OpenWeatherMapAPI v2.1.4
Begonnen von mgmino, 09 April 2021, 07:35:39
mgmino
How do I specify imperial units?
What is the meaning of the following for city? -- Woods (historical)
The code returned is 28 (two digit); all of the codes in the OpenWeatherMap API documentation are three digit
Can we get the three digit OpenWeatherMap code?
What are the parameters in the function? -- WeatherAsHtmlH("MyWeather","h",10)
my guess is WeatherAsHtmlD(<weather-device-name>, h | v | d, <number-of-three-hours-forecasts>)
CoolTux
two digit is historical since the original function of Yahoo Weather came.
Your guess is correct
Das TuxNet Wiki:
https://www.cooltux.net
mgmino
Thank you for your quick response. A few additional questions:
a) can the module provide imperial units (the OpenWeatherMap supports units=imperial)
b) why does the "get city" return "Woods (historical)"
c) the weather code 613 is not translated
d) I am willing to make some of these changes but don't know what the protocol is. Do I just report issues or work with the developer to fix them -- I like to be part of the solution rather than the problem
CoolTux
If the OpenWeatherMap API can do that, so can the module. It just needs to be adjusted
I do not understand that. What's with you in Reading City
The weather code 613 definitely comes from OpenWeatherMap and has not been translated
If you look at the module file OpenWeatherMapAPI.pm you should quickly see how the module works.
You are welcome to contribute something to the module, I would be very happy.
I can give you an account on my Git server or you can do the whole thing via github and send me a pull request.
github.com/fhem
Please excuse my bad English, I'm not that good at this language
best regards
Marko
Das TuxNet Wiki:
