(Gelöst) JSON Senden in Post Request
Begonnen von Esjay, 09 September 2020, 21:22:53
Esjay
Guten Abend zusammen,
ich sitze mal wieder an einem Problem, bei dem ich nicht weiter komme.
Ich würde gerne den im Anhang zu sehenden Request in Fhem umsetzen.
Ich dachte an etwas wie
defmod MyDevice HTTPMOD none 0
attr MyDevice userattr set01Data set01Name set01TextArg:0,1 set01URL setHeader1
attr MyDevice DbLogExclude .*
attr MyDevice set01Data {"set" :{"command":"componentstate","componentstate":{"component":"LEDDEVICE","state":$val}}}
attr MyDevice set01Name LEDDevice
attr MyDevice set01TextArg 1
attr MyDevice set01URL http://192.168.178.76:8090/json-rpc
attr MyDevice setHeader1 Content-Type: application/json
attr MyDevice showBody 1
attr MyDevice showError 1
attr MyDevice verbose 5
Log
2020.09.09 21:16:53 5:  MyDevice: set called with LEDDevice false
2020.09.09 21:16:53 5:  MyDevice: set found option LEDDevice in attribute set01Name
2020.09.09 21:16:53 4:  MyDevice: set will now set LEDDevice -> false
2020.09.09 21:16:53 5:  MyDevice: AddToQueue adds type set01 to URL http://192.168.178.76:8090/json-rpc, data {"set" :{"command":"componentstate","componentstate":{"component":"LEDDEVICE","state":$val}}}, header Content-Type: application/json, retry 0, initial queue len: 0
2020.09.09 21:16:53 5:  MyDevice: HandleSendQueue called, qlen = 1
2020.09.09 21:16:53 4:  MyDevice: HandleSendQueue sends set01 with timeout 2 to http://192.168.178.76:8090/json-rpc,
data: {"set" :{"command":"componentstate","componentstate":{"component":"LEDDEVICE","state":false}}},
header: Content-Type: application/json
2020.09.09 21:16:53 5:  HttpUtils url=http://192.168.178.76:8090/json-rpc
2020.09.09 21:16:53 4:  IP: 192.168.178.76 -> 192.168.178.76
2020.09.09 21:16:53 5:  HttpUtils request header:
POST /json-rpc HTTP/1.0
Host: 192.168.178.76:8090
User-Agent: fhem
Accept-Encoding: gzip,deflate
Content-Length: 94
2020.09.09 21:16:55 3:  MyDevice: Read callback: Error: read from http://192.168.178.76:8090 timed out
2020.09.09 21:16:55 4:  MyDevice: Read callback: request type was set01 retry 0, no headers, no body
2020.09.09 21:16:55 5:  MyDevice: Read callback: body empty
2020.09.09 21:16:55 4:  MyDevice: Read found no charset header (bodyDecode was set to auto)
2020.09.09 21:16:55 5:  MyDevice: GetCookies is looking for Cookies
2020.09.09 21:16:55 5:  MyDevice: ExtractSid called, context set, num 01
2020.09.09 21:16:55 4:  MyDevice: no header to look for redirects
2020.09.09 21:16:55 5:  MyDevice: CheckAuth decided no authentication required
Abgeleitet von hier
https://wiki.fhem.de/wiki/HTTPMOD#Advanced_configuration_to_define_a_set_command_and_send_data_to_a_device
Ursprung des Ganzen ist der Versuch mein Hyperion Ng über fhem zu steuern.
Siehe hier:
https://docs.hyperion-project.org/en/json/#what-is-json
Wäre für jeden Tipp dankbar.
