Leistungsprognose für Wechselrichter
Begonnen von ch.eick, 18 Januar 2021, 08:35:46
MadMax
#870
Hallo Heiko,
Danke.
Ich hatte bei der Batterie kWh statt Wh gehabt, ich denke das das daher kam.
Gruß Max
defmod SolarForecast SolarForecast
attr SolarForecast Wh/kWh Wh
attr SolarForecast beam1Content pvForecast
attr SolarForecast beam2Content pvReal
attr SolarForecast beam2FontColor FFF700
attr SolarForecast flowGraphicAnimate 1
attr SolarForecast historyHour -2
attr SolarForecast interval 30
attr SolarForecast layoutType double
attr SolarForecast room Informationen->Wetter,Strom->Photovoltaik
attr SolarForecast showDiff no
attr SolarForecast showNight 0
setstate SolarForecast updated
setstate SolarForecast 2021-05-30 16:32:59 .associatedWith DWD_Forecast_Wernigerode DWD_Forecast_Magdeburg Inverters SMA_Energymeter SBS_6
setstate SolarForecast 2021-05-30 17:46:58 .lastupdateForecastValues 1622389618
setstate SolarForecast 2021-05-31 23:59:59 AllPVforecastsToEvent 0 Wh
setstate SolarForecast 2021-05-30 17:46:58 Current_AutarkyRate 100 %
setstate SolarForecast 2021-05-30 17:46:58 Current_BatCharge 100 %
setstate SolarForecast 2021-05-30 17:46:58 Current_Consumption 202 W
setstate SolarForecast 2021-05-30 17:46:58 Current_GridConsumption 0 W
setstate SolarForecast 2021-05-30 17:46:58 Current_GridFeedIn 2990 W
setstate SolarForecast 2021-05-30 17:46:58 Current_PV 3192 W
setstate SolarForecast 2021-05-30 17:46:58 Current_PowerBatIn 0 W
setstate SolarForecast 2021-05-30 17:46:58 Current_PowerBatOut 0 W
setstate SolarForecast 2021-05-30 17:46:58 Current_SelfConsumption 202 W
setstate SolarForecast 2021-05-30 17:46:58 Current_SelfConsumptionRate 6 %
setstate SolarForecast 2021-05-30 17:00:00 LastHourGridconsumptionReal 0 Wh
setstate SolarForecast 2021-05-30 17:00:00 LastHourPVforecast 7565 Wh
setstate SolarForecast 2021-05-30 17:00:00 LastHourPVreal 2274 Wh
setstate SolarForecast 2021-05-30 17:46:58 NextHours_Sum01_PVforecast 4800 Wh
setstate SolarForecast 2021-05-30 17:46:58 NextHours_Sum02_PVforecast 7766 Wh
setstate SolarForecast 2021-05-30 17:46:58 NextHours_Sum03_PVforecast 9010 Wh
setstate SolarForecast 2021-05-30 17:46:58 NextHours_Sum04_ConsumptionForecast 434028 Wh
setstate SolarForecast 2021-05-30 17:46:58 NextHours_Sum04_PVforecast 9269 Wh
setstate SolarForecast 2021-05-30 17:46:58 RestOfDayConsumptionForecast 869662 Wh
setstate SolarForecast 2021-05-30 17:46:58 RestOfDayPVforecast 9288 Wh
setstate SolarForecast 2021-05-30 00:59:22 Today_Hour01_BatIn 0 Wh
setstate SolarForecast 2021-05-30 00:59:22 Today_Hour01_BatOut 642000 Wh
setstate SolarForecast 2021-05-30 00:59:22 Today_Hour01_GridConsumption 4 Wh
setstate SolarForecast 2021-05-30 00:59:22 Today_Hour01_GridFeedIn 4 Wh
setstate SolarForecast 2021-05-30 16:21:54 currentBatteryDev SBS_6 pin=POWER_IN:W pout=POWER_OUT:W intotal=BAT_LOADTOTAL:Wh outtotal=SPOT_ETOTAL:Wh charge=ChargeStatus
setstate SolarForecast 2021-05-29 14:58:05 currentForecastDev DWD_Forecast_Wernigerode
setstate SolarForecast 2021-05-28 19:32:31 currentInverterDev Inverters pv=SPOT_PACTOT:W etotal=SPOT_ETOTAL:Wh
setstate SolarForecast 2021-05-30 16:32:59 currentMeterDev SMA_Energymeter gcon=SMAEM3009_Bezug_Wirkleistung:W contotal=SMAEM3003_Bezug_Wirkleistung_Zaehler:kWh gfeedin=SMAEM3009_Einspeisung_Wirkleistung:W feedtotal=SMAEM300_Einspeisung_Wirkleistung_Zaehler:kWh
setstate SolarForecast 2021-05-29 14:54:38 currentRadiationDev DWD_Forecast_Magdeburg
setstate SolarForecast 2021-05-28 19:25:52 inverterStrings S1
setstate SolarForecast 2021-05-29 10:36:34 moduleDirection S1=E
setstate SolarForecast 2021-05-28 19:26:48 modulePeakString S1=20.13
setstate SolarForecast 2021-05-28 19:27:09 moduleTiltAngle S1=30
SN vom Energymeter habe ich entfernt.
Lenovo M910Q Tiny Debian 12, FHEM 6.3, 2x Siemens Logo 0BA7, Homematic CCU3, Philips HUE, 5x SMA Wechselrichter, BYD HVM, SMA EVCharger, Daikin Wärmepumpe über CAN
Contrib: https://svn.fhem.de/trac/browser/trunk/fhem/contrib/MadMax
dk3572
#871
Hallo Heiko,
habe einen 3. Consumer (Spuelmaschine) definiert.
Nach einem Neustart von Fhem existieren die Readings des 3. Consumer, aber die Attr ist verschwunden und ich erhalte folgende Meldung:
Messages collected while initializing FHEM:configfile: The device "Spuelmaschine" doesn't exist!
Autosave deactivated
Wenn ich die Readings des 3. Consumer lösche und neu starte ist alles wieder gut.
Nur eben der 3. Consumer bleibt nicht existent.
Definiert habe ich sie wie folgt:
Spuelmaschine icon=scene_dishwasher@orange type=dishwasher mode=can power=2500 etotal=ENERGY_Today:kWh mintime=120
Hast du eine Idee?
