HM-LC-SW1-BA-PCB Schellwert für "battery low"
Begonnen von marc2, 24 März 2013, 15:48:45
marc2
Hi !
Auf die Gefahr hin, dass dies schon eimal thematisiert wurde (ich habe allerdings nichts gefunden). Das
gute Stück meldet bei mir quasi unabhängig von der Versorgungsspannung "battery: low". Da man den Aktor ja mit
beliebigen Spannungen zwischen 5V und 15V betreiben kann, gibt es wohl die Möglichkeit, den Schwellwert
zu setzen (gemäß ELV Forum). Allein welches der unendlich vielen Register ist es ?
list:         register | range              | peer     |exp| description
   0: intKeyVisib      |   - to -           |          |exp| visibility of internal channel options:visib,invisib
   0: pairCentral      |   0 to 16777215    |          |   | pairing to central
   3: lgActionType     |   - to -           | required |   |  options:toggleToCntInv,off,toggleToCnt,jmpToTarget
   3: lgCtDlyOff       |   - to -           | required |exp| Jmp on condition from delayOff options:geLo,between,outside,ltLo,geHi,ltHi
   3: lgCtDlyOn        |   - to -           | required |exp| Jmp on condition from delayOn options:geLo,between,outside,ltLo,geHi,ltHi
   3: lgCtOff          |   - to -           | required |exp| Jmp on condition from Off options:geLo,between,outside,ltLo,geHi,ltHi
   3: lgCtOn           |   - to -           | required |exp| Jmp on condition from On options:geLo,between,outside,ltLo,geHi,ltHi
   3: lgCtValHi        |   0 to 255         | required |exp| Condition value high for CT table
   3: lgCtValLo        |   0 to 255         | required |exp| Condition value low for CT table
   3: lgMultiExec      |   - to -           | required |   | multiple execution per repeat of long trigger options:on,off
   3: lgOffDly         |   0 to 111600s     | required |exp| off delay
   3: lgOffTime        |   0 to 111600s     | required |exp| off time, 111600 = infinite
   3: lgOffTimeMode    |   - to -           | required |exp| off time mode options:minimal,absolut
   3: lgOnDly          |   0 to 111600s     | required |exp| on delay
   3: lgOnTime         |   0 to 111600s     | required |exp| on time, 111600 = infinite
   3: lgOnTimeMode     |   - to -           | required |exp| on time mode options:minimal,absolut
   3: lgSwJtDlyOff     |   - to -           | required |exp| Jump from delayOff options:on,off,dlyOn,no,dlyOff
   3: lgSwJtDlyOn      |   - to -           | required |exp| Jump from delayOn options:on,off,dlyOn,no,dlyOff
   3: lgSwJtOff        |   - to -           | required |exp| Jump from Off options:on,off,dlyOn,no,dlyOff
   3: lgSwJtOn         |   - to -           | required |exp| Jump from On options:on,off,dlyOn,no,dlyOff
   3: shActionType     |   - to -           | required |   |  options:toggleToCntInv,off,toggleToCnt,jmpToTarget
   3: shCtDlyOff       |   - to -           | required |exp| Jmp on condition from delayOff options:geLo,between,outside,ltLo,geHi,ltHi
   3: shCtDlyOn        |   - to -           | required |exp| Jmp on condition from delayOn options:geLo,between,outside,ltLo,geHi,ltHi
   3: shCtOff          |   - to -           | required |exp| Jmp on condition from Off options:geLo,between,outside,ltLo,geHi,ltHi
   3: shCtOn           |   - to -           | required |exp| Jmp on condition from On options:geLo,between,outside,ltLo,geHi,ltHi
   3: shCtValHi        |   0 to 255         | required |exp| Condition value high for CT table
   3: shCtValLo        |   0 to 255         | required |exp| Condition value low for CT table
   3: shOffDly         |   0 to 111600s     | required |exp| off delay
   3: shOffTime        |   0 to 111600s     | required |exp| off time, 111600 = infinite
   3: shOffTimeMode    |   - to -           | required |exp| off time mode options:minimal,absolut
   3: shOnDly          |   0 to 111600s     | required |exp| on delay
   3: shOnTime         |   0 to 111600s     | required |exp| on time, 111600 = infinite
   3: shOnTimeMode     |   - to -           | required |exp| on time mode options:minimal,absolut
   3: shSwJtDlyOff     |   - to -           | required |exp| Jump from delayOff options:on,off,dlyOn,no,dlyOff
   3: shSwJtDlyOn      |   - to -           | required |exp| Jump from delayOn options:on,off,dlyOn,no,dlyOff
   3: shSwJtOff        |   - to -           | required |exp| Jump from Off options:on,off,dlyOn,no,dlyOff
   3: shSwJtOn         |   - to -           | required |exp| Jump from On options:on,off,dlyOn,no,dlyOff
Ich betreibe den Aktor übrigens and einem CUNO. Der Tatsache, dass ein Repeater HM-Sys-sRP-Pl dazwischen hängt, ist
zu verdanken, dass es überhaupt funktioniert :-)
Gruß,Marc
martinp876
Hi Marc,
weil es noch fehlt. Kommt gleich.
lowBatLimitBA
Gruss,
Martin
marc2
Hallo Martin !