Otto123
#1
ich habe keine Ahnung davon, aber ich lese Wiki und was Du senden sollst/willst anders:
attr MyDevice set01Data {"command":"componentstate","componentstate":{"component":"LEDDEVICE","state":$val}}
Ein set MyDevice LEDDevice false würde dann $val durch false ersetzen und diesen String senden {"command":"componentstate","componentstate":{"component":"LEDDEVICE","state":false}}
Esjay
Hallo Otto
ich möchte ja keine "10" sondern ein "true" oder "false" senden. Daher auch das Attribut "set01TextArg"
Hab gerade gesehen das du nochmal editiert hast :-).
Wegen dem set war ich mir auch unsicher, aber ich dachte ich übernehme das aus dem Wiki.
Aber auch mit deinem Aufruf, welchen ich vorher bereits getestet habe, erhalte ich das gleiche in grün im Log.
2020.09.09 21:49:45 1:  Logfile gelöscht
2020.09.09 21:49:55 5:  MyDevice: set called with LEDDevice true
2020.09.09 21:49:55 5:  MyDevice: set found option LEDDevice in attribute set01Name
2020.09.09 21:49:55 4:  MyDevice: set will now set LEDDevice -> true
2020.09.09 21:49:55 5:  MyDevice: AddToQueue adds type set01 to URL http://192.168.178.76:8090/json-rpc, data {"command":"componentstate","componentstate":{"component":"LEDDEVICE","state":$val}}, header Content-Type: application/json, retry 0, initial queue len: 0
2020.09.09 21:49:55 5:  MyDevice: HandleSendQueue called, qlen = 1
2020.09.09 21:49:55 4:  MyDevice: HandleSendQueue sends set01 with timeout 2 to http://192.168.178.76:8090/json-rpc,
data: {"command":"componentstate","componentstate":{"component":"LEDDEVICE","state":true}},
2020.09.09 21:49:55 5:  HttpUtils url=http://192.168.178.76:8090/json-rpc
2020.09.09 21:49:55 4:  IP: 192.168.178.76 -> 192.168.178.76
2020.09.09 21:49:55 5:  HttpUtils request header:
User-Agent: fhem
Content-Length: 84
2020.09.09 21:49:57 3:  MyDevice: Read callback: Error: read from http://192.168.178.76:8090 timed out
2020.09.09 21:49:57 4:  MyDevice: Read callback: request type was set01 retry 0, no headers, no body
2020.09.09 21:49:57 5:  MyDevice: Read callback: body empty
2020.09.09 21:49:57 4:  MyDevice: Read found no charset header (bodyDecode was set to auto)
2020.09.09 21:49:57 5:  MyDevice: GetCookies is looking for Cookies
2020.09.09 21:49:57 5:  MyDevice: ExtractSid called, context set, num 01
2020.09.09 21:49:57 4:  MyDevice: no header to look for redirects
2020.09.09 21:49:57 5:  MyDevice: CheckAuth decided no authentication required
amenomade
Geht das mit curl auf dem Fhem Rechner?
curl --data '{"command":"componentstate","componentstate":{"component":"LEDDEVICE","state":$val}}'  http://192.168.178.76:8090/json-rpc
Otto123
@amenomade da wird doch aber $val nicht aufgelöst!? wegen ' $variable'
entweder so ?
curl --data {"command":"componentstate","componentstate":{"component":"LEDDEVICE","state":$val}}  http://192.168.178.76:8090/json-rpcoder so testen:
curl --data '{"command":"componentstate","componentstate":{"component":"LEDDEVICE","state":false}}'  http://192.168.178.76:8090/json-rpc
Esjay
Nabend:
fhem@FHEM:~$ curl --data '{"command":"componentstate","componentstate":{"component":"LEDDEVICE","state":$val}}'  http://192.168.178.76:8090/json-rpc
    "command": "",
    "error": "Errors during message parsing, please consult the Hyperion Log.",
    "success": false,
    "tan": 0
fhem@FHEM:~$
fhem@FHEM:~$ curl --data '{"command":"componentstate","componentstate":{"component":"LEDDEVICE","state":true}}'  http://192.168.178.76:8090/json-rpc
    "command": "componentstate",
    "success": true,
    "tan": 0
fhem@FHEM:~$
Bin erst auf das $val hereingefallen, aber wenn ich true nehme bekomme ich eine positive Rückmeldung.
amenomade
entweder so ?
