Fehlermeldung nach Update von FHEM
Begonnen von Sonic, 25 März 2013, 11:53:36
Sonic
Ich denke ein einfaches Problem, aber ich bekomme nach dem Update diese Fehlermeldung.
Handelt es sich hier um ein Problem des Schreibschutz ?
Wie kann ich das Beheben ?
vielen Dank
KLAUS
File(s) skipped for an update! Error while writing:
Can't write ././CHANGED: Permission denied
58 file(s) have been updated:
==> 2013-03-25 07:45:21 ./fhem.pl
==> 2013-03-15 07:45:12 FHEM/00_FBAHA.pm
==> 2013-03-11 21:00:14 FHEM/00_FHZ.pm
==> 2013-03-19 07:45:12 FHEM/00_HMLAN.pm
==> 2013-03-22 07:45:18 FHEM/00_TCM.pm
==> 2013-03-25 07:45:16 FHEM/01_FHEMWEB.pm
==> 2013-03-24 07:45:15 FHEM/10_CUL_HM.pm
==> 2013-03-23 07:45:10 FHEM/10_EnOcean.pm
==> 2013-03-05 07:45:12 FHEM/10_FBDECT.pm
==> 2013-03-12 07:45:15 FHEM/10_FRM.pm
==> 2013-03-11 21:00:14 FHEM/10_FS20.pm
==> 2013-03-22 07:45:18 FHEM/10_MAX.pm
==> 2013-03-17 07:45:17 FHEM/10_OWServer.pm
==> 2013-03-11 21:00:14 FHEM/11_FHT.pm
==> 2013-03-22 07:45:18 FHEM/14_CUL_MAX.pm
==> 2013-03-11 21:00:14 FHEM/15_CUL_EM.pm
==> 2013-03-08 07:45:11 FHEM/20_FRM_I2C.pm
==> 2013-03-12 07:45:15 FHEM/20_FRM_LCD.pm
==> 2013-03-12 07:45:15 FHEM/20_FRM_OUT.pm
==> 2013-03-12 07:45:15 FHEM/20_FRM_PWM.pm
==> 2013-03-10 07:45:11 FHEM/21_OWID.pm
==> 2013-03-11 21:00:14 FHEM/30_HUEBridge.pm
==> 2013-03-17 07:45:17 FHEM/31_HUEDevice.pm
==> 2013-03-22 07:45:18 FHEM/31_LightScene.pm
==> 2013-03-13 07:45:11 FHEM/45_TRX.pm
==> 2013-03-20 07:45:12 FHEM/46_TRX_LIGHT.pm
==> 2013-03-25 07:45:16 FHEM/57_Calendar.pm
==> 2013-03-22 07:45:17 FHEM/70_VIERA.pm
==> 2013-03-15 07:45:12 FHEM/71_YAMAHA_AVR.pm
==> 2013-03-14 07:45:17 FHEM/72_FB_CALLMONITOR.pm
==> 2013-03-21 07:45:15 FHEM/73_PRESENCE.pm
==> 2013-03-25 07:45:16 FHEM/91_notify.pm
==> 2013-03-11 21:00:14 FHEM/91_watchdog.pm
==> 2013-03-11 21:00:14 FHEM/92_FileLog.pm
==> 2013-03-24 07:45:15 FHEM/93_DbLog.pm
==> 2013-03-08 07:45:11 FHEM/98_Heating_Control.pm
==> 2013-03-12 19:35:05 FHEM/98_SVG.pm
==> 2013-03-21 07:45:15 FHEM/98_THRESHOLD.pm
==> 2013-03-11 21:00:14 FHEM/98_WOL.pm
==> 2013-03-11 21:00:14 FHEM/98_XmlList.pm
==> 2013-03-25 07:45:16 FHEM/98_telnet.pm
==> 2013-03-25 07:45:16 FHEM/Blocking.pm
==> 2013-03-05 07:45:12 FHEM/DevIo.pm
==> 2013-03-25 07:45:16 FHEM/HMConfig.pm
==> 2013-03-22 07:45:18 FHEM/TcpServerUtils.pm
==> 2013-03-09 07:45:13 FHEM/lib/Device/Firmata.pm
==> 2013-03-09 07:45:13 FHEM/lib/Device/Firmata/Constants.pm
==> 2013-03-09 07:45:13 FHEM/lib/Device/Firmata/Platform.pm
==> 2013-03-09 07:45:13 FHEM/lib/Device/Firmata/Protocol.pm
==> 2013-03-09 07:45:13 FHEM/lib/LiquidCrystal_I2C.pm
==> 2013-03-11 07:45:27 docs/HOWTO.html
==> 2013-03-11 07:45:27 docs/HOWTO_DE.html
==> 2013-03-25 07:45:20 docs/commandref.html
==> 2013-03-24 07:45:18 docs/commandref_DE.html
==> 2013-03-11 07:45:27 docs/faq.html
==> 2013-03-11 07:45:26 www/pgm2/darkstyle.css
==> 2013-03-25 07:45:17 www/pgm2/smallscreenstyle.css
==> 2013-03-25 07:45:17 www/pgm2/style.css
Puschel74
ZitatCan't write ././CHANGED: Permission denied
Das heisst das fhem nicht in das Verzeichniss schreiben kann/darf.
Rechte auf das fhem-Verzeichnis passend setzen und es sollte klappen.
Sonic
Hallo Puschel74
ich habe die Rechte nicht eingeschränkt. Ich weiss gar nicht wie das geht.
Ich habe ein Verzeichnis CHANGED nicht gefunden.
Auch nicht im FHEM Verzeichnis.
Kann das das Problem sein ?
Muss ich das Verzeichnis anlegen ?
danke
KLAUS
Puschel74
einfach mal schauen welche Rechte für den Ordner /fhem vergeben sind und ggf. anpassen.
Da sich aber leider grade meine Glaskugel eintrübt wäre es nett wenn du mal deine Plattform, auf der fhem läuft,
nennen würdest (Win,Linux,FB,RPi,NAS,...)
Sonic
Hallo Puschel,
ich betreibe das auf der Fritz Box 7390.
Es steckt ein USB Stick dran als Backup Medium.
danke
KLAUS
