 22:06:17 3: CULMAX, target device 111111 has no name !
Offline Wzut
Antw:maxfakewallthermostat question
« Antwort #1 am: 07 Juni 2020, 08:33:50 »
please post a list of your CULMAX device
Offline kroonen
  • Full Member
« Antwort #2 am: 07 Juni 2020, 09:53:03 »
Hi
Did again so enabled the sendext again. And now it works. I think maybe issue with credits yesterday.
regards Richard
Offline Wzut
« Antwort #3 am: 07 Juni 2020, 14:41:42 »
hmm, strange. If the credits are low you will have other lines in the log.
This two lines are not real errors , more like information. Do you have more than one CUL device ?
other point in your 99_myUtils :
my $CULMAX     = $defs{$heizung}{LASTInputDev};this is a little bit unlucky because the Internal LASTInputDev sometimes could be empty.
IMHO saver
sub MaxFakeWallThermostat {
    my $heizung  = shift;
    my $aktTemp  = shift;
    my $CULMAX   = (exists($defs{$heizung}{IODev}->{NAME})) ? $defs{$heizung}{IODev}->{NAME} : '';
    my $desiredTemp    = ReadingsNum($heizung, 'desiredTemperature', 0);
    my $windowOpenTemp = ReadingsNum($heizung, 'windowOpenTemperature', 0);
    return if (!$CULMAX || !$desiredTemp && !$windowOpenTemp);
    my $lastTemp       = ReadingsNum($heizung, 'LastExtTemperature', 0);
    my $lastSet        = ReadingsAge($heizung, 'LastExtTemperature', 0);
    if ((($desiredTemp != $windowOpenTemp) && ($lastSet > 599)) || (abs($aktTemp-$lastTemp) > 0.1)) {
Log3($CULMAX, 3, "$CULMAX, set fakeWT $heizung $desiredTemp $aktTemp");
readingsSingleUpdate($defs{$heizung}, 'LastExtTemperature', $aktTemp, 0);
my $ret = CommandSet(undef, "$CULMAX fakeWT $heizung $desiredTemp $aktTemp");
Log3($CULMAX, 2, "$CULMAX, error : $ret") if ($ret);
    return;
« Letzte Änderung: 07 Juni 2020, 14:43:32 von Wzut »
Offline kroonen
  • Full Member
« Antwort #4 am: 08 Juni 2020, 22:28:35 »
Thnx for the update for the 99_myutils (maybe also the fhem max wiki need to be change here)
I'm also testing the culfw on the esp 8266 with an cc1101 soldered on, from Manfred, and looks very good already (so maybe this gives some of my errors;-)
https://github.com/Man-fred/culfw-esp8266
Offline kroonen
  • Full Member
« Antwort #5 am: 09 Juni 2020, 22:26:23 »
still one question
a fakewallthermostat is this limited to 1, because of one 11111 address?
I have more temperature sensors and more cul max basic radiatorthermostats
regards Richard
Offline Wzut
« Antwort #6 am: 10 Juni 2020, 06:45:00 »
Did you read https://forum.fhem.de/index.php/topic,106258.0.html ?
IMHO the problems with fakeWT are the same as with fakeSC.
As an alternative to fakeSC, I created the new vitrualShutterContact device. Its advantage is that you can define as many of them as you want.
In some cases there is already support for a virtualWallThermostat in the code from 10_MAX and 14_CUL_MAX.
First attempts with it are very promising.
I think I'll have that done by autumn. Until then you have to get along with the only one fakeWT.
Offline kroonen
  • Full Member
« Antwort #7 am: 10 Juni 2020, 12:17:11 »
Thnx for the answer.
I'm looking forward to test it.
Good job already with the max module.
