Crypt::Rijndael_PP Installation RasPiOS
Begonnen von TomLee, 15 November 2020, 18:51:32
TomLee
hat weniger mit FHEM direkt zu tun aber ohne die Installation geht kein Echo, Sauger an und mit einlesen komm ich nicht weiter.
Kann mir wer sagen warum es bei einer komplett neuen RasPI-OS-Installation (OK, nicht ganz neu, alle Biblitheken und sonstige Abhängigkeiten für meinen FHEM-Server sind bereits installiert) zu folgender Meldung kommt :
pi@FHEMPIOS:~ $ sudo cpan Crypt::Rijndael_PP
Loading internal logger. Log::Log4perl recommended for better logging
CPAN.pm requires configuration, but most of it can be done automatically.
If you answer 'no' below, you will enter an interactive dialog for each
configuration option instead.
Would you like to configure as much as possible automatically? [yes] yes
Fetching with LWP:
http://www.cpan.org/authors/01mailrc.txt.gz
Reading '/root/.cpan/sources/authors/01mailrc.txt.gz'
............................................................................DONE
Fetching with LWP:
http://www.cpan.org/modules/02packages.details.txt.gz
Reading '/root/.cpan/sources/modules/02packages.details.txt.gz'
  Database was generated on Sun, 15 Nov 2020 16:29:03 GMT
  New CPAN.pm version (v2.28) available.
  [Currently running version is v2.20]
  You might want to try
    install CPAN
    reload cpan
  to both upgrade CPAN.pm and run the new version without leaving
  the current session.
Fetching with LWP:
http://www.cpan.org/modules/03modlist.data.gz
Reading '/root/.cpan/sources/modules/03modlist.data.gz'
DONE
Writing /root/.cpan/Metadata
Running install for module 'Crypt::Rijndael_PP'
Fetching with LWP:
http://www.cpan.org/authors/id/D/DE/DELTA/Crypt-Rijndael_PP-0.05.tar.gz
Fetching with LWP:
http://www.cpan.org/authors/id/D/DE/DELTA/CHECKSUMS
Checksum for /root/.cpan/sources/authors/id/D/DE/DELTA/Crypt-Rijndael_PP-0.05.tar.gz ok
'YAML' not installed, will not store persistent state
Configuring D/DE/DELTA/Crypt-Rijndael_PP-0.05.tar.gz with Makefile.PL
Checking if your kit is complete...
Looks good
Generating a Unix-style Makefile
Writing Makefile for Crypt::Rijndael_PP
Writing MYMETA.yml and MYMETA.json
  /usr/bin/perl Makefile.PL INSTALLDIRS=site -- OK
Running make for D/DE/DELTA/Crypt-Rijndael_PP-0.05.tar.gz
cp Rijndael_PP.pm blib/lib/Crypt/Rijndael_PP.pm
cp comp.pl blib/lib/Crypt/comp.pl
Manifying 1 pod document
  /usr/bin/make -- OK
Running make test
PERL_DL_NONLAZY=1 "/usr/bin/perl" "-MExtUtils::Command::MM" "-MTest::Harness" "-e" "undef *Test::Harness::Switches; test_harness(0, 'blib/lib', 'blib/arch')" t/*.t
t/00base.t ........... ok
t/01re_all_knb.t ..... ok
t/02rnd_hin_u_her.t .. ok
t/03compxs.t ......... ok
t/04cbc.t ............ ok
All tests successful.
Files=5, Tests=411, 25 wallclock secs ( 0.35 usr  0.04 sys + 25.02 cusr  0.09 csys = 25.50 CPU)
Result: PASS
  /usr/bin/make test -- OK
Running make install
ERROR: Can't create '/usr/local/man/man3'
mkdir /usr/local/man: File exists at /usr/share/perl/5.28/ExtUtils/Install.pm line 489.
at -e line 1.
make: *** [Makefile:703: pure_site_install] Fehler 17
  /usr/bin/make install  -- NOT OK
Auch ein
sudo cpan Crypt::Cipher::AES
endet mit
Files found in blib/arch: installing files in blib/lib into architecture dependent library tree
at -e line 1.
make: *** [Makefile:1551: pure_site_install] Fehler 17
  MIK/CryptX-0.069.tar.gz
make funktioniert ja trotzdem hab ich mal ein
sudo apt-get install build-essential
ausgeführt, das ergibt auch:
0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
Wegen der Meldung:
Fetching with LWP:
  Database was generated on Fri, 13 Nov 2020 15:29:02 GMT
    install CPAN
    reload cpan
dacht ich mir hilft womöglich ein install CPAN, aber auch die /usr/bin/make install  -- NOT OK Meldung :
pi@FHEMPIOS:~ $ sudo perl -MCPAN -e shell
Autoconfiguration complete.
commit: wrote '/root/.cpan/CPAN/MyConfig.pm'
You can re-run configuration any time with 'o conf init' in the CPAN shell
Terminal does not support AddHistory.
cpan shell -- CPAN exploration and modules installation (v2.20)
Enter 'h' for help.
cpan[1]> install CPAN
Fetching with LWP:
Fetching with LWP:
  Database was generated on Sun, 15 Nov 2020 12:55:59 GMT
    install CPAN
    reload cpan
Fetching with LWP:
DONE
Running install for module 'CPAN'
Fetching with LWP:
http://www.cpan.org/authors/id/A/AN/ANDK/CPAN-2.28.tar.gz
Fetching with LWP:
http://www.cpan.org/authors/id/A/AN/ANDK/CHECKSUMS
Checksum for /root/.cpan/sources/authors/id/A/AN/ANDK/CPAN-2.28.tar.gz ok
Scanning cache /root/.cpan/build for sizes
DONE
Configuring A/AN/ANDK/CPAN-2.28.tar.gz with Makefile.PL
Importing PAUSE public key into your GnuPG keychain... done!
