[gelöst]log db - Fehler beim Insert
Begonnen von bartman121, 23 Oktober 2020, 20:04:12
bartman121
DBD::mysql::st execute_array failed: executing 329 generated 2 errors at ./FHEM/93_DbLog.pm line 2652.
ich finde partout nicht raus was die zwei Fehler sind, aus einem verbose 5 ergeben sich auch keine weiteren Hinweise.
list logdb:
   COLUMNS    field length used for Device: 64, Type: 64, Event: 512, Reading: 64, Value: 128, Unit: 32
   CONFIGURATION ./db.conf
   DEF        ./db.conf .*:.*
   FUUID      5c4c4706-f33f-1dd6-409f-4c9691c08c98f6c1
   FVERSION   93_DbLog.pm:v4.10.2-s22246/2020-06-23
   MODE       asynchronous
   MODEL      MYSQL
   NAME       logdb
   NR         216
   NTFY_ORDER 50-logdb
   PID        4350
   REGEXP     .*:.*
   STATE      DBD::mysql::st execute_array failed: executing 357 generated 2 errors at ./FHEM/93_DbLog.pm line 2652.
   TYPE       DbLog
   UTF8       0
   dbconn     mysql:database=fhem;host=fhem;port=3306
   dbuser     fhemuser
   HELPER:
     COLSET     1
     DEVICECOL  64
     EVENTCOL   512
     OLDSTATE   DBD::mysql::st execute_array failed: executing 357 generated 2 errors at ./FHEM/93_DbLog.pm line 2652.
     PACKAGE    main
     READINGCOL 64
     TC         current
     TH         history
     TYPECOL    64
     UNITCOL    32
     VALUECOL   128
     VERSION    4.10.2
   Helper:
     DBLOG:
       state:
         logdb:
           TIME       1603476090.90517
           VALUE      DBD::mysql::st execute_array failed
     2020-10-23 20:01:30   CacheUsage      358
     2020-10-23 20:01:28   NextSync        2020-10-23 20:01:58 or if CacheUsage 500 reached
     2019-07-26 02:00:42   reduceLogState  Rows processed: 78354, deleted: 64532, time: 42.00sec
     2020-10-23 20:01:30   state           DBD::mysql::st execute_array failed: executing 357 generated 2 errors at ./FHEM/93_DbLog.pm line 2652.
   DbLogType  Current/History
   asyncMode  1
   room       ZZZ_System->Datenbank
   verbose    0
configcheck:
Result of version check
Used Perl version: 5.30.0
Used DBI (Database independent interface) version: 1.643
Used DBD (Database driver) version mysql: 4.050
Used DbLog version: 4.10.2.
Your local DbLog module is up to date.
Recommendation: No update of DbLog is needed. Your DBD version fulfills UTF8 support, no need to update DBD.
Result of configuration read check
Connection parameter store type: configDB (don't forget upload configuration file if changed. Use "configdb filelist" and look for your configuration file.)
Connection parameter: Connection -> mysql:database=fhem;host=fhem;port=3306, User -> fhemuser, Password -> read o.k.
Result of connection check
Connection to database fhem successfully done.
Recommendation: settings o.k.
Result of encoding check
Encoding used by Client (connection): LATIN1
Encoding used by DB fhem: LATIN1
Result of logmode check
Logmode of DbLog-device logdb is: asynchronous
Result of insert mode check
Insert mode of DbLog-device logdb is: Array
Recommendation: Setting attribute "bulkInsert" to "1" may result a higher write performance in most cases. Feel free to try this mode.
Result of plot generation method check
WARNING - at least one of your FHEMWEB devices has attribute "plotfork = 1" and/or attribute "plotEmbed = 2" not set.
WEB: plotfork=1 / plotEmbed=0
WEBhook: plotfork=0 / plotEmbed=0
WEBphone: plotfork=1 / plotEmbed=0
Recommendation: You should set attribute "plotfork = 1" and "plotEmbed = 2" in relevant devices. If these attributes are not set, blocking situations may occure when creating plots. Note: Your system must have sufficient memory to handle parallel running Perl processes. See also global attribute "blockingCallMax".
Result of table 'history' check
Column width set in DB history: 'DEVICE' = 32, 'TYPE' = 32, 'EVENT' = 512, 'READING' = 32, 'VALUE' = 255, 'UNIT' = 32
Column width used by logdb: 'DEVICE' = 64, 'TYPE' = 64, 'EVENT' = 512, 'READING' = 64, 'VALUE' = 128, 'UNIT' = 32
Recommendation: The relation between column width in table history and the field width used in device logdb don't meet the requirements. Please make sure that the width of database field definition is equal or larger than the field width used by the module. Compare the given results.