Vielen Dank dafür ! Funktioniert wunderbar ! Ich habe den schwellwert auf 6V gesetzt und bin mit dem
Netzteil von oben und unten jeweils and die Schwelle rangefahren. Beim jeweils übernächsten Schaltvorgang,
bzw. Statusrequest, wechselt das battery reading dann korrekt von low auf ok, bzw. umgekehrt :-)
By the way, das "set <device> regSet <> <>" loggt derzeit einen Fehler in 10_CUL_HM.pm. Funktionieren
tut es aber trotzdem:
Argument "u" isn't numeric in numeric lt (<) at ./FHEM/10_CUL_HM.pm line 2875.
Bei eigentlich jedem Device fürt ein "geConfig" oder "getRegraw ListX" bei mir zu einem
RESPONSE TIMEOUT:RegisterRead, so auch beim HM-LC-SW1-BA-PCB. Irgendwann fuktioniert es dann
aber. Dies passiert auch bei Devices die eigenlich ja immer "online" sind (z.B.
HM-LC-SW2-FM). Gibt es dafür eine Erklärung ?
Gruß, Marc
martinp876
Hi Marc,
getRegRaw ist eigentlich nicht sehr lang. Das Device muss eine 'ende-kennung' schicken.
kannst du einmal mitloggen? Und die rohdaten
attr global verbose 1
attr global mseclog 1
attr <hmlan> loglevel 1
set <device> getConfig
attr <device> expert 2
list <device>
ggf auch list der channels
Gruss
Martin
marc2
Hi Martin,
hier die logs:
2013.03.27 22:16:15.745 1: SW: As1035B001F143211EFF0D00040000000000
2013.03.27 22:16:15.777 1: CUL1: A1035B001F143211EFF0D00040000000000 -60
2013.03.27 22:16:16.341 1: CUL1: A1035F001F143211EFF0D00040000000000 -68
2013.03.27 22:16:16.429 1: CUL1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -80
2013.03.27 22:16:16.453 1: SW: As0A358002F143211EFF0D00
2013.03.27 22:16:16.485 1: CUNO1: A1035F001F143211EFF0D00040000000000 -70
2013.03.27 22:16:16.501 1: CUNO1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -64.5
2013.03.27 22:16:16.777 1: CUL1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -79
2013.03.27 22:16:16.809 1: CUNO1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -65
2013.03.27 22:16:16.837 1: CUL1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -69
2013.03.27 22:16:17.061 1: CUNO1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -64.5
2013.03.27 22:16:17.185 1: CUL1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -79
2013.03.27 22:16:17.229 1: CUL1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -67.5
2013.03.27 22:16:17.309 1: CUNO1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -66
2013.03.27 22:16:17.329 1: CUNO1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -60
2013.03.27 22:16:17.457 1: SW: As1035B001F143211EFF0D00040000000000
2013.03.27 22:16:17.485 1: CUL1: A1035B001F143211EFF0D00040000000000 -59.5
2013.03.27 22:16:17.517 1: CUL1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -79
2013.03.27 22:16:17.561 1: CUNO1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -65
2013.03.27 22:16:18.053 1: CUL1: A1035F001F143211EFF0D00040000000000 -66
2013.03.27 22:16:18.069 1: CUNO1: A1035F001F143211EFF0D00040000000000 -60
2013.03.27 22:16:18.089 1: CUL1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -78
2013.03.27 22:16:18.125 1: CUL1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -68
2013.03.27 22:16:18.309 1: CUNO1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -65.5
2013.03.27 22:16:18.337 1: CUNO1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -64.5
2013.03.27 22:16:22.289 1: SW: As1035B001F143211EFF0D00040000000000
2013.03.27 22:16:22.317 1: CUL1: A1035B001F143211EFF0D00040000000000 -60
2013.03.27 22:16:22.885 1: CUL1: A1035F001F143211EFF0D00040000000000 -69
2013.03.27 22:16:22.973 1: CUL1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -79.5
2013.03.27 22:16:23.017 1: CUL1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -68
2013.03.27 22:16:23.053 1: CUNO1: A1035F001F143211EFF0D00040000000000 -63
2013.03.27 22:16:23.069 1: CUNO1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -66
2013.03.27 22:16:23.089 1: CUNO1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -62.5
2013.03.27 22:16:23.317 1: CUL1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -80
2013.03.27 22:16:23.361 1: CUL1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -67
2013.03.27 22:16:23.553 1: CUNO1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -66
2013.03.27 22:16:23.573 1: CUNO1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -64
2013.03.27 22:16:23.725 1: CUL1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -80
2013.03.27 22:16:23.769 1: CUL1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -67.5
2013.03.27 22:16:23.801 1: CUNO1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -66
2013.03.27 22:16:23.821 1: CUNO1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -62.5
2013.03.27 22:16:24.133 1: CUL1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -79
2013.03.27 22:16:24.177 1: CUL1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -68
