« am: 16 Juni 2020, 19:25:33 »
ich nutze einen Bewegungsmelder in Verbindung mit einem Switch. Der Switch meldet seit paar Tagen MISSING ACK
Listing des Switch:
DEF 3C83E6
FUUID 5c44b2f7-f33f-4e46-9947-0c1bc5f31d9c3d3d
IODev HMLAN1
NAME keller_deckenleuchten
NOTIFYDEV global
NR 333
NTFY_ORDER 50-keller_deckenleuchten
STATE MISSING ACK
TYPE CUL_HM
chanNo 01
peerList keller_bm,
protCmdDel 13
protResnd 30 last_at:2020-06-16 19:07:05
protResndFail 10 last_at:2020-06-16 19:07:10
protSnd 10 last_at:2020-06-16 19:06:51
protState CMDs_done_Errors:1
2020-06-16 19:07:10 commState CMDs_done_Errors:1
2020-06-16 19:07:10 state MISSING ACK
helper:
HM_CMDNR 246
cSnd 012CD7B93C83E6010E,112CD7B93C83E60201000000
cfgChkResult No regs found for:keller_deckenleuchten
dlvl 00
dlvlCmd ++A0112CD7B93C83E60201000000
mId 0002
peerFriend peerSens,peerVirt
peerOpt 3:switch
regLst 0,1,3p
rxType 1
cmds:
TmplKey keller_bm,:no:1592319640.09014
TmplTs 1592319640.09014
cmdKey :1:1:0::0002:01keller_bm,
TmplCmds:
tplSet_keller_bm_chn-01:[SwCondAbove_long|SwCondAbove_short|SwCondBelow_long|SwCondBelow_short|SwOff_long|SwOff_short|SwOnCond_long|SwOnCond_short|SwOn_long|SwOn_short|SwToggle_long|SwToggle_short|autoOff_long|autoOff_short|motionOnSw_long|motionOnSw_short]
cmdList:
assignHmKey:
clear:[readings|trigger|register|oldRegs|rssi|msgEvents|msgErrors|attack|all]
deviceRename:newName
eventL:-peer- -cond-
eventS:-peer- -cond-
fwUpdate:-filename- -bootTime- ...
getConfig:
getDevInfo:
getRegRaw:[List0|List1|List2|List3|List4|List5|List6] ... [-PeerChannel-]
getSerial:
getVersion:
inhibit:[on|off]
off:
on-for-timer:-ontime-
on-till:-time-
on:
pair:
peerBulk:-peer1,peer2,...- [set|unset]
peerIODev:[IO] -btn- [set|unset]... not for future use
peerSmart:[remove_keller_bm|bd_fenster|di_fenster|he_fenster|lu_fenster|v_bd_dg_fenster|v_hwr_fenster|v_wz_fenster_re_li|vccu]
press:[long|short] -peer- [-repCount(long only)-] [-repDelay-] ...
raw:data ...
regBulk:-list-.-peer- -addr1:data1- -addr2:data2- ...
regSet:[prep|exec] -regName- -value- ... [-peerChannel-]
reset:
sign:[on|off]
statusRequest:
toggle:
tplDel:tmplt
unpair:
expert:
def 1
det 0
raw 1
tpl 0
io:
newChn +3C83E6,00,00,00
rxt 0
vccu vccu
p:
3C83E6
00
00
00
prefIO:
HMLAN1
mRssi:
mNo
io:
HMLAN1:
prt:
bErr 0
sProc 0
q:
qReqConf
qReqStat
role:
chn 1
dev 1
prs 1
rssi:
shadowReg:
tmpl:
nb:
cnt 1
IODev HMLAN1
IOgrp vccu:HMLAN1
autoReadReg 4_reqStatus
devStateIcon on.*:on-for-timer
expert 2_full
firmware 2.8
fp_Untergeschoss 463,445,0,keller_deckenleuchten,
model HM-LC-SW1-FM
peerIDs 00000000,3AC0DF01,
room Keller,CUL_HM
serialNr MEQ0710035
subType switch
webCmd statusRequest:toggle:on:off
Listing des Bewegungsmelders:
DEF 3AC0DF
FUUID 5c44b2f8-f33f-4e46-e4ce-1ea3ea4e778f0f4f
HMLAN1_MSGCNT 38
HMLAN1_RAWMSG E3AC0DF,0000,5850F94E,FF,FFB1,06A0413AC0DF3C83E601082260
HMLAN1_RSSI -79
HMLAN1_TIME 2020-06-16 19:22:17
IODev HMLAN1
LASTInputDev HMLAN1
MSGCNT 38
NAME keller_bm
NOTIFYDEV global
NR 344
NTFY_ORDER 50-keller_bm
STATE motion
TYPE CUL_HM
chanNo 01
lastMsg No:06 - t:41 s:3AC0DF d:3C83E6 01082260
peerList keller_deckenleuchten,
protLastRcv 2020-06-16 19:22:17
protRcv 32 last_at:2020-06-16 19:22:17