(You may wish to trust it locally with 'gpg --lsign-key 450F89EC')
Looks good
Writing Makefile for CPAN
Running make for A/AN/ANDK/CPAN-2.28.tar.gz
cp lib/CPAN.pm blib/lib/CPAN.pm
cp lib/CPAN/Mirrors.pm blib/lib/CPAN/Mirrors.pm
cp lib/CPAN/Exception/blocked_urllist.pm blib/lib/CPAN/Exception/blocked_urllist.pm
cp lib/CPAN/Index.pm blib/lib/CPAN/Index.pm
cp lib/CPAN/DeferredCode.pm blib/lib/CPAN/DeferredCode.pm
cp lib/CPAN/HTTP/Credentials.pm blib/lib/CPAN/HTTP/Credentials.pm
cp lib/CPAN/API/HOWTO.pod blib/lib/CPAN/API/HOWTO.pod
cp lib/CPAN/Tarzip.pm blib/lib/CPAN/Tarzip.pm
cp lib/CPAN/Admin.pm blib/lib/CPAN/Admin.pm
cp lib/CPAN/Complete.pm blib/lib/CPAN/Complete.pm
cp lib/CPAN/FirstTime.pm blib/lib/CPAN/FirstTime.pm
cp lib/CPAN/URL.pm blib/lib/CPAN/URL.pm
cp lib/CPAN/Nox.pm blib/lib/CPAN/Nox.pm
cp lib/CPAN/CacheMgr.pm blib/lib/CPAN/CacheMgr.pm
cp lib/CPAN/Plugin/Specfile.pm blib/lib/CPAN/Plugin/Specfile.pm
cp lib/CPAN/Exception/yaml_not_installed.pm blib/lib/CPAN/Exception/yaml_not_installed.pm
cp lib/CPAN/Plugin.pm blib/lib/CPAN/Plugin.pm
cp lib/CPAN/Bundle.pm blib/lib/CPAN/Bundle.pm
cp lib/CPAN/InfoObj.pm blib/lib/CPAN/InfoObj.pm
cp lib/CPAN/HTTP/Client.pm blib/lib/CPAN/HTTP/Client.pm
cp lib/CPAN/Prompt.pm blib/lib/CPAN/Prompt.pm
cp lib/CPAN/LWP/UserAgent.pm blib/lib/CPAN/LWP/UserAgent.pm
cp lib/CPAN/Exception/yaml_process_error.pm blib/lib/CPAN/Exception/yaml_process_error.pm
cp lib/CPAN/Debug.pm blib/lib/CPAN/Debug.pm
cp lib/CPAN/HandleConfig.pm blib/lib/CPAN/HandleConfig.pm
cp lib/CPAN/Distrostatus.pm blib/lib/CPAN/Distrostatus.pm
cp lib/CPAN/Exception/RecursiveDependency.pm blib/lib/CPAN/Exception/RecursiveDependency.pm
cp lib/App/Cpan.pm blib/lib/App/Cpan.pm
cp lib/CPAN/Version.pm blib/lib/CPAN/Version.pm
cp lib/CPAN/FTP.pm blib/lib/CPAN/FTP.pm
cp lib/CPAN/Kwalify/distroprefs.yml blib/lib/CPAN/Kwalify/distroprefs.yml
cp lib/CPAN/Module.pm blib/lib/CPAN/Module.pm
cp lib/CPAN/Shell.pm blib/lib/CPAN/Shell.pm
cp lib/CPAN/Queue.pm blib/lib/CPAN/Queue.pm
cp lib/CPAN/Author.pm blib/lib/CPAN/Author.pm
cp lib/CPAN/Kwalify/distroprefs.dd blib/lib/CPAN/Kwalify/distroprefs.dd
cp lib/CPAN/Distribution.pm blib/lib/CPAN/Distribution.pm
cp lib/CPAN/Distroprefs.pm blib/lib/CPAN/Distroprefs.pm
cp lib/CPAN/Kwalify.pm blib/lib/CPAN/Kwalify.pm
cp lib/CPAN/FTP/netrc.pm blib/lib/CPAN/FTP/netrc.pm
cp scripts/cpan blib/script/cpan
"/usr/bin/perl" -MExtUtils::MY -e 'MY->fixin(shift)' -- blib/script/cpan
cp scripts/cpan-mirrors blib/script/cpan-mirrors
"/usr/bin/perl" -MExtUtils::MY -e 'MY->fixin(shift)' -- blib/script/cpan-mirrors
Manifying 2 pod documents
Manifying 16 pod documents
  /usr/bin/make -- OK
Running make test
t/00signature.t ............... skipped: No Module::Signature found [INC = /root/.cpan/build/CPAN-2.28-0/blib/lib /root/.cpan/build/CPAN-2.28-0/blib/arch /etc/perl /usr/local/lib/arm-linux-gnueabihf/perl/5.28.1 /usr/local/share/perl/5.28.1 /usr/lib/arm-linux-gnueabihf/perl5/5.28 /usr/share/perl5 /usr/lib/arm-linux-gnueabihf/perl/5.28 /usr/share/perl/5.28 /usr/local/lib/site_perl /usr/lib/arm-linux-gnueabihf/perl-base .]