2013.03.27 22:16:24.301 1: CUNO1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -65.5
2013.03.27 22:16:24.321 1: CUNO1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -62
2013.03.27 22:16:24.541 1: CUL1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -79
2013.03.27 22:16:24.561 1: CUNO1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -65.5
2013.03.27 22:16:24.585 1: CUL1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -67.5
2013.03.27 22:16:24.801 1: CUNO1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -63
2013.03.27 22:16:24.945 1: CUL1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -79
2013.03.27 22:16:24.993 1: CUL1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -68
2013.03.27 22:16:25.049 1: CUNO1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -66
2013.03.27 22:16:25.069 1: CUNO1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -64
2013.03.27 22:16:27.641 1: SW: As1035B001F143211EFF0D00040000000000
2013.03.27 22:16:27.673 1: CUL1: A1035B001F143211EFF0D00040000000000 -60.5
2013.03.27 22:16:28.237 1: CUL1: A1035F001F143211EFF0D00040000000000 -68.5
2013.03.27 22:16:28.297 1: CUNO1: A1035F001F143211EFF0D00040000000000 -65.5
2013.03.27 22:16:28.325 1: CUL1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -78.5
2013.03.27 22:16:28.369 1: CUL1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -69
2013.03.27 22:16:28.545 1: CUNO1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -66
2013.03.27 22:16:28.565 1: CUNO1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -66
2013.03.27 22:16:28.673 1: CUL1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -78.5
2013.03.27 22:16:28.717 1: CUL1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -70
2013.03.27 22:16:28.797 1: CUNO1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -66.5
2013.03.27 22:16:28.817 1: CUNO1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -64.5
2013.03.27 22:16:29.077 1: CUL1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -79.5
2013.03.27 22:16:29.125 1: CUL1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -68.5
2013.03.27 22:16:29.293 1: CUNO1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -65.5
2013.03.27 22:16:29.313 1: CUNO1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -64.5
2013.03.27 22:16:29.485 1: CUL1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -78
2013.03.27 22:16:29.533 1: CUL1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -66.5
2013.03.27 22:16:29.553 1: CUNO1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -66
2013.03.27 22:16:29.573 1: CUNO1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -62
2013.03.27 22:16:29.893 1: CUL1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -79.5
2013.03.27 22:16:29.937 1: CUL1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -68
2013.03.27 22:16:30.045 1: CUNO1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -66
2013.03.27 22:16:30.061 1: CUNO1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -64.5
2013.03.27 22:16:30.301 1: CUL1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -79.5
2013.03.27 22:16:30.345 1: CUL1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -68.5
2013.03.27 22:16:30.541 1: CUNO1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -65.5
2013.03.27 22:16:30.561 1: CUNO1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -64
2013.03.27 22:16:32.021 1: SW: As1035B001F143211EFF0D00040000000000
2013.03.27 22:16:32.049 1: CUL1: A1035B001F143211EFF0D00040000000000 -61.5
2013.03.27 22:16:32.181 1: CUL1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -78.5
2013.03.27 22:16:32.289 1: CUNO1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -66.5
2013.03.27 22:16:32.617 1: CUL1: A1035F001F143211EFF0D00040000000000 -66
2013.03.27 22:16:32.645 1: CUL1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -79
2013.03.27 22:16:32.689 1: CUL1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -66.5
2013.03.27 22:16:32.789 1: CUNO1: A1035F001F143211EFF0D00040000000000 -66
2013.03.27 22:16:32.805 1: CUNO1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -66.5
2013.03.27 22:16:32.825 1: CUNO1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -65
2013.03.27 22:16:33.053 1: CUL1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -78.5
2013.03.27 22:16:33.097 1: CUL1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -67.5
2013.03.27 22:16:33.289 1: CUNO1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -66
2013.03.27 22:16:33.309 1: CUNO1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -64.5
2013.03.27 22:16:33.461 1: CUL1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -79
2013.03.27 22:16:33.505 1: CUL1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -66.5
2013.03.27 22:16:33.537 1: CUNO1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -65.5
