Neues Modul: Signalbot (Integration für den Signal Messenger) via signal-cli
Begonnen von Adimarantis, 31 Januar 2021, 19:16:19
HarryT
Zitat von: Adimarantis am 14 April 2026, 20:40:02Looks like something in your environment does not work with my check for the Protocol::Dbus, but as it only affects the check script, it is probably safe to ignore. All I'm doing is
#!/usr/bin/perl -w
use strict;
use warnings;
use Protocol::DBus;
print \$Protocol::DBus::VERSION."\n";
Thanks again. If I run your script the answer is
SCALAR(0x558dd3bd40)
No idea what it is.
Anyway, to night trying to reregister gives me first an
  Failed to register: StatusCode: 502 (ExternalServiceFailureException)
and the second time
  Failed to register: [429] Rate Limited (RateLimitException)
So no luck yet, I have to wait another day.
FHEM 6.4 auf Raspberry Pi3  (1,2 Ghz)
RFXTRX433XL, ZWave, KFL200 and ConBeeIII
Raspberry Pi1 (0,7 Ghz), Raspberry Pi4 and RaspberryPi 5 for testing
German reading skills are good.
HarryT
Hi all,
I guess I am stupid but don't see what I might do wrong.
My steps:
systemctl stop signal
In firefox and chromium I tried:
https://signalcaptchas.org/registration/generate
I copied the link of the response page
Then I paste it in the command with as result:
sudo -E /opt/signal/bin/signal-cli --config /var/lib/signal-cli -u +31xxxxxxxx register --reregister --captcha signalcaptcha://signal-hcaptcha.5fad97ac-4e44-b18a-b950b20148ff.registration.P1_eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.haJwZACjZXhwzmnfezOncGFzc2tlecUFSikWaW3xRzETPW0brJMts9_Pl3PQPAz5OlHQypsb9BuOsBVjvGrLk672Qff_5Os8nnUR9zCwzrNrhnAobstzeUhkbD645vU7yN-UK0wzlrjfLbLQPAX-0Cfo6Z6ExW8Di63APjywaET3N2VaMxh-SyXaXjIN-cVCr5uglL8B6UMbaPImUsxxNHVsfgPWwKR5mntA6NQ9IFnxsOMCxYaYU3bySorGzjaEcRVB0WDUNT-lkcvPYdvRPq-BldRsX5NdxAeukyMigFSoUNvfkzIoe0mw82Wi230QdGkTPubrdQxORNoTP-4oxVP2Qe8BwVbn_PfCRNPNU5YEXpmK4wDYdoQTk-zisOwUGj0Ge4EIilwcF2vHp7U5HcSTFKl62gmbb0NKWtg_gJr1B-cdBdgagFVlL_ZjL9fJCZEEie_9DRT4J9XOSPfcvKICHUrHn9e2nMunJHrxxuNCHRuVdLAxdObeelqgkCxjzGZgScc4h2t_Ub_Bm-MzxTe08W7JC4Q7wjgavWTrUki-2riqUAuuavkqti2Oge98e5mjKc4VZzt0LS9sEjHdrCSLfEtB0ttpUbfALwjCiOKex0PTtc_ZD3jcAUBk_YSVurT17QLqyxZXxEYIhmRGoj1U7HQ4cNiL4JJARUNx4LC8BGP6aI_68dkRDqlndfNQUIc2oAOpl1kTVxQ21LDrxCgrt5o5wHIfzZWOhci_Op1l9_XRkPG0LLHdX0AweWZcDfwrIVnjLoQ-BQVD05Ck2t0OxPhmeAKIN1A-s2SWc02j26Ed7F8IIHpeNWMEbRGVx3Ibp6dpMVDp4lpCFUzAr7aligvzFIBN7UX_lHD9XoMwIRud_-MnohkXyIoIvHFyxd9KGpBiJfFzYFQavzEY7DUrp0PaV3yKtgA8zh2lNmLyQwK-Z-oyiUVomFlQW1HeMitI5dqvdyLmjNVp75BSSR5wqi1uG8n1R325txvkU5AJ4fH-JZ__g7H8Q34ed7Zn-8gzffIa_XxGYZRqBHg2-Bd4YQRyBeTumHN64Htbw2J1jLLK_SW6oIsAf9xaHzndLc56zySHfQhwgG9kxsBiztZmKx9bLPlXUR2MYam8TYnDP1CMlIK3HiY0rexoJwT-sQcd2RDcGJiT-ORwwnhCTPHSHISw9nNrW9KMPt80UsXTV52t9KU781z8T1eNiJELf2Ba7H_Iidlc19DdjL2Viio03qBhw_Y5OLJ37m6yunAyixyai5KgKBns_vJIROXfQwmLCe4-qd0l71buDrlUOsZGbRAL8fG0qvoz_XrlcgwjHKhxvFqhtPuUKRo-vEU5KbdI0KJNC5eLjx6ptOY3-BZZ-j1oL_cJeALBo7vuiwWVzIAIR-wsIo4Ada8sVYdSOGEA72ooX1u3gFScEfX8QDmJsaDAXWVFb9X2MaY3HlojTC9iAYMqr7JwjNJqa0jB6gnI8IO8RYnGKArQCTpzrMsj2Z_50K-p-iKCMnSCGLKMm-KSZ07Znc1ZGbx5-uxTrR8yAfkpjj36qwcPDbvtfv1zOcbuA60_bl0Iq4oJRPdrZvqAwogQs9D8MZWUDF6Dhrro3mwybTx9estROfPLzk0oS8XTXFLsNhN_-FpmvEX1HZ1R-NEdXLBkM2odQhfNf0TB5ng0moxvFEjsbbNmjwRGZG7bWYniBOgWLHS1pkNz5K3NGea7iVlxzA_q3c-wprUh9GQC9nW8pE8xjqM5zcvZNl42DGZba3VM_fPR1YPvDzNKmgYwHuwRu3jDX2Mq-KChxTNtvKFTd12MmY9iMCTptkZ8_IDvmk55BoLDS1jlREGia3KoMzk1ZmQ5ZGWoc2hhcmRfaWTOAzGDbw.3o1TrkJo4ZuZfSyjO66Uc5NWD93V1F4uTfbXN-Tt27Y