t/01loadme.t .................. ok
t/02nox.t ..................... ok
t/03pkgs.t .................... ok
t/04clean_load.t .............. ok
t/10version.t ................. ok
t/11mirroredby.t .............. ok
t/12cpan.t .................... ok
t/13tarzip.t .................. ok
t/14forkbomb.t ................ skipped: test only run when called with --doit
t/30shell.t ................... skipped: no Expect, maybe try env CPAN_RUN_SHELL_TEST_WITHOUT_EXPECT=1
t/31sessions.t ................ skipped: Module::Build not installed
t/41distribution.t ............ skipped: No yaml module installed
t/42distroprefs.t ............. skipped: YAML required
t/43distroprefspref.t ......... ok
t/44cpanmeta.t ................ ok
t/50pod.t ..................... skipped: Test::Pod 1.00 required for testing POD
t/51pod.t ..................... ok
t/52podcover.t ................ skipped: Test::Pod::Coverage 0.18 required for testing pod coverage
t/60credentials.t ............. ok
t/70_critic.t ................. skipped: Test::Perl::Critic only run when AUTHOR_TEST set
t/71_minimumversion.t ......... skipped: running MinimumVersion test only run when AUTHOR_TEST set
t/97-compile.t ................ ok
t/97-cpanpm_output_hook.t ..... ok
t/97-expand_filenames.t ....... ok
t/97-install_hack.t ........... ok
t/97-mock.t ................... ok
t/97-process_options.t ........ ok
t/97-process_setup_options.t .. ok
t/97-return_values.t .......... ok
t/97-run.t .................... skipped: Skipping test when running as root, Pod::Perldoc often fails for root user
Files=31, Tests=443, 58 wallclock secs ( 0.51 usr  0.21 sys + 47.06 cusr  4.51 csys = 52.29 CPU)
Result: PASS
ERROR: Can't create '/usr/local/man/man1'
at -e line 1.
make: *** [Makefile:923: pure_site_install] Fehler 17
Failed during this command:
ANDK/CPAN-2.28.tar.gz                        : install NOT OK
Weil da
zurückkam, hab ich versucht das nachzuinstallieren, mein aber es jetzt so zu verstanden zu haben das das gar nicht nötig ist und ignoriert werden kann, wieder mit der /usr/bin/make install  -- NOT OK Meldung
sudo install YAML
pi@FHEMPIOS:~ $ sudo cpan YAML
Reading '/root/.cpan/Metadata'
Running install for module 'YAML'
Fetching with LWP:
http://www.cpan.org/authors/id/T/TI/TINITA/YAML-1.30.tar.gz
Fetching with LWP:
http://www.cpan.org/authors/id/T/TI/TINITA/CHECKSUMS
Checksum for /root/.cpan/sources/authors/id/T/TI/TINITA/YAML-1.30.tar.gz ok
Configuring T/TI/TINITA/YAML-1.30.tar.gz with Makefile.PL
Looks good
Warning: prerequisite Test::Deep 0 not found.
Warning: prerequisite Test::YAML 1.05 not found.
Writing Makefile for YAML
Running make for T/TI/TINITA/YAML-1.30.tar.gz
---- Unsatisfied dependencies detected during ----
----          TINITA/YAML-1.30.tar.gz         ----
    Test::Deep [build_requires]
    Test::YAML [build_requires]
Running install for module 'Test::Deep'
Fetching with LWP:
http://www.cpan.org/authors/id/R/RJ/RJBS/Test-Deep-1.130.tar.gz
Fetching with LWP:
http://www.cpan.org/authors/id/R/RJ/RJBS/CHECKSUMS
Checksum for /root/.cpan/sources/authors/id/R/RJ/RJBS/Test-Deep-1.130.tar.gz ok
Configuring R/RJ/RJBS/Test-Deep-1.130.tar.gz with Makefile.PL
Looks good
Writing Makefile for Test::Deep
Running make for R/RJ/RJBS/Test-Deep-1.130.tar.gz
cp lib/Test/Deep/Number.pm blib/lib/Test/Deep/Number.pm
cp lib/Test/Deep/Ignore.pm blib/lib/Test/Deep/Ignore.pm
cp lib/Test/Deep/Methods.pm blib/lib/Test/Deep/Methods.pm
cp lib/Test/Deep/ListMethods.pm blib/lib/Test/Deep/ListMethods.pm
cp lib/Test/Deep/ArrayElementsOnly.pm blib/lib/Test/Deep/ArrayElementsOnly.pm
cp lib/Test/Deep/Cache.pm blib/lib/Test/Deep/Cache.pm
cp lib/Test/Deep/RefType.pm blib/lib/Test/Deep/RefType.pm
cp lib/Test/Deep/HashElements.pm blib/lib/Test/Deep/HashElements.pm
cp lib/Test/Deep/Set.pm blib/lib/Test/Deep/Set.pm
cp lib/Test/Deep/RegexpMatches.pm blib/lib/Test/Deep/RegexpMatches.pm
cp lib/Test/Deep/Ref.pm blib/lib/Test/Deep/Ref.pm
cp lib/Test/Deep/Hash.pm blib/lib/Test/Deep/Hash.pm
cp lib/Test/Deep/Array.pm blib/lib/Test/Deep/Array.pm
cp lib/Test/Deep/HashKeysOnly.pm blib/lib/Test/Deep/HashKeysOnly.pm