2013.03.27 22:16:33.557 1: CUNO1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -64.5
2013.03.27 22:16:33.865 1: CUL1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -79
2013.03.27 22:16:33.913 1: CUL1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -66.5
2013.03.27 22:16:34.037 1: CUNO1: A1635A0101EFF0DF1432102020105400AF10B430C21123C -66.5
2013.03.27 22:16:34.057 1: CUNO1: A1635E0101EFF0DF1432102020105400AF10B430C21123C -66
2013.03.27 22:16:37.553 1: SW: As0B36B001F143211EFF0D0103
2013.03.27 22:16:37.713 1: CUL1: A0B36B001F143211EFF0D0103 -61
2013.03.27 22:16:38.145 1: CUL1: A0B36F001F143211EFF0D0103 -66
2013.03.27 22:16:38.233 1: CUL1: A0E36A0101EFF0DF143210100000000 -79
2013.03.27 22:16:38.253 1: SW: As0A368002F143211EFF0D00
2013.03.27 22:16:38.277 1: CUL1: A0A368002F143211EFF0D00 -62
2013.03.27 22:16:38.297 1: CUNO1: A0B36F001F143211EFF0D0103 -65
2013.03.27 22:16:38.313 1: CUNO1: A0E36A0101EFF0DF143210100000000 -66
2013.03.27 22:16:40.721 1: CUL1: A0DBE84101C5C64F143210601210E -54
2013.03.27 22:16:40.741 1: SW: As0DBE8002F143211C5C6401012100
2013.03.27 22:16:40.897 1: CUNO1: A0DBE84101C5C64F143210601210E -34.5
2013.03.27 22:16:40.921 1: CUL1: A0DBE8002F143211C5C6401012100 -62
2013.03.27 22:16:47.209 1: CUL1: A0B51A4401D36AB1859C7028A -44
2013.03.27 22:16:47.541 1: CUNO1: A0B51A4401D36AB1859C7028A -64
2013.03.27 22:16:47.561 1: CUNO1: A0E5180021859C71D36AB0101C80041 -85.5
2013.03.27 22:16:47.729 1: CUL1: A0E5180021859C71D36AB0101C80041 -69.5
2013.03.27 22:16:48.693 1: CUL1: A0B52A4401D36AB1859C70198 -45
2013.03.27 22:16:49.025 1: CUNO1: A0B52A4401D36AB1859C70198 -65
2013.03.27 22:16:49.041 1: CUNO1: A0E5280021859C71D36AB0101000040 -83.5
2013.03.27 22:16:49.217 1: CUL1: A0E5280021859C71D36AB0101000040 -69
Mit Blick auf das "list" sollte es nicht funktioniert haben. Der "R-ledMode"
wird nach wie vor als "set_on" angezeigt. Gesetzt wurde definitiv, die LED
leuchtet wenn der Aktor an ist.
fhem> list Tuerklingel
   CHANGED
   CUL1_MSGCNT 42
   CUL1_RAWMSG A0E36A0101EFF0DF143210100000000F6
   CUL1_RSSI  -79
   CUL1_TIME  2013-03-27 22:16:38
   CUNO1_MSGCNT 42
   CUNO1_RAWMSG A0E36A0101EFF0DF14321010000000010
   CUNO1_RSSI -66
   CUNO1_TIME 2013-03-27 22:16:38
   DEF        1EFF0D
   EVENTS     2
   IODev      CUNO1
   LASTInputDev CUNO1
   MSGCNT     84
   NAME       Tuerklingel
   NR         183
   STATE      RESPONSE TIMEOUT:RegisterRead
   TYPE       CUL_HM
   lastMsg    No:36 - t:10 s:1EFF0D d:F14321 0100000000
   protCmdDel 1
   protLastRcv 2013-03-27 22:16:38
   protResnd  4 last_at:2013-03-27 22:16:32
   protResndFail 1 last_at:2013-03-27 22:16:37
   protSnd    2 last_at:2013-03-27 22:16:37
   protState  CMDs_done_events:5
   rssi_at_CUL1 avg:-79.04 min:-80 max:-78 lst:-79 cnt:23
   rssi_at_CUNO1 avg:-65.8 min:-66.5 max:-64.5 lst:-66 cnt:23
   rssi_at_rpt_CUL1 avg:-67.78 min:-70 max:-66.5 lst:-66.5 cnt:19
   rssi_at_rpt_CUNO1 avg:-63.81 min:-66 max:-60 lst:-66 cnt:19
   Readings:
     2013-03-26 00:15:03   CommandAccepted yes
     2013-03-25 22:13:25   PairedTo        0xF14321
     2013-03-25 22:13:25   R-intKeyVisib   invisib
     2013-03-25 22:15:15   R-ledMode       set_on
     2013-03-25 22:13:25   R-lowBatLimitBA 6 V
     2013-03-25 22:13:25   R-pairCentral   0xF14321
     2013-03-27 22:08:33   battery         ok
     2013-03-26 00:15:03   deviceMsg       off (to CUNO1)
     2013-03-27 22:08:33   powerOn         -
     2013-03-27 22:16:37   state           RESPONSE TIMEOUT:RegisterRead
     Regl_00::
       VAL
   Helper:
     burstEvtCnt 5
     mId        006C
     peerIDsRaw ,00000000
     rxType     2
     Rssi:
       At_cul1:
         avg        -79.0434782608696
         cnt        23
         lst        -79
         max        -78
         min        -80
       At_cuno1:
         avg        -65.8043478260869
         cnt        23
         lst        -66
         max        -64.5
         min        -66.5
       At_rpt_cul1:
         avg        -67.7894736842105
         cnt        19
         lst        -66.5
         max        -66.5
         min        -70
       At_rpt_cuno1:
         avg        -63.8157894736842
         cnt        19
         lst        -66
         max        -60
         min        -66
   IODev      CUNO1
   devStateIcon on:Wecker.Wochenende off:Wecker.Aus
   event-on-change-reading battery
   event-on-update-reading state,deviceMsg
   expert     2
   firmware   1.4
   model      HM-LC-SW1-BA-PCB
   peerIDs    00000000,
   room       Flur
   serialNr   JEQ0655984
   subType    switch
   webCmd     toggle:on:off:statusRequest
Gruß, Marc
martinp876
Hi Marc,
das sieht wirklich nicht gut aus. Deine Infrastruktur habe ich noch nicht verstanden:
In betrieb hast du eine CUL, CUNO und einen repeater?