VG Dieter
FUUID      5fd65ec0-f33f-cd72-ba56-13a41f24f97a012f
   FVERSION   76_SolarForecast.pm:v0.49.0-s21735/2020-04-20 TESTING
   MODE       Automatic - next polltime: 18:40:35
   NAME       SolarForecast
   NOTIFYDEV  DWD,DWD_PV,SMA_Wechselrichter,SMA_Zaehler,SMA_Wechselrichter_Bat
   NR         446
   NTFY_ORDER 50-SolarForecast
   STATE      updated
   TYPE       SolarForecast
   HELPER:
     FW         WEB
     INITCONTOTAL 2055990.2
     INITFEEDTOTAL 5264821.7
     PACKAGE    FHEM::SolarForecast
     SPGDETAIL  SolarForecast
     SPGDEV     SolarForecast
     SPGROOM    Photovoltaik
     VERSION    0.49.0
     VERSION_API unused
     VERSION_ErrCodes unused
     VERSION_SMUtils 1.22.0
     2021-05-30 18:39:25   Current_AutarkyRate 99 %
     2021-05-30 18:39:25   Current_BatCharge 90 %
     2021-05-30 18:39:25   Current_Consumption 519 W
     2021-05-30 18:39:25   Current_GridConsumption 3 W
     2021-05-30 18:39:25   Current_GridFeedIn 0 W
     2021-05-30 18:39:25   Current_PV      744 W
     2021-05-30 18:39:25   Current_PowerBatIn 228 W
     2021-05-30 18:39:25   Current_PowerBatOut 0 W
     2021-05-30 18:39:25   Current_SelfConsumption 516 W
     2021-05-30 18:39:25   Current_SelfConsumptionRate 69 %
     2021-05-30 18:00:00   LastHourGridconsumptionReal 1808 Wh
     2021-05-30 18:00:00   LastHourPVforecast 1860 Wh
     2021-05-30 18:00:00   LastHourPVreal  1162 Wh
     2021-05-30 18:39:25   NextHours_Sum01_PVforecast 742 Wh
     2021-05-30 18:39:25   NextHours_Sum02_PVforecast 1078 Wh
     2021-05-30 18:39:25   NextHours_Sum03_PVforecast 1165 Wh
     2021-05-30 18:39:25   NextHours_Sum04_ConsumptionForecast -702 Wh
     2021-05-30 18:39:25   NextHours_Sum04_PVforecast 1174 Wh
     2021-05-30 18:39:25   RestOfDayConsumptionForecast -574 Wh
     2021-05-30 18:39:25   RestOfDayPVforecast 1174 Wh
     2021-05-30 00:59:13   Today_Hour01_BatIn 0 Wh
     2021-05-30 00:59:13   Today_Hour01_BatOut 256 Wh
     2021-05-30 00:59:13   Today_Hour01_GridConsumption 1 Wh
     2021-05-30 00:59:13   Today_Hour01_GridFeedIn 2 Wh
     2021-05-30 00:59:13   Today_Hour01_PVreal 0 Wh
     2021-05-30 01:59:53   Today_Hour02_BatIn 0 Wh
     2021-05-30 01:59:53   Today_Hour02_BatOut 244 Wh
     2021-05-30 01:59:53   Today_Hour02_GridConsumption 1 Wh
     2021-05-30 01:59:53   Today_Hour02_GridFeedIn 0 Wh
     2021-05-30 01:59:53   Today_Hour02_PVreal 0 Wh
     2021-05-30 02:59:24   Today_Hour03_BatIn 0 Wh
     2021-05-30 02:59:24   Today_Hour03_BatOut 320 Wh
     2021-05-30 02:59:24   Today_Hour03_GridConsumption 2 Wh
     2021-05-30 02:59:24   Today_Hour03_GridFeedIn 3 Wh
     2021-05-30 02:59:24   Today_Hour03_PVreal 0 Wh
     2021-05-30 03:58:54   Today_Hour04_BatIn 0 Wh
     2021-05-30 03:58:54   Today_Hour04_BatOut 262 Wh
     2021-05-30 03:58:54   Today_Hour04_GridConsumption 2 Wh
     2021-05-30 03:58:54   Today_Hour04_GridFeedIn 1 Wh
     2021-05-30 03:58:54   Today_Hour04_PVreal 0 Wh
     2021-05-30 04:59:34   Today_Hour05_BatIn 0 Wh
     2021-05-30 04:59:34   Today_Hour05_BatOut 293 Wh
     2021-05-30 04:59:34   Today_Hour05_GridConsumption 1 Wh
     2021-05-30 04:59:34   Today_Hour05_GridFeedIn 1 Wh
     2021-05-30 04:59:34   Today_Hour05_PVreal 0 Wh
     2021-05-30 05:59:04   Today_Hour06_BatIn 0 Wh
     2021-05-30 05:59:04   Today_Hour06_BatOut 226 Wh
     2021-05-30 05:59:04   Today_Hour06_GridConsumption 2 Wh
     2021-05-30 05:59:04   Today_Hour06_GridFeedIn 3 Wh
     2021-05-30 05:59:04   Today_Hour06_PVforecast 27 Wh
     2021-05-30 05:59:04   Today_Hour06_PVreal 15 Wh
     2021-05-30 06:59:44   Today_Hour07_BatIn 74 Wh
     2021-05-30 06:59:44   Today_Hour07_BatOut 172 Wh
     2021-05-30 06:59:44   Today_Hour07_GridConsumption 3 Wh
     2021-05-30 06:59:44   Today_Hour07_GridFeedIn 2 Wh
     2021-05-30 06:59:44   Today_Hour07_PVforecast 307 Wh
     2021-05-30 06:59:44   Today_Hour07_PVreal 256 Wh
     2021-05-30 07:59:53   Today_Hour08_BatIn 1291 Wh
     2021-05-30 07:59:53   Today_Hour08_BatOut 10 Wh
     2021-05-30 07:59:53   Today_Hour08_GridConsumption 3 Wh
     2021-05-30 07:59:53   Today_Hour08_GridFeedIn 4 Wh
     2021-05-30 07:59:53   Today_Hour08_PVforecast 1130 Wh
     2021-05-30 07:59:53   Today_Hour08_PVreal 1559 Wh
     2021-05-30 08:59:24   Today_Hour09_BatIn 2369 Wh
     2021-05-30 08:59:24   Today_Hour09_BatOut 0 Wh
     2021-05-30 08:59:24   Today_Hour09_GridConsumption 9 Wh
     2021-05-30 08:59:24   Today_Hour09_GridFeedIn 167 Wh
     2021-05-30 08:59:24   Today_Hour09_PVforecast 3228 Wh
     2021-05-30 08:59:24   Today_Hour09_PVreal 2870 Wh
     2021-05-30 09:58:54   Today_Hour10_BatIn 77 Wh
     2021-05-30 09:58:54   Today_Hour10_BatOut 0 Wh
     2021-05-30 09:58:54   Today_Hour10_GridConsumption 0 Wh
     2021-05-30 09:58:54   Today_Hour10_GridFeedIn 3649 Wh
     2021-05-30 09:58:54   Today_Hour10_PVforecast 4313 Wh
     2021-05-30 09:58:54   Today_Hour10_PVreal 3980 Wh
     2021-05-30 10:59:26   Today_Hour11_BatIn 50 Wh
     2021-05-30 10:59:26   Today_Hour11_BatOut 0 Wh
     2021-05-30 10:59:26   Today_Hour11_GridConsumption 0 Wh
     2021-05-30 10:59:26   Today_Hour11_GridFeedIn 4247 Wh
     2021-05-30 10:59:26   Today_Hour11_PVforecast 4560 Wh
     2021-05-30 10:59:26   Today_Hour11_PVreal 4846 Wh
     2021-05-30 11:58:53   Today_Hour12_BatIn 0 Wh
     2021-05-30 11:58:53   Today_Hour12_BatOut 0 Wh
     2021-05-30 11:58:53   Today_Hour12_GridConsumption 0 Wh
     2021-05-30 11:58:53   Today_Hour12_GridFeedIn 4847 Wh
     2021-05-30 11:58:53   Today_Hour12_PVforecast 5413 Wh
     2021-05-30 11:58:53   Today_Hour12_PVreal 5191 Wh
     2021-05-30 12:59:34   Today_Hour13_BatIn 45 Wh
     2021-05-30 12:59:34   Today_Hour13_BatOut 0 Wh
