Nach Update viele Warnungen im Log
Begonnen von Tommy82, 07 März 2021, 16:27:47
Tommy82
ich habe eben ein Fhem update durchgeführt und nach dem Neustart habe ich den Log voll mit
2021.03.07 16:24:52.641 1: PERL WARNING: Use of uninitialized value $newType in string ne at ./FHEM/01_FHEMWEB.pm line 2292.
2021.03.07 16:24:52.641 1: stacktrace:
2021.03.07 16:24:52.642 1:     main::__ANON__                      called by ./FHEM/01_FHEMWEB.pm (2292)
2021.03.07 16:24:52.642 1:     main::FW_select                     called by ./FHEM/01_FHEMWEB.pm (1465)
2021.03.07 16:24:52.643 1:     main::FW_detailSelect               called by ./FHEM/01_FHEMWEB.pm (1541)
2021.03.07 16:24:52.643 1:     main::FW_doDetail                   called by ./FHEM/01_FHEMWEB.pm (1175)
2021.03.07 16:24:52.643 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (596)
2021.03.07 16:24:52.644 1:     main::FW_Read                       called by fhem.pl (3842)
2021.03.07 16:24:52.644 1:     main::CallFn                        called by ./FHEM/98_freezemon.pm (1235)
2021.03.07 16:24:52.644 1:     main::freezemon_callFn              called by ./FHEM/98_freezemon.pm (1348)
2021.03.07 16:24:52.644 1:     main::__ANON__                      called by fhem.pl (773)
2021.03.07 16:24:52.645 1: PERL WARNING: Use of uninitialized value $oldType in string ne at ./FHEM/01_FHEMWEB.pm line 2292.
2021.03.07 16:24:52.645 1: stacktrace:
2021.03.07 16:24:52.646 1:     main::__ANON__                      called by ./FHEM/01_FHEMWEB.pm (2292)
2021.03.07 16:24:52.646 1:     main::FW_select                     called by ./FHEM/01_FHEMWEB.pm (1465)
2021.03.07 16:24:52.646 1:     main::FW_detailSelect               called by ./FHEM/01_FHEMWEB.pm (1541)
2021.03.07 16:24:52.647 1:     main::FW_doDetail                   called by ./FHEM/01_FHEMWEB.pm (1175)
2021.03.07 16:24:52.647 1:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (596)
2021.03.07 16:24:52.647 1:     main::FW_Read                       called by fhem.pl (3842)
2021.03.07 16:24:52.648 1:     main::CallFn                        called by ./FHEM/98_freezemon.pm (1235)
2021.03.07 16:24:52.648 1:     main::freezemon_callFn              called by ./FHEM/98_freezemon.pm (1348)
2021.03.07 16:24:52.648 1:     main::__ANON__                      called by fhem.pl (773)
Allnetl Wandtablett mit FTUI
CoolTux
Suche im Forum sollte Dir helfen.
Was ich gestern dazu gelesen habe war das fhem.pl nicht geupdatet würde. Gehe davon aus das es bei Dir auch so ist. Schau mal ob Deine fhem.pl aktuell ist.
Das TuxNet Wiki:
https://www.cooltux.net
Sany
#2
bei mir wird auch das Log vollgeschrieben mit den gleichen Meldungen. Ebenso nach Update heute. Habe noch keinen Zusammenhang erkennen können, wann das aufritt. Kommt immer beim klick auf den attr-button, also beim Ändern eines Attributes. <-- das hat sich jetzt erledigt. Hatte zwischendurch ein neues Device angelegt und an anderen etwas geändert.
fhem.pl ist brandneu von heute: fhem.pl                23904 2021-03-07 09:20:31Z rudolfkoenig, da gibt es wohl nix neueres.
@cooltux
ZitatSuche im Forum sollte Dir helfen.
wenn ich nach $newType oder $oldType suche komme ich exakt auf diesen Thread. Ich habe sonst nix dazu gefunden. Wo hast Du da was dazu gelesen?
Sany
fhem als LXC auf Proxmox auf einem minix Z100 , weitere LXC mit ZigBee2MQTT, volvo2mqtt, MariaDB und Grafana.
[NEU: Homeassistant mit matter per mqtt an fhem].
Sowie Homematic, FS20, mySensors, Tasmota (MQTT2), Shelly(MQTT2), kein Z-Wave mehr  ....
frank
vielleicht die brandneue attribut gruppierung?
FHEM: 6.0(SVN) => Pi3(buster)
Die Meldung trat bei mir genau einmal auf.
Tommy82
Ich hab die Meldung ca. 50x heute im Log....
CoolTux
Bei meinem Verdacht handelte es sich um eine andere globale Variablen. Hab den Beitrag gefunden gehabt.
Das TuxNet Wiki:
CoolTux
Ach so, fast vergessen. Kommt die Meldung denn weiterhin? Auch nach nochmaligen Neustart?
Das TuxNet Wiki:
Sany
im Moment nicht mehr, Neustart habe ich noch nicht gemacht (werde ich erst morgen wieder dazukommen).
Ich hatte zwischendurch mal eine neues Device angelegt und bei ein paar anderen Änderungen gemacht.
Danke fuer den Hinweis, habs gefixt.
Tommy82
Also bei mir kommt es immer wenn ich an einem Device etwas andere und Speicher. Aber wenn Rudi es gefixt hast gucken wir morgen nach dem Update mal weiter.
Sany
nach Update heute morgen sind die Meldungen verschwunden.
Vielen Dank!
ToKa
Dafür habe ich nach dem heutigen Update folgende Meldung
2021.03.08 10:33:32 0:  Strange call for nonexistent : ReadFn
2021.03.08 10:33:32 1:  stacktrace:
2021.03.08 10:33:32 1:      main::CallFn                        called by fhem.pl (773)
VG
Torsten
RaspberryPi3 mit RaZberry2 und Conbee II
Fibaro: FGWPE/F-101 Switch & FIBARO System FGWPE/F Wall Plug Gen5, FGSD002 Smoke Sensor
EUROtronic: SPIRIT Wall Radiator Thermostat Valve Control
Shelly2.5 Rollladenaktoren
Zipato Bulb 2, Osram und InnrLight
Leider reicht mir dieses Info nicht, ich brauche mehr, z.Bsp. die umgebenden Zeilen nach "attr global verbose 5".
Diese Warnung hat nichts mit dem vorherigen Problem zu tun, insofern ist es auch falsch in diesem Thema.
Bitte in der Zukunft Betreffs wie "Nach Update" meiden, das ist fuer mich so sinnvoll wie "Nach dem Fruehstueck auf dem Balkon". Ist zwar richtig, hilft aber nicht.
Tommy82
Vielen Dank!
Kann ich Bestätigen, ist bei mir auch so.
Danke für das schnelle fixen.