rssi_at_HMLAN1 cnt:38 min:-81 max:-74 avg:-76.94 lst:-79
2020-06-16 17:00:38 Activity alive
2019-02-06 15:28:14 D-firmware 1.6
2019-02-06 15:28:14 D-serialNr MEQ0538604
2020-03-28 12:55:12 PairedTo 0x2CD7B9
2020-03-28 12:55:13 R-brightFilter 7
2020-03-28 12:55:13 R-captInInterval off
2020-03-28 12:55:13 R-evtFltrNum 1
2020-03-28 12:55:13 R-evtFltrPeriod 1 s
2020-03-28 12:55:14 R-keller_deckenleuchten_chn-01-peerNeedsBurst off
2020-03-28 12:55:13 R-minInterval 60
2020-03-28 12:55:12 R-pairCentral 0x2CD7B9
2020-03-28 12:55:12 R-sabotageMsg on
2020-03-28 12:55:13 R-sign off
2020-03-28 12:55:12 RegL_00. 00:00 02:01 0A:2C 0B:D7 0C:B9 10:01
2020-03-28 12:55:13 RegL_01. 00:00 01:12 02:72 08:00 22:00
2020-03-28 12:55:14 RegL_04.keller_deckenleuchten_chn-01 00:00 01:00
2020-06-16 19:22:17 battery ok
2020-06-16 19:22:17 brightness 34
2019-09-27 13:29:33 cover closed
2020-06-16 19:22:17 motion on (to keller_deckenleuchten)
2020-06-16 19:22:17 motionCount 8_next:60s
2020-06-16 17:17:42 motionDuration 62
2020-06-16 17:00:40 peerList keller_deckenleuchten,
2020-03-28 12:55:11 powerOn 2020-03-28 12:55:11
2020-06-16 19:21:30 recentStateType info
2020-06-16 19:21:30 sabotageError off
2020-06-16 19:22:17 state motion
2020-06-16 19:22:17 trigger_cnt 8
helper:
HM_CMDNR 6
mId 004A
moStart 1592328137.41329
peerFriend peerAct,peerVirt
peerOpt 4:motionDetector
regLst 0,1,4p
rxType 28
supp_Pair_Rep 0
cmds:
TmplKey keller_deckenleuchten,:no:1592319640.05471
TmplTs 1592319640.05471
cmdKey :1:1:0::004A:01keller_deckenleuchten,
TmplCmds:
cmdList:
assignHmKey:
getConfig:
getDevInfo:
peerChan:-btnNumber- -actChn- ... single [set|unset] [actor|remote|both]
peerSmart:[remove_keller_deckenleuchten|HM_306BE5_Sw_04|HM_velux_down|HM_velux_stop|HM_velux_up|bd_rollo|rt_bd_dg_WindowRec|rt_bd_dg_remote|rt_bd_og_WindowRec|rt_bd_og_remote|rt_diele_WindowRec|rt_diele_remote|rt_hwr_WindowRec|rt_hwr_remote|rt_wz_li_WindowRec|rt_wz_li_remote|rt_wz_re_WindowRec|rt_wz_re_remote|v_bd_dg_fenster|v_hwr_fenster|v_wz_fenster_re_li|vccu]
raw:data ...
reset:
sign:[on|off]
tplDel:tmplt
trgEventL:[-peer-] -condition-
trgEventS:[-peer-] -condition-
trgPressL:[-peer-]
trgPressS:[-peer-]
unpair:
expert:
def 1
det 0
raw 1
tpl 0
io:
newChn +3AC0DF,00,00,00
nextSend 1592328137.9398
rxt 2
vccu vccu
p:
3AC0DF
00
00
00
prefIO:
HMLAN1
mRssi:
mNo 06
io:
HMLAN1:
-77
-77
prt:
bErr 0
sProc 0
sleeping 1
q:
qReqConf
qReqStat
role:
chn 1
dev 1
rssi:
at_HMLAN1:
avg -76.9473684210526
cnt 38
lst -79
max -74
min -81
shadowReg:
tmpl:
IODev HMLAN1
IOgrp vccu:HMLAN1
actCycle 000:20
actStatus alive
expert 2_full
firmware 1.6
model HM-SEC-MDIR-2
peerIDs 00000000,3C83E601,
room CUL_HM,Keller
serialNr MEQ0538604
subType motionDetector
Normalerweise sag ich immer "HM ist lanweilig" weil alles so gut funktioniert, deshalb hab ich mich lange nicht mehr intensiv mit dem Thema befasst und könnte jetzt eure Hilfe gebrauchen
« Letzte Änderung: 17 Juni 2020, 00:29:18 von grappa24 »
Gespeichert
FHEM 6.0, 2 x RasPi 3B+, Debian Stretch; KNX, FS20, HM, HUE, Tradfri, Shellies
Rollo-/Lichtsteuerung/-szenarien, Velux via HM, T-Sensoren, Wassermelder, Fensterkontakte, Heizungssteuerung, HEOS, Sprachsteuerung mit Alexa-FHEM, Xiaomi Flower Care, Netatmo, ...