     2021-05-30 12:59:34   Today_Hour13_GridConsumption 0 Wh
     2021-05-30 12:59:34   Today_Hour13_GridFeedIn 4778 Wh
     2021-05-30 12:59:34   Today_Hour13_PVforecast 3581 Wh
     2021-05-30 12:59:34   Today_Hour13_PVreal 4994 Wh
     2021-05-30 13:59:04   Today_Hour14_BatIn 0 Wh
     2021-05-30 13:59:04   Today_Hour14_BatOut 0 Wh
     2021-05-30 13:59:04   Today_Hour14_GridConsumption 0 Wh
     2021-05-30 13:59:04   Today_Hour14_GridFeedIn 3335 Wh
     2021-05-30 13:59:04   Today_Hour14_PVforecast 4766 Wh
     2021-05-30 13:59:04   Today_Hour14_PVreal 3728 Wh
     2021-05-30 14:59:44   Today_Hour15_BatIn 150 Wh
     2021-05-30 14:59:44   Today_Hour15_BatOut 98 Wh
     2021-05-30 14:59:44   Today_Hour15_GridConsumption 15 Wh
     2021-05-30 14:59:44   Today_Hour15_GridFeedIn 2300 Wh
     2021-05-30 14:59:44   Today_Hour15_PVforecast 3697 Wh
     2021-05-30 14:59:44   Today_Hour15_PVreal 3312 Wh
     2021-05-30 15:59:14   Today_Hour16_BatIn 2 Wh
     2021-05-30 15:59:14   Today_Hour16_BatOut 3 Wh
     2021-05-30 15:59:14   Today_Hour16_GridConsumption 11 Wh
     2021-05-30 15:59:14   Today_Hour16_GridFeedIn 1992 Wh
     2021-05-30 15:59:14   Today_Hour16_PVforecast 2635 Wh
     2021-05-30 15:59:14   Today_Hour16_PVreal 2440 Wh
     2021-05-30 16:59:54   Today_Hour17_BatIn 26 Wh
     2021-05-30 16:59:54   Today_Hour17_BatOut 409 Wh
     2021-05-30 16:59:54   Today_Hour17_GridConsumption 16 Wh
     2021-05-30 16:59:54   Today_Hour17_GridFeedIn 1123 Wh
     2021-05-30 16:59:54   Today_Hour17_PVforecast 2551 Wh
     2021-05-30 16:59:54   Today_Hour17_PVreal 1799 Wh
     2021-05-30 17:56:07   Today_Hour18_BatIn 411 Wh
     2021-05-30 17:56:07   Today_Hour18_BatOut 582 Wh
     2021-05-30 17:56:07   Today_Hour18_GridConsumption 1808 Wh
     2021-05-30 17:56:07   Today_Hour18_GridFeedIn 21 Wh
     2021-05-30 17:56:07   Today_Hour18_PVforecast 1860 Wh
     2021-05-30 17:56:07   Today_Hour18_PVreal 1162 Wh
     2021-05-30 18:39:25   Today_Hour19_BatIn 262 Wh
     2021-05-30 18:39:25   Today_Hour19_BatOut 27 Wh
     2021-05-30 18:39:25   Today_Hour19_GridConsumption 6 Wh
     2021-05-30 18:39:25   Today_Hour19_GridFeedIn 5 Wh
     2021-05-30 18:39:25   Today_Hour19_PVforecast 1038 Wh
     2021-05-30 18:39:25   Today_Hour19_PVreal 717 Wh
     2021-05-30 18:39:25   Today_Hour20_PVforecast 595 Wh
     2021-05-30 18:39:25   Today_Hour21_PVforecast 206 Wh
     2021-05-30 18:39:25   Today_Hour22_PVforecast 27 Wh
     2021-05-30 18:39:25   Today_PVforecast 39934 Wh
     2021-05-30 18:39:25   Today_SunRise   05:19
     2021-05-30 18:39:25   Today_SunSet    21:26
     2021-05-30 18:39:25   Tomorrow_ConsumptionForecast 8793 Wh
     2021-05-30 18:39:25   Tomorrow_PVforecast 45493 Wh
     2021-05-30 18:39:25   Tomorrow_SunRise 05:19
     2021-05-30 18:39:25   Tomorrow_SunSet 21:27
     2021-05-30 18:39:25   consumer01      name='Waschmaschine' state='on' planningstate='planned'
     2021-05-30 18:39:25   consumer01_planned_start 2021-05-30 18:00:00
     2021-05-30 18:39:25   consumer01_planned_stop 2021-05-30 22:00:00
     2021-05-30 18:39:25   consumer02      name='Trockner' state='on' planningstate='planned'
     2021-05-30 18:39:25   consumer02_planned_start 2021-05-30 18:00:00
     2021-05-30 18:39:25   consumer02_planned_stop 2021-05-30 23:00:00
     2021-05-30 18:31:37   consumer03      name='Spülmaschine' state='on' planningstate='planned'
     2021-05-30 18:31:37   consumer03_planned_start 2021-05-30 18:00:00
     2021-05-30 18:31:37   consumer03_planned_stop 2021-05-30 20:00:00
     2021-05-28 06:46:39   currentBatteryDev SMA_Wechselrichter_Bat pin=power_in:W pout=power_out:W intotal=bat_loadtoday:kWh outtotal=etoday:kWh charge=chargestatus
     2021-04-19 11:41:42   currentForecastDev DWD
     2021-04-28 06:45:38   currentInverterDev SMA_Wechselrichter pv=total_pac_fc:kW etotal=etotal_fc:kWh
     2021-04-06 19:24:25   currentMeterDev SMA_Zaehler gcon=gcon:W contotal=contotal:kWh gfeedin=gfeedin:W feedtotal=feedtotal:kWh
     2021-04-17 12:33:40   currentRadiationDev DWD_PV
     2021-04-10 08:24:00   energyH4Trigger 1on=2000 1off=1700 2on=4000 2off=3700 3on=6000 3off=5700
     2021-05-30 18:04:49   energyH4Trigger_1 off
     2021-05-30 16:59:54   energyH4Trigger_2 off
     2021-05-30 16:08:34   energyH4Trigger_3 off
     2021-01-27 19:08:53   inverterStrings Süddach
     2020-12-13 19:39:52   moduleArea      32
     2021-01-27 19:07:57   moduleDirection Süddach=S
     2021-01-27 19:10:15   modulePeakString Süddach=6.175
     2021-01-27 19:11:29   moduleTiltAngle Süddach=45
     2021-05-30 18:39:25   nextPolltime    18:40:35
     2021-04-04 12:41:37   powerTrigger    1on=1000 1off=500 2on=3000 2off=2500 3on=5500 3off=5000
     2021-05-30 07:10:14   powerTrigger_1  on
     2021-05-30 16:43:34   powerTrigger_2  off
     2021-05-30 14:15:24   powerTrigger_3  off
     2021-05-30 06:00:14   pvCorrectionFactor_06 1.00 (automatic - old factor: 1.50, cloudiness range: 1, found history days in range: 1)
     2021-05-30 06:00:14   pvCorrectionFactor_06_autocalc done
     2021-05-30 07:00:54   pvCorrectionFactor_07 0.75 (automatic - old factor: 0.72, cloudiness range: 1, found history days in range: 1)
     2021-05-30 07:00:54   pvCorrectionFactor_07_autocalc done
     2021-05-30 08:01:03   pvCorrectionFactor_08 0.88 (automatic - old factor: 0.84, cloudiness range: 1, found history days in range: 1)
     2021-05-30 08:01:03   pvCorrectionFactor_08_autocalc done
     2021-05-30 09:00:34   pvCorrectionFactor_09 0.89 (automatic - old factor: 1.27, cloudiness range: 1, found history days in range: 0)
     2021-05-30 09:00:34   pvCorrectionFactor_09_autocalc done