Currently the default values for field width are:
DEVICE: 64
TYPE: 64
EVENT: 512
READING: 64
VALUE: 128
UNIT: 32
You can change the column width in database by a statement like 'alter table history modify VALUE varchar(128);' (example for changing field 'VALUE'). You can do it for example by executing 'sqlCmd' in DbRep or in a SQL-Editor of your choice. (switch logdb to asynchron mode for non-blocking).
Alternatively the field width used by logdb can be adjusted by setting attributes 'colEvent', 'colReading', 'colValue'. (pls. refer to commandref)
Result of table 'current' check
Column width set in DB current: 'DEVICE' = 32, 'TYPE' = 32, 'EVENT' = 512, 'READING' = 32, 'VALUE' = 255, 'UNIT' = 32
Recommendation: The relation between column width in table current and the field width used in device logdb don't meet the requirements. Please make sure that the width of database field definition is equal or larger than the field width used by the module. Compare the given results.
DEVICE: 64
TYPE: 64
EVENT: 512
READING: 64
VALUE: 128
UNIT: 32
You can change the column width in database by a statement like 'alter table current modify VALUE varchar(128);' (example for changing field 'VALUE'). You can do it for example by executing 'sqlCmd' in DbRep or in a SQL-Editor of your choice. (switch logdb to asynchron mode for non-blocking).
Result of check 'Search_Idx' availability
Index 'Search_Idx' exists and contains recommended fields 'DEVICE', 'TIMESTAMP', 'READING'.
Result of check 'Report_Idx' availability for DbRep-devices
At least one DbRep-device assigned to logdb is used, but the recommended index 'Report_Idx' is missing.
Recommendation: You can create the index by executing statement 'CREATE INDEX Report_Idx ON `history` (TIMESTAMP,READING) USING BTREE;'
Depending on your database size this command may running a long time.
Please make sure the device 'logdb' is operating in asynchronous mode to avoid FHEM from blocking when creating the index.
Note: If you have just created another index which covers the same fields and order as suggested (e.g. a primary key) you don't need to create the 'Report_Idx' as well !
Hat Jemand eine Idee wie ich dem Fehler auf die Schliche kommen kann?
DS_Starter
Du könntest dir mal den Cache mit
set <> listCache
genauer ansehen. Wir hatten so etwas schon öfter im Forum diskutiert.
Meist sind es non-ASCII Zeichen die in irgendwelchen Events enthalten sind.
Du müßtest im Cache solche Zeichen finden die du wahrscheinlich recht leicht erkennen solltest.
Wenn du die Quelle nicht ausmachen kannst, setzte dir das Attribut useCharfilter =1.
Damit müsste das Problem in der Zukunft nicht mehr auftreten.
bartman121
listCache:
192 => 2020-10-23 20:25:13|BA.HT|MAX|lastcmd: set_maxValveSetting 0|lastcmd|set_maxValveSetting|
193 => 2020-10-23 20:25:13|PID.BA.HT|PID20|state: processing|state|processing|
194 => 2020-10-23 20:25:20|BA.HT|MAX|state: on|state|30.5|