(the phone number and the captcha code is intential damaged)
I enter this as a command in the terminal (raspbianOS 64 bit trixie)
I always get the answer:
Failed to register: [403] Authorization failed! (AuthorizationFailedException)
Is this just bad luck or do I make a stupid mistake somewhere?
enno
Moin HarryT,
as Jörg wrote in his post. The first answer for SMS register will come back with an error. This is what you get. Now you have to wait 1 minute. Than you register with voice option. See the -v behind "register"sudo -E /opt/signal/bin/signal-cli --config /var/lib/signal-cli -u +49..... register -v --reregister --captcha signalcaptcha://......
Is this the way you tried? Or do you always use the same command?
Gruss
  Enno
Einfacher FHEM Anwender auf Intel®NUC mit Proxmox und Debian
HarryT
Hi Enno
Zitat von: enno am 15 April 2026, 15:03:47Is this the way you tried? Or do you always use the same command?
No in the second command I use  ...register -v --reregister --captcha.....
And the answer is:
2026-04-15T16:35:42.866+0200 [main] DEBUG org.asamk.signal.App - Starting signal-cli 0.14.2
2026-04-15T16:35:44.291+0200 [main] INFO  com.zaxxer.hikari.HikariDataSource - HikariPool-1 - Starting...
2026-04-15T16:35:44.656+0200 [main] INFO  com.zaxxer.hikari.pool.HikariPool - HikariPool-1 - Added connection org.sqlite.jdbc4.JDBC4Connection@5ca17ab0
2026-04-15T16:35:44.664+0200 [main] INFO  com.zaxxer.hikari.HikariDataSource - HikariPool-1 - Start completed.
2026-04-15T16:35:49.091+0200 [main] INFO  com.zaxxer.hikari.HikariDataSource - HikariPool-1 - Shutdown initiated...
2026-04-15T16:35:49.106+0200 [main] INFO  com.zaxxer.hikari.HikariDataSource - HikariPool-1 - Shutdown completed.
Failed to register: Invalid verification method: Before requesting voice verification you need to request SMS verification and wait a minute.
org.asamk.signal.manager.api.VerificationMethodNotAvailableException: Invalid verification method
at org.asamk.signal.manager.util.NumberVerificationUtils.handleVerificationSession(NumberVerificationUtils.java:66)
at org.asamk.signal.manager.internal.RegistrationManagerImpl.register(RegistrationManagerImpl.java:135)
at org.asamk.signal.commands.RegisterCommand.register(RegisterCommand.java:81)
at org.asamk.signal.commands.RegisterCommand.handleCommand(RegisterCommand.java:52)
at org.asamk.signal.commands.CommandHandler.handleRegistrationCommand(CommandHandler.java:33)
at org.asamk.signal.App.handleRegistrationCommand(App.java:268)
at org.asamk.signal.App.handleCommand(App.java:177)
at org.asamk.signal.App.init(App.java:147)
at org.asamk.signal.Main.main(Main.java:56)
I thought it was mentioned that the first call would abort with error 400 or something. So I guess 403 is a real error/problem. But I am out of ideas what can be wrong
Greetings
tomcat.x
Zitat von: HarryT am 15 April 2026, 16:41:58I thought it was mentioned that the first call would abort with error 400 or something. So I guess 403 is a real error/problem.