     2021-05-30 10:00:04   pvCorrectionFactor_10 0.92 (automatic - old factor: 1.17, cloudiness range: 1, found history days in range: 0)
     2021-05-30 10:00:04   pvCorrectionFactor_10_autocalc done
     2021-05-30 11:00:37   pvCorrectionFactor_11 0.99 (automatic - old factor: 1.01, cloudiness range: 2, found history days in range: 1)
     2021-05-30 11:00:37   pvCorrectionFactor_11_autocalc done
     2021-05-30 12:00:03   pvCorrectionFactor_12 0.96 (automatic - old factor: 1.09, cloudiness range: 2, found history days in range: 0)
     2021-05-30 12:00:03   pvCorrectionFactor_12_autocalc done
     2021-05-30 13:00:44   pvCorrectionFactor_13 0.95 (automatic - old factor: 0.71, cloudiness range: 3, found history days in range: 1)
     2021-05-30 13:00:44   pvCorrectionFactor_13_autocalc done
     2021-05-30 14:00:14   pvCorrectionFactor_14 0.86 (automatic - old factor: 0.97, cloudiness range: 3, found history days in range: 1)
     2021-05-30 14:00:14   pvCorrectionFactor_14_autocalc done
     2021-05-30 15:00:54   pvCorrectionFactor_15 0.80 (automatic - old factor: 0.81, cloudiness range: 3, found history days in range: 1)
     2021-05-30 15:00:54   pvCorrectionFactor_15_autocalc done
     2021-05-30 16:00:24   pvCorrectionFactor_16 0.76 (automatic - old factor: 0.65, cloudiness range: 4, found history days in range: 1)
     2021-05-30 16:00:24   pvCorrectionFactor_16_autocalc done
     2021-05-30 17:01:04   pvCorrectionFactor_17 0.75 (automatic - old factor: 0.71, cloudiness range: 3, found history days in range: 1)
     2021-05-30 17:01:04   pvCorrectionFactor_17_autocalc done
     2021-05-30 18:00:08   pvCorrectionFactor_18 0.59 (automatic - old factor: 0.64, cloudiness range: 3, found history days in range: 1)
     2021-05-30 18:00:08   pvCorrectionFactor_18_autocalc done
     2021-05-29 19:01:02   pvCorrectionFactor_19 0.48 (automatic - old factor: 0.48, cloudiness range: 3, found history days in range: 3)
     2021-05-29 20:00:32   pvCorrectionFactor_20 0.45 (automatic - old factor: 0.45, cloudiness range: 3, found history days in range: 2)
     2021-05-29 21:00:02   pvCorrectionFactor_21 0.56 (automatic - old factor: 0.42, cloudiness range: 3, found history days in range: 2)
     2021-05-29 22:00:43   pvCorrectionFactor_22 0.50 (automatic - old factor: 1, cloudiness range: 2, found history days in range: 2)
     2021-05-30 18:39:25   pvCorrectionFactor_Auto on
     2021-05-30 18:39:25   state           updated
   DbLogExclude .*
   Wh/kWh     Wh
   alias      Solar Vorhersage
   autoRefresh 120
   beam1Color 0033FF
   beam2Color 149600
   beam2Content pvReal
   consumer01 TP_Waschmaschine icon=scene_washing_machine@orange type=washingmachine mode=can power=2500 etotal=total:kWh mintime=120 mode=can
   consumer02 TP_Trockner icon=scene_clothes_dryer@orange type=dryer mode=can power=2500 etotal=total:kWh mintime=60 mode=can
   flowGraphicSize 200
   forcePageRefresh 1
   graphicSelect both
   historyHour -12
   layoutType double
   numHistDays 30
   room       Photovoltaik
   sameWeekdaysForConsfc 1
   showDiff   no
   showNight  0
CID        DVES_2EF549
   DEF        DVES_2EF549
   DEVICETOPIC Spuelmaschine
   FUUID      6092bc02-f33f-cd72-867e-e1ac1734d10b65f4
   FVERSION   10_MQTT2_DEVICE.pm:0.244470/2021-05-15
   IODev      MQTT2_Server
   LASTInputDev MQTT2_Server
   MQTT2_Server_MSGCNT 18
   MQTT2_Server_TIME 2021-05-30 18:40:33
   MSGCNT     18
   NAME       Spuelmaschine
   NR         496
   STATE      1:on
2:off
   TYPE       MQTT2_DEVICE
   JSONMAP:
     Channel_0  0
     Channel_1  0
     Channel_2  0
     Channel_3  0
     Channel_4  0
     Color      0
     Dimmer     0
     HSBColor   0
     POWER1     0
     POWER2     0
     POWER3     0
     POWER4     0
     2021-05-07 20:49:13   BASE            55
     2021-05-07 20:49:13   DeviceName      Spuelmaschine
     2021-05-30 18:40:33   ENERGY_ApparentPower 0
     2021-05-30 18:40:33   ENERGY_Current  0.000
     2021-05-30 18:40:33   ENERGY_Factor   0.00
     2021-05-30 18:40:33   ENERGY_Period   0
     2021-05-30 18:40:33   ENERGY_Power    0
     2021-05-30 18:40:33   ENERGY_ReactivePower 0
     2021-05-30 18:40:33   ENERGY_Today    0.000
     2021-05-30 18:40:33   ENERGY_Total    5.326
     2021-05-30 18:40:33   ENERGY_TotalStartTime 2021-05-05T15:34:42
     2021-05-30 18:40:33   ENERGY_Voltage  220
     2021-05-30 18:40:33   ENERGY_Yesterday 0.000
     2021-05-07 20:49:13   Emulation       0
     2021-05-07 20:49:13   FLAG            0
     2021-05-07 20:49:13   FriendlyName1   Spuelmaschine
     2021-05-07 20:49:13   FriendlyName2
     2021-05-07 20:49:13   FriendlyName3
     2021-05-07 20:49:13   FriendlyName4
     2021-05-07 20:49:13   FriendlyName5
     2021-05-07 20:49:13   FriendlyName6
     2021-05-07 20:49:13   FriendlyName7
     2021-05-07 20:49:13   FriendlyName8
     2021-05-07 11:19:30   GPIO            Not supported
     2021-05-07 20:49:13   GPIO_1          0
     2021-05-07 20:49:13   GPIO_10         320
     2021-05-07 20:49:13   GPIO_11         224
     2021-05-07 20:49:13   GPIO_12         0
     2021-05-07 20:49:13   GPIO_13         0
     2021-05-07 20:49:13   GPIO_14         0
     2021-05-07 20:49:13   GPIO_2          321
     2021-05-07 20:49:13   GPIO_3          0
     2021-05-07 20:49:13   GPIO_4          32
     2021-05-07 20:49:13   GPIO_5          2720
     2021-05-07 20:49:13   GPIO_6          2656
     2021-05-07 20:49:13   GPIO_7          0
     2021-05-07 20:49:13   GPIO_8          0
     2021-05-07 20:49:13   GPIO_9          2624
     2021-05-30 18:40:33   Heap            27
     2021-05-30 18:32:00   IODev           MQTT2_Server
