Innr LED-Spot GU10 6W Smart RGBW 350lm dimmbar Farben lassen sich nicht veränder
Begonnen von Andy1987, 01 November 2020, 20:54:12
Andy1987
habe das Problem die Farbe nicht wechseln zu können (bekomme nur Blau), da ich in "color_temp" keinen
anderen Wert wie null eingetragen bekomme.
DEF                     RS230C 0x588e81fffe1e84be RGB1
FRIENDLYNAME    RGB1
FUUID                 5f9ebff3-f33f-7b75-67c3-be1e1330f1ec3564
IODev                 MQTT
MODEL                RS230C
NAME                  RGB1
NOTIFYDEV          RS230C 0x588e81fffe1e84be RGB1
NR                      40
SID                     0x588e81fffe1e84be
STATE                 ON
TYPE                   XiaomiMQTTDevice
defmod RGB1 XiaomiMQTTDevice RS230C 0x588e81fffe1e84be RGB1
attr RGB1 IODev MQTT
attr RGB1 room Wohnen
attr RGB1 stateFormat state
attr RGB1 webCmd on:off:brightness:color mode:rgb
attr RGB1 widgetOverride color mode 2 brightness:slider,0,15,255 rgb:colorpicker,HSV
Raw definition:
setstate RGB1 ON
setstate RGB1 2020-11-01 20:24:41 brightness 255
setstate RGB1 2020-11-01 15:53:45 hsv 0,100,100
setstate RGB1 2020-11-01 20:24:41 state ON
setstate RGB1 2020-11-01 20:24:41 transmission-state incoming publish received
Readings:
brightness                165
hsv                          0,100,100
state                        ON
colorInit:
defmod colorInit notify RGB1:rgb.*|global:INITIALIZED set 0x588e81fffe1e8b4e remove
attr colorInit room Wohnen
setstate colorInit 2020-11-01 15:54:48
setstate colorInit 2020-11-01 15:54:48 state active
zigbee2mqtt:info  2020-11-01 20:32:02: MQTT publish: topic 'zigbee2mqtt/RGB1', payload '{"state":"ON","brightness":165,"color":{},"color_temp":null}'
Habt vielen Dank im Voraus :-)
Gruss, Andreas