195 => 2020-10-23 20:25:20|BA.HT|MAX|desiredTemperature: on|desiredTemperature|30.5|\xB0C
196 => 2020-10-23 20:25:20|BA.HT|MAX|RSSI: -66|RSSI|-66|
197 => 2020-10-23 20:25:20|BA.HT|MAX|battery: ok|battery|ok|
198 => 2020-10-23 20:25:20|BA.HT|MAX|rferror: 0|rferror|0|
199 => 2020-10-23 20:25:20|BA.HT|MAX|gateway: 1|gateway|1|
200 => 2020-10-23 20:25:20|BA.HT|MAX|mode: manual|mode|manual|
201 => 2020-10-23 20:25:20|BA.HT|MAX|panel: unlocked|panel|unlocked|
202 => 2020-10-23 20:25:20|Pfl_Yucca_Buero|XIAOMIBTLESENS|firmware: 3.1.9|firmware|3.1.9|
203 => 2020-10-23 20:25:20|Pfl_Yucca_Buero|XIAOMIBTLESENS|batteryPercent: 98|batteryPercent|98|
204 => 2020-10-23 20:25:13|SZ.HT|MAX|lastcmd: set_maxValveSetting 0|lastcmd|set_maxValveSetting|
205 => 2020-10-23 20:25:20|Pfl_Yucca_Buero|XIAOMIBTLESENS|batteryState: ok|batteryState|ok|
206 => 2020-10-23 20:25:20|BA.HT|MAX|maxValveSetting: 0|maxValveSetting|0|%
207 => 2020-10-23 20:25:20|BA.HT|MAX|lastcmd: maxValveSetting 0|lastcmd|maxValveSetting|
208 => 2020-10-23 20:25:20|cul_cube|CUL|credit10ms: 2899|credit10ms|2899|
209 => 2020-10-23 20:25:20|Pfl_Yucca_Buero|XIAOMIBTLESENS|fertility: 139|fertility|139|
210 => 2020-10-23 20:25:20|Pfl_Yucca_Buero|XIAOMIBTLESENS|lux: 132|lux|132|
211 => 2020-10-23 20:25:20|Pfl_Yucca_Buero|XIAOMIBTLESENS|temperature: 19.1|temperature|19.1|°C
212 => 2020-10-23 20:25:20|Pfl_Yucca_Buero|XIAOMIBTLESENS|moisture: 30|moisture|30|
213 => 2020-10-23 20:25:20|gassistant|GASSISTANT|gassistant-fhem-localHome: inactive|gassistant-fhem-localHome|inactive|
214 => 2020-10-23 20:25:21|hcconn|HOMECONNECTCONNECTION|tokenExpiry: Sat Oct 24 20:25:21 2020|tokenExpiry|Sat Oct 24 20:25:21 2020|
215 => 2020-10-23 20:25:13|PID.SZ.HT|PID20|desired: 17|desired|17|
216 => 2020-10-23 20:25:21|hcconn|HOMECONNECTCONNECTION|state: Connected|state|Connected|
217 => 2020-10-23 20:25:22|SMV4HCX48E|HOMECONNECT|BSH.Common.Status.DoorState: BSH.Common.EnumType.DoorState.Open|BSH.Common.Status.DoorState|BSH.Common.EnumType.DoorState.Open|
218 => 2020-10-23 20:25:22|SMV4HCX48E|HOMECONNECT|BSH.Common.Status.RemoteControlStartAllowed: 0|BSH.Common.Status.RemoteControlStartAllowed|0|
219 => 2020-10-23 20:25:22|SMV4HCX48E|HOMECONNECT|BSH.Common.Status.OperationState: BSH.Common.EnumType.OperationState.Inactive|BSH.Common.Status.OperationState|BSH.Common.EnumType.OperationState.Inactive|
220 => 2020-10-23 20:25:22|SMV4HCX48E|HOMECONNECT|state: Idle|state|Idle|
221 => 2020-10-23 20:25:22|SMV4HCX48E|HOMECONNECT|BSH.Common.Status.RemoteControlActive: 1|BSH.Common.Status.RemoteControlActive|1|
222 => 2020-10-23 20:25:22|SZ.HT|MAX|valveposition: 0|valveposition|0|%
223 => 2020-10-23 20:25:22|SZ.HT|MAX|state: on|state|30.5|
224 => 2020-10-23 20:25:22|SZ.HT|MAX|desiredTemperature: on|desiredTemperature|30.5|\xB0C
225 => 2020-10-23 20:25:22|SZ.HT|MAX|RSSI: -70.5|RSSI|-70.5|
226 => 2020-10-23 20:25:13|PID.SZ.HT|PID20|measured: 19.7|measured|19.7|