     2021-05-17 10:43:17   Info1_FallbackTopic cmnd/DVES_2EF549_fb/
     2021-05-17 10:43:17   Info1_GroupTopic cmnd/tasmotas/
     2021-05-17 10:43:17   Info1_Module    Gosund SP1 v23
     2021-05-17 10:43:17   Info1_Version   9.4.0.3(tasmota)
     2021-05-17 10:43:17   Info2_Hostname  tasmota_2EF549-5449
     2021-05-17 10:43:17   Info2_IPAddress 192.168.178.77
     2021-05-17 10:43:17   Info2_WebServerMode Admin
     2021-05-17 10:43:17   Info3_RestartReason Power On
     2021-05-30 18:33:48   LWT             Online
     2021-05-30 18:40:33   LoadAvg         19
     2021-05-07 20:49:13   Module_0        Gosund SP1 v23
     2021-05-07 11:19:30   Module_55       Gosund SP1 v23
     2021-05-30 18:40:33   MqttCount       28
     2021-05-07 20:49:13   NAME            Gosund SP1 v23
     2021-05-30 18:40:33   POWER           ON
     2021-05-07 13:38:05   PowerDelta1     10
     2021-05-07 20:49:13   SetOption3      ON
     2021-05-30 18:40:33   Sleep           50
     2021-05-30 18:40:33   SleepMode       Dynamic
     2021-05-30 18:40:33   Time            2021-05-30T18:40:33
     2021-05-05 20:55:42   Timezone        99
     2021-05-30 18:40:33   Uptime          13T07:57:20
     2021-05-30 18:40:33   UptimeSec       1151840
     2021-05-07 20:49:13   WebPassword     ****
     2021-05-30 18:40:33   Wifi_AP         1
     2021-05-30 18:40:33   Wifi_BSSId      38:10:D5:0E:36:13
     2021-05-30 18:40:33   Wifi_Channel    6
     2021-05-30 18:40:33   Wifi_Downtime   0T00:00:09
     2021-05-30 18:40:33   Wifi_LinkCount  4
     2021-05-30 18:40:33   Wifi_RSSI       68
     2021-05-30 18:40:33   Wifi_SSId       DK-Wlan
     2021-05-30 18:40:33   Wifi_Signal     -66
     2021-05-05 20:50:34   attrTemplateVersion 20200522 or prior
     2021-05-27 12:47:34   running         off
     2021-05-30 18:34:33   statENERGY_Current Hour: 0.000 Day: 0.000 Month: 0.000 Year: 0.000 (since: 2021-05-12 )
     2021-05-30 16:59:55   statENERGY_CurrentLast Hour: 0.000 Day: 0.000 Month: - Year: -
     2021-05-30 18:34:33   statENERGY_Power Hour: 0 Day: 0 Month: 0 Year: 0 (since: 2021-05-12 )
     2021-05-30 16:59:55   statENERGY_PowerLast Hour: 0 Day: 0 Month: - Year: -
     2021-05-11 13:20:45   statStateDay    on: 13:20:50 on_Count: 1
     2021-05-10 23:59:55   statStateDayLast on: 24:00:00 on_Count: 1
     2021-05-11 13:20:45   statStateMonth  on: 3d 16:37:17 on_Count: 1 (since: 2021-05-07_20:43:28)
     2021-05-11 13:20:45   statStateYear   on: 3d 16:37:17 on_Count: 1 (since: 2021-05-07_20:43:28)
     2021-05-20 08:48:34   state           on
     2021-05-08 16:14:43   subscriptions   cmnd/DVES_2EF549_fb/# cmnd/tasmota_2EF549/# cmnd/tasmotas/#
   helper:
     _98_statistics Statistik
   DbLogExclude .*
   alias      Spülmaschine
   autocreate 0
   comment    NOTE: For on-for-timer SetExtensions are used. You may add on-for-timer option running on the device. The following is limited to 1h max duration, but will not affect future simple "on" commands:<br>on-for-timer {my $duration = $EVTPART1*10; 'cmnd/cmnd/tasmota_2EF549/Backlog POWER1 1; delay '.$duration.'; POWER1 0'}<br>See the "Praxisbeispiele" in the wiki for "pulseTime1" alternative option and it's restrictions.
   devStateIcon 1.on:rc_GREEN:off 1.off:rc_RED:on 2.on:general_an@green 2.off:general_aus
   event-min-interval ENERGY_Current:900,ENERGY_Power:900
   event-on-change-reading running,state,POWER,ENERGY_Current,ENERGY_Today,ENERGY_Total,ENERGY_Power,ENERGY_Voltage:5
   group      Schalten
   icon       scene_dishwasher
   jsonMap    POWER1:0 POWER2:0 POWER3:0 POWER4:0 Dimmer:0 Channel_0:0 Channel_1:0 Channel_2:0 Channel_3:0 Channel_4:0 HSBColor:0 Color:0
   model      tasmota_basic_state_power1
   readingList tele/tasmota_2EF549/LWT:.* LWT
  tele/tasmota_2EF549/STATE:.* { json2nameValue($EVENT,'',$JSONMAP) }
  tele/tasmota_2EF549/SENSOR:.* { json2nameValue($EVENT,'',$JSONMAP) }
  tele/tasmota_2EF549/INFO.:.* { json2nameValue($EVENT,'',$JSONMAP) }
  tele/tasmota_2EF549/UPTIME:.* { json2nameValue($EVENT,'',$JSONMAP) }
  stat/tasmota_2EF549/POWER1:.* state
  stat/tasmota_2EF549/RESULT:.* { json2nameValue($EVENT,'',$JSONMAP) }
   room       Küche
   setList    off:noArg    cmnd/tasmota_2EF549/POWER1 0
  on:noArg     cmnd/tasmota_2EF549/POWER1 1
  toggle:noArg cmnd/tasmota_2EF549/POWER1 2
  setOtaUrl:textField cmnd/tasmota_2EF549/OtaUrl $EVTPART1
  upgrade:noArg   cmnd/tasmota_2EF549/upgrade 1
   stateFormat 1:state
2:running
   webCmd     on:off
DS_Starter
Hallo Dieter,
du hast immer schwierige Sachen  :)
Wir können erstmal festhalten, dass die Meldung:
nicht aus dem Modul kommt, sondern eine FHEM Kernmeldung ist.
Kann es sein dass die Spülmaschine erst nach dem Start automatisiert über den MQTT2_Server Server angelegt wird ?
D.H. wenn sich das Device am MQTT2 Server anmeldet ?
Nur mal als Idee.
ESXi@NUC+Debian+MariaDB, PV: SMA, Victron MPII+Pylontech+CerboGX
dk3572
Zitat von: DS_Starter am 30 Mai 2021, 19:07:56
Hallo Dieter,
Nur mal als Idee.
Das die Meldung nicht aus dem Modul kommt ist mir schon klar.  ;)
Wollte ja nur darauf hinweisen.
Die Spülmaschine wurde per autocreate vom MQTT2_Server angelegt.
Das geschieht aber doch nur beim Ersten mal, oder?
Das Device wird doch nicht bei jedem Start neu angelegt?
Wenn es so wäre, wie könnte ich das testen bzw. ändern?
Danke für deine Hilfe bei meinen schwierigen Sachen  ;D
VG Dieter
DS_Starter
Ja, eigentlich nur beim ersten mal. Aber speicherst du die Konfiguration auch ab mit dem neu angelegten MQTT Device ?
Nur mal sicherheitshalber nachgefragt  ;)
dk3572
also bitte  ;) ;D
Das MQTT Device (Spülmaschine) habe ich ja schon länger angelegt.
