Shelly Modul verursacht Warnings in main.pl()
Begonnen von Homalix99, 25 September 2020, 13:23:42
Homalix99
ich habe seit geraumer Zeit einen Shelly 1 im Einsatz. Das Modul 36_Shelly.pm verursacht folgende Warning und müllt das Log zu:
PERL WARNING: Use of uninitialized value $value in string eq at fhem.pl line 4753.
2020.09.25 13:11:38.648 1: stacktrace:
2020.09.25 13:11:38.648 1:     main::__ANON__                      called by fhem.pl (4753)
2020.09.25 13:11:38.649 1:     main::readingsBulkUpdateIfChanged   called by ./FHEM/36_Shelly.pm (894)
2020.09.25 13:11:38.649 1:     main::Shelly_status                 called by ./FHEM/36_Shelly.pm (848)
2020.09.25 13:11:38.649 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (634)
2020.09.25 13:11:38.650 1:     main::__ANON__                      called by fhem.pl (751)
2020.09.25 13:12:38.719 1: PERL WARNING: Use of uninitialized value $value in string eq at fhem.pl line 4753.
2020.09.25 13:12:38.720 1: stacktrace:
2020.09.25 13:12:38.721 1:     main::__ANON__                      called by fhem.pl (4753)
2020.09.25 13:12:38.722 1:     main::readingsBulkUpdateIfChanged   called by ./FHEM/36_Shelly.pm (894)
2020.09.25 13:12:38.723 1:     main::Shelly_status                 called by ./FHEM/36_Shelly.pm (848)
2020.09.25 13:12:38.724 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (634)
2020.09.25 13:12:38.724 1:     main::__ANON__                      called by fhem.pl (751)
2020.09.25 13:13:38.809 1: PERL WARNING: Use of uninitialized value $value in string eq at fhem.pl line 4753.
2020.09.25 13:13:38.810 1: stacktrace:
2020.09.25 13:13:38.812 1:     main::__ANON__                      called by fhem.pl (4753)
2020.09.25 13:13:38.813 1:     main::readingsBulkUpdateIfChanged   called by ./FHEM/36_Shelly.pm (894)
2020.09.25 13:13:38.814 1:     main::Shelly_status                 called by ./FHEM/36_Shelly.pm (848)
2020.09.25 13:13:38.815 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (634)
2020.09.25 13:13:38.816 1:     main::__ANON__                      called by fhem.pl (751)
Hier ein List meiner Def:
   .AttrList
   CHANGED
   DEF        192.168.3.60
   DURATION   0
   FUUID      5f3281f9-f33f-5615-55df-3a0b529bd742fd17
   INTERVAL   60
   NAME       Shelly_DG_Bad
   NR         1740
   STATE      off
   TCPIP      192.168.3.60
   TYPE       Shelly
   .attraggr:
   .attrminint:
     2020-08-11 13:33:14   cloud           disabled
     2020-09-19 13:48:31   firmware        1047-long-id-for-shelly-devices
     2020-09-22 08:01:39   network         <html>connected to <a href="http://192.168.3.60">192.168.3.60</a></html>
     2020-09-25 07:09:11   relay           off
     2020-09-25 07:09:11   state           off
   group      Licht
   model      shelly1
   room       DG_Nord
VG
Alex
- RPI 4 fhem in Docker, 2 x Arduino Uno, HM-GW, HM-Dev. (Fensterkontakte, HK-Thermostate, div. Aktoren), JeeLink,
- GPIOs, HM-LAN, ESPs (MQTT2)
-Überwachung Fenster/Türen/Licht, HK-Thermostatregelung, Rollosteuerung, Überw. Betriebstemperaturen Heizung, Erfassung Gas/Wasser, PV-Anl., Wetter (WS1600)
Homalix99
Nochmal das Ganze Log nach Fhem update (Zeilennummern haben sich geändert):
2020.09.25 16:37:09.610 1: PERL WARNING: Use of uninitialized value $value in string eq at fhem.pl line 4824.