cp lib/Test/Deep/NoTest.pm blib/lib/Test/Deep/NoTest.pm
cp lib/Test/Deep/Any.pm blib/lib/Test/Deep/Any.pm
cp lib/Test/Deep/HashKeys.pm blib/lib/Test/Deep/HashKeys.pm
cp lib/Test/Deep/None.pm blib/lib/Test/Deep/None.pm
cp lib/Test/Deep/Boolean.pm blib/lib/Test/Deep/Boolean.pm
cp lib/Test/Deep/RegexpRefOnly.pm blib/lib/Test/Deep/RegexpRefOnly.pm
cp lib/Test/Deep/Obj.pm blib/lib/Test/Deep/Obj.pm
cp lib/Test/Deep/RegexpVersion.pm blib/lib/Test/Deep/RegexpVersion.pm
cp lib/Test/Deep/RegexpOnly.pm blib/lib/Test/Deep/RegexpOnly.pm
cp lib/Test/Deep/MM.pm blib/lib/Test/Deep/MM.pm
cp lib/Test/Deep/Stack.pm blib/lib/Test/Deep/Stack.pm
cp lib/Test/Deep/ScalarRef.pm blib/lib/Test/Deep/ScalarRef.pm
cp lib/Test/Deep/String.pm blib/lib/Test/Deep/String.pm
cp lib/Test/Deep/Isa.pm blib/lib/Test/Deep/Isa.pm
cp lib/Test/Deep/Blessed.pm blib/lib/Test/Deep/Blessed.pm
cp lib/Test/Deep/ArrayLength.pm blib/lib/Test/Deep/ArrayLength.pm
cp lib/Test/Deep/RegexpRef.pm blib/lib/Test/Deep/RegexpRef.pm
cp lib/Test/Deep/All.pm blib/lib/Test/Deep/All.pm
cp lib/Test/Deep/HashEach.pm blib/lib/Test/Deep/HashEach.pm
cp lib/Test/Deep/Shallow.pm blib/lib/Test/Deep/Shallow.pm
cp lib/Test/Deep/Class.pm blib/lib/Test/Deep/Class.pm
cp lib/Test/Deep/Cache/Simple.pm blib/lib/Test/Deep/Cache/Simple.pm
cp lib/Test/Deep.pm blib/lib/Test/Deep.pm
cp lib/Test/Deep/Code.pm blib/lib/Test/Deep/Code.pm
cp lib/Test/Deep/ArrayEach.pm blib/lib/Test/Deep/ArrayEach.pm
cp lib/Test/Deep/Regexp.pm blib/lib/Test/Deep/Regexp.pm
cp lib/Test/Deep/ScalarRefOnly.pm blib/lib/Test/Deep/ScalarRefOnly.pm
cp lib/Test/Deep/ArrayLengthOnly.pm blib/lib/Test/Deep/ArrayLengthOnly.pm
cp lib/Test/Deep/Cmp.pm blib/lib/Test/Deep/Cmp.pm
  /usr/bin/make -- OK
Running make test
t/all.t ..................... ok
t/any.t ..................... ok
t/array.t ................... ok
t/array_each.t .............. ok
t/arraylength.t ............. ok
t/bag.t ..................... ok
t/bagrecursion.t ............ ok
t/blessed.t ................. ok
t/boolean.t ................. ok
t/cache.t ................... ok
t/circular.t ................ ok
t/class.t ................... ok
t/code.t .................... ok
t/deep_utils.t .............. ok
t/descend.t ................. ok
t/error.t ................... ok
t/hash.t .................... ok
t/hash_each.t ............... ok
t/hashkeys.t ................ ok
t/ignore.t .................. ok
t/import.t .................. ok
t/isa.t ..................... ok
t/leaf-wrapper.t ............ ok
t/listmethods.t ............. ok
t/memory.t .................. ok
t/methods.t ................. ok
t/none.t .................... ok
t/notest.t .................. ok
t/notest_extra.t ............ ok
t/number.t .................. ok
t/reftype.t ................. ok
t/regexp.t .................. ok
t/regexpref.t ............... ok
t/rt78288_blessed_object.t .. ok
t/scalar.t .................. ok
t/scalarref.t ............... ok
t/set.t ..................... ok
t/shallow.t ................. ok
t/string.t .................. ok
Files=39, Tests=1260, 15 wallclock secs ( 0.92 usr  0.29 sys + 13.42 cusr  1.36 csys = 15.99 CPU)
Result: PASS
at -e line 1.
make: *** [Makefile:782: pure_site_install] Fehler 17
Running install for module 'Test::YAML'
Fetching with LWP:
http://www.cpan.org/authors/id/T/TI/TINITA/Test-YAML-1.07.tar.gz
Checksum for /root/.cpan/sources/authors/id/T/TI/TINITA/Test-YAML-1.07.tar.gz ok
Configuring T/TI/TINITA/Test-YAML-1.07.tar.gz with Makefile.PL
Looks good
Warning: prerequisite Test::Base 0.89 not found.
Writing Makefile for Test::YAML
Running make for T/TI/TINITA/Test-YAML-1.07.tar.gz
----       TINITA/Test-YAML-1.07.tar.gz       ----
    Test::Base [requires]
Running install for module 'Test::Base'
Fetching with LWP:
http://www.cpan.org/authors/id/I/IN/INGY/Test-Base-0.89.tar.gz
Fetching with LWP:
http://www.cpan.org/authors/id/I/IN/INGY/CHECKSUMS
Checksum for /root/.cpan/sources/authors/id/I/IN/INGY/Test-Base-0.89.tar.gz ok
Configuring I/IN/INGY/Test-Base-0.89.tar.gz with Makefile.PL
Looks good
Warning: prerequisite Spiffy 0.40 not found.