Wollte es heute nur zum Forecast hinzufügen.
Gehört zwar jetzt nicht direkt hier her, aber für das MQTT Device existiert neben dem MQTT2_Server ein weiteres MQTT2_Server Device im Room hidden. Ist das normal?
AuthenticatedBy allowed_MQTTS_Server
   AuthenticatedUser xxxxx
   BUF
   FD         31
   NAME       MQTT2_Server_192.168.xxx.xx_63030
   NR         581
   PEER       192.168.xxx.xx
   PORT       63030
   SNAME      MQTT2_Server
   SSL
   STATE      Connected
   TEMPORARY  1
   TYPE       MQTT2_SERVER
   WBCallback
   cflags     238
   cid        DVES_2EF549
   keepalive  30
   lastMsgTime 1622397777.7172
   lwt        tele/tasmota_2EF549/LWT:Offline
   protoNum   4
   protoTxt   MQTT
   usr        xxxxx
     2021-05-30 18:33:48   state           Connected
   subscriptions:
     cmnd/DVES_2EF549_fb/# 1622392428.24889
     cmnd/tasmota_2EF549/# 1622392428.24841
     cmnd/tasmotas/# 1622392428.24873
   room       hidden
DS_Starter
Scheint normal zu sein. Ich habe sogar noch mehr als einen MQTT2_SERVER im Raum hidden. Ich denke das hängt von der Anzahl der MQTT2 Clients ab, habe mich aber nicht näher damit befasst weil läuft alles einwandfrei. MQTT mag ich.  :)
Aber wenn du die Spuelmaschine nicht im Attr registrierst startet FHEM ohne Fehlermeldung ?
dk3572
#877
Ja, wenn ich die Readings aus dem Forecast wieder lösche, startet fhem ohne Meldung.
Das Attr existiert ja nach einem Neustart gar nicht mehr.
DS_Starter
Könnte ein Reihenfolgeproblem beim Start sein. Ich probier da mal was.
dk3572
meinen letzten Hinweis noch gelesen?
DS_Starter
Ja, die Attribute werden beim Start ja geprüft und wenn ein Fehler auftritt, in diesem Fall dass die Spuelmaschine noch nicht existiert, wird das Attr nicht gesetzt. Ich denke das ist der Punkt. Die Prüfung muss ich von der Startroutine entkoppeln.
So die Idee ...
DS_Starter
Test mal die Version aus dem contrib Dieter. Schau mal wie es jetzt aussieht.
dk3572
ich wusste du bekommst es hin, und das auch noch so schnell, RESPEKT  ;)
Meldung taucht nach Neustatr nicht mehr auf und Consumer bleibt erhalten.
Danke und schönen Abend noch.
VG Dieter
DS_Starter
papa
Habe eben nochmal aktualisiert - hat sich erst mal wie erwartet nichts geändert.
pvHistory
28 => 22 => etotal: 1418600, pvfc: 20, pvrl: 0
            confc: -, con: 1, gcon: 1, gfeedin: 0
            batintotal: 0, batin: 0, batouttotal: 0, batout: 0
            wid: 2, wcc: 72, wrp: 29.00, temp: 10.1, pvcorrf: 2.00/2
      23 => etotal: 1418600, pvfc: 0, pvrl: 0
            confc: -, con: 0, gcon: 0, gfeedin: 0
            wid: 102, wcc: 67, wrp: 21.00, temp: 9.30, pvcorrf: 1/0
      24 => etotal: 1418600, pvfc: 0, pvrl: 0
      99 => etotal: , pvfc: 20, pvrl: 0
            batintotal: , batin: 0, batouttotal: , batout: 0
            wid: , wcc: , wrp: , pvcorrf: , dayname: Fri
29 => 01 => etotal: 1418600, pvfc: 0, pvrl: 0
            confc: -, con: 1, gcon: 2, gfeedin: 1
            wid: 102, wcc: 64, wrp: 7.00, temp: 7.80, pvcorrf: 1/0
      02 => etotal: 1418600, pvfc: 0, pvrl: 0
            wid: 102, wcc: 63, wrp: 5.00, temp: 7.60, pvcorrf: 1/0
      03 => etotal: 1418600, pvfc: 0, pvrl: 0
            confc: -, con: -2, gcon: 0, gfeedin: 2
            wid: 102, wcc: 64, wrp: 4.00, temp: 7.30, pvcorrf: 1/0
      04 => etotal: 1418600, pvfc: 0, pvrl: 0
            confc: -, con: 0, gcon: 1, gfeedin: 1
            wid: 102, wcc: 66, wrp: 2.00, temp: 7.20, pvcorrf: 1/0
      05 => etotal: 1418600, pvfc: 0, pvrl: 0
            wid: 102, wcc: 67, wrp: 2.00, temp: 7, pvcorrf: 1/0
      06 => etotal: 1418610, pvfc: 29, pvrl: 20
            confc: -, con: 20, gcon: 1, gfeedin: 1
            wid: 2, wcc: 71, wrp: 1.00, temp: 7.40, pvcorrf: 1.42/4
      07 => etotal: 1418640, pvfc: 118, pvrl: 100
            confc: -, con: 99, gcon: 1, gfeedin: 2
            wid: 3, wcc: 75, wrp: 1.00, temp: 8.10, pvcorrf: 1.10/2
      08 => etotal: 1418740, pvfc: 286, pvrl: 210
            confc: -, con: 210, gcon: 0, gfeedin: 0
            wid: 2, wcc: 73, wrp: 1.00, temp: 8.60, pvcorrf: 1.18/2
      09 => etotal: 1418950, pvfc: 396, pvrl: 340
            confc: -, con: 352, gcon: 20, gfeedin: 8
            wid: 2, wcc: 74, wrp: 1.00, temp: 9.60, pvcorrf: 0.93/3
      10 => etotal: 1419320, pvfc: 519, pvrl: 330
            confc: -, con: 329, gcon: 1, gfeedin: 2
            wid: 2, wcc: 75, wrp: 1.00, temp: 10.7, pvcorrf: 0.86/4
      11 => etotal: 1419650, pvfc: 908, pvrl: 540
            confc: -, con: 720, gcon: 182, gfeedin: 2
            wid: 2, wcc: 76, wrp: 1.00, temp: 11.7, pvcorrf: 1.23/2
      12 => etotal: 1420190, pvfc: 1005, pvrl: 560
            confc: -, con: 580, gcon: 21, gfeedin: 1
            wid: 2, wcc: 76, wrp: 0.00, temp: 12.7, pvcorrf: 1.14/5
      13 => etotal: 1420800, pvfc: 1052, pvrl: 650
            confc: -, con: 651, gcon: 4, gfeedin: 3
            wid: 2, wcc: 67, wrp: 0.00, temp: 11.9, pvcorrf: 1.01/3
      14 => etotal: 1421490, pvfc: 1331, pvrl: 490
            confc: -, con: 491, gcon: 2, gfeedin: 1