Senden zum Device sollte nur die CUNO
Was nicht gut aussieht ist das ack. Das soll gesendet werden, im LOG kann ich nicht sehen ob von CUL oder CUNO. Aber es scheint nicht an die Luft zu kommen. Sonst sollte es von der CUL empfangen werden und von Repeater wiederholt, passiert aber nicht.
=> die CUNO sendet dieses message nicht.
Am Ende ist zu sehen, dass ACKs Generell gesendet werden kann, aber auch hier nicht vom repeater.
Ein Problem ist auf meiner Seite, die Wiederholung von ACKs muss ich sicherstellen...
Der repeater sollte kein Problem machen, das ist in HM sicher gewaerleistet.
Kannst du austesten, ob es an der CUNO liegt? Moegliche tests sind
- Betrieb nur mit CUNO und CUL, aber IODev auf CUL setzen
- Betrieb nur mit CUNO, ohne CUL
- Betrieb nur mit CUL, ohne CUNO
Nachtrag:
das Device ist eigentlich als Burst eingetragen. Dafuer funktioniert es mit der CUNO gut, garantiert ist dies nicht.
Gruss
Martin
marc2
Hallo Martin,
primär nutze ich den CUNO. Der CUL kommt dort zum Eisatz, wo der CUNO aufgrund
hoher Dämpfung (diverse Wände) miese RSSI Werte hat und unzuverlässig läuft.
Den Repeater nutze ich derzeit nur für den HM-LC-SW1-BA-PCB, da CUNO und CUL
alleine ja keinen Burst können (mit dem Repeater tut's wunderbar - bis auf getConfig).
Die getConfig Probleme sind bei mir aber eher generischer Natur. Um es übersichtlicher
zu machen, habe ich den CUNO und den Repeater eben mal abgelemmt und einen das ganze
für einen HM-LC-SW2-FM noch einmal durchgespielt.
2013.03.28 19:25:15.580 1: CUL1: A0CE186701CCD3D000000000155 -72.5
2013.03.28 19:25:19.596 1: SW: As104CA001F143211859C700040000000000
2013.03.28 19:25:25.604 1: SW: As104CA001F143211859C700040000000000
2013.03.28 19:25:25.764 1: CUL1: A164CA0101859C7F1432103020100000000000000F14321 -69
2013.03.28 19:25:25.864 1: SW: As0A4C8002F143211859C700
2013.03.28 19:25:26.012 1: CUL1: A0C4DA0101859C7F14321030000 -70
2013.03.28 19:25:26.112 1: SW: As0A4D8002F143211859C700
2013.03.28 19:25:26.280 1: SW: As0B4EA001F143211859C70103
2013.03.28 19:25:30.904 1: SW: As0B4EA001F143211859C70103
2013.03.28 19:25:31.364 1: CUL1: A164EA0101859C7F14321011D36AB021D36AB0100000000 -69
2013.03.28 19:25:31.464 1: SW: As0A4E8002F143211859C700
2013.03.28 19:25:31.628 1: SW: As104FA001F143211859C701040000000001
2013.03.28 19:25:32.296 1: CUL1: A0C4FA0101859C7F14321030800 -71
2013.03.28 19:25:32.388 1: SW: As0A4F8002F143211859C700
2013.03.28 19:25:32.480 1: CUL1: A0C4FA0101859C7F14321030800 -69.5
2013.03.28 19:25:33.324 1: SW: As104FA001F143211859C701040000000001
2013.03.28 19:25:36.992 1: CUL1: A0D1B84101B8F26F1432106013100 -58.5
2013.03.28 19:25:37.084 1: SW: As0D1B8002F143211B8F2601013100
2013.03.28 19:25:37.536 1: SW: As104FA001F143211859C701040000000001
2013.03.28 19:25:43.060 1: SW: As104FA001F143211859C701040000000001
2013.03.28 19:25:47.828 1: SW: As104FA001F143211859C701040000000001
2013.03.28 19:25:52.344 1: SW: As0B50A001F143211859C70203
2013.03.28 19:25:52.504 1: CUL1: A0E50A0101859C7F143210100000000 -70
2013.03.28 19:25:52.604 1: SW: As0A508002F143211859C700
2013.03.28 19:25:52.768 1: SW: As1051A001F143211859C702040000000001
2013.03.28 19:25:53.196 1: CUL1: A0E50A0101859C7F143210100000000 -70
2013.03.28 19:25:57.476 1: SW: As1051A001F143211859C702040000000001
2013.03.28 19:26:03.468 1: SW: As1051A001F143211859C702040000000001
2013.03.28 19:26:03.620 1: CUL1: A0C51A0101859C7F14321030800 -69
2013.03.28 19:26:03.720 1: SW: As0A518002F143211859C700
2013.03.28 19:26:04.320 1: CUL1: A0C51A0101859C7F14321030800 -68.5
2013.03.28 19:26:04.648 1: SW: As1051A001F143211859C702040000000001
2013.03.28 19:26:09.404 1: SW: As1051A001F143211859C702040000000001
2013.03.28 19:26:09.556 1: CUL1: A0C51A0101859C7F14321030800 -68.5
2013.03.28 19:26:09.852 1: CUL1: A0C51A0101859C7F14321030800 -69
2013.03.28 19:26:10.256 1: CUL1: A0C51A0101859C7F14321030800 -69.5
2013.03.28 19:26:14.060 1: SW: As1052A001F143211859C701041D36AB0103
2013.03.28 19:26:14.220 1: CUL1: A1652A0101859C7F1432103020000326400FF00FF016466 -69.5
2013.03.28 19:26:14.324 1: SW: As0A528002F143211859C700
2013.03.28 19:26:14.520 1: CUL1: A1652A0101859C7F1432103020000326400FF00FF016466 -69.5
2013.03.28 19:26:14.924 1: CUL1: A1652A0101859C7F1432103020000326400FF00FF016466 -69.5
2013.03.28 19:26:15.256 1: SW: As1052A001F143211859C701041D36AB0103
2013.03.28 19:26:20.980 1: SW: As1052A001F143211859C701041D36AB0103
2013.03.28 19:26:21.140 1: CUL1: A1652A0101859C7F1432103020000326400FF00FF016466 -68