227 => 2020-10-23 20:25:22|SZ.HT|MAX|battery: ok|battery|ok|
228 => 2020-10-23 20:25:22|SZ.HT|MAX|rferror: 0|rferror|0|
229 => 2020-10-23 20:25:22|SZ.HT|MAX|gateway: 1|gateway|1|
230 => 2020-10-23 20:25:22|SZ.HT|MAX|mode: manual|mode|manual|
231 => 2020-10-23 20:25:22|SZ.HT|MAX|panel: locked|panel|locked|
232 => 2020-10-23 20:25:22|EC3000_C1A8|EC3000|power: 67.6|power|67.6|
233 => 2020-10-23 20:25:22|SZ.HT|MAX|maxValveSetting: 0|maxValveSetting|0|%
234 => 2020-10-23 20:25:22|SZ.HT|MAX|lastcmd: maxValveSetting 0|lastcmd|maxValveSetting|
235 => 2020-10-23 20:25:22|gassistant|GASSISTANT|gassistant-fhem-lasterror: none|gassistant-fhem-lasterror|none|
236 => 2020-10-23 20:25:22|EC3000_BCF0|EC3000|power: 30.1|power|30.1|
237 => 2020-10-23 20:25:13|PID.SZ.HT|PID20|p_p: -21.6|p_p|-21.6|
238 => 2020-10-23 20:25:22|Pfl_Aloe|XIAOMIBTLESENS|batteryState: ok|batteryState|ok|
239 => 2020-10-23 20:25:22|Pfl_Aloe|XIAOMIBTLESENS|batteryPercent: 100|batteryPercent|100|
240 => 2020-10-23 20:25:22|Pfl_Aloe|XIAOMIBTLESENS|firmware: 2.9.4|firmware|2.9.4|
241 => 2020-10-23 20:25:22|BA.TEMP|XIAOMISMARTHOME_DEVICE|temperature: 20.4|temperature|20.4|°C
242 => 2020-10-23 20:25:22|BA.TEMP|XIAOMISMARTHOME_DEVICE|humidity: 67|humidity|67|%
243 => 2020-10-23 20:25:22|SZ.TEMP|XIAOMISMARTHOME_DEVICE|temperature: 19.7|temperature|19.7|°C
244 => 2020-10-23 20:25:22|SZ.TEMP|XIAOMISMARTHOME_DEVICE|humidity: 70|humidity|70|%
245 => 2020-10-23 20:25:22|motion_vorrat|XIAOMISMARTHOME_DEVICE|batteryState: ok|batteryState|ok|
246 => 2020-10-23 20:25:22|motion_vorrat|XIAOMISMARTHOME_DEVICE|batteryVoltage: 3.0|batteryVoltage|3.0|
247 => 2020-10-23 20:25:23|Pfl_Aloe|XIAOMIBTLESENS|fertility: 112|fertility|112|
248 => 2020-10-23 20:25:13|PID.SZ.HT|PID20|p_d: 0|p_d|0|
249 => 2020-10-23 20:25:23|Pfl_Aloe|XIAOMIBTLESENS|lux: 50|lux|50|
250 => 2020-10-23 20:25:23|Pfl_Aloe|XIAOMIBTLESENS|moisture: 31|moisture|31|
251 => 2020-10-23 20:25:23|Pfl_Aloe|XIAOMIBTLESENS|temperature: 21.9|temperature|21.9|°C
252 => 2020-10-23 20:25:23|gassistant|GASSISTANT|gassistant-fhem-connection: connected|gassistant-fhem-connection|connected|
253 => 2020-10-23 20:25:23|gassistant|GASSISTANT|gassistant-fhem-usedFeatureLevel: 3|gassistant-fhem-usedFeatureLevel|3|
254 => 2020-10-23 20:25:23|gassistant|GASSISTANT|gassistant-fhem-googleSync: Google SYNC finished|gassistant-fhem-googleSync|Google SYNC finished|
255 => 2020-10-23 20:25:25|Pfl_neu|XIAOMIBTLESENS|batteryState: ok|batteryState|ok|
256 => 2020-10-23 20:25:25|Pfl_neu|XIAOMIBTLESENS|batteryPercent: 98|batteryPercent|98|
257 => 2020-10-23 20:25:25|Pfl_neu|XIAOMIBTLESENS|firmware: 3.2.1|firmware|3.2.1|
258 => 2020-10-23 20:25:25|Pfl_neu|XIAOMIBTLESENS|state: active|state|active|
259 => 2020-10-23 20:25:13|PID.SZ.HT|PID20|p_i: 2.39700000000005|p_i|2.39700000000005|
260 => 2020-10-23 20:25:25|Pfl_neu|XIAOMIBTLESENS|state: write sensor data|state|write sensor data|