Writing Makefile for Test::Base
Running make for I/IN/INGY/Test-Base-0.89.tar.gz
----        INGY/Test-Base-0.89.tar.gz        ----
    Spiffy [requires]
Running install for module 'Spiffy'
Fetching with LWP:
http://www.cpan.org/authors/id/I/IN/INGY/Spiffy-0.46.tar.gz
Checksum for /root/.cpan/sources/authors/id/I/IN/INGY/Spiffy-0.46.tar.gz ok
Configuring I/IN/INGY/Spiffy-0.46.tar.gz with Makefile.PL
Looks good
Writing Makefile for Spiffy
Running make for I/IN/INGY/Spiffy-0.46.tar.gz
cp lib/Spiffy.pm blib/lib/Spiffy.pm
cp lib/Spiffy.pod blib/lib/Spiffy.pod
cp lib/Spiffy/mixin.pm blib/lib/Spiffy/mixin.pm
  /usr/bin/make -- OK
Running make test
t/autoload.t ............ ok
t/base.t ................ ok
t/base2.t ............... ok
t/cascade.t ............. ok
t/const.t ............... ok
t/early.t ............... ok
t/export1.t ............. ok
t/export2.t ............. ok
t/export3.t ............. ok
t/export4.t ............. ok
t/export5.t ............. ok
t/export6.t ............. ok
t/export7.t ............. ok
t/exporter.t ............ ok
t/field.t ............... ok
t/field2.t .............. ok
t/field3.t .............. ok
t/filter.t .............. ok
t/filter2.t ............. ok
t/filter3.t ............. ok
t/filter4.t ............. ok
t/filter5.t ............. ok
t/mixin.t ............... ok
t/mixin2.t .............. ok
t/mixin3.t .............. ok
t/new.t ................. ok
t/package.t ............. ok
t/parse.t ............... ok
t/release-pod-syntax.t .. skipped: these tests are for release candidate testing
t/stub.t ................ ok
t/super.t ............... ok
t/super2.t .............. ok
Files=32, Tests=198, 10 wallclock secs ( 0.43 usr  0.17 sys +  9.33 cusr  1.15 csys = 11.08 CPU)
Result: PASS
at -e line 1.
make: *** [Makefile:708: pure_site_install] Fehler 17
  Has already been unwrapped into directory /root/.cpan/build/Test-Base-0.89-0
  Has already been prepared
cp lib/Test/Base/Filter.pm blib/lib/Test/Base/Filter.pm
cp lib/Test/Base.pod blib/lib/Test/Base.pod
cp lib/Test/Base.pm blib/lib/Test/Base.pm
cp lib/Test/Base/Filter.pod blib/lib/Test/Base/Filter.pod
  /usr/bin/make -- OK
Running make test
t/000-require-modules.t .. ok
t/append.t ............... ok
t/arguments.t ............ ok
t/array.t ................ ok
t/author-pod-syntax.t .... skipped: these tests are for testing by the author
t/autoload.t ............. ok
t/base64.t ............... ok
t/blocks-scalar.t ........ ok
t/blocks_grep.t .......... ok
t/chomp.t ................ ok
t/chop.t ................. ok
t/compact.t .............. ok
t/compile.t .............. ok
t/deep.t ................. ok
t/delimiters.t ........... ok
t/description.t .......... ok
t/diff_is.t .............. ok
t/dumper.t ............... ok
t/embed_perl.t ........... ok
t/escape.t ............... ok
t/eval.t ................. ok
t/eval_all.t ............. ok
t/eval_stderr.t .......... ok
t/eval_stdout.t .......... ok
t/expected-zero.t ........ ok
t/export.t ............... ok
t/exported_func.t ........ ok
t/filter_arguments.t ..... ok
t/filter_delay.t ......... ok
t/filter_functions.t ..... ok
t/filters-append.t ....... ok
t/filters.t .............. ok
t/filters_map.t .......... ok
t/first_block.t .......... ok
t/flatten.t .............. ok
t/get_url.t .............. skipped: Need to figure out network testing
t/hash.t ................. ok
t/head.t ................. ok
t/internals.t ............ ok
t/is.t ................... ok
t/jit-run.t .............. ok
t/join-deep.t ............ ok
t/join.t ................. ok
t/last.t ................. ok
t/late.t ................. ok
t/lazy-filters.t ......... ok
t/lines.t ................ ok
t/list.t ................. ok
t/main_filters.t ......... 1/6 # Filters returning numbers are supposed to do munging $_: your filter 'main::mike5' apparently doesn't.
t/main_filters.t ......... ok
t/multi-level-inherit.t .. ok
t/name.t ................. ok
t/next.t ................. ok
t/no_diff.t .............. ok
t/no_plan.t .............. ok
t/normalize.t ............ ok
t/only-with-implicit.t ... ok
t/only.t ................. ok
t/oo.t ................... ok
t/oo_run.t ............... ok
t/parentheses.t .......... ok
t/prepend.t .............. ok
t/preserve-order.t ....... ok
t/prototypes.t ........... ok
t/quick-plan.t ........... ok
t/quick_test.t ........... ok
t/read_file.t ............ ok
t/regexp.t ............... ok
t/repeated-filters.t ..... ok
t/require.t .............. ok
t/reserved_names.t ....... ok
t/reverse-deep.t ......... ok
t/reverse.t .............. ok
t/run-args.t ............. ok
t/run_compare.t .......... ok
t/run_is.t ............... ok
t/run_is_deep.t .......... ok
t/run_is_deeply.t ........ ok
t/run_like.t ............. ok
t/run_unlike.t ........... ok
t/simple.t ............... ok
t/skip.t ................. ok
t/slice.t ................ ok
t/sort-deep.t ............ ok
t/sort.t ................. ok
t/spec_file.t ............ ok
t/spec_string.t .......... ok
t/split-deep.t ........... ok
t/split-regexp.t ......... ok
t/split.t ................ ok
t/strict-warnings.t ...... ok
t/strict.t ............... ok
t/subclass-autoclass.t ... ok
t/subclass-import.t ...... ok
t/subclass.t ............. ok
t/subclass_late.t ........ ok
t/tail.t ................. ok
t/tie_output.t ........... ok
t/trim.t ................. ok
t/unchomp.t .............. ok
t/undef.t ................ ok
t/use-test-more.t ........ ok
t/use.t .................. ok
t/write_file.t ........... ok
t/xxx.t .................. skipped: Requires YAML
t/yaml.t ................. skipped: Requires YAML
t/zero-blocks.t .......... ok
Files=106, Tests=431, 43 wallclock secs ( 1.12 usr  0.52 sys + 38.06 cusr  4.00 csys = 43.70 CPU)
Result: PASS
at -e line 1.
