Anzeige von Version (Firmwarestand) Tasmota
Begonnen von Huabafranze, 04 August 2020, 22:05:17
Huabafranze
ich habe einige tasmota Geräte zuhause mit folgender Konfiguration verbaut:
IODev MQTT2_FHEM_Server
alias Entertainment
autocreate 1
comment NOTE: For on-for-timer SetExtensions are used. You may add on-for-timer option running on the device. The following is limited to 1h max duration, but will not affect future simple "on" commands:<br>on-for-timer {my $duration = $EVTPART1*10; 'cmnd//Wohnzimmer/test/cmnd/tasmota/Backlog POWER1 1; delay '.$duration.'; POWER1 0'}<br>See the "Praxisbeispiele" in the wiki for "pulseTime1" alternative option and it's restrictions.
devStateIcon {my $online = ReadingsVal($name,"LWT","0") eq "Online"?"10px-kreis-gruen":"10px-kreis-rot";; my $stat = ReadingsVal($name,"POWER1","off") eq "on"?"it_television\@orange":"it_television\@black";; "<a href=\"http://".ReadingsVal($name,"IPAddress","none")." \"target=\"_blank\">".FW_makeImage($online). "</a> <a href=\"/fhem?cmd.dummy=set $name toggle&XHR=1\">".FW_makeImage($stat). "</a>"}
event-on-change-reading .*
genericDeviceType switch
icon it_television
jsonMap POWER1:0 POWER2:0 POWER3:0 POWER4:0 Dimmer:0 Channel_0:0 Channel_1:0 Channel_2:0 Channel_3:0 Channel_4:0 HSBColor:0 Color:0
model tasmota_basic_state_power1
readingList /Wohnzimmer/test/tele/tasmota/LWT:.* LWT
  /Wohnzimmer/test/tele/tasmota/STATE:.* { json2nameValue($EVENT,'',$JSONMAP) }
  /Wohnzimmer/test/tele/tasmota/SENSOR:.* { json2nameValue($EVENT,'',$JSONMAP) }
  /Wohnzimmer/test/tele/tasmota/INFO.:.* { json2nameValue($EVENT,'',$JSONMAP) }
  /Wohnzimmer/test/tele/tasmota/UPTIME:.* { json2nameValue($EVENT,'',$JSONMAP) }
  /Wohnzimmer/test/tele/tasmota/POWER1:.* POWER1
  /Wohnzimmer/test/stat/tasmota/RESULT:.* { json2nameValue($EVENT,'',$JSONMAP) }
Gosund_06:/Wohnzimmer/test/stat/tasmota/POWER1:.* POWER1
Gosund_06:/Wohnzimmer/test/cmnd/tasmota/POWER:.* POWER
Gosund_06:/Wohnzimmer/test/stat/tasmota/UPGRADE:.* { json2nameValue($EVENT) }
room MQTT2_DEVICE
setList off:noArg    /Wohnzimmer/test/cmnd/tasmota/POWER1 0
  on:noArg     /Wohnzimmer/test/cmnd/tasmota/POWER1 1
  toggle:noArg /Wohnzimmer/test/cmnd/tasmota/POWER1 2
  setOtaUrl:textField /Wohnzimmer/test/cmnd/tasmota/OtaUrl $EVTPART1
  upgrade:noArg   /Wohnzimmer/test/cmnd/tasmota/upgrade 1
setStateList set_on set_off toggle
webCmd on:off
Ich würde nun noch gerne neben dem Icon die Firmwareversion anzeigen, also das Reading "Version". Was müsste ich da anpassen?
PS. ich kenne mich mit Perl codes eigentlich gar nicht aus. Was hier als "Perl" eingegeben ist, habe ich mit copy-paste gemacht.
Woody14623
In case you did not find it yet, what you want is:
attr <device_name> stateFormat state<br>Version
Note that if you edit it via the web interface, you can put a newline after state, and it will show the icon associated instead of just the state text.  I don't know  how to do that in the command line though.
carlos
Bei mr haben alle tasmota Geräte dasselbe stateFormat
Hier ein sonoffdualR2 :
attr MQTT2_sonoffdualR2 stateFormat LWT\
<a href="http://IPAddress" target="_blank">Hostname</a>\
CH1\
1:POWER1 \
CH2\
2:POWER2\
<br>\
<b>Tasmota Revision:</b>\
Version\
<br>\
<b>Wifi AP Wifi_AP:</b>\
Wifi_SSId
Da habe ich alles was ich brauche.
btw. in den templates ist diesbezüglich, finde ich, auch ein ziemliches durcheinander.
Das könnte man mal vereinheitlichen auch im zusammenhang mit devStateIcon.
Wo ich das jetzt lese was ich geschrieben habe, hier ist noch mein devStateIcon:
attr MQTT2_sonoffdualR2 devStateIcon 1.on:on:POWER1+off 1.off:off:POWER1+on 2.on:on:POWER2+off 2.off:off:POWER2+on Online:10px-kreis-gruen@green Offline:10px-kreis-rot@red
Ist nur ein Verbesserungsvorschlag, die Template Geschichte an sich finde ich toll.
Hubert
FHEM svn auf Intel NUC mit proxmox, 3 Raspberry Pi, signalduino, nanoCUL,  toom Baumarkt Funksteckdosen, einige sonoffs, hue, shelly