Think you're right. I also had the 403 in one of my tries, don't know why and don't know why it worked the next day (when I had the expected 400 error).
FHEM: 6.4 auf Raspi 4B, Raspbian (noch Buster), Perl v5.28.1 mit Sender/Empfänger: 3 x CULv3, Duofern Stick
Gateways: FRITZ!Box 6591 (OS: 8.25), Trädfri, ConBee 2,  piVCCU (HM-MOD-RPI-PCB), OpenMQTTGateway
Sensoren/Aktoren: FRITZ!DECT, FS20, FHT, HMS, HomeMatic, Trädfri, DuoFern, NetAtmo, UNIRoll
Adimarantis
Have you tried with the updated Signalbot (3.23) as I made it ignore that first error and thus it should hopefully now go through the process correctly
And I'd appreciate a tester, as I did not....
HarryT
Zitat von: Adimarantis am 15 April 2026, 19:40:01Have you tried with the updated Signalbot (3.23) as I made it ignore that first error and thus it should hopefully now go through the process correctly
I tried it without installing anything to be sure nothing interferes on my system.
But I am willing to test. So I made fhem install on my test system and tried.
HOME_JAVE was wrongly set in signale.service, but maybe that was from a previous test. I will look at that later.
I tried to register from Signalbot in FHEM. I used  https://signalcaptchas.org/registration/generate to get a captcha. (Would be nice to display this link when the captcha is asked.)
Anyway, it did not help. I got no error message in the signalbot screen, but in the signalbot logging I get:
2026-04-15_23:03:12 SignalBot lastError: Error in getIdentity:The method `org.asamk.Signal.getIdentity' does not exist on this object.
2026-04-15_23:03:29 SignalBot register +31xxxxxxx
2026-04-15_23:04:09 SignalBot lastError: Error in registerWithCaptcha:AuthorizationFailedException [403] Authorization failed!
If I can be helpfull in testing a newe version I am happy to do so.
-I have test machines so it would not destroy my home automation.
-I have scripts to install my systems so it is easy to generate a fresh installation
Greetings
 Harry
HarryT
Hi all
Reregister a numbwer works for me now.
For the people who want to know more:
I am not sure what made the difference. I normally had my Raspberry connected with WiFi and Cable over 2 routers after each other. The last router works only in ipv4.
Today I decided to connect my WiFi through another network. Just 1 modem/router and ipv6. After that the registration worked immediately. 10 minutes before not.
But it might be that something else triggered this the difference.
Some findings:
- "signal_install.sh restore"  restores also signal.service. If you have "JAVA_HOME=/opt/java" in the backup file a restart of signal might fail after the restore. Not much to do about it but be aware. With "sudo nano -c /etc/systemd/system/signal.service" you can change it in "#JAVA_HOME=" save it and restart your computer.
After that make a fresh backup with signal_install.sh backup
- the signalbot module works fine. I would prefer if it says what you should do when starting registering a new number. But that might also be in the wiki. However whether the registering is correct or not, you have to find this out in the logging. After a short time you get the call with the verification code when the registration was succesfull.
Thanks Jorg for your work
Greetings
 Harry
Gisbert
Zitat von: Adimarantis am 13 April 2026, 21:34:31You're right about the jre 25 - I updated the installer accordingly in the svn.
What puzzles me most is the errors you're getting with install Protocol::Dbus
That is mandatory for using Signalbot.
Something might be missing on your system. I recommend running
sudo cpan -T install Protocol::DBusby itself and see if you can understand what's going wrong and make it work.
Then you should try the installer again.
Hallo Adimarantis,
ich hab die Version 0.14.2 (Signalbot:3.23 signal-cli:0.14.2 Protocol::DBus:0.22), die an und für sich stabil läuft.