make: *** [Makefile:732: pure_site_install] Fehler 17
  Has already been unwrapped into directory /root/.cpan/build/Test-YAML-1.07-0
cp lib/Test/YAML.pm blib/lib/Test/YAML.pm
cp lib/Test/YAML.pod blib/lib/Test/YAML.pod
cp bin/test-yaml blib/script/test-yaml
"/usr/bin/perl" -MExtUtils::MY -e 'MY->fixin(shift)' -- blib/script/test-yaml
  /usr/bin/make -- OK
Running make test
t/author-pod-syntax.t .. skipped: these tests are for testing by the author
t/load.t ............... ok
Files=2, Tests=1,  0 wallclock secs ( 0.10 usr  0.01 sys +  0.39 cusr  0.02 csys =  0.52 CPU)
Result: PASS
at -e line 1.
make: *** [Makefile:726: pure_site_install] Fehler 17
  Has already been unwrapped into directory /root/.cpan/build/YAML-1.30-0
cp lib/YAML.pod blib/lib/YAML.pod
cp lib/YAML/Node.pm blib/lib/YAML/Node.pm
cp lib/YAML/Marshall.pm blib/lib/YAML/Marshall.pm
cp lib/YAML/Tag.pm blib/lib/YAML/Tag.pm
cp lib/YAML/Loader/Base.pod blib/lib/YAML/Loader/Base.pod
cp lib/YAML/Node.pod blib/lib/YAML/Node.pod
cp lib/YAML/Tag.pod blib/lib/YAML/Tag.pod
cp lib/YAML/Loader.pod blib/lib/YAML/Loader.pod
cp lib/YAML/Types.pm blib/lib/YAML/Types.pm
cp lib/YAML/Error.pm blib/lib/YAML/Error.pm
cp lib/YAML/Dumper.pod blib/lib/YAML/Dumper.pod
cp lib/YAML/Dumper/Base.pod blib/lib/YAML/Dumper/Base.pod
cp lib/YAML/Error.pod blib/lib/YAML/Error.pod
cp lib/YAML/Loader.pm blib/lib/YAML/Loader.pm
cp lib/YAML/Types.pod blib/lib/YAML/Types.pod
cp lib/YAML/Mo.pm blib/lib/YAML/Mo.pm
cp lib/YAML/Dumper/Base.pm blib/lib/YAML/Dumper/Base.pm
cp lib/YAML/Any.pod blib/lib/YAML/Any.pod
cp lib/YAML/Marshall.pod blib/lib/YAML/Marshall.pod
cp lib/YAML/Dumper.pm blib/lib/YAML/Dumper.pm
cp lib/YAML/Any.pm blib/lib/YAML/Any.pm
cp lib/YAML.pm blib/lib/YAML.pm
cp lib/YAML/Loader/Base.pm blib/lib/YAML/Loader/Base.pm
Manifying 11 pod documents
  /usr/bin/make -- OK
Running make test
t/000-compile-modules.t ............ ok
t/2-scalars.t ...................... ok
t/author-pod-syntax.t .............. skipped: these tests are for testing by the author
t/basic-tests.t .................... ok
t/bugs-emailed.t ................... ok
t/bugs-rt.t ........................ ok
t/changes.t ........................ ok
t/dump-basics.t .................... ok
t/dump-blessed-glob.t .............. ok
t/dump-blessed.t ................... ok
t/dump-code.t ...................... ok
t/dump-file-utf8.t ................. ok
t/dump-file.t ...................... ok
t/dump-nested.t .................... ok
t/dump-opts.t ...................... ok
t/dump-perl-types-512.t ............ skipped: test only for perls before v5.13.5-11-gfb85c04
t/dump-perl-types-514.t ............ ok
t/dump-perl-types.t ................ ok
t/dump-stringify.t ................. ok
t/dump-stringy-numbers.t ........... ok
t/dump-synopsis.t .................. ok
t/dump-tests-512.t ................. skipped: test only for perls before v5.13.5-11-gfb85c04
t/dump-tests-514.t ................. ok
t/dump-tests.t ..................... ok
t/dump-works.t ..................... ok
t/errors.t ......................... ok
t/export.t ......................... ok
t/freeze-thaw.t .................... ok
t/global-api.t ..................... ok
t/inbox.t .......................... ok
t/io-handle.t ...................... ok
t/issue-149.t ...................... ok
t/issue-69.t ....................... ok
t/load-code.t ...................... ok
t/load-fails.t ..................... ok
t/load-passes.t .................... ok
t/load-slides.t .................... ok
t/load-spec.t ...................... ok
t/load-tests.t ..................... ok
t/load-works.t ..................... ok
t/marshall.t ....................... ok
t/no-load-blessed.t ................ ok
t/node-info.t ...................... ok
t/numify.t ......................... ok
t/preserve.t ....................... ok
t/pugs-objects.t ................... ok
t/references.t ..................... ok
t/regexp.t ......................... ok
t/roundtrip.t ...................... ok
t/rt-90593.t ....................... ok
t/svk.t ............................ ok
t/test.t ........................... ok
t/trailing-comments-content.t ...... ok
t/trailing-comments-non-content.t .. ok
Files=54, Tests=542, 110 wallclock secs ( 0.83 usr  0.26 sys + 69.36 cusr 40.10 csys = 110.55 CPU)
Result: PASS
at -e line 1.
make: *** [Makefile:773: pure_site_install] Fehler 17
Kann mir irgendwer erklären was mir diese Fehlermeldung sagen möchte, weil genau die verstehe ich nicht zu interpretieren wie ich vorzugehen habe das sie nicht mehr kommt und vermute ich als Ursache meines Problems:
Thomas
Otto123
Hallo Thomas,
Du versuchst:
ich mach immer
sudo cpan install Crypt::Rijndael_PP
Du hast install vergessen?