Oops ja sorry wegen $val.
amenomade
#7
Also... seeeeehr ähnlich wie das andere Problem, wo ich auch versuche zu helfen.
https://forum.fhem.de/index.php/topic,45176.msg1083919.html#msg1083919
Ich kann mir im Moment das nicht erklären. Ich habe dort einen Test vorgeschlagen:
ZitatEDIT: eine andere Idee wäre, ein PRESENCE Device zu definieren, nur um zu sehen, ob der Sonoff aus Fhem erreichbar ist:
define sonoffpres PRESENCE lan-ping 192.168.178.93 10
Meldet er "present"?
Also bei dir die IP anpassen
Läuft fhem in einem Container?
Esjay
Hier das Ergebnis :
   ADDRESS    192.168.178.76
   CFGFN
   DEF        lan-ping 192.168.178.76
   FUUID      5f5940e2-f33f-a126-8539-fe366cdb6cb72e29
   INTERVAL_NORMAL 30
   INTERVAL_PRESENT 30
   MODE       lan-ping
   NAME       Hyperiontest
   NOTIFYDEV  global
   NR         54512
   NTFY_ORDER 50-Hyperiontest
   STATE      present
   TYPE       PRESENCE
     2020-09-09 22:53:54   model           lan-ping
     2020-09-09 22:56:20   presence        present
     2020-09-09 22:56:20   state           present
   helper:
     CURRENT_STATE present
   DbLogExclude .*
Nochmal ein List vom Device
   BUSY       0
   CFGFN
   DEF        none 0
   FUUID      5f591f94-f33f-a126-b74b-06ed878acd21a42e
   Interval   0
   LASTSEND   1599680995.05848
   MainURL
   ModuleVersion 3.5.22 - 7.2.2020
   NAME       MyDevice
   NOTIFYDEV  global
   NR         53979
   NTFY_ORDER 50-MyDevice
   STATE      ???
   TRIGGERTIME 0
   TRIGGERTIME_FMT
   TYPE       HTTPMOD
   addr       http://192.168.178.76:8090
   auth       0
   buf
   data       {"command":"componentstate","componentstate":{"component":"LEDDEVICE","state":true}}
   displayurl http://192.168.178.76:8090/json-rpc
   host       192.168.178.76
   httpbody
   httpversion 1.0
   ignoreredirects 1
   loglevel   4
   path       /json-rpc
   protocol   http
   redirects  0
   timeout    2
   value      true
   QUEUE:
     2020-09-09 21:49:57   LAST_ERROR      read from http://192.168.178.76:8090 timed out
   REQUEST:
     ignoreredirects 0
     retryCount 0
     type       set01
     value      true
   sslargs:
   DbLogExclude .*
   set01Name  LEDDevice
   set01TextArg 1
   set03NoArg 1
   showBody   1
   showError  1
   userattr   set01Data set01Name set01TextArg:0,1 set01URL set03NoArg:0,1 setHeader1
   verbose    5
Ehem läuft auf einem LXC unter Proxmox.
amenomade
Und das "curl" hast Du IM Container gemacht? (sorry, wenn das nicht möglich ist, und die Frage blöd ist, ich kenne mich nicht so gut mit Container aus)
Esjay
Alles gut.. Jap den habe ich in dem Container gemacht.
Habe jetzt nochmal einen anderen curl abgesetzt:
Response siehe unten.
fhem@FHEM:~$ curl -X POST -i 'http://192.168.178.76:8090/json-rpc' --data '{
comm>  "command":"componentstate",
>  "componentstate":{
>    "state":false
HTTP/1.1 200 OK.
