Support-Thread Modul 36_Shelly.pm
Begonnen von Prof. Dr. Peter Henning, 03 Februar 2021, 08:03:09
Starkstrombastler
Zitat von: piet_pit am 11 Februar 2026, 14:28:03Es kommt die Fehlermeldung "not enough parameter".
Der kleine Unterschied zwischen pct und ct (für colour-temperature) hat hier für den Fehler gesorgt. Ist im aktuellen Update gefixt.
IPC\Ubuntu + Fhem, 1wire, Shellies, Siemens Logo!, Z-Wave, PhilipsTV, Vu+duo2, KM200
xypzo
#1291
Can someone explain the following:
I bought four Shelly Dimmers gen3.
One is working flawless with the shelly module.
The other 3 I can't send PCT info to, but dimming can be done with the DIM set command...
They all have the same firmware. Also, the 3 others cant be reached with MQTT2 in FHEM, it reads but can't send any commands.
EDIT: I found the solution, when defined the dimmer, set model to shellyprodm1pm