2020.09.25 16:37:09.611 1: stacktrace:
2020.09.25 16:37:09.612 1:     main::__ANON__                      called by fhem.pl (4824)
2020.09.25 16:37:09.612 1:     main::readingsBulkUpdateIfChanged   called by ./FHEM/36_Shelly.pm (925)
2020.09.25 16:37:09.613 1:     main::Shelly_status                 called by ./FHEM/36_Shelly.pm (879)
2020.09.25 16:37:09.613 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (634)
2020.09.25 16:37:09.613 1:     main::__ANON__                      called by fhem.pl (760)
2020.09.25 16:38:09.797 1: PERL WARNING: Use of uninitialized value $value in string eq at fhem.pl line 4824.
2020.09.25 16:38:09.798 1: stacktrace:
2020.09.25 16:38:09.798 1:     main::__ANON__                      called by fhem.pl (4824)
2020.09.25 16:38:09.798 1:     main::readingsBulkUpdateIfChanged   called by ./FHEM/36_Shelly.pm (925)
2020.09.25 16:38:09.798 1:     main::Shelly_status                 called by ./FHEM/36_Shelly.pm (879)
2020.09.25 16:38:09.798 1:     main::__ANON__                      called by FHEM/HttpUtils.pm (634)
2020.09.25 16:38:09.799 1:     main::__ANON__                      called by fhem.pl (760)
Im Modul 36_Shelly.pm:
Zeile 925: readingsBulkUpdateIfChanged($hash,"overpower".$subs,$overpower);
Modul versucht nicht vorhandes Reading 'overpower' zu aktualisieren und löst warning aus.
Dienlich wäre auch, wenn das Modul in 'disable' unterstützen würde.
VG
Alex
amenomade
Zeig mal die Log mit verbose 5 auf dem Shelly, insb die Zeilen "[Shelly_status] has obtained data $data"
Homalix99
hier ein Logauszug mit Verbose 5 am Shelly Objekt:
2020.09.26 13:47:41.064 5: [Shelly_status] Issue a non-blocking call to http://192.168.3.60/status
2020.09.26 13:47:41.133 5: [Shelly_status] has obtained data {"wifi_sta":{"connected":true,"ssid":"FRITZ!Box_7170_bal_Client","ip":"192.168.3.60","rssi":-62},"cloud":{"enabled":false,"connected":false}   ,"mqtt":{"connected":false},"time":"","serial":1,"has_update":false,"mac":"500291EFF85E","relays" :[{"ison":false, "has_timer":false}],"meters":[{"power":0.00,"is_valid":"true"}],"inputs":[{"input":0}]   ,"ext_temperature":{},"update":{"status":"unknown","has_update":false,"new_version":"","old_version":"20191217-140757/1047-long-id-for-shelly-devices@a0661583"},"ram_total":50960,"ram_free":40952,"fs_s   ize":233681,"fs_free":173441,"uptime":8423}
VG
Alex
Carsten1981
ich würde das gerne noch mal aufgreifen, da ich jetzt das gleiche problem habe. Gibt es da mitlerweile eine Lösung für?
Gruß Carsten
fhem 5.8 CUL 433, 8x DS18B20, 8fach 230V Relais
benachrichtigungen über Telegram, Steuerung Solar- und Kaminpumpe, Steuerung Somfy Rollos, Lichtsteuerung über Intertechno, Steuerung Heizungspumpe und Mischer Fußbodenheizung
Homalix99
ich habe den Shelly seit ca. 5 Wochen entfernt, da er den mechanischen Lichtschalter  immer öfter ignoriert hat und das Licht sich nicht mehr ausschalten lies. In Fhem war er im Error-Zustand. Mit Schalten in Fhem auf "off" verschwand der Error und der Shelly zeigte sich wieder normal. Da das Problem in immer kürzeren Abständen auftrat (zum Schluß so 2 bis 3 mal die Woche) habe ich diesen genervt entfernt. Das Teil ist nicht zu gebrauchen, vielleicht HW Fehler.
Alex
micky0867
Ich habe letzte Woche einen ShellyDimmer, an dem ein Lichtschalter angeschlossen ist, per MQTT eingebunden.
Der Status des Schalters wird auch korrekt nach fhem übertragen.
Bisher habe ich keine Probleme und bin sehr zufrieden mit dem Shelly.
Carsten1981
Danke für die schnellen Antwort,
Shellys rausschmeißen wäre eine ganz doofe alternative, habe davon 8 im Einsatz und sie haben bis jetzt anstandslos funktioniert, und das tuen sie auch jetzt noch, nur das Log wird leider ganz schön zugemüllt