Date: Wed, 09 Sep 2020 21:06:51 UTC
Server: Hyperion Webserver
Content-Length: 71
    "success": true,
    "tan": 0
Kannst du daraus etwas erkennen?
amenomade
Ja, dass es geht! ;)
Kannst Du noch mit Option -v das curl machen?
Esjay
fhem@FHEM:~$ curl -X  POST -v -i 'http://192.168.178.76:8090/json-rpc' --data '{
"componentstate":{
   "state":false
Note: Unnecessary use of -X or --request, POST is already inferred.
* Expire in 0 ms for 6 (transfer 0x563b7b532e90)
*   Trying 192.168.178.76...
* TCP_NODELAY set
* Expire in 200 ms for 4 (transfer 0x563b7b532e90)
* Connected to 192.168.178.76 (192.168.178.76) port 8090 (#0)
> POST /json-rpc HTTP/1.1
> User-Agent: curl/7.64.0
> Accept: */*
> Content-Length: 111
> Content-Type: application/x-www-form-urlencoded
* upload completely sent off: 111 out of 111 bytes
< HTTP/1.1 200 OK.
HTTP/1.1 200 OK.
< Content-Type: application/json
< Server: Hyperion Webserver
< Date: Wed, 09 Sep 2020 21:19:56 UTC
< Content-Length: 71
Content-Length: 71
    "success": true,
    "tan": 0
* Connection #0 to host 192.168.178.76 left intact
amenomade
#13
Dann versuch mal noch die gleiche Headers im HTTPMOD zu setzen:
setHeader2 User-Agent: curl/7.64.0
setHeader3 Accept: */*
Length wird nw vom HTTPMOD automatisch kalkuliert, und ContentType auch hast Du schon.
Esjay
Leider auch keine Änderung
2020.09.09 23:28:06 5:  MyDevice: set called with LEDDevice false
2020.09.09 23:28:06 5:  MyDevice: set found option LEDDevice in attribute set01Name
2020.09.09 23:28:06 4:  MyDevice: set will now set LEDDevice -> false
2020.09.09 23:28:06 5:  MyDevice: AddToQueue adds type set01 to URL http://192.168.178.76:8090/json-rpc, data {"command":"componentstate","componentstate":{"component":"LEDDEVICE","state":$val}}, header Content-Type: application/json
Accept: */*, retry 0, initial queue len: 0
2020.09.09 23:28:06 5:  MyDevice: HandleSendQueue called, qlen = 1
2020.09.09 23:28:06 5:  MyDevice: HandleSendQueue - call with HTTP METHOD: POST
2020.09.09 23:28:06 4:  MyDevice: HandleSendQueue sends set01 with timeout 2 to http://192.168.178.76:8090/json-rpc,
data: {"command":"componentstate","componentstate":{"component":"LEDDEVICE","state":false}},
Accept: */*
2020.09.09 23:28:06 5:  HttpUtils url=http://192.168.178.76:8090/json-rpc
2020.09.09 23:28:06 4:  IP: 192.168.178.76 -> 192.168.178.76
2020.09.09 23:28:06 5:  HttpUtils request header:
Accept: */*
Content-Length: 85
2020.09.09 23:28:08 3:  MyDevice: Read callback: Error: read from http://192.168.178.76:8090 timed out
2020.09.09 23:28:08 4:  MyDevice: Read callback: request type was set01 retry 0, no headers, no body
2020.09.09 23:28:08 5:  MyDevice: Read callback: body empty
2020.09.09 23:28:08 4:  MyDevice: Read found no charset header (bodyDecode was set to auto)
2020.09.09 23:28:08 5:  MyDevice: GetCookies is looking for Cookies
2020.09.09 23:28:08 5:  MyDevice: ExtractSid called, context set, num 01
2020.09.09 23:28:08 4:  MyDevice: no header to look for redirects
2020.09.09 23:28:08 5:  MyDevice: CheckAuth decided no authentication required