261 => 2020-10-23 20:25:26|Pfl_neu|XIAOMIBTLESENS|state: read sensor data|state|read sensor data|
262 => 2020-10-23 20:25:26|Pfl_neu|XIAOMIBTLESENS|fertility: 93|fertility|93|
263 => 2020-10-23 20:25:26|Pfl_neu|XIAOMIBTLESENS|lux: 42|lux|42|
264 => 2020-10-23 20:25:26|Pfl_neu|XIAOMIBTLESENS|temperature: 18.6|temperature|18.6|°C
265 => 2020-10-23 20:25:26|Pfl_neu|XIAOMIBTLESENS|moisture: 30|moisture|30|
266 => 2020-10-23 20:25:26|Pfl_neu|XIAOMIBTLESENS|state: active|state|active|
267 => 2020-10-23 20:25:26|Pfl_neu|XIAOMIBTLESENS|water_ok: ok|water_ok|ok|
268 => 2020-10-23 20:25:26|Pfl_neu|XIAOMIBTLESENS|minMoisture ok|state|minMoisture ok|
269 => 2020-10-23 20:25:26|Pfl_neu|XIAOMIBTLESENS|maxMoisture ok|state|maxMoisture ok|
270 => 2020-10-23 20:25:13|PID.SZ.HT|PID20|actuation: 0|actuation|0|
271 => 2020-10-23 20:25:27|motion_kueche|XIAOMISMARTHOME_DEVICE|state: off|state|off|
272 => 2020-10-23 20:25:27|motion_vorrat|XIAOMISMARTHOME_DEVICE|state: off|state|off|
273 => 2020-10-23 20:25:29|Pfl_Yucca_Kueche|XIAOMIBTLESENS|firmware: 3.1.9|firmware|3.1.9|
274 => 2020-10-23 20:25:29|Pfl_Yucca_Kueche|XIAOMIBTLESENS|batteryPercent: 96|batteryPercent|96|
275 => 2020-10-23 20:25:29|Pfl_Yucca_Kueche|XIAOMIBTLESENS|batteryState: ok|batteryState|ok|
276 => 2020-10-23 20:25:29|Pfl_Yucca_Kueche|XIAOMIBTLESENS|fertility: 263|fertility|263|
277 => 2020-10-23 20:25:29|Pfl_Yucca_Kueche|XIAOMIBTLESENS|lux: 115|lux|115|
278 => 2020-10-23 20:25:29|Pfl_Yucca_Kueche|XIAOMIBTLESENS|temperature: 19.6|temperature|19.6|°C
279 => 2020-10-23 20:25:29|Pfl_Yucca_Kueche|XIAOMIBTLESENS|moisture: 41|moisture|41|
280 => 2020-10-23 20:25:32|Pfl_Monstera_rechts|XIAOMIBTLESENS|firmware: 3.1.8|firmware|3.1.8|
281 => 2020-10-23 20:25:13|PID.SZ.HT|PID20|actuationCalc: -19.2029999999999|actuationCalc|-19.2029999999999|
282 => 2020-10-23 20:25:32|Pfl_Monstera_rechts|XIAOMIBTLESENS|batteryState: ok|batteryState|ok|
283 => 2020-10-23 20:25:32|Pfl_Monstera_rechts|XIAOMIBTLESENS|batteryPercent: 99|batteryPercent|99|
284 => 2020-10-23 20:25:33|Pfl_Monstera_rechts|XIAOMIBTLESENS|fertility: 714|fertility|714|
285 => 2020-10-23 20:25:33|Pfl_Monstera_rechts|XIAOMIBTLESENS|moisture: 37|moisture|37|
286 => 2020-10-23 20:25:33|Pfl_Monstera_rechts|XIAOMIBTLESENS|temperature: 18.3|temperature|18.3|°C
287 => 2020-10-23 20:25:33|Pfl_Monstera_rechts|XIAOMIBTLESENS|lux: 56|lux|56|
288 => 2020-10-23 20:25:41|KU.TEMP|LACROSSE|temperature: 20.7|temperature|20.7|°C
289 => 2020-10-23 20:25:41|KU.TEMP|LACROSSE|humidity: 70|humidity|70|%
290 => 2020-10-23 20:25:41|AZ.TEMP|LACROSSE|battery: ok|battery|ok|
291 => 2020-10-23 20:25:41|AZ.TEMP|LACROSSE|temperature: 19.5|temperature|19.5|°C
292 => 2020-10-23 20:25:13|PID.SZ.HT|PID20|delta: -2.7|delta|-2.7|
293 => 2020-10-23 20:25:42|WZ.TEMP|LACROSSE|temperature: 22.6|temperature|22.6|°C
294 => 2020-10-23 20:25:42|cul_cube|CUL|credit10ms: 2808|credit10ms|2808|
295 => 2020-10-23 20:25:13|PID.BA.HT|PID20|desired: 17|desired|17|