TomLee
Tatsache  ::)
Ich hab mir alle Befehle (recht und schlecht) dokumentiert und hier das install vergessen  ;D
Trotzdem:
Warum auch immer, weiß ich selbst nicht genau, aber davon gelesen, hab jetzt folgendes ausgeführt:
root@FHEMPIOS:~#rm -r .cpan
vorsichtshalber einen reboot.
Dann:
pi@FHEMPIOS:~ $ sudo cpan install Crypt::Rijndael_PP
Fetching with LWP:
Fetching with LWP:
    install CPAN
    reload cpan
Fetching with LWP:
DONE
Fetching with LWP:
Fetching with LWP:
Looks good
  /usr/bin/make -- OK
Running make test
Files=5, Tests=411, 25 wallclock secs ( 0.37 usr  0.03 sys + 24.53 cusr  0.11 csys = 25.04 CPU)
Result: PASS
at -e line 1.
Und jetzt ?  ;D
Da ist der Haken weiterhin, vermute ich.
amenomade
#3
Es ist ein bisschen OT, aber warum wollt ihr unbedingt die "pure perl implementation" von Crypt::Rijndael (aka  Crypt::Rijndael_PP) installieren?
Es reicht für Fhem auf einer normalen Rasbian Installation ein
sudo apt install libcrypt-rijndael-perl
EDIT: siehe sogar das Disclaimer auf https://metacpan.org/pod/Crypt::Rijndael_PP
ZitatThis is a pure perl implementation of the new AES Rijndael. You want to use Crypt::Rijndael where available. This implementation is really slow, but I am working on it.
betateilchen
Zitat von: amenomade am 15 November 2020, 20:14:03
Es ist ein bisschen OT, aber warum wollt ihr unbedingt die "pure perl implementation" ... installieren?
Einfache Regel: je weniger Ahnung ein Anwender hat, umso einen härteren Lösungsweg wählt er sich aus.
Warum das so ist? Vermutlich reiner Masochismus.
Christoph Morrison
Ja dann wäre ein guter Start doch mal in /usr/local/man zu gucken.
Was sagt
stat  /usr/local/man;
stat /usr/local/man/man3;
stat /usr/local/man/man2;
df -h;
amenomade
Ich kann mich dunkel erinnern, dass irgendein Modul es so empfehlt. Aber wenn AES auch benötigt wird, kann man genauso
sudo apt install libcryptx-perlmachen. Das installiert Crypt::Cipher::AES mit.
amenomade
grep -rnw '/opt/fhem/FHEM' -e 'Crypt::Rijndael_PP'
ergibt nur 72_XiaomiDevice.pm
Und dieses Modul akzeptiert auch Crypt::Cipher::AES als Alternativ, und es lässt sich über apt installieren, was immer besser ist. Siehe oben wie.
Wegen Crypt::Rijndael_PP: der Autor hat im Disclaimer geschrieben, dass er daran arbeitet, aber es gibt keine neue Version seit 2016... und man kann es nur über Cpan installieren. Ich weiss nicht, warum Markus dieses _PP Modul ausgewählt hat, statt Crypt::Rijndael
TomLee
ZitatWarum das so ist? Vermutlich reiner Masochismus.
Treffer, sinnbildlich ist der Höhepunkt immer dich breit grinsend, abgeklärt und winkend entweder ganz gemütlich in der Bimmelbahn oder mit 250 Sachen in deinem Vehikel an mir vorbeiziehen zu sehen.
ZitatEs ist ein bisschen OT, aber warum wollt ihr unbedingt die "pure perl implementation" von Crypt::Rijndael (aka  Crypt::Rijndael_PP) installieren?
Weils im Wiki und im Thread zu Mi Vacuum so beschrieben wird und ich es schlicht nicht besser weiß.
pi@FHEMPIOS:~ $ sudo apt install libcrypt-rijndael-perl
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
libcrypt-rijndael-perl ist schon die neueste Version (1.13-1+b4).
libcrypt-rijndael-perl wurde als manuell installiert festgelegt.
Also wieder das disabled aus der Definition genommen:
   DEF        192.168.188.24 4173624f436549676b77503775336e70
   FUUID      5faf283c-f33f-78f5-0dde-6b50f9c0c09aa47b
   NAME       xd_vacuum
   NR         340
   STATE      Crypt::Cipher::AES or Crypt::Rijndael_PP is required!