2013.03.28 19:26:21.844 1: CUL1: A1652A0101859C7F1432103020000326400FF00FF016466 -68.5
2013.03.28 19:26:25.568 1: SW: As1052A001F143211859C701041D36AB0103
2013.03.28 19:26:26.028 1: CUL1: A1652A0101859C7F1432103020000326400FF00FF016466 -70
2013.03.28 19:26:26.432 1: CUL1: A1652A0101859C7F1432103020000326400FF00FF016466 -69
2013.03.28 19:26:30.032 1: SW: As1052A001F143211859C701041D36AB0103
2013.03.28 19:26:34.396 1: SW: As1053A001F143211859C701041D36AB0203
2013.03.28 19:26:39.836 1: SW: As1053A001F143211859C701041D36AB0203
2013.03.28 19:26:39.996 1: CUL1: A1653A0101859C7F1432103020000326400FF00FF011333 -69.5
2013.03.28 19:26:40.100 1: SW: As0A538002F143211859C700
2013.03.28 19:26:40.296 1: CUL1: A1653A0101859C7F1432103020000326400FF00FF011333 -69
2013.03.28 19:26:40.700 1: CUL1: A1653A0101859C7F1432103020000326400FF00FF011333 -68.5
2013.03.28 19:26:41.032 1: SW: As1053A001F143211859C701041D36AB0203
2013.03.28 19:26:42.740 1: CUL1: A0DD784101C5C64F143210601210E -52.5
2013.03.28 19:26:45.088 1: SW: As1053A001F143211859C701041D36AB0203
   CUL1_MSGCNT 22
   CUL1_RAWMSG A1653A0101859C7F1432103020000326400FF00FF0113330B
   CUL1_RSSI  -68.5
   CUL1_TIME  2013-03-28 19:26:40
   DEF        1859C7
   EVENTS     8
   IODev      CUL1
   LASTInputDev CUL1
   MSGCNT     22
   NAME       Schalter_Gehege_1
   NR         138
   TYPE       CUL_HM
   channel_01 Licht_Gehege
   channel_02 Heizplatte_Gehege
   lastMsg    No:53 - t:10 s:1859C7 d:F14321 03020000326400FF00FF011333
   protCmdDel 7
   protLastRcv 2013-03-28 19:26:40
   protResnd  18 last_at:2013-03-28 19:26:50
   protResndFail 4 last_at:2013-03-28 19:26:55
   protSnd    7 last_at:2013-03-28 19:26:34
   protState  CMDs_done_events:22
   rssi_at_CUL1 avg:-69.27 min:-71 max:-68 lst:-68.5 cnt:22
   Readings:
     2013-02-02 15:03:23   CommandAccepted yes
     2013-03-28 19:25:26   PairedTo        0xF14321
     2013-02-02 12:56:55   R-intKeyVisib   set_invisib
     2013-02-02 12:56:55   R-pairCentral   set_0xF14321
     2013-03-28 19:25:26   RegL_00:         02:01 03:00 04:00 05:00 06:00 07:00 08:00 09:00 0A:F1 0B:43 0C:21 00:00
     2013-02-02 14:56:09   noReceiver      src:1859C7 (A001) 0106
     2013-03-16 16:38:10   powerOn         -
     2013-03-28 19:26:55   state           RESPONSE TIMEOUT:RegisterRead
   Helper:
     burstEvtCnt 22
     mId        0009
     rxType     1
     Rssi:
       At_cul1:
         avg        -69.2727272727273
         cnt        22
         lst        -68.5
         max        -68
         min        -71
     Shadowreg:
   IODev      CUL1
   expert     2
   firmware   1.9
   model      HM-LC-SW2-FM
   peerIDs
   serialNr   IEQ0536340
   subType    switch
   webCmd     getConfig
   DEF        1859C701
   NAME       Licht_Gehege
   NR         141
   STATE      off
   TYPE       CUL_HM
   chanNo     01
   device     Schalter_Gehege_1
   Readings:
     2013-03-27 22:50:32   CommandAccepted yes
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-lgActionType jmpToTarget
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-lgCtDlyOff geLo
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-lgCtDlyOn geLo
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-lgCtOff geLo
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-lgCtOn geLo
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-lgCtValHi 100
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-lgCtValLo 50
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-lgMultiExec on
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-lgOffDly 0 s
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-lgOffTime 111600 s
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-lgOffTimeMode absolut
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-lgOnDly 0 s
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-lgOnTime 111600 s
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-lgOnTimeMode absolut
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-lgSwJtDlyOff off
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-lgSwJtDlyOn off
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-lgSwJtOff off
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-lgSwJtOn dlyOff
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-shActionType jmpToTarget
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-shCtDlyOff geLo
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-shCtDlyOn geLo