            wid: 2, wcc: 66, wrp: 0.00, temp: 12.9, pvcorrf: 1.24/1
      15 => etotal: 1421980, pvfc: 1099, pvrl: 850
            confc: -, con: 851, gcon: 2, gfeedin: 1
            wid: 2, wcc: 64, wrp: 0.00, temp: 13.8, pvcorrf: 1.03/3
      16 => etotal: 1422830, pvfc: 994, pvrl: 0
            confc: -, con: 1, gcon: 3, gfeedin: 2
            wid: 2, wcc: 60, wrp: 1.00, temp: 14.5, pvcorrf: 0.95/4
      17 => etotal: 1422830, pvfc: 1325, pvrl: 0
            confc: -, con: 0, gcon: 4, gfeedin: 4
            wid: 2, wcc: 55, wrp: 1.00, temp: 14.8, pvcorrf: 1.36/3
      18 => etotal: 1422830, pvfc: 934, pvrl: 3510
            confc: -, con: 3510, gcon: 1, gfeedin: 1
            wid: 1, wcc: 52, wrp: 1.00, temp: 15.1, pvcorrf: 1.16/3
      19 => etotal: 1426340, pvfc: 726, pvrl: 0
            confc: -, con: -446, gcon: 1, gfeedin: 447
            wid: 1, wcc: 44, wrp: 1.00, temp: 14.9, pvcorrf: 1.19/1
      20 => etotal: 1426340, pvfc: 214, pvrl: 1640
            confc: -, con: 1627, gcon: 1, gfeedin: 14
            wid: 1, wcc: 40, wrp: 1.00, temp: 14.3, pvcorrf: 0.60/1
      21 => etotal: 1427980, pvfc: 103, pvrl: 70
            confc: -, con: 71, gcon: 2, gfeedin: 1
            wid: 1, wcc: 36, wrp: 1.00, temp: 12.3, pvcorrf: 0.74/1
      22 => etotal: 1428050, pvfc: 16, pvrl: 20
            confc: 1, con: 22, gcon: 2, gfeedin: 0
            wid: 1, wcc: 33, wrp: 1.00, temp: 10.6, pvcorrf: 0.91/2
      23 => etotal: 1428070, pvfc: 0, pvrl: 0
            confc: -, con: -1, gcon: 0, gfeedin: 1
            wid: 101, wcc: 29, wrp: 1.00, temp: 8.90, pvcorrf: 1/0
      24 => etotal: 1428070, pvfc: 0, pvrl: 0
            confc: -, con: -1, gcon: 1, gfeedin: 2
      99 => etotal: , pvfc: 11055, pvrl: 9330
            confc: 1, con: 9086, gcon: 254, gfeedin: 498
            wid: , wcc: , wrp: , pvcorrf: , dayname: Sat
30 => 01 => etotal: 1428070, pvfc: 0, pvrl: 0
            confc: 1, con: 5, gcon: 6, gfeedin: 1
            wid: 101, wcc: 23, wrp: 1.00, temp: 5.80, pvcorrf: 1/0
      02 => etotal: 1428070, pvfc: 0, pvrl: 0
            confc: 1, con: 0, gcon: 1, gfeedin: 1
            wid: 101, wcc: 22, wrp: 1.00, temp: 5.30, pvcorrf: 1/0
      03 => etotal: 1428070, pvfc: 0, pvrl: 0
            confc: -2, con: 0, gcon: 1, gfeedin: 1
            wid: 101, wcc: 23, wrp: 1.00, temp: 4.70, pvcorrf: 1/0
      04 => etotal: 1428070, pvfc: 0, pvrl: 0
            wid: 101, wcc: 26, wrp: 1.00, temp: 4.30, pvcorrf: 1/0
      05 => etotal: 1428070, pvfc: 0, pvrl: 10
            confc: -, con: 11, gcon: 2, gfeedin: 1
            wid: 101, wcc: 27, wrp: 1.00, temp: 4.30, pvcorrf: 1/0
      06 => etotal: 1428080, pvfc: 37, pvrl: 30
            confc: 20, con: 28, gcon: 0, gfeedin: 2
            wid: 1, wcc: 31, wrp: 1.00, temp: 4.90, pvcorrf: 1.00/4
      07 => etotal: 1428110, pvfc: 117, pvrl: 150
            confc: 99, con: 150, gcon: 1, gfeedin: 1
            wid: 1, wcc: 34, wrp: 1.00, temp: 6.60, pvcorrf: 0.60/2
      08 => etotal: 1428260, pvfc: 332, pvrl: 310
            confc: 210, con: 310, gcon: 1, gfeedin: 1
            wid: 1, wcc: 36, wrp: 1.00, temp: 8.80, pvcorrf: 0.75/2
      09 => etotal: 1428570, pvfc: 535, pvrl: 550
            confc: 352, con: 551, gcon: 5, gfeedin: 4
            wid: 1, wcc: 38, wrp: 1.00, temp: 11.3, pvcorrf: 0.73/1
      10 => etotal: 1429180, pvfc: 870, pvrl: 730
            confc: 329, con: 728, gcon: 4, gfeedin: 6
            wid: 1, wcc: 39, wrp: 1.00, temp: 13.1, pvcorrf: 0.84/2
      11 => etotal: 1429910, pvfc: 1265, pvrl: 1230
            confc: 720, con: 1233, gcon: 7, gfeedin: 4
            wid: 1, wcc: 45, wrp: 0.00, temp: 14.4, pvcorrf: 1.02/2
      12 => etotal: 1431140, pvfc: 1365, pvrl: 1770
            confc: 580, con: 1771, gcon: 8, gfeedin: 7
            wid: 1, wcc: 47, wrp: 1.00, temp: 15.9, pvcorrf: 0.99/1
      13 => etotal: 1433070, pvfc: 1335, pvrl: 1710
            confc: 651, con: 1791, gcon: 99, gfeedin: 18
            wid: 1, wcc: 53, wrp: 0.00, temp: 17.9, pvcorrf: 0.96/3
      14 => etotal: 1434780, pvfc: 1559, pvrl: 1200
            confc: 491, con: 1202, gcon: 8, gfeedin: 6
            wid: 1, wcc: 57, wrp: 0.00, temp: 18.3, pvcorrf: 1.15/4
      15 => etotal: 1435980, pvfc: 1289, pvrl: 1840
            confc: 851, con: 1838, gcon: 11, gfeedin: 13
            wid: 2, wcc: 58, wrp: 0.00, temp: 18.7, pvcorrf: 1.04/4
      16 => etotal: 1437900, pvfc: 1211, pvrl: 1050
            confc: 1, con: 611, gcon: 5, gfeedin: 444
            wid: 2, wcc: 58, wrp: 0.00, temp: 18.9, pvcorrf: 1.10/4
      17 => etotal: 1438950, pvfc: 1374, pvrl: 820
            confc: -, con: 298, gcon: 2, gfeedin: 524
            wid: 2, wcc: 56, wrp: 0.00, temp: 19, pvcorrf: 1.36/3
      18 => etotal: 1439910, pvfc: 1284, pvrl: 770
            confc: 3510, con: 171, gcon: 0, gfeedin: 599
            wid: 1, wcc: 55, wrp: 0.00, temp: 18.9, pvcorrf: 1.66/0
      19 => etotal: 1440800, pvfc: 679, pvrl: 710
            confc: -446, con: 275, gcon: 0, gfeedin: 435
            wid: 1, wcc: 54, wrp: 0.00, temp: 18.8, pvcorrf: 1.27/3