Heute morgen hab ich in den log reingeschaut und folgendes gesehen, was ich mit Signalbot in Verbindung bringe:
2026.04.25 02:45:00.443 2: restart.FHEM: backup: Started the backup in the background, watch the log for details
Backup done
IO::Framed::X::ReadError: Read error: Connection reset by peer
    ==> X::Tiny::create('IO::Framed::X', 'ReadError', ** argument not available anymore (already freed) **) (called in /usr/local/share/perl/5.36.0/IO/Framed/Read.pm at line 87)
    ==> IO::Framed::Read::_expand_read_buffer(IO::Framed=HASH(0x55fa9e3e8a58), '65536') (called in /usr/local/share/perl/5.36.0/IO/Framed/Read.pm at line 117)
    ==> IO::Framed::Read::read_until(IO::Framed=HASH(0x55fa9e3e8a58), '
') (called in /usr/local/share/perl/5.36.0/Protocol/DBus/Authn.pm at line 252)
    ==> Protocol::DBus::Authn::_read_line(Protocol::DBus::Authn=HASH(0x55fa9777b278)) (called in /usr/local/share/perl/5.36.0/Protocol/DBus/Authn.pm at line 99)
    ==> (eval)(Protocol::DBus::Authn=HASH(0x55fa9777b278)) (called in /usr/local/share/perl/5.36.0/Protocol/DBus/Authn.pm at line 96)
    ==> Protocol::DBus::Authn::go(Protocol::DBus::Authn=HASH(0x55fa9777b278)) (called in /usr/local/share/perl/5.36.0/Protocol/DBus/Client.pm at line 105)
    ==> Protocol::DBus::Client::initialize(Protocol::DBus::Client=HASH(0x55fa976f3958)) (called in .//FHEM/50_Signalbot.pm at line 1244)
    ==> main::Signalbot_setup(HASH(0x55fa97b28a68)) (called in .//FHEM/50_Signalbot.pm at line 1633)
    ==> main::Signalbot_Read(HASH(0x55fa97b28a68)) (called in .//FHEM/98_apptime.pm at line 178)
    ==> main::apptime_getTiming('mySignal', 'Signalbot_Read', 'Signalbot_Read', ** argument not available anymore (already freed) **, HASH(0x55fa97b28a68)) (called in .//FHEM/98_apptime.pm at line 138)
    ==> main::CallFn('mySignal', 'ReadFn', HASH(0x55fa97b28a68)) (called in fhem.pl at line 789)
    ...propagated at /usr/local/share/perl/5.36.0/Protocol/DBus/Authn.pm, line 153
Ist das von irgendeiner Relevanz. Wie kann ich es wegbringen oder einfach hartnäckig  ::)  :-\  :'( ignorieren?
Viele Grüße Gisbert
Adimarantis
Schaut nach einem (temporären) Verbindungsproblem aus.
Sofern du erfolgreich Nachrichten senden/empfangen kannst und sich das nicht häuft, würde ich das eher ignorieren
Jörg
KarlHeinz2000
Ich habe jetzt auch versucht zu updaten.
Die Installation von Java25 macht Probleme.
Downloading private jdk21 build for armv7l platform...successful
Unpacking ...tar (child): openjdk-25.0.35-armv7l-glibc2.28.tar.gz: Cannot open: No such file or directory
Unter dem Link im liegt nur die 21, oder verstehe ich hier etwas falsch?
Adimarantis
Da ist irgendwo noch eine inkonsistenz im Script - da es so viele Varianten gibt ist das schwer alles zu testen.
Schau einfach mal auf
https://adoptium.net/temurin/releases/
Und lade dir von da die jre 25 Version runter die zu deinem System passt.
Diese dann nach /opt/java installieren.
Ob es funktioniert merkst du wenn "/opt/java/bin/java --version" korrekt eine Version ausgibt
Dann sollte der Installer die Version finden und weiter durchlaufen.
Jörg
KarlHeinz2000
Danke! Habe es installieren können. Leider startet es nicht. Ich habe auf meinem Pi3B bullseye mit 32 bit laufen :-(
Adimarantis
für 32 Bit habe ich keine Quelle - für JDK21 hatte ich recht aufwändig eine Version selbst compiliert und zur Verfügung gestellt, aber das für JDK25 wieder zu machen ist mir jetzt echt zuviel Aufwand.
Weini hat im Post https://forum.fhem.de/index.php?msg=1361919 festgestellt dass es für Raspbian Trixie eine JDK 25 für 32 Bit gibt. Aber ich schätze mal du bist auf einem älteren OS und willst nicht unbedingt upgraden
KyleK
Ich hab heute festgestellt dass mein SignalBot seit Ende Mai nicht mehr funktioniert, das FHEM Device zeigte "Disconnected".
Ein Reinit in FHEM brachte nichts.
Ein reregister auf der Kommandozeile wurde mit HTTP 400 quittiert.
Ich hab daraufhin das install-Script angepasst: Signal-CLI auf die 0.14.4.1 und libsignal auf die 0.94.4.
Nach der Installation und dem Neustart von signal.service lief sofort wieder alles.
FHEM on Futro S940
CUL868
7x MAX! Thermostat, 8x MAX! Fensterkontakte
Conbee II + deConz, TradFri Lampen, Osram Smart+ Steckdosen