296 => 2020-10-23 20:25:13|PID.SZ.HT|PID20|state: processing|state|processing|
297 => 2020-10-23 20:25:13|WZ.HT2|ZWAVE|state: dim 14|state|dim 14|
298 => 2020-10-23 20:25:13|WZ.HT2|ZWAVE|valveposition: 14|valveposition|14|
299 => 2020-10-23 20:25:13|PID.WZ.HT2|PID20|desired: 22|desired|22|
300 => 2020-10-23 20:25:13|PID.WZ.HT2|PID20|measured: 22.6|measured|22.6|
301 => 2020-10-23 20:25:13|PID.WZ.HT2|PID20|p_p: -4.20000000000001|p_p|-4.20000000000001|
302 => 2020-10-23 20:25:13|PID.WZ.HT2|PID20|p_d: 0|p_d|0|
303 => 2020-10-23 20:25:13|PID.WZ.HT2|PID20|p_i: 18.0839999999996|p_i|18.0839999999996|
304 => 2020-10-23 20:25:13|PID.WZ.HT2|PID20|actuation: 14|actuation|14|
305 => 2020-10-23 20:25:13|PID.WZ.HT2|PID20|actuationCalc: 13.8839999999996|actuationCalc|13.8839999999996|
306 => 2020-10-23 20:25:13|PID.BA.HT|PID20|measured: 20.4|measured|20.4|
307 => 2020-10-23 20:25:13|PID.WZ.HT2|PID20|delta: -0.600000000000001|delta|-0.600000000000001|
308 => 2020-10-23 20:25:13|PID.WZ.HT2|PID20|state: processing|state|processing|
309 => 2020-10-23 20:25:13|mqtt2client|MQTT2_CLIENT|CONNECTED|state|CONNECTED|
310 => 2020-10-23 20:25:13|owntracks|MQTT2_DEVICE|redfin_lon: 13.7030741|redfin_lon|13.7030741|
311 => 2020-10-23 20:25:13|owntracks|MQTT2_DEVICE|redfin_t: p|redfin_t|p|
312 => 2020-10-23 20:25:13|owntracks|MQTT2_DEVICE|redfin_tid: in|redfin_tid|in|
313 => 2020-10-23 20:25:13|owntracks|MQTT2_DEVICE|redfin_batt: 100|redfin_batt|100|
314 => 2020-10-23 20:25:13|owntracks|MQTT2_DEVICE|redfin_lat: 51.0452863|redfin_lat|51.0452863|
315 => 2020-10-23 20:25:13|owntracks|MQTT2_DEVICE|redfin__type: location|redfin__type|location|
316 => 2020-10-23 20:25:13|owntracks|MQTT2_DEVICE|redfin_tst: 1602896613|redfin_tst|1602896613|
317 => 2020-10-23 20:25:13|PID.BA.HT|PID20|p_p: -27.2|p_p|-27.2|
318 => 2020-10-23 20:25:13|owntracks|MQTT2_DEVICE|redfin_vac: 2|redfin_vac|2|
319 => 2020-10-23 20:25:13|owntracks|MQTT2_DEVICE|redfin_alt: 166|redfin_alt|166|
320 => 2020-10-23 20:25:13|owntracks|MQTT2_DEVICE|redfin_vel: 0|redfin_vel|0|
321 => 2020-10-23 20:25:13|owntracks|MQTT2_DEVICE|redfin_conn: w|redfin_conn|w|
322 => 2020-10-23 20:25:13|owntracks|MQTT2_DEVICE|redfin_acc: 30|redfin_acc|30|
323 => 2020-10-23 20:25:13|owntracks|MQTT2_DEVICE|andreas__type: location|andreas__type|location|
324 => 2020-10-23 20:25:13|owntracks|MQTT2_DEVICE|andreas_tst: 1603476065|andreas_tst|1603476065|
325 => 2020-10-23 20:25:13|owntracks|MQTT2_DEVICE|andreas_batt: 27|andreas_batt|27|
326 => 2020-10-23 20:25:13|owntracks|MQTT2_DEVICE|andreas_conn: w|andreas_conn|w|
327 => 2020-10-23 20:25:13|owntracks|MQTT2_DEVICE|andreas_inregions_1: zuhause|andreas_inregions_1|zuhause|
328 => 2020-10-23 20:25:13|PID.BA.HT|PID20|p_d: 0|p_d|0|
329 => 2020-10-23 20:25:13|owntracks|MQTT2_DEVICE|andreas_alt: 165|andreas_alt|165|
330 => 2020-10-23 20:25:13|owntracks|MQTT2_DEVICE|andreas_acc: 16|andreas_acc|16|