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-shCtOff geLo
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-shCtOn geLo
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-shCtValHi 100
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-shCtValLo 50
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-shOffDly 0 s
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-shOffTime 111600 s
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-shOffTimeMode absolut
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-shOnDly 0 s
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-shOnTime 111600 s
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-shOnTimeMode absolut
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-shSwJtDlyOff off
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-shSwJtDlyOn off
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-shSwJtOff off
     2013-03-08 21:30:08   R-Schalter_Licht_Gehege_Btn_01-shSwJtOn dlyOff
     2013-03-18 21:20:03   R-Schalter_Licht_Gehege_Btn_02-lgActionType jmpToTarget
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-lgCtDlyOff geLo
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-lgCtDlyOn geLo
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-lgCtOff geLo
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-lgCtOn geLo
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-lgCtValHi 100
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-lgCtValLo 50
     2013-03-18 21:20:03   R-Schalter_Licht_Gehege_Btn_02-lgMultiExec on
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-lgOffDly 0 s
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-lgOffTime 111600 s
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-lgOffTimeMode absolut
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-lgOnDly 0 s
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-lgOnTime 111600 s
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-lgOnTimeMode absolut
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-lgSwJtDlyOff on
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-lgSwJtDlyOn on
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-lgSwJtOff dlyOn
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-lgSwJtOn on
     2013-03-18 21:20:03   R-Schalter_Licht_Gehege_Btn_02-shActionType jmpToTarget
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-shCtDlyOff geLo
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-shCtDlyOn geLo
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-shCtOff geLo
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-shCtOn geLo
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-shCtValHi 100
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-shCtValLo 50
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-shOffDly 0 s
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-shOffTime 111600 s
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-shOffTimeMode absolut
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-shOnDly 0 s
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-shOnTime 111600 s
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-shOnTimeMode absolut
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-shSwJtDlyOff on
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-shSwJtDlyOn on
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-shSwJtOff dlyOn
     2013-02-17 19:29:17   R-Schalter_Licht_Gehege_Btn_02-shSwJtOn on
     2013-03-28 19:27:54   RegL_01:
     2013-03-28 19:27:54   RegL_03:Schalter_Licht_Gehege_Btn_01
     2013-03-28 19:27:54   RegL_03:Schalter_Licht_Gehege_Btn_02
     2013-03-27 22:51:34   deviceMsg       off (to broadcast)
     2013-03-28 19:25:31   peerList        Schalter_Licht_Gehege_Btn_01,Schalter_Licht_Gehege_Btn_02,
     2013-03-27 22:51:34   state           off
   Helper:
     peerIDsRaw ,1D36AB02,1D36AB01,00000000
   model      HM-LC-SW2-FM
   peerIDs    00000000,1D36AB01,1D36AB02,
   room       Gehege
   subType    switch
   DEF        1859C702
   NAME       Heizplatte_Gehege
   NR         144
   STATE      on
   TYPE       CUL_HM
   chanNo     02
   Readings:
     2013-03-15 21:34:50   CommandAccepted yes
     2013-03-17 09:02:16   deviceMsg       on (to broadcast)
     2013-03-17 09:02:16   state           on
   Helper:
   icon       icoHEIZUNG
   model      HM-LC-SW2-FM
   peerIDs    00000000,
   room       Gehege
   subType    switch
Gruß, Marc
marc2
Hi !