      20 => etotal: 1441510, pvfc: 235, pvrl: 160
            confc: 1627, con: 160, gcon: 1, gfeedin: 1
            wid: 1, wcc: 58, wrp: 1.00, temp: 17.8, pvcorrf: 0.82/3
      21 => etotal: 1441680, pvfc: 121, pvrl: 60
            confc: 71, con: 60, gcon: 0, gfeedin: 0
            wid: 2, wcc: 55, wrp: 1.00, temp: 16.1, pvcorrf: 1.08/4
      22 => etotal: -, pvfc: 14, pvrl: -
            confc: 1, con: -, gcon: -, gfeedin: -
            batintotal: -, batin: -, batouttotal: -, batout: -
            wid: 1, wcc: 50, wrp: 1.00, temp: 14.1, pvcorrf: 1.25/0
      23 => etotal: -, pvfc: 0, pvrl: -
            confc: -1, con: -, gcon: -, gfeedin: -
            wid: 101, wcc: 46, wrp: 1.00, temp: 12.1, pvcorrf: 1/0
      24 => etotal: -, pvfc: 0, pvrl: -
      99 => etotal: , pvfc: 13622, pvrl: 13100
            confc: 9065, con: 11194, gcon: 164, gfeedin: 2070
            wid: , wcc: , wrp: , pvcorrf: , dayname: Sun
pvNext
NextHour00 => starttime: 2021-05-30 20:00:00, today: 1, pvfc: 121, confc: 71, wid: 2, wcc: 55, wrp: 1.00, correff: 1.08/4, Rad1h: 200.00, temp=16.1
NextHour01 => starttime: 2021-05-30 21:00:00, today: 1, pvfc: 14, confc: 1, wid: 1, wcc: 50, wrp: 1.00, correff: 1.25/0, Rad1h: 20.00, temp=14.1
NextHour02 => starttime: 2021-05-30 22:00:00, today: 1, pvfc: 0, confc: -1, wid: 101, wcc: 46, wrp: 1.00, correff: 1/0, Rad1h: 0.00, temp=12.1
NextHour03 => starttime: 2021-05-30 23:00:00, today: 1, pvfc: 0, confc: -1, wid: 101, wcc: 46, wrp: 1.00, correff: 1/0, Rad1h: 0.00, temp=12.1
NextHour04 => starttime: 2021-05-31 00:00:00, today: 0, pvfc: 0, confc: 1, wid: 101, wcc: 40, wrp: 1.00, correff: 1/0, Rad1h: 0.00, temp=9.70
NextHour05 => starttime: 2021-05-31 01:00:00, today: 0, pvfc: 0, confc: 1, wid: 101, wcc: 37, wrp: 1.00, correff: 1/0, Rad1h: 0.00, temp=8.90
NextHour06 => starttime: 2021-05-31 02:00:00, today: 0, pvfc: 0, confc: -2, wid: 101, wcc: 37, wrp: 1.00, correff: 1/0, Rad1h: 0.00, temp=8
NextHour07 => starttime: 2021-05-31 03:00:00, today: 0, pvfc: 0, confc: -, wid: 101, wcc: 33, wrp: 1.00, correff: 1/0, Rad1h: 0.00, temp=7.10
NextHour08 => starttime: 2021-05-31 04:00:00, today: 0, pvfc: 0, confc: -, wid: 1, wcc: 28, wrp: 1.00, correff: 1/0, Rad1h: 0.00, temp=6.40
NextHour09 => starttime: 2021-05-31 05:00:00, today: 0, pvfc: 35, confc: 20, wid: 1, wcc: 27, wrp: 1.00, correff: 0.81/0, Rad1h: 70.00, temp=6.80
NextHour10 => starttime: 2021-05-31 06:00:00, today: 0, pvfc: 213, confc: 99, wid: 1, wcc: 25, wrp: 1.00, correff: 0.91/0, Rad1h: 370.00, temp=7.70
NextHour11 => starttime: 2021-05-31 07:00:00, today: 0, pvfc: 484, confc: 210, wid: 1, wcc: 22, wrp: 1.00, correff: 0.89/0, Rad1h: 850.00, temp=9.80
NextHour12 => starttime: 2021-05-31 08:00:00, today: 0, pvfc: 741, confc: 352, wid: 1, wcc: 22, wrp: 1.00, correff: 0.81/0, Rad1h: 1430.00, temp=12.1
NextHour13 => starttime: 2021-05-31 09:00:00, today: 0, pvfc: 1002, confc: 329, wid: 1, wcc: 23, wrp: 1.00, correff: 0.79/1, Rad1h: 1990.00, temp=14.1
NextHour14 => starttime: 2021-05-31 10:00:00, today: 0, pvfc: 1384, confc: 720, wid: 1, wcc: 26, wrp: 1.00, correff: 0.90/0, Rad1h: 2440.00, temp=15.6
NextHour15 => starttime: 2021-05-31 11:00:00, today: 0, pvfc: 1673, confc: 580, wid: 1, wcc: 26, wrp: 0.00, correff: 0.95/0, Rad1h: 2790.00, temp=16.8
NextHour16 => starttime: 2021-05-31 12:00:00, today: 0, pvfc: 2414, confc: 651, wid: 1, wcc: 27, wrp: 0.00, correff: 1.28/0, Rad1h: 3000.00, temp=17.9
NextHour17 => starttime: 2021-05-31 13:00:00, today: 0, pvfc: 1536, confc: 491, wid: 1, wcc: 26, wrp: 0.00, correff: 0.77/0, Rad1h: 3160.00, temp=18.8
NextHour18 => starttime: 2021-05-31 14:00:00, today: 0, pvfc: 2500, confc: 851, wid: 1, wcc: 28, wrp: 0.00, correff: 1.43/0, Rad1h: 3030.00, temp=19.5
NextHour19 => starttime: 2021-05-31 15:00:00, today: 0, pvfc: 1521, confc: 1, wid: 1, wcc: 25, wrp: 0.00, correff: 0.87/0, Rad1h: 2760.00, temp=20
NextHour20 => starttime: 2021-05-31 16:00:00, today: 0, pvfc: 1307, confc: -, wid: 1, wcc: 24, wrp: 0.00, correff: 0.86/0, Rad1h: 2390.00, temp=20.2
NextHour21 => starttime: 2021-05-31 17:00:00, today: 0, pvfc: 2305, confc: 3510, wid: 1, wcc: 24, wrp: 1.00, correff: 1.93/0, Rad1h: 1880.00, temp=20.1
NextHour22 => starttime: 2021-05-31 18:00:00, today: 0, pvfc: 867, confc: -446, wid: 1, wcc: 24, wrp: 1.00, correff: 1.05/0, Rad1h: 1300.00, temp=19.5
NextHour23 => starttime: 2021-05-31 19:00:00, today: 0, pvfc: 320, confc: 1627, wid: 1, wcc: 20, wrp: 0.00, correff: 0.68/0, Rad1h: 730.00, temp=18.2
NextHour24 => starttime: 2021-05-31 20:00:00, today: 0, pvfc: 119, confc: 142, wid: 1, wcc: 18, wrp: 1.00, correff: 0.68/0, Rad1h: 270.00, temp=16.1
NextHour25 => starttime: 2021-05-31 21:00:00, today: 0, pvfc: 24, confc: 12, wid: 1, wcc: 16, wrp: 1.00, correff: 1.25/0, Rad1h: 30.00, temp=13.4
NextHour26 => starttime: 2021-05-31 22:00:00, today: 0, pvfc: 0, confc: -2, wid: 101, wcc: 16, wrp: 1.00, correff: 1/0, Rad1h: 0.00, temp=10.9
NextHour27 => starttime: 2021-05-31 23:00:00, today: 0, pvfc: 0, confc: -2, wid: 101, wcc: 16, wrp: 1.00, correff: 1/0, Rad1h: 0.00, temp=10.9