331 => 2020-10-23 20:25:13|owntracks|MQTT2_DEVICE|andreas_vel: 0|andreas_vel|0|
332 => 2020-10-23 20:25:13|owntracks|MQTT2_DEVICE|andreas_vac: 11|andreas_vac|11|
333 => 2020-10-23 20:25:13|owntracks|MQTT2_DEVICE|andreas_lat: 51.0453386|andreas_lat|51.0453386|
334 => 2020-10-23 20:25:13|owntracks|MQTT2_DEVICE|andreas_tid: as|andreas_tid|as|
335 => 2020-10-23 20:25:13|owntracks|MQTT2_DEVICE|andreas_lon: 13.7032151|andreas_lon|13.7032151|
336 => 2020-10-23 20:25:13|owntracks|MQTT2_DEVICE|andreas_t: p|andreas_t|p|
337 => 2020-10-23 20:25:15|logdb|DBLOG|state: connected|state|connected|
338 => 2020-10-23 20:25:15|WZ.HT1|MAX|valveposition: 12|valveposition|12|%
339 => 2020-10-23 20:25:13|PID.BA.HT|PID20|p_i: 7.71000000000032|p_i|7.71000000000032|
340 => 2020-10-23 20:25:15|WZ.HT1|MAX|state: on|state|30.5|
341 => 2020-10-23 20:25:15|WZ.HT1|MAX|desiredTemperature: on|desiredTemperature|30.5|\xB0C
342 => 2020-10-23 20:25:15|WZ.HT1|MAX|RSSI: -49|RSSI|-49|
343 => 2020-10-23 20:25:15|WZ.HT1|MAX|battery: ok|battery|ok|
344 => 2020-10-23 20:25:15|WZ.HT1|MAX|rferror: 0|rferror|0|
345 => 2020-10-23 20:25:15|WZ.HT1|MAX|gateway: 1|gateway|1|
346 => 2020-10-23 20:25:15|WZ.HT1|MAX|mode: manual|mode|manual|
347 => 2020-10-23 20:25:15|WZ.HT1|MAX|panel: unlocked|panel|unlocked|
348 => 2020-10-23 20:25:15|myLaCrosseGateway|LACROSSEGATEWAY|state: initialized|state|initialized|
349 => 2020-10-23 20:25:15|WZ.HT1|MAX|maxValveSetting: 12|maxValveSetting|12|%
350 => 2020-10-23 20:25:13|PID.BA.HT|PID20|actuation: 0|actuation|0|
351 => 2020-10-23 20:25:15|WZ.HT1|MAX|lastcmd: maxValveSetting 12|lastcmd|maxValveSetting|
352 => 2020-10-23 20:25:15|cul_cube|CUL|credit10ms: 3232|credit10ms|3232|
353 => 2020-10-23 20:25:17|AZ.HT|MAX|RSSI: -63|RSSI|-63|
354 => 2020-10-23 20:25:17|AZ.HT|MAX|lastcmd: maxValveSetting 0|lastcmd|maxValveSetting|
355 => 2020-10-23 20:25:17|cul_cube|CUL|credit10ms: 3121|credit10ms|3121|
356 => 2020-10-23 20:25:18|gassistant|GASSISTANT|gassistant-fhem-version: 3.0.2|gassistant-fhem-version|3.0.2|
357 => 2020-10-23 20:25:18|gassistant|GASSISTANT|gassistant-fhem-lastServerError: none|gassistant-fhem-lastServerError|none|
358 => 2020-10-23 20:25:18|gassistant|GASSISTANT|gassistantFHEM.loginURL: <html><a href="https://fhemconnector.eu.auth0.com/authorize?audience=https://europe-west1-fhem-ga-connector.cloudfunctions.net/&scope=offline_access%20openid%20profile&response_type=code&client_id=EI0TI2Y0W1743Ico53Nvsg1FsmoZniCC&code_challenge=kqkNgMnwKdN5DMhixH7IDa4U9N5X8Vr7Wn84r-M9mcU&code_challenge_method=S256&redirect_uri=https://europe-west1-fhem-ga-connector.cloudfunctions.net/codelanding/start" target="_blank">Click here to login (new window/tab)</a><br></html>|gassistantFHEM.loginURL|<html><a href="https://fhemconnector.eu.auth0.com/authorize?audience=https://europe-west1-fhem-ga-connector.cloudfunctions.net/&|
359 => 2020-10-23 20:25:18|KU.HT|MAX|valveposition: 0|valveposition|0|%