Ich habe den Debug Output einmal aufbereitet, da er natürlich
durch weitere Meldungen verunreinigt ist. Der Wert hinter dem
Doppelpunkt ist die Payload:
Thermometer_Nord          ==> Action_Detector_HM        : 0000000155
CUL                       ==> Schalter_Gehege_1         : 59C700040000000000
Schalter_Gehege_1         ==> CUL                       : 432103020100000000000000F14321
Schalter_Gehege_1         ==> CUL                       : 4321030000
CUL                       ==> Schalter_Gehege_1         : 59C70103
Schalter_Gehege_1         ==> CUL                       : 4321011D36AB021D36AB0100000000
CUL                       ==> Schalter_Gehege_1         : 59C701040000000001
Schalter_Gehege_1         ==> CUL                       : 4321030800
Bewegungsmelder_Nordwest  ==> CUL                       : 432106013100
CUL                       ==> Bewegungsmelder_Nordwest  : 8F2601013100
CUL                       ==> Schalter_Gehege_1         : 59C70203
Schalter_Gehege_1         ==> CUL                       : 43210100000000
CUL                       ==> Schalter_Gehege_1         : 59C702040000000001
CUL                       ==> Schalter_Gehege_1         : 59C701041D36AB0103
Schalter_Gehege_1         ==> CUL                       : 432103020000326400FF00FF016466
CUL                       ==> Schalter_Gehege_1         : 59C701041D36AB0203
Schalter_Gehege_1         ==> CUL                       : 432103020000326400FF00FF011333
Bewegungsmelder_Flur_EG   ==> CUL                       : 43210601210E
Gruß, Marc
martinp876
Hi Marc,
primaer antwortet den device schlecht.
19:25:19.596  SW:   4C A001 F14321 1859C7 00040000000000              #request
19:25:25.604  SW:   4C A001 F14321 1859C7 00040000000000              #repeat nach 6 sec
19:25:25.764  CUL1: 4C A010 1859C7 F14321 03020100000000000000F14321  #antwort von device, inhalt korrupt
19:25:25.864  SW:   4C 8002 F14321 1859C7 00                          #ACK von Zentrale
19:25:26.012  CUL1: 4D A010 1859C7 F14321 030000                      #antwort2. teil, ist ok
19:25:26.112  SW:   4D 8002 F14321 1859C7 00                          #ACK von Zentrale
19:25:26.280  SW:   4E A001 F14321 1859C7 0103                       #request
19:25:30.904  SW:   4E A001 F14321 1859C7 0103                       #repeat nach 5 sec (timer ist random)
19:25:31.364  CUL1: 4E A010 1859C7 F14321 011D36AB021D36AB0100000000 #antwort von device
19:25:31.464  SW:   4E 8002 F14321 1859C7 00                         #ACK von Zentrale
19:25:31.628  SW:   4F A001 F14321 1859C7 01040000000001             #request
19:25:32.296  CUL1: 4F A010 1859C7 F14321 030800                     #antwort von device, nicht komplett
19:25:32.388  SW:   4F 8002 F14321 1859C7 00                         #ACK von Zentrale
19:25:32.480  CUL1: 4F A010 1859C7 F14321 030800                     #nachlaeufer? kein Problem
19:25:33.324  SW:   4F A001 F14321 1859C7 01040000000001             #repeat
19:25:37.536  SW:   4F A001 F14321 1859C7 01040000000001             #repeat
19:25:43.060  SW:   4F A001 F14321 1859C7 01040000000001             #repeat
19:25:47.828  SW:   4F A001 F14321 1859C7 01040000000001             #repeat => erfolglos
19:25:52.344  SW:   50 A001 F14321 1859C7 0203                       #request
19:25:52.504  CUL1: 50 A010 1859C7 F14321 0100000000                 #antwort von device
19:25:52.604  SW:   50 8002 F14321 1859C7 00                         #ACK von Zentrale
19:25:53.196  CUL1: 50 A010 1859C7 F14321 0100000000                 #nachlaeufer? kein Problem
19:25:52.768  SW:   51 A001 F14321 1859C7 02040000000001             #request
19:25:57.476  SW:   51 A001 F14321 1859C7 02040000000001             #repeat
19:26:03.468  SW:   51 A001 F14321 1859C7 02040000000001             #repeat
19:26:03.620  CUL1: 51 A010 1859C7 F14321 030800                     #antwort von device, nicht komplett
19:26:03.720  SW:   51 8002 F14321 1859C7 00                         #ACK von Zentrale
19:26:04.320  CUL1: 51 A010 1859C7 F14321 030800                     #antwort von device, kein ACK mehr
19:26:04.648  SW:   51 A001 F14321 1859C7 02040000000001             #repeat
19:26:09.404  SW:   51 A001 F14321 1859C7 02040000000001             #repeat
19:26:09.556  CUL1: 51 A010 1859C7 F14321 030800                     #antwort von device, kein ACK mehr
19:26:09.852  CUL1: 51 A010 1859C7 F14321 030800                     #antwort von device, kein ACK mehr
19:26:10.256  CUL1: 51 A010 1859C7 F14321 030800                     #antwort von device, kein ACK mehr
==> das mit den fehlenden acks auf duplicte messages wird in der nächsten Version korrigiert
==> dein Device scheint die ACKs nicht zu erhalten, es reagiert gnerell schlecht. Kann es sein, dass es funkprobleme in der Gegend gibt?
Gruss
Martin
marc2
Hallo Martin,
generell kann ich mich nicht über Funkprobleme beklagen. Probleme
habe ich eigentlich nur beim getConfig, wobei die HM-LC-SW2-FM am
ehesten Probleme machen, andere Devices selten oder garnicht. Ich
habe noch einen HM-LC-SW2-FM runmliegen. Den werde ich mal in
unmittelbarer Nähe des CUNOs testen.
Gruß, Marc
