[CUL_HM] kein cmd get deviceInfo bei virtuellen entities
Begonnen von frank, 07 Januar 2021, 17:37:43
frank
hallo martin,
1. ist es richtig, das virtuelle entities keinen cmd deviceInfo haben?
HMinfoTools.js versucht dort ggf das hminfo configcheck ergebnis zu finden, wenn das reading cfgState einen fehler liefert.
wäre es möglich, get deviceInfo zu ergänzen?
command syntax:
[optional]         : optional = the parameter is optional
(valX|valY)        : list     = one value valX or valY must be given
[(valX|{valY})]    : default  = one value valX or valY CAN be given. If non is given it defaults to valY
-peer-             : other    = the name of a peer needs to be given
[(-peer-|{self01})]: default  = a peername can be given. If emty the command will use 'self01'
Gets ------
cmdList [({short}|long)]
param -param-
Sets ------
peerChan:-btnNumber- -actChn- [({single}|dual|reverse)] [({set}|unset)] [(actor|remote|{both})]
peerSmart:-peerOpt-
postEvent:-condition-
press:[(long|{short})] [(-peer-|{all})] [(noBurst|{Burst})] [(-repCount-|{0})] [(-repDelay-|{0.25})]
pressL:[(-peer-|{all})]
pressS:[(-peer-|{all})]
tplSet_0:-tplChan-
tplSet_Ventil.Bad:-tplPeer-
valvePos:(off|0.0..99.0;0.1)
Options:
-condition- : 0              , 1              , 255            , slider         ,
-peer- : Ventil.Bad     ,
-peerOpt- : DimPBU01_Sw1_V01, DimPBU01_Sw1_V02, DimPBU01_chn01 , DimUP01        , Fenster.Bad    ,
          SD.AZ          , SD.SZ          , SD.WZ          , SDTeam_Btn1    , SwitchES01_SenF,
          SwitchES01_SenI, SwitchES01_SenPwr, SwitchES01_SenU, SwitchES01_Sw  , SwitchPBU01_Btn_01,
          SwitchPBU01_Btn_02, SwitchPBU01_Sw_01, SwitchPBU01_Sw_02, SwitchPBU02_Btn_01, SwitchPBU02_Btn_02,
          SwitchPBU02_Sw_01, SwitchPBU02_Sw_02, SwitchPBU03    , SwitchPBU05    , SwitchPBU06    ,
          SwitchUP01     , SwitchUP02     , Tuer.SZ        , Tuer.WZ.Terrasse, VentilControler.AZ.Nord_Btn1,
          VentilControler.AZ.West_Btn1, VentilControler.Kueche_Btn1, VentilControler.SZ_Btn1, VentilControler.WZ_Btn1, ccu_Btn1       ,
          remove_Ventil.Bad, rssi_hmuart_Btn1, virtAktorAlarmOff_Btn1, virt_vd_Btn1   ,
-tplChan- :
-tplDel- :
-tplPeer- :
2. das neue list cmd gibt es auch nicht bei virtuellen entities.
FHEM: 6.0(SVN) => Pi3(buster)