360 => 2020-10-23 20:25:18|KU.HT|MAX|state: on|state|30.5|
361 => 2020-10-23 20:25:13|PID.BA.HT|PID20|actuationCalc: -19.4899999999997|actuationCalc|-19.4899999999997|
362 => 2020-10-23 20:25:18|KU.HT|MAX|desiredTemperature: on|desiredTemperature|30.5|\xB0C
363 => 2020-10-23 20:25:18|KU.HT|MAX|RSSI: -76.5|RSSI|-76.5|
364 => 2020-10-23 20:25:18|KU.HT|MAX|battery: ok|battery|ok|
365 => 2020-10-23 20:25:18|KU.HT|MAX|rferror: 0|rferror|0|
366 => 2020-10-23 20:25:18|KU.HT|MAX|gateway: 1|gateway|1|
367 => 2020-10-23 20:25:18|KU.HT|MAX|mode: manual|mode|manual|
368 => 2020-10-23 20:25:18|KU.HT|MAX|panel: locked|panel|locked|
369 => 2020-10-23 20:25:18|gassistant|GASSISTANT|gassistant-fhem-connection: connecting...|gassistant-fhem-connection|connecting...|
370 => 2020-10-23 20:25:19|gassistant|GASSISTANT|gassistant-fhem-versionAvailable: 3.0.3|gassistant-fhem-versionAvailable|3.0.3|
371 => 2020-10-23 20:25:19|KU.HT|MAX|maxValveSetting: 0|maxValveSetting|0|%
372 => 2020-10-23 20:25:13|PID.BA.HT|PID20|delta: -3.4|delta|-3.4|
373 => 2020-10-23 20:25:19|KU.HT|MAX|lastcmd: maxValveSetting 0|lastcmd|maxValveSetting|
374 => 2020-10-23 20:25:19|cul_cube|CUL|credit10ms: 3010|credit10ms|3010|
375 => 2020-10-23 20:25:19|Pfl_Miau|XIAOMIBTLESENS|batteryState: ok|batteryState|ok|
376 => 2020-10-23 20:25:19|Pfl_Miau|XIAOMIBTLESENS|batteryPercent: 100|batteryPercent|100|
377 => 2020-10-23 20:25:19|Pfl_Miau|XIAOMIBTLESENS|firmware: 3.1.9|firmware|3.1.9|
378 => 2020-10-23 20:25:19|Pfl_Miau|XIAOMIBTLESENS|fertility: 1676|fertility|1676|
379 => 2020-10-23 20:25:19|Pfl_Miau|XIAOMIBTLESENS|lux: 74|lux|74|
380 => 2020-10-23 20:25:19|Pfl_Miau|XIAOMIBTLESENS|temperature: 22.5|temperature|22.5|°C
381 => 2020-10-23 20:25:19|Pfl_Miau|XIAOMIBTLESENS|moisture: 63|moisture|63|
382 => 2020-10-23 20:25:20|BA.HT|MAX|valveposition: 0|valveposition|0|%
383 => 2020-10-23 20:25:45|logdb|DBLOG|state: DBD::mysql::st execute_array failed: executing 191 generated 2 errors at ./FHEM/93_DbLog.pm line 2652.|state|DBD::mysql::st execute_array failed|executing 191 generated 2 errors
384 => 2020-10-23 20:25:47|AUSSEN.TEMP|LACROSSE|temperature: 15.2|temperature|15.2|°C
385 => 2020-10-23 20:25:47|AUSSEN.TEMP|LACROSSE|avg_aussen: 0.0|avg_aussen|0.0|
386 => 2020-10-23 20:25:49|cul_cube|CUL|credit10ms: 2702|credit10ms|2702|
387 => 2020-10-23 20:25:49|SonoffA|MQTT2_DEVICE|Temp3: 20.7|Temp3|20.7|
388 => 2020-10-23 20:25:54|KU.TEMP|LACROSSE|temperature: 20.8|temperature|20.8|°C
Das Problem tritt auch mit gesetztem usechartfilter=1 auf :/
DS_Starter
Ich sehe diese:
ZitatDas Problem tritt auch mit gesetztem usechartfilter=1 auf :/
Die Zeichen sind schon im Cache drin. Du musst den Cache erst leeren. Am einfachsten mit einem FHEM Restart nachdem du das Attr gesetzt hast.
bartman121
habs gelöst....
Das Problem war dieser Eintrag:
Die Spalte fürs Reading war zu schmal, hab sie angepasst und sofort leerte sich der Cache ...
Thema ist gelöst
