Chart-Line springt immer wieder auf Null-Linie
Begonnen von stobor, 03 Juli 2020, 08:45:27
stobor
ich lasse mir die Temperatur als Chart anzeigen:
<div data-type="chart"
data-logdevice='["FileLog_HM_PoolTemperatur"]'
data-columnspec='["4:1.ACTUAL_TEMPERATURE:"]'
data-style='["ftui l2"]'
data-ptype='["lines"]'
data-uaxis='["primary"]'
data-legend='["Temperatur"]'
data-yunit="°C"
data-ytext="Temperatur"
data-minvalue="auto"
data-maxvalue="auto"
data-height="250"
data-yticks="auto"
data-nofulldays="true"
data-cursorgroup="1"
data-scrollgroup="1"
data-xticks="auto">
</div>
Im Log stehen diese Daten:
2020-07-03_00:51:52 HM_PoolTemperatur hmstate: Initialized
2020-07-03_00:51:52 HM_PoolTemperatur 1.ACTUAL_TEMPERATURE: 19.7
2020-07-03_00:51:52 HM_PoolTemperatur 1.ACTUAL_TEMPERATURE_STATUS: 0
2020-07-03_01:19:36 HM_PoolTemperatur hmstate: Initialized
2020-07-03_01:19:36 HM_PoolTemperatur 1.ACTUAL_TEMPERATURE: 19.6
2020-07-03_01:19:36 HM_PoolTemperatur 1.ACTUAL_TEMPERATURE_STATUS: 0
2020-07-03_02:12:20 HM_PoolTemperatur hmstate: Initialized
2020-07-03_02:12:20 HM_PoolTemperatur 1.ACTUAL_TEMPERATURE: 19.5
2020-07-03_02:12:20 HM_PoolTemperatur 1.ACTUAL_TEMPERATURE_STATUS: 0
2020-07-03_03:05:43 HM_PoolTemperatur hmstate: Initialized
2020-07-03_03:05:43 HM_PoolTemperatur 1.ACTUAL_TEMPERATURE: 19.4
2020-07-03_03:05:43 HM_PoolTemperatur 1.ACTUAL_TEMPERATURE_STATUS: 0
2020-07-03_03:34:05 HM_PoolTemperatur hmstate: Initialized
2020-07-03_03:34:05 HM_PoolTemperatur 1.ACTUAL_TEMPERATURE_STATUS: 0
2020-07-03_03:34:05 HM_PoolTemperatur 1.ACTUAL_TEMPERATURE: 19.3
2020-07-03_04:27:00 HM_PoolTemperatur hmstate: Initialized
2020-07-03_04:27:00 HM_PoolTemperatur 1.ACTUAL_TEMPERATURE_STATUS: 0
2020-07-03_04:27:00 HM_PoolTemperatur 1.ACTUAL_TEMPERATURE: 19.2
2020-07-03_04:43:19 HM_PoolTemperatur hmstate: Initialized
2020-07-03_04:43:21 HM_PoolTemperatur hmstate: Initialized
2020-07-03_04:43:21 HM_PoolTemperatur 1.ACTUAL_TEMPERATURE_STATUS: 0
2020-07-03_04:43:21 HM_PoolTemperatur 1.ACTUAL_TEMPERATURE: 19.2
2020-07-03_05:20:34 HM_PoolTemperatur hmstate: Initialized
2020-07-03_05:20:34 HM_PoolTemperatur 1.ACTUAL_TEMPERATURE_STATUS: 0
2020-07-03_05:20:34 HM_PoolTemperatur 1.ACTUAL_TEMPERATURE: 19.1
2020-07-03_05:22:46 HM_PoolTemperatur hmstate: Initialized
2020-07-03_05:22:46 HM_PoolTemperatur 1.ACTUAL_TEMPERATURE_STATUS: 0
2020-07-03_05:22:46 HM_PoolTemperatur 1.ACTUAL_TEMPERATURE: 19.0
2020-07-03_05:59:24 HM_PoolTemperatur hmstate: Initialized
2020-07-03_05:59:24 HM_PoolTemperatur 1.ACTUAL_TEMPERATURE: 18.9
2020-07-03_05:59:24 HM_PoolTemperatur 1.ACTUAL_TEMPERATURE_STATUS: 0
2020-07-03_06:16:12 HM_PoolTemperatur hmstate: Initialized
2020-07-03_06:16:12 HM_PoolTemperatur 1.ACTUAL_TEMPERATURE: 18.9
2020-07-03_06:16:12 HM_PoolTemperatur 1.ACTUAL_TEMPERATURE_STATUS: 0
2020-07-03_07:10:17 HM_PoolTemperatur hmstate: Initialized
2020-07-03_07:10:17 HM_PoolTemperatur 1.ACTUAL_TEMPERATURE: 18.8
2020-07-03_07:10:17 HM_PoolTemperatur 1.ACTUAL_TEMPERATURE_STATUS: 0
2020-07-03_08:02:54 HM_PoolTemperatur hmstate: Initialized
2020-07-03_08:02:54 HM_PoolTemperatur 1.ACTUAL_TEMPERATURE_STATUS: 0
2020-07-03_08:02:54 HM_PoolTemperatur 1.ACTUAL_TEMPERATURE: 18.8
Warum springt der Graph aber immer wieder mal auf die Null-Linie - siehe Screenshot?
Intel NUC (Ubuntu 24.04.4 LTS)  mit CUL V3.2 (FW 1.57 CUL868) für FS20 und CCU3 für HM(IP) + Arduino Mega (Firmata) - FHEM Revision: 31515 - FS20, HM(IP), MQTT, Philips HUE, ModBus
Nobbynews
#1
Abgesehen davon, dass der Screenshot fehlt, liegt es vermutlich an Deiner Definition:
Dein "ACTUAL_TEMPERATURE:" passt halt auf beides. Daher der Wert 0.
Die rechteckige Darstellung dürfte daher kommen, dass sich zu diesen Zeiten die Reihenfolge der beiden Werte vertauscht.
stobor
Wie kann ich den das System dazu bringen, dass
- nur die Temperatur geloggt wird
oder
- der Graph nur auf die wirklichen Temperaturwerte zugreift?
Nobbynews
stobor
define FileLog_HM_PoolTemperatur FileLog ./log/Klima/HM_PoolTemperatur-%Y-%m.log HM_PoolTemperatur
setuuid FileLog_HM_PoolTemperatur 5ef70556-f33f-2cfb-d426-83fb4ebaa2a3240d
attr FileLog_HM_PoolTemperatur room Klima
Nobbynews
Da fehlt imho der Trigger.
Mach mal im ersten Step aus
ein
define FileLog_HM_PoolTemperatur FileLog ./log/Klima/HM_PoolTemperatur-%Y-%m.log HM_PoolTemperatur:1.ACTUAL_TEMPERATURE:.*
Wenn dann immer noch beide Werte geloggt werden, würde ich mir ein userreading z.B. local_Temp erstellen und das dann loggen.
stobor
