Autor Thema: USB problem  (Gelesen 4125 mal)
gkoper
  • Gast
USB problem
« am: 10 März 2013, 19:08:27 »
Dear all
I am quite new to this but I just quickly wanted to test fhem running on an RPI with an FHZ1300PC. The system freezes as soon as I try to connect the associated USB port. This seems very much the problem that has been recently described in the RPI-forum. But I do not need the latest edition, so is there anyone that could give me (a link to) a working .img file for the RPI so that I can proceed?
Thanks in advance,
Ger
Offline dougie
  • Sr. Member
    • dougie's tools
Aw: USB problem
« Antwort #1 am: 10 März 2013, 19:57:31 »
Have you already installed the kernel update? The kernel from the latest image has a broken USB implementation re. the FTDI USB/serial converter.
BR
Ralf
gkoper
  • Gast
Aw: USB problem
« Antwort #2 am: 10 März 2013, 20:01:10 »
Dear dougie
Thanks for your question. I tried "update" from the raspi-config window and it did a lot of things. Did not help though, not even after rebooting.
Maybe a more specific command?
Ger
Offline dougie
  • Sr. Member
    • dougie's tools
Aw: USB problem
« Antwort #3 am: 10 März 2013, 20:37:04 »
Hi Ger,
please have a look at this one:
https://github.com/Hexxeh/rpi-update#readme
BR
Ralf
gkoper
  • Gast
Aw: USB problem
« Antwort #4 am: 10 März 2013, 21:23:33 »
Thanks Ralf
that worked, although it took some retries because of some initially missing modules.
Ger
Offline dougie
  • Sr. Member
    • dougie's tools
Aw: USB problem
« Antwort #5 am: 10 März 2013, 21:28:04 »
...my pleasure. :-)