   TYPE       XiaomiDevice
   helper:
   alexaName  Sauger
   disable    1
   event-on-change-reading .*
   genericDeviceType switch
   homebridgeMapping On=state,valueOn=Cleaning,cmdOn=start,cmdOff=charge
RotationSpeed=fan_power,minValue=0,maxValue=90,cmd=fan_power,delay=1 BatteryLevel=batteryPercent,maxValue=100,minValue=0,minStep=1 StatusLowBattery=battery,values=ok:BATTERY_LEVEL_NORMAL;;low:BATTERY_LEVEL_LOW ChargingState=state,values=Docked:NOT_CHARGING;;Charging:CHARGING;;/.*/:NOT_CHARGEABLE OccupancyDetected=state,values=/Docked|Charging/:OCCUPANCY_DETECTED;;/.*/:OCCUPANCY_NOT_DETECTED FilterLifeLevel=consumables_filter,minValue=0,maxValue=100 FilterChangeIndication=consumables_filter,values=0:CHANGE_FILTER
   icon       vacuum_top
   room       Homekit,XIAOMI
   stateFormat state
   subType    VacuumCleaner
mit dem Ergebnis das FHEM mehrmals neustartet, am Ende steht immer folgender Eintrag 2020.11.15 20:22:42 1: xd_vacuum: Crypt::Cipher::AES or Crypt::Rijndael_PP is required! im Log aber auch einmal zwischendurch 2020.11.15 20:21:14 3: xd_vacuum: disconnecting
2020.11.15 20:21:14 2: xd_vacuum: connecting
2020.11.15 20:21:14 3: xd_vacuum: initialized
send: Cannot determine peer address at ./FHEM/72_XiaomiDevice.pm line 3844.
mit top sehe ich immer wieder 100% Auslastung in der Zeit.
Irgendwann nach mehreren Neustarts ist das Device wieder disabled und FHEM wieder ganz normal erreichbar.
ZitatAber wenn AES auch benötigt wird
Ich mein nicht, muss ich nochmal genauer lesen.
ZitatJa dann wäre ein guter Start doch mal in /usr/local/man zu gucken.
pi@FHEMPIOS:/opt/fhem/log $ stat  /usr/local/man;
  Datei: /usr/local/man -> share/man
  Größe: 9          Blöcke: 0          EA Block: 4096   symbolische Verknüpfung
Gerät: b302h/45826d Inode: 19033       Verknüpfungen: 1
Zugriff: (0777/lrwxrwxrwx)  Uid: (    0/    root)   Gid: (    0/    root)
Zugriff    : 2020-11-12 16:01:16.332760322 +0100
Modifiziert: 2020-08-20 12:26:09.021463915 +0200
Geändert   : 2020-08-20 12:47:19.453429492 +0200
Geburt    : -
pi@FHEMPIOS:/opt/fhem/log $ stat /usr/local/man/man3;
stat: der Aufruf von stat für '/usr/local/man/man3' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
pi@FHEMPIOS:/opt/fhem/log $ stat /usr/local/man/man2;
stat: der Aufruf von stat für '/usr/local/man/man2' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
pi@FHEMPIOS:/opt/fhem/log $ df -h;
Dateisystem    Größe Benutzt Verf. Verw% Eingehängt auf
/dev/root        29G    2,6G   26G   10% /
devtmpfs        430M       0  430M    0% /dev
tmpfs           463M       0  463M    0% /dev/shm
tmpfs           463M    7,2M  456M    2% /run
tmpfs           5,0M    4,0K  5,0M    1% /run/lock
tmpfs           463M       0  463M    0% /sys/fs/cgroup
/dev/mmcblk0p1  253M     54M  199M   22% /boot
/dev/sda1        15G    9,7G  5,3G   65% /media/usbstick
tmpfs            93M       0   93M    0% /run/user/1000
amenomade
Dann mach einfach:
und Schluss
TomLee
Danke Dir.
Werd die Tage nochmal alles neu machen und dann hier gleich mit dem richtigen Befehl.
Wernieman
Leider schreiben einige Modulauthoren immer den cpan Befehl. Es ist immer besser, mit Distri-Bortmitteln zu arbeiten und nur im Notfall auf cpan zurückzugreifen.
Es ist nur nicht einfach, das passende Modul zu finden ...
- Bitte um Input für Output
Otto123
#12
da hätte ich was. Einmalige Vorbereitung:
sudo apt-get update
sudo apt-get install apt-file
sudo apt-file update
Dann einfach das Gesuchte (oder mehrere per Leerzeichen getrennt) abfragen
s="Crypt::Cipher::AES"
echo $s|tr " " "\n"|sed 's/$/./;s/^/\//'|apt-file search -l -f -
Christoph Morrison
Würde es dir helfen, wenn ich in der CRef beschreibe, wie man ein Paket mit MacPorts installiert? Oder mit ... Activestate Perl unter Windows? Oder yast? Oder ipkg?
Welcher der drölfzig Paketmanager darf's denn sein?
CPAN ist nunmal das Perleigene Paketrepository, das auf jeder Plattform (die einen C-Compiler laufen lassen kann) unterstützt wird. Mit cpanm gibt es einen sehr guten, unkomplizierten Client dafür.
Ich habe das auch mal im Wiki dokumentiert.
Es ist nur für Leute einfacher, die cpan nicht benutzen wollen oder können. Die meisten Leute haben wohl ihre erste Begegnung mit CPAN über den cpan-Client - und sind für ihr Leben geschädigt. Tatsächlich erhöht man mit einem Distri-Paket die Komplexität, denn es gibt eine weitere Schicht an Fehlern, die beim Packen und Installieren der Pakete gemacht werden kann. Und es ist auch keineswegs so, dass z.B. apt ein Paket immer in einem funktionsfähigen Zustand zurück lässt, während mit einem CPAN-Client - egal welchen - maximal Perl nicht mehr korrekt läuft.
Wernieman
Will hier keine Grundsatzdiskussion anstoßen, aber spätestens nach dem nächsten Perl-Update hast Du mit cpan ein (lösbares) Problem. Da hier im Forum die meisten mit Debian-Derivaten arbeiten ...
@Otto:
Dein Einzeiler finde ich gut ... aber braucht Du wirklich das tr??
